Theta meditation
Ахнаф
Post by Ахнаф » Tue Nov 03, 2009 15:16
Андрей Патрушев wrote:Ahnaf wrote(a):
I would like to clarify the following question. I ordered and received the CDs theta meditation - 5 pieces. When they began to lose (the use of laptops), I saw that at the bottom left (where the inscriptions are in the playback) when setting any of the five CDs theta meditation is the inscription "Giprotrans", every disk is written in different names (well, as it should be in the book, Visualization, Concentration, etc.) Is that I is all the same put, wrong, confused? Or is it as it should be and you have to believe the inscription, which is on top of the drive, and does not come out while playing? Huh?
On the basis of the recording method of disks, most likely, it is still only Giprotrans...
Ask me to answer my question/request. If I instead of the 5 different CDs theta meditation sent 5 disc hypnotrance, inform me, please, how to replace. It is necessary to restore the rights of the consumer, isn't it?
Post by Dimas » Tue Nov 03, 2009 15:21
Ahnaf
???You sent 5 discs of Hypnotic trance?If so, will correct! Please write a letter to mindmachine@bk.ru and resolve the issue. You send us the extra 4 drives, and we give You the missing.
иван_IV
Post by иван_IV » Tue Nov 03, 2009 20:36
Ахнаф wrote:If it's all Giprotrans, we would like to replace. How to do it? :oops:
He once thought the same... all the same DISCID 020A8C01 drives, on all drives for one file, all files are the same length... and to the ear - not defined :roll:
Have grabil drives (Graber also was confused with what he was given disk) to. wav file size bytes in bytes.
Launched file comparison (who remembers DOS command "FC")... nothing different files. :)
So, try this option check.
Or - another option comparison ready wav files through foobar2000 player (you need to add a special plugin).
Actually, this is what he gave me:
Differences found in 1 out of 1 track pairs.
Comparing:
"OTA Patrushev\Theta meditation (CD)\3 - Hypnotic trance\Andrey Patrushev - Hypnotic Trance.wav"
"OTA Patrushev\Theta meditation (CD)\4 - Creative visualization\Andrey Patrushev - Creative Visualization.wav"
Differences found: 238066298 sample(s), starting at 0.0305215 second(s), peak: 0.3312378 at 1459.0580060 second(s), 2ch
Perhaps much more difficult to identify, all discs otlichalis from each other, and whether the label contents... suddenly the plant in the manufacture of files mixed up?
Post by Андрей Патрушев » Tue Nov 03, 2009 20:49
Yes, indeed, but the problem... :? Will have to do to even for a few seconds was different...
иван_IV
Post by иван_IV » Tue Nov 03, 2009 20:55
Андрей Патрушев wrote:Yes, indeed, but the problem... :? Will have to do to even for a few seconds was different...
Opinion old party will be? ;)
Or, how in house conditions to determine compliance with labels on the cover and the recorded information?
The remastered disc wasn't it? Verify those copies that are left for test use. :)
Been thanked: 182 times
Post by Андрей Кабанков » Tue Nov 03, 2009 22:51
All of the drives are different.No opinion is not necessary.The name of the disc and therefore its matrix laser engraved notch on the inner hole of the disc.
Ahnaf
You have sent 5 different drives.
Do not enter people astray.
Ахнаф
Post by Ахнаф » Wed Nov 04, 2009 8:13
Андрей Кабанков wrote:Ahnaf
Andrew!
I myself few days are already in the "error"! If the disk says one thing, while playing out another, and the length they all have the same, what should I think? I myself need to understand! And no, I'm not going to enter! I hope to have it figured out now, I sent a reply e-mail, I looked, it seems like everything is correct and matches.
иван_IV
Post by иван_IV » Wed Nov 04, 2009 11:35
Андрей Кабанков wrote:All of the drives are different.No opinion is not necessary.The name of the disc and therefore its matrix laser engraved notch on the inner hole of the disc.
The fact that all the different disks I wrote. Do not dispute this. :?
Yes, actually I pointerisovalsya whether "visible" is listed on the disc - "Kishimoto" (itself). Since the hearing is not to determine. And, of the possibility of such a marriage in the production of audio CDs - I think they know...
But since the seller claims that everything is correct - I see no reason to challenge. Although, it would be good to know how to identify the copied disc 5-wav files (some of them that). Just for fun...
PS the Last vivid example of such confusion that I remember about 3 years ago went out the next disc in gr. Alice (Deluxe version). On the first day of sales was the autograph session. Many people signed their own discs. Came home, turned on the recording... and then...: who Butusov recorded, one ABBA. But, the box, the inscription on the disk and autograph honor to honor. :roll:
But, there is at least a hearing can determine that ABBA or Butusov - is clearly not Alice.
And, here... :roll:
Except that, there is only the fact that those who bought these discs have the expected effect from listening to the respective CD. :wiz
Шумовик
Post by Шумовик » Wed Nov 04, 2009 13:18
Well, the EAC, for example, shows the name of the disk (m/b CD text?)
And aunt they are different.
Post by Андрей Кабанков » Wed Nov 04, 2009 13:44
The confusion stems from the fact that the player Windows shows one drive name,do not know what is the reason, all of the drives Patrushev defines us as Endorphins.
иван_IV
Post by иван_IV » Fri Nov 06, 2009 10:38
Андрей Кабанков wrote:Confusion stems from the fact that the player Windows shows one drive name,do not know what is the reason, all of the drives Patrushev defines us as Endorphins.
All the confusion due to the same DISCID.
And DISCID depends only on the number of tracks and their duration (but not the content). It is for this parameter are classified discs to CDDB (compact disc database is a centralized database for music CDs)
So from the point of view of the presence of tracks on the disc and their duration: the disc is exactly the same. This is not a "Windows bug", this "feature". :)
Well, determined as Endorphins, because they were lost on the computer first. I am on this account not sharpened, but surely there 1 file with the same duration. But, even though their theta-meditations, distinguished by the presence of the strobe signal, and the hearing - are clearly different.
If anyone can distinguish CDs theta meditation from each other by ear under blind audition take off my hat. :wiz
Алексей Кузнецов
Post by Алексей Кузнецов » Thu Nov 12, 2009 23:29
Dear John VI, get ready to take off his hat. I called a friend of mine, which in July bought the discs theta-meditation on "my" = your question does she hear the differences, she said issue, and does anyone not hear it? There, according to her very good to hear all the differences. "They're all different" - her words. She lives ka Karelian isthmus and when will the city let me hear it.
иван_IV
Post by иван_IV » Fri Nov 13, 2009 23:23
Алексей Кузнецов wrote:get ready to take off his hat.
Heh... will have to listen... But I'm afraid, in my youth, my long fascination with heavy (very heavy) music good headphones, but still more than 2 hours a day is very detrimental to the hearing... that can not be noticed in the audio signal.
Here's how you listen - explain to me how it should sound for example "concentration" and "deconcentration".
And, then test... a week after I listened to the disks you someone will include one of them... if you can guess what work is? :)
Well, well... already preparing :wiz However, that would take off his hat to a lady, occasion and don't need. :)
Алексей Кузнецов
Post by Алексей Кузнецов » Sat Nov 14, 2009 17:44
Ivan VI of this lady of about 60, she was doing yoga and it probably helps her now. When I will be able to listen to theta, I'll tell you the result. I can tell only through a Conductor, the Star wanderer and the Massage one, now, after 9 months of listening, I hear them differently than the original. And a lot in me has changed. Some changes seems to be good, but the habit they scare me. Some oppressive feeling that somebody was watching me and helping me. Don't know how to more accurately describe the feeling. And still can't get to the subconscious in everyday life. Listen to theta, perhaps.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Mon Nov 30, 2009 13:36
for Lily.mp3
This link on meditation I asked "navorotami"Andrei Patrushev .He kindly agreed to do it and here is the link. Share the gift of Andrew with everyone . :) :D
иван_IV
Post by иван_IV » Mon Nov 30, 2009 20:18
Алексей Кузнецов wrote:Ivan VI of this lady of about 60, she was doing yoga and it probably helps her now. When I will be able to listen to theta, I'll tell you the result. I can tell only through a Conductor, the Star wanderer and the Massage one, now, after 9 months of listening, I hear them differently than the original....
Yes, it is worthy of respect and trust age.
As listen - will share impression.
At the same time, I want to share the statement of the author's own discs of the series "Theta meditation", which is on this forum:
Андрей Патрушев wrote:disks only theta and low. Frequency distributed across the range, so that the brain has chosen its own (Holopenichsky autofocusing). Since the matrix, and monaurally and binaural beats plus amplitude modulation at very low. Different disks, only ultra low frequencies, which, in contrast to the Delta, theta, alpha, beta waves are very characteristic of different States. Neither hearing, nor by spectral analysis of disks does not distinguish between.
P. S. so far, the hat stays in place... :wiz
Ламер
Post by Ламер » Mon Feb 01, 2010 14:07
I am playing poker professionally and the specific work that is required to be very concentrated and focused during the gaming session, for making careless mistakes - costly:(.
Accordingly, the question is: can I listen to this disk directly during the game, to increase the concentration, or any side effects?
Post by Андрей Патрушев » Mon Feb 01, 2010 14:11
Ламер wrote:I am playing poker professionally and the specific work that is required to be very concentrated and focused during the gaming session, for making careless mistakes - costly:(.
No, of course.
Read the description and warning. :)
Ламер
Post by Ламер » Mon Feb 01, 2010 14:18
Read what is written on the box of the disk and the answer to my question seemed to me ambiguous, has decided to clarify :)
Thank you for your prompt response
Додди
Post by Додди » Wed Feb 17, 2010 6:47
The idea of the dead...
I think I saw a video where the speaker is filled with the sand and sound waves from him to build different patterns?
I.e. one wave - one "mandala", the other - the other...
The variant that generated the figures, if you look at them, regardless of music, will produce a similar effect? But if in conjunction with the music - enhancing?
!Энди
Post by !Энди » Wed Feb 17, 2010 12:37
And you can link to a video of it and the fact that Gugel does not help.
Сергей_Л
Post by Сергей_Л » Fri Mar 12, 2010 19:10
SW.Andrew, tell me this question:
somewhere I briefly read that on the program, L03, you can superimpose captions (additional headphones as I understand it - save for the sake of clarity of the channels MM) and to the hypnotic session.
I have an interest in astral proektsii, etc.
will the captions Orlova (Hemi-sync) superimposed on the Theta rhythm to give a result, or better a session for suggestion ?
as an option - are there any plans to create separate disks, with a similar theme ?
(as I understand it is still very popular in ru-net).
Sincerely, ATP advance for the answer.
Низами
Post by Низами » Tue Mar 30, 2010 5:24
Andrei Patrushev Hello .
Listen to Lucid dreams do not remember how to fall asleep do not remember how take the headphones off when I Wake up but sosninyh dreams was not . What to do to osoznannoe dream experience ? The first 6 hour sleep is very long and bright.
Thanks in advance for the answer .
Post by Андрей Патрушев » Tue Mar 30, 2010 10:49
!Энди wrote:And you can link to a video of it and the fact that Gugel does not help.
Somewhere here on the website:
http://www.cymascope.com/cyma_research/phonology.html
Post by Андрей Патрушев » Tue Mar 30, 2010 10:53
Сергей_Л wrote:SW.Andrew, tell me this question:
Hello.
Of course, you can (through editor and mixer). You can just - with machine headphones, and the text loudly on the speakers.
Captions Orlova (Hemi-sync) thus superimposed on the theta rhythm.
