Advice from Andrei Patrushev
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Mon Jul 30, 2012 13:35
Over the rainbow can you tell that the universal recommendation is check out after the alpha session, apparently when You decide that "well, that's the most it can rainbow watch", then you need. I, for example, to combination with a track integrator of ultra brain looked immediately after the session. Now I look at her and at the same time listening to the integrator.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Mon Jul 30, 2012 17:04
Прохожий wrote:Hello Andrey,I have a question:you correctly WROTE that spasms after HEALING can not be,SPASM appeared only as a consequence of the problems raised by the disk.And the problem he raised is quite serious,in the coccyx and above the hand BURNED and ached so I had to chop baralgin,but you please do not misunderstand what I'm complaining NO not at all I'm just stating a FACT which IS,and was sick WELL, DID a little bit BUT a VERY GOOD and LONG,and from THIS the most PAIN and having spasms.The question:is it possible in CASE of severe pain use analgesic KATADOLON is the new generation product,one of the best,maybe you've heard of him as CRISTEC ached VERY much,Yes I have a small hernia and just above the protrusion and the aura is my most so to say the problem area,but not TO the same degree.Thanks in advance for your answer.
I have the opposite observation,about the pain and pills. Gone for a week and gave my Navigator friend.That appeared intercostal neuralgia ,stabbed deeply and stand up straight was difficult. Two days rubbed some sort of ointment to relieve muscle pain ,has not passed. While I was gone ,she 3 days listening to disc Healing in the evening and morning Endorphins ,removed and the pain and even cheered.
Although I agree that after listening to the disc the body tries to recover and stirs up old sores. Here it remains only to endure. Or obezbolivatmi. And at the expense of new drugs and all the super new - as you do not want to put on yourself experiments. Often it is the same old but the price is biting.
Прохожий
Post by Прохожий » Mon Jul 30, 2012 22:00
Good day,I agree with you completely that HEALING heals but still in my case it happened through a SERIOUS aggravation.
Прохожий
Post by Прохожий » Tue Jul 31, 2012 22:23
Good day,Andrew, my question is:stopping the internal dialogue,and MORE ossumane yourself in the PRESENT moment,so to speak, the CLAIMED effect of disc HEALING, or it's my PERSONAL thing,thanks in advance for your answer.
Post by Воффка » Wed Aug 01, 2012 13:49
Passer-by
Yes who will disassemble what is the effect... as far as I remember, You and the conductor used a rainbow and a massage of the brain. Yes and enjoy :)
p.s. In General as far as I know the disks bring nothing new, and only just did the personal characteristics and show.
Прохожий
Post by Прохожий » Wed Aug 01, 2012 14:02
Good day VOFFKA.I agree with you that you CANNOT get what you already have and a man as such has ABSOLUTELY everything for a TRUE nature at heart he is a part of the ABSOLUTE.And all our task is only to detect IT in yourself sometimes a VERY deep FULLNESS.And it is in this that the discs and help.
Post by Воффка » Wed Aug 01, 2012 14:05
Another negative ORP water with regular consumption helps :)
Прохожий
Post by Прохожий » Wed Aug 01, 2012 16:00
Thanks for the advice,what kind of negative water and how it can be obtained?
Post by Воффка » Thu Aug 02, 2012 8:44
Прохожий wrote:Thanks for the advice,what kind of negative water and how it can be obtained?
In short, ORP (oxidation reduction potential) water is negative in other words "living" water, if ORP goes to positive values, the water becomes "dead". Here to help:
http://ikar.udm.ru/w_main.htm
viewforum.php?f=44
further discussion on the water there.
Прохожий
Post by Прохожий » Thu Aug 02, 2012 13:45
THANK you VOFFKA!!! :o
Прохожий
Post by Прохожий » Fri Aug 03, 2012 16:17
Good day,Andrew, I have a few questions for you.First:is it POSSIBLE to listen immediately after the alpha session, or, in those 2 hours SPECIAL suggestibility of the CHINESE medical music there are no UNDERWATER suggestions and only a HEALTHY tone for CERTAIN organs.At your own risk, I took a couple of short tracks seems to be as ALIVE and as neither mental nor physical is not deteriorated and still would love to know your opinion.And IF it's POSSIBLE to say so without harm to HEALTH CAN instead of the usual alpha for such a case to use one of the sessions of the "L" that where in the first 12 minutes of special suggestion.Second question:you advised me to put in MM instead of the squarewave signal SIN,that is, if I understand correctly then in the instructions it is marked(a) as a sine wave?And if I understand you correctly WHAT to change from what I'm listening to MM on this signal?Third question:And what about brightness points WHAT do you recommend I iznochalno was a brightness WHERE the left is MUCH stronger flash than the right.I would like to know what the meaning that one eye flashing brighter and the other less and THAT I you would suggest?In advance VERY grateful for the answer!
Светлана Соловьева
Post by Светлана Соловьева » Sun Aug 12, 2012 9:31
Hi Andrew!I come to You for help. My child has mental retardation (Delay of Psycho-speech Development) on the background hyperactivity disorder(birth trauma). What You posovetuete where to start and you can do all these disks for him to use. I would be grateful for an answer.
Ашот Васильевич
Has thanked: 2 times
Post by Ашот Васильевич » Wed Aug 15, 2012 13:03
Hello Andrey Vadimovich!
Is it possible Your CDs to listen through this device http://bliss.ru/acoustic/bliss-vibrosound-bt120.html?
Thank you.
Ашот Васильевич
Post by Ашот Васильевич » Wed Aug 15, 2012 13:04
Column vibro-acoustic
Speakers:4 Ohm (speaker), 2 Ohms (subwoofer)
Output power:10 W
Frequency range:40 Hz – 20 KHz
Sensitivity:
Signal/noise:85 DB
To put it directly overhead. Use pillows instead of Sleepsonic.
Ашот Васильевич
Post by Ашот Васильевич » Wed Aug 15, 2012 13:08
I have some other, simpler: http://rostov-na-donu.dns-shop.ru/catal ... ilver.html
Binaural beats are felt. Speakers stereo. obviously sigsaly mix it and apply vibration on poverchnosti (e.g. the floor, if lay and if the wall if you sit near the walls). But castany range only up to 18 000 Hz. Your disk is clearly not appropriate.
Ашот Васильевич
Post by Ашот Васильевич » Wed Aug 15, 2012 13:12
Can this vibrolance is the analogue of Echofon? (Sorry, now is not neurophon no echofon don't buy).
I just don't hear in one ear and unable to fully obtain the effect of Your drives, if you are simply listening with headphones. Headphones beats binaurally I have not heard. and the effects will therefore not be complete.
Ашот Васильевич
Post by Ашот Васильевич » Wed Aug 15, 2012 13:18
Here's the Dodge as you can. Initially bought Sleepsonic. The effect of immersion and improved immediately. Unless of course the correct pillow to put below the hearing ear is captured and the portion of the signal and another channel, which is aimed at not hearing ear. Plus Balan put on Nekustamie louder. In the end, became traceable binaural beats. Then bought a small komputernye the speakers with a wide frequency dapsonom to 20,000 Hz. Disposes them so that the hearing ear to hear clearly Beene, when comparing the sound from the two channels. only then will fully know what is the impact of binaural beats. Much faster and softer began to sink.
Ашот Васильевич
Post by Ашот Васильевич » Wed Aug 15, 2012 13:27
Although it's probably not quite right. Such as the beating should be born votre head, the result of binaural perception of sound inside the head. But I still never before was not heard in this World. Always heard tolkl so through one ear. So that the beating can only hear that)).. But nevertheless the impact chuvstvuetsya. Here interested because vibrolance. By the way if it is tightly applied to his head by not hearing of the ear, the sound starts to go right in the head and clearly audible. in this connection I want another thing to do. Take two kolonii and to put each speaker in a separate channel. That is, one channel for each vibracolor: right and left. And then columns to provide two sides to the head. But how to fix I don't know. Speakers are quite heavy.
Ашот Васильевич
Post by Ашот Васильевич » Wed Aug 15, 2012 13:30
I apologize that many reports have described the essence of the problem. But you have not let a large number of words for one message.
Andrey Vadimovich, I would like to hear Your comments on wisecasino.
Thank you.
Sincerely, Ashot.
Post by Воффка » Wed Aug 15, 2012 14:06
Frequency har-ka needs to be 20Hz-20kHz for the right job.
Ашот Васильевич
Post by Ашот Васильевич » Wed Aug 15, 2012 14:09
And the lower frequency limit is also important for discs Andrei Patrushev?
Дмитрий Смирнов
Post by Дмитрий Смирнов » Fri Aug 17, 2012 18:53
Question to Andrey Patrushev.
As I understand it, from reading the forum, You are saying that when viewing flashing lights, the brain forms new neural pathways, which then help in the visualization process. Why then listen to the audio? Is it possible to do without it? Whether the effect on the development of visualization?
Another question? You talked about the fact that the development of a visualization can be determined by measuring the stability of images before my eyes. And what painting would You advise to start? Photorealistic painting, or complex geometric shapes, such as the Indian mandalas? As You make measurements? Simply click the stopwatch to start and stop when the picture is floated, or absolutely missing, or something different?
It is also interesting if You can share the experience of practical use of imaging, some interesting examples.
Post by Воффка » Fri Aug 17, 2012 20:34
Ашот Васильевич wrote:And the lower frequency limit is also important for discs Andrei Patrushev?
Yes.
Post by Андрей Патрушев » Sun Aug 19, 2012 22:29
Прохожий wrote:is it POSSIBLE to listen immediately after the alpha session, or, in those 2 hours SPECIAL suggestibility of the CHINESE medical music there are no UNDERWATER suggestions and only a HEALTHY tone for CERTAIN organs.At your own risk, I took a couple of short tracks seems to be as ALIVE and as neither mental nor physical is not deteriorated and still would love to know your opinion.
You can...
Прохожий wrote:is it POSSIBLE instead of the usual alpha for such a case to use one of the sessions of the "L" that where in the first 12 minutes of special suggestion.
Sessions L, there is no suggestions. It all depends on what you need.
Прохожий wrote:the Second question:you advised me to put in MM instead of the squarewave signal SIN,that is, if I understand correctly then in the instructions it is marked(a) as a sine wave?And if I understand you correctly WHAT to change from what I'm listening to MM on this signal?
Disappear higher harmonics characteristic of the square wave signal which, apparently, were You excited at the sessions of relaxation.
Прохожий wrote:the Third question:what about brightness points WHAT do you recommend I iznochalno was a brightness WHERE the left is MUCH stronger flash than the right.I would like to know what the meaning that one eye flashing brighter and the other less and THAT I you would suggest?
It's not the exact configuration of the electric circuit. In the settings (see manual) have the opportunity to fix it.
Post by Андрей Патрушев » Sun Aug 19, 2012 22:30
Svetlana Solovyova
Hello.
Drive "Star Wanderer".
