Bracelets Life
If it is impossible to take "as 3.0" bracelets this version work with the Operator in the mode "standard" (active tuning).
The essence of the work "Standard" is not to "feel" it working (although with a significant "distortions" and sufficient sensitivity - perhaps even highlighting the ranges of such forms), and to correct areas of significant dissonance with the "Standard" in the cocoon, the 3.0 L is already doing and stiffer 3.0 N - softer and wider, then " + " the details (particular manifestations).
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
Re: The Bracelets Of Life
I have long wanted to ask. How to properly dispose of BJ technology?
I mean I for some reason suddenly not like there is a bracelet card PC or escho something, or like a fragile bracelet of their skin is worn out, I'll make a new one to replace and old what to do? well, not to keep them otstatki the crowd on the shelf there in the end and can accumulate very much.
I think, special. measures for disposal of not needed, unless, of course, we are not talking about how to erase information from the object. Then - briefly - in any way.
It is about how to completely erase information from unnecessary object. Mental traces of bracelets you can also disable, I then read somewhere about it. Just personally, I have accumulated a lot of printouts with matrices panaceas, light AMB , of which stoppage nowhere to go.
Or just enough to physically destroy the object and forget about it?
Just print myself in the future PC will begin to use and where to put lishnee are not in demand?
To overwrite information on the subject can only be an older version, e.g. 2.0 -> 3.0 (and it already cannot be erased at all, at least available means). Physically destroy an object is possible.
Although I do not understand, why do something to erase and destroy. I have the same Panacea handled dozens, if not hundreds of objects. Without any utilization.
Hatred if you don't want to hildren
the items were radioactive around you can physically destroy, so if there is a desire to leave "for the future" wrapped in aluminum foil or any aluminum box - screen. About there are some thick /compared to foil/ aluminum packaging for bottles of alcoholic beverages, often in the form of a high cylinder. Thus, it is possible to store and "blanks" for the stabilizer to prevent the creation of unnecessary anomalies are not going to make the Stabilizer. Through craniofa you can also restrict remote work BJ for particular products, because as already written - BJ and work remotely.Хастред wrote: lishnee which won't be popular
Bopara - nonsense written. BJ escaped, especially foil
put in a pile and forget. Let them work - don't want to destroy them.Хастред wrote:It is about how to completely erase information from unnecessary object. Mental traces of bracelets you can also disable, I then read somewhere about it. Just personally, I have accumulated a lot of printouts with matrices panaceas, light AMB , of which stoppage nowhere to go.
Actually BJ screening no reason, other works (in relation to the transfer of energy) principle, i.e., nothing is transmitted, but from a mental (and astral) contact and interaction, such (physical) isolation of multidimensional objects (with "subtle bodies") will not help, because the contact is carried out through multidimensional space, and such "lock-up" is present only in a narrow range in some of its faces (in the physical world). Analogy = how to disable Postings from stranded cable, the other connected, this is the result of physical isolation of multidimensional objects. H0 on "insulator" to assign other additional properties (insulation in a multidimensional world), H0 is a different story and yourself (demo) it won't happen. When you have the necessary skills, physical "insulators" can be optional, if only as carriers isolating mental forms.......
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
1. this only applies to thembofara wrote:I wrote about craniofa based on this videos, and more precisely min: 8:38. There is about cartridges "transfer power and signal", and how better to keep the foil when they are not needed.
2. they were made to BJ or during 1.0
3. they (the cartridges) are stupid and piercing, unlike BJ
ie to start with it was not worth it.
in addition TO all the modern products (and DIY) great program, so it is enough (if necessary) to confuse the necessary task (for example, temporary de-activation, though I don't see any value and meaning)
Prompt somebody, whether as a BJ wearing a chain on your neck?
Want label 1 copy БЖ2.0 "obseity" chain that I always wear.
Somewhere on the forum I read that the ankles and the wrists meridians are, therefore, in the form of bracelets...
Please excuse me, if stupidity was asked - I'm new
you can, but if this is the first BJ you better at least watch (but the bracelet), chains can be a little uncomfortable
better then a little more expensive to take the card transfer 2.0 and if the chain does not like it, replace with another item.
Oh, thank you, Michael! So quickly, thank you.
Please explain "may be a little uncomfortable"?
well, the neck will have more energy, can bias to occur, the feeling can be not comfortable in self-perception, perception or health.
Can and map, the fact that it's best to wear all the time, I watch for the night shoot, and the chain on me all the time.
But, if You say bracelet, then the bracelet
can night (before the night) on the map to put the chain, and in the morning watch. In principle, 5 minutes is enough on the map.
Thank you.
For a full charge how many items on the map must be object?
a couple of hours, but for regular change enough for a few minutes
Michael, thank you for taking the time. Map transfer ordered
