You are absolutely right.Прохожий wrote:thank you very much.That is, IF I understand correctly, this drug is quite possible to combine with listening and work on a MM machine?
Advice from Andrei Patrushev
Andrew, I want to start to learn meditation (concentration on the breath) at the initial stage the plan to use the disks for a deeper dive, do you think that's a good start, alpha or theta ? Discs alpha worked with theta yet ? And you how to me advised between alpha and theta to take a course of beta, but to listen to CDs focused on Wake 4 hours before sleep does not work, is it possible to skip the beta yet?
CEST
On the breath - better alpha.
Well, skip. A year work out, then still take the beta, and after another year work out... Then we will talk about the difference.
Then tell us about the difference
And to experiment on live humans is not humane
CEST
All the experiments have already put...
If You have a fairly strong beta waves (more precisely, a good voluntary attention) and so be swept...
In the absence of anything terrible would have happened. You would have thought that meditating, and even caught a couple "ozarenie"...
Good day Andrew.Read the posts above and honestly just at a loss...That is until I listen to BITTU then I see no reason to listen tattoo or that there may be some UNPLEASANT consequences.I just my betta nowhere to go,and the frequency of my betta 25-30Hz.And that's Andrew in the background of the work with agriculture and Healing!This is the first .And second, today I started to WATCH a rainbow.The question is:do you think it POSSIBLE to combine YOUR programme with APK"RELAXATION",called A. I. Kuchinova he said that provided the break for 4-5 hours, it's possible,but I still would like to know your opinion.And if THIS combination is possible I would like to know how often you can change the texts,that is, for example in the morning I listened with ANTIAFFIRMATIVE and in the evening a package of Affirmatsii for Rainbow or need kakya regular sequence in audition.Thanks in advance for the answer!
And if you can please explain what is AFFIRMATSII and why they are used.
I gave You a link to the articleПрохожий wrote:Yes, and if you can please explain what is AFFIRMATSII and why they are used.
For a fuller understanding read more about affirmations http://www.mindmachine.ru/articles/affirmations.htm then will understand the difference.
Thanks for the tip,dear Voffka.
And from you Andrew I would very much like to hear the opinion of my first post.
I'm sorry, You remind me of a drug addict who can't find a dose, so I went to the pharmacy, picked there's a whole slew of tablets and intends to swallow them all...Прохожий wrote:And from you Andrew I would very much like to hear the opinion of my first post.
So the article Andrei Patrushev wrote, it is his opinionПрохожий wrote:Thanks for the tip,dear Voffka.And from you Andrew I would very much like to hear the opinion of my first post.
It turns out that it came earlier than the issue
Good time of day.Andrew you're so vain but I have really serious problem here, and try what may I DO to help.And could you still clarify to me:is it possible COMBINATION of the RAINBOW and APK?Or maybe they can be alternated for example with the morning Rainbows and evening as uspokaivali Relaxation.I would be very grateful for an answer.
Passer-by
Here I am about that it can behave only perfectly healthy people. A sick man must go forward with caution, weighing every step...
Thanks for the warning Andrew, I think you understood,as both programs are VERBAL suggestion and since neither YOU nor I know WHAT exactly and I. A. Kuchin(with all due respect to him)you and will not tell them the result can be UNPREDICTABLE so to say can be a COMPLETE success and maybe a full timeout.It's not a parallel listening is harmless(in this respect), HEALING where there is no verbal suggestions.All I knew so when I listen to or watch APK what that one then wait a couple of weeks but rather a month when it is more settled, and then VERY carefully try something else.Then a question:what do you think is it possible with APK audition programs in which there are no subliminal suggestions.For example soft alpha sessions with the aim to make the processing of the negative.Of course the effect of the apps APK is good but sometimes sticks so not pokazyvaetsya.Recently after put in,so that WAS just terrible(when I wrote to you)a few hours later, I heard soft alpha session and directly physically adsutil as I let go ill fear though like A. I. Kuchin told me that APC is mostly in alpha.Because of what it could be?May be due to the fact that pop up the most deep-seated fears that need to be processed through awareness of them,and as your alpha I have very little and that what is in the APK is not quite enough so, I felt better from the ADDITIONAL so say the influx of alpha waves.Do I understand correctly?After all, as I explained to A. Tuchin the process of refining and transformation is through a so to speak of AWARENESS MIND the fact that it WAS deep inside and did not give rest.And only then it ceases to disturb.But all the different "Islamic"and the INITIAL of the capabilities of processing that is the level of alpha is also different.I correctly think?Thanks in advance for your answer.
Yes, of course.Прохожий wrote:Then such question:how you think is it possible with APK audition programs in which there are no subliminal suggestions.
Good day and thanks for the reply.Andrew and MY ideas of what is RIGHT and LESS painful processing negativity that POPs up when,during the course of agricultural programmes largely depends on the alpha,are close to the truth.That is, do I understand correctly that ONE and THE so to speak negative of people with MORE accumulated alpha will process less painful and PERHAPS even faster and conversely people with less developed and developed the alpha condition will be the same negative heavier and perhaps longer.Very interesting to know your opinion,thanks in advance for your answer.
And one more thing.How do you think the alpha session to listen TO session best APK so to speak to enter the BODY more elastic as or after agriculture?
You are absolutely right.Прохожий wrote:Good day and thank you for the reply.Andrew and MY ideas of what is RIGHT and LESS painful processing negativity that POPs up when,during the course of agricultural programmes largely depends on the alpha,are close to the truth.That is, do I understand correctly that ONE and THE so to speak negative of people with MORE accumulated alpha will process less painful and PERHAPS even faster and conversely people with less developed and developed the alpha condition will be the same negative heavier and perhaps longer.Very interesting to know your opinion,thanks in advance for your answer.
I think it is better to and with a gap of three hours.Прохожий wrote:and one more thing.How do you think the alpha session to listen TO session best APK so to speak to enter the BODY more elastic as or after agriculture?
Good day and thank you very much
for the answer!
Andrei Patrushev
Hello. Andrew! I'm curious what I have the dominant frequency of brain activity
Tell me, how can you learn? Only on measuring devices or there are indirect signs? I have read the descriptions of alpha and beta and theta, but something based on the description to determine it does not work...
Hello dear Voffka.Glad I could be of use to you.In order to know the DOMINANT frequency of the brain need to do an EEG(electroencephalogram),and that is the FULL description of percentage,they nazyvayutsya indexes.And it is possible to determine what your PRIMARY frequency.
Good time of day.There are ABSOLUTELY no conditions except one you just need to come without any moral ustanovok,that is, if you WANT to see what waves are dominant in a normal condition and should be in his normal state without any auto suggestions come and sit in the chair as if you sat in your favorite home chair(if you have it of course),then you will be able to know exactly what the BASIC wave in a normal condition.
Good time of day.Andrew I have a question, you understand it may seem funny but still:Why is VALID for redemption from a SUBCONSCIOUS fear of it need SERIOUSLY and also be aware and UNDERSTAND that serious how it interferes with life and only then the fear is either completely gone or become less or if the person is advanced in working with your higher power he will be given the answer that, if not get rid of fear but will make life bearable.But all these options still need to be aware of your own and go through his residence.There's no other way to salvation WITHOUT the awareness and experience?That is not pulling his consciousness and destroying where he originated?Mean not just lock fear something navreme,here I do not understand the fear ceases to torment but HE still remains without any changes,it is clear to me.Namely ways WITHOUT his ACKNOWLEDGEMENT and ACCOMMODATION but with the same substantial effect and such serious things.Thanks in advance for your answer.
