Dialect Welcome back!)))
From the first post ...betta used in the morning, then sleep will be calm and on time. Alpha, alpha-theta gives relaxation , sometimes very strong , because of the driving itself , it is often difficult, if, immediately after the session on the road. All natural.
Judging from what you wrote , you pass the session at the center for special . Who's stopping you take for example Machine to apply the same alpha and the other session? Same rims Guide and Healing? At a very low cost, some people think that they are ineffective. But the policy to help people rather than take snih yet available on these disks. Question , you used them?
If not, please try it. If Yes, then most likely not so, and not got the result,holding ekzekutsii in the other cities and centres. Pain in the head is not always Fizicheskie damage , often it can be far from those problems that you thought up yourself.
Andrei Patrushev often said. My observations over all these years confirm that often it is psychosomatic or old not solved problem, block . And in recent years has become a very sensitive psi-operator treatment of the citizens of almost any country .
Pain signals without physical damage to the brain could be signals to you that something is wrong, or that you is the information and you or not to notice or block certain installations units does not pass it to you. Sometimes you just have to ask, what the pain and the thought comes.
Tested more than once.
Observations from the friends who went to Germany for permanent residence after the collapse of the Union, showed an interesting "movie"))) Vospitannye in Russian , but spoke German at home,and some thinking on it, it was easier to adapt in Germany , although language praktichesski had to relearn again. And those who knew the language , but think in Russian , as is often said on it, basically, at those there were some cudnosti and tension in connection with what to misliti retrained in the language. When I talked to them , they said they used to have kind of like to think even on ateaze, but an innate habit of thinking in Russian all the same controls etc this causes headaches. Now when I speak Russian , already accustomed to hard to think in German, and again headaches. But this is one of the possible factors, and in no way can not be a statement that you have from that pain.
Blocks, installation and templates , from which can be the confrontation of mind and consciousness , and as a consequence headaches,you can remove the Guide, with proper coursework listening, home , charge))) and relaxation and recuperation Healing and also the house and WITHOUT charge.
PS. Tension often gives a lock on the energy and meridians that may also provoke the pain and not only headaches. Hence the podskazak, check for yourself
Turn to the chiropractor for the needles.... Pump simultaneously with Provodnikom and Healing. Is also verified. Because walking mohtaram))) this time , money and of little help often. Except of course for emergency cases,although these cases were decided there have a masters in needles.
With best wishes
