Popular questions and answers (FAQ)
Вы нашли ответ на свой вопрос?
Да
13
43%
Частично
6
20%
Нет
11
37%
Total votes: 30
Г0сть
Post by Г0сть » Wed Jul 21, 2010 12:24
Andrew, it is expected the expansion of the Catalog?
In what direction is the search for useful gadgets?
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Sat Oct 09, 2010 22:45
join voprosu Guest :)
in the section "mindmachine" there is no innovation?
Post by Dimas » Mon Oct 11, 2010 11:54
the Owner
There is, in later, can not say for sure.
Post by Андрей Патрушев » Mon Oct 11, 2010 12:53
Malvina wrote:How snoring is not harmful? Here we read:"when snoring often occur apnea, during which, due to lack of oxygen suffer from the vital organs and systems. People suffering from snoring, do not have time to sleep for the night, they reduced efficiency."
Snore so that the walls shake... :oops: Everything else is exactly the opposite. :?
Песочные Часы
Studies of the effects of Mind machines, Modulator, СК1М
Post by Песочные Часы » Fri Oct 15, 2010 15:20
Hello, Dear developers and forum administrators!
Your products are very interested in me! But mostly, not even for its amazing effects, and those how exactly are these effects.
As I understand it, your design is analogues of their foreign colleagues? Did they have any studies? If Yes, how many years they tested how that affects people these products and what conclusions they came to about her effects on the brain, the mind, and therefore human activity?
Maybe you yourself carried out any surveys with forecasting further human behavior?
I will be very grateful if you could help me find something literature about these studies.
Thank you.
Post by Андрей Патрушев » Fri Oct 15, 2010 17:22
Песочные Часы
Post by Песочные Часы » Fri Oct 15, 2010 17:24
Good evening!)
Thank you very much=)
Саулюс
Post by Саулюс » Wed Oct 20, 2010 18:11
Hello :)
I look and in our country there mindmachine on sale. And I have a question, is it worth it to buy a machine if the main interest in the sound stimulation, but not in light glasses. That is, does specifically listen to the cars without glasses greater effect in what? compared to just listening without cars? As for example while reading and studying glasses not wearing 8) and you can only listen to the disc.
Post by Guest » Tue Oct 26, 2010 19:41
...Yes, and headphones are common, if I understand correctly, complete with the machine going, that is, maintain the same 20-20,000 range and quality as in the simple good player. It turns out that if somebody bungled the program for PC to control points, the need for "the machine" quite Talab? :? ...of course, given that PC bylab normal quality sound card.
Post by Андрей Патрушев » Tue Oct 26, 2010 21:10
Саулюс wrote:Hello :)
The audio path less effechve than light. Machine can be effectively used before and / or after school, however, exposed points in time.
Post by Андрей Патрушев » Tue Oct 26, 2010 21:14
Anonymous wrote:...Yes, and headphones are common, if I understand correctly, complete with the machine going, that is, maintain the same 20-20,000 range and quality as in the simple good player. It turns out that if somebody bungled the program for PC to control points, the need for "the machine" quite Talab? :? ...of course, given that PC bylab normal quality sound card.
Earlier in the sale was a special set-top boxes - something like an external sound card plus fee control points and special software with very rich features in the sound tract. But for some reason they didn't catch on...
Саулюс
Post by Саулюс » Sun Nov 07, 2010 20:02
Thank you:) for the replies. Maybe that for my needs enough for the sound path. :)
Француз
Post by Француз » Mon Nov 15, 2010 19:56
Hello. I have a problem. After anaesthesia has become a very bad memory and concentration ,on the back span can't dream I don't remember.What drives Patrushev have closani , and will it help?
Post by Андрей Патрушев » Mon Nov 15, 2010 20:37
Француз wrote:Hello. I have a problem. After anaesthesia has become a very bad memory and concentration ,on the back span can't dream I don't remember.What drives Patrushev have closani , and will it help?
Hello.
With the big share of probability will help You Star Voyager.
.Француз
Post by .Француз » Wed Nov 17, 2010 4:08
Thanks for the reply.
Post by Нетрезвый Сурдопереводчик » Fri Nov 19, 2010 13:46
Tell me please,A. Patrushev plans to release any new discs? :D
НИКИРА
Andrew THANK you!!
Post by НИКИРА » Wed Feb 23, 2011 1:52
Andrew many thanks for your creativity and creating such a wonderful ROM drive. :)
Соловей
Post by Соловей » Wed Feb 23, 2011 9:21
There is no answer to the question "what is the meaning of life?" - Buy MM and live happily ever after :) - about the survey.
Елена Ямпольская
Post by Елена Ямпольская » Sat Feb 26, 2011 1:28
for the gifted please explain:
I have a MM навапро100, want to listen to CDs via Patrushev MM.
1.You need the CD or DVD player or something? Which is better?
2. On what characteristics to look for when buying a CD or DVD (or something), that would not cut the high frequency.
3.Let's say I bought a certain device for disks, connected to MM, question: the Disc is tapped in conjunction with a session, or simply using MM. (Maybe the question is of course stupid, but I have no DVD, no SD, so I can't figure out how it is technically going on)
4.In the case that disc to listen to in conjunction with Cesia, too, is a question time session ,for example, 15 minutes, and drive 1 hour. It turns out that the session ends, and drive another 45 min listening?
Been thanked: 182 times
Post by Андрей Кабанков » Sat Feb 26, 2011 11:50
1.Any device that plays a CD.
2.With a simple CD player will do.
3.Among disks A. Patrushev has drives with audiostrobe and without.
Those without audiostrobe tapped without the use of MM.Those that audiostrobe are encoded to signal points and are tapped using MM as a decoder of the signal.When listening to MM is set to AUS (audiostrobe decoder) and session not reproduced.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Sat Feb 26, 2011 12:04
...are connected with a cord МиниДжек3,5 x МиниДжек3,5 (is usually included) line out of the player (or computer) and MM input (I EXT).
Drives Patrushev and without audiostrobe can control the MM signal, so I use it - better attunement with broadcast disks, States.
Sincerely, MAG.no
Елена Ямпольская
Post by Елена Ямпольская » Sat Feb 26, 2011 13:26
Andrey Kabanov
MAG.no
thank you :o
домашний
Post by домашний » Thu Mar 10, 2011 16:43
Hello!
The question is.
Should I feel something special directly after the session? I'm not talking about stable changes, namely short-term effects immediately after the session, which takes place in a short time. Does it need to be?
In fact after the session I feel nothing. What is the state of wearing sunglasses and headphones, in the same their and take it. In books and articles on the website says that we are all very different and therefore created so many sessions, designed for the same effect, it is necessary to try them all and find the right fit.
So do I need to find a session, directly after listening to which I feel a change?
Post by Маг.нет » Thu Mar 10, 2011 19:35
Not necessarily...
How much time used? When sessions started?
Sincerely, MAG.no
домашний
Post by домашний » Sun Mar 13, 2011 16:24
Used recently for a few days.
Use session only from the group Relaxation is over all turns.
