Try.Ашот Васильевич wrote:Hello Andrey Vadimovich!
Is it possible Your CDs to listen through this device http://bliss.ru/acoustic/bliss-vibrosound-bt120.html?
Thank you.
Advice from Andrei Patrushev
I doubt it...Ашот Васильевич wrote:Can this vibrolance is the analogue of Echofon?
And so you can - some tape-they will press against the head due to gravity.Ашот Васильевич wrote:can Take two kolonii and to put each speaker in a separate channel. That is, one channel for each vibracolor: right and left. And then columns to provide two sides to the head. But how to fix I don't know. Speakers are quite heavy.
It is not only neironnykh ties, but also in training a specific brain activity that the effectiveness of the combination of light and sound.Дмитрий Смирнов wrote:As I understand it, from reading the forum, You are saying that when viewing flashing lights, the brain forms new neural pathways, which then help in the visualization process. Why then listen to the audio? Is it possible to do without it? Whether the effect on the development of visualization?
Picture is better to take the beautiful, who You personally like, and it is better to choose the world's masterpieces. Mandalas can also be used. You can just look at the scenery. With a stopwatch I have not tried, since this much distraction, just feel like long enough to keep the picture.Дмитрий Смирнов wrote:Another question? You talked about the fact that the development of a visualization can be determined by measuring the stability of images before my eyes. And what painting would You advise to start? Photorealistic painting, or complex geometric shapes, such as the Indian mandalas? As You make measurements? Simply click the stopwatch to start and stop when the picture is floated, or absolutely missing, or something different?
In fact, visualization is only the first step. We need to develop all the senses.Дмитрий Смирнов wrote:I Wonder also if You can share the experience of practical use of imaging, some interesting examples.
For example, once traveled as a criminologist, to steal a car. The car was abandoned in the forest by removing the front door and spare tire. Witnesses saw the thieves only door, so the spare they could hide in the woods. While the investigator wrote the Protocol inspection of the scene, I decided to look for the spare tire: he closed his eyes, imagining the wheel. Wheel indefinitely dangling somewhere in space. When I added the smell of rubber and the feeling of touching the protector, the image of the wheel suddenly a very well established and moved to a certain place. Following the way, I turned my head, opened my eyes, and outlined a guideline and went for it. After approximately 150 metres, away from the trail, I found (or rather, very precisely left) is the wheel in the hole, zasidannia paporotnika (if I was close to two metres - would not have noticed).<
Ашот Васильевич
- Has thanked: 2 times
- Been thanked: 1 time
I tried... so much garbage... the Device is interesting, but not for these purposes.Андрей Патрушев wrote:Try.Ашот Васильевич wrote:Hello Andrey Vadimovich!
Thank you.
In General it is necessary to order Echofon... Communicated by email. mail delivery to Rostov 59 USD.Delivery time 5-7 days. Can you tell me whether you need it to customs and all you can experience some issues when ordering and sending, and how can they be avoided?
Thank you.
Up to 1000 USD (including shipment) customs is not necessary. It is better not to save on the courier. Here, perhaps, and all I can say is...Ашот Васильевич wrote:Can you tell me whether you need it to customs and all you can experience some issues when ordering and sending, and how can they be avoided?
сэр Виктор
Andrew advise
Andrew ,tell me where to start. I am a novice.And I have this problem. Chasing thoughts constantly and even at night.
Talking to discuss. 6 months that it's gone and now 2 times stronger it haunts me. What software product it can be solved.
sir Victor
Please don't breed with one question in different themes.
Thoughts are good, worse when they do not...
Hello, Andrey Vadimovich,
I want to ask You a question about the methods of reception of nicotinic acid. I'd like to ask You: is it possible to replace the vitamins from the list at any others? Some vitamin complexes sold. What vitamins are strictly required for admission in the use of nicotinic acid?
Thank you
Thank you
Terve
The number and composition of vitamins, with the words of Oleg Vasilyevich, was calculated according to the table drawn up by the Polling. I, unfortunately, not found (though not very hard). You can look for in his books.
Very critical are the vitamins B1 and B2, the rest are also needed, but their absence, at least, does not lead to such obvious negative consequences, such as very high fever and arrhythmia. Also important is calcium and magnesium.
You can see in the reference composition and to convert the ones that are on sale. Now there are good complexes, such as "Nootropic", "Alphabet", where everything is.
Table until you get caught ,but the vitamins from Polling these http://www.kobra.ru/multi_vitamins.htm anyone tried it? There's a lot in each capsule. And will it be similar to that advised Oleg. Because the problem is really finding the right vitamins in the right doses.Андрей Патрушев wrote:the Number and composition of vitamins, with the words of Oleg Vasilyevich, was calculated according to the table drawn up by the Polling. I, unfortunately, not found (though not very hard). You can look for in his books.
The link above taken from here http://www.kobra.ru/products.htm. Someone can say they should apply, or another divorce?
LILY-P
Well, vitamins are not all so simple... My head at Department of normal physiology believes that synthetic vitamins are useless eat. I myself have repeatedly faced with the fact that the diagnostic complex ЛИРА100 athletes who at the instigation of the coaches large amounts of vitamins, showed strong toxicity and imbalance in all the organs... From personal experience, I believe that a course of vitamins twice a year (spring and autumn) of 15 days may be useful, at least as a stimulating stressor.
How, then, handfuls of vitamins and the system Oleg Vasilyevich? It turns out that the acceptance of artificial vitamins this course gives a solid stress? But what about the restoration of the organism in his system .And narkocentr-detox?Андрей Патрушев wrote:I Myself have repeatedly faced with the fact that the diagnostic complex ЛИРА100 athletes who train at the instigation of large amounts of vitamins, showed strong toxicity and imbalance for all bodies
Andrew , a few times I had a course of alpha and beta, plan to start working with theta, what is the drive of this series do you recommend to listen to first and what would you recommend to listen to after theta?
CEST
Journey through the Inner Worlds.
Massage Of The Brain.
Andrew,welcome!... Is it possible to use any of Your disk person after a stroke (left side paralyzed)? If so,what and under what scheme?...Thanks in advance for the answer!...
And-mountains-S
Hello.
Massage of the Brain specifically for this purpose made.
Hello.
Hello, Andrew!
Can you please tell me how to solve this problem.
I have a friend whose childhood fun parent is affectionately called a fool, lovingly so to speak. And the man is very insecure, afraid to start new things, afraid to say superfluous word, etc.
We talked about Your disks, in particular the Conductor and the disc-Hypnosis.
What program works would You recommend affirmations/affirmatsii it is best to use in this case?
Have all of Your CDs and mind machine, though not of the PHOTOSONIX company.
Kasia
Hello!
Disks, machine, etc. can only help at the beginning (to do it yourself the first step). While the person may begin to act by yourself nothing will change...
Hello!
Well. Thanks for the reply.
It is clear that people need to start doing on their own, but the "wobble" at the beginning, so to speak, can he and to help.
The first steps of the proposed MM alpha session (although he is afraid of MM, especially the glasses) or to hear the Conductor through the day and self-Hypnosis with the installation, found here - I love and deeply accept myself for who I am.
Hello, Andrey.
What do You think, will effectively combine session alfaria with passive meditation, for example, Nadabrahma? I mean - hour session alfaria and meditation simultaneously?
Nelly
Why not?
Why not?
Thank you!
Famously Tovarisch started, Yes, everything is. Exhausted with MM did not want to further work with her. Thought in one fell swoop to solve everything. Want to try a few days several hours in a row listening to a Guide and a Healing (the benefit of other discs not given). Now I think... not to take away Lee. If I decide to do this so he gets the discs and sports. While just reading the forum.Андрей Патрушев wrote:While the person may begin to act by yourself nothing will change...
Kasia
Well, that at least started.
If you understand that failures do not happen, and there's only feedback
so, you see, and then move forward.
