Bracelets Life
no idea never read, and probably will not, take everything only as a response and not as an exact match, if there are some personal resonances - maybe it's good, but never try to get a picture that way.
Анатольевич
Re: The Bracelets Of Life
Michael, good day! I have a question.
About 3 months ago bought BJ 2.0, 2.6 , IIM-1, AP and AC (watch).
Use started gradually. BJ 2.0, then added the IIM-1, then BJ 2.6., then at and AC. Acquaintance went smoothly and easily. The complexities of the situations were not, and if there was, it was because of my wrong interpretation of the situation, eventually all ended in the best way than I originally wanted.
After about 1 - 1.5 months from commencement of use of these things, I'm in a weird state of consciousness, the world became more "plastic", pliable to change, ie I began to form certain situations and developments, and do not "pull" them to their reality, and "go live" in the reality where these events are already formed (or was formed). Increased the flow of money modules of the BZ (the passage of air, surf and spiders-move).
Relative to as – to use started with chesy on the left hand, the results were not evident until did not wear a watch on his right hand. "Time management" is a physical thing I bought ie one unit of time I can do a lot more (appointments, tasks, etc. everything happens in time) the feeling that time has "slowed down" in 2-3 times.
Causes alertness and concerns the following situation. 2 weeks was on vacation, BJ just wore (modules not used) phone at next to me was not (also didn't use it). After leaving home for work, there were complications (torn BJ 2.0 on the left hand, severe pain in the left elbow, all kinds of small and medium difficulty work, the money became less, lost the ability (power) to influence events, etc.) the feeling that exploded a connection with the BZ.
And if before the leave was "excessive" force and confidence in the possibility of the formation of events, which sometimes had to consciously restrain "that would be the roof blown off", but now the opportunities and 25% left.
1. Is this normal?
2. How to return the opportunities that beat or are they coming back?
3. Plan to buy a BJ – and BJ 2.5 Range since leaving on vacation for 1 month. and would like for them to adapt when you are away from work, what would be the situations even more shaking. Can they right now use? or wait until everything is back to normal still with the existing BJ 2.0. and 2.6.?<
1. Is this normal?
I will Express my opinion on this, if anything, Michael and others will correct. A normal person going on vacation , off from work, so all the processes that you have worked on time before the holiday , all were connected with work , with earning money and promoting your ideas....Vacation - and the body , together with the task ...go on vacation. Gave the opportunity to relax and reboot. This is because you are not accustomed to this or indicated it is the consciousness that vacation is a break from work , not from BJ and all that Sneem is connected. The brain of inertia vosprinyali -vacation means a complete rest from everything. Not even using the bracelets , people leaving the home have some difficulties switching . Just give yourself time and set goals..all is working again. I'm on vacation resting from work , but still when the opportunity did not fail to tell , even with the other side of the world people that there are MM))). But it's so fleeting. But BJ just took to work on the rest . And they worked very well . And a lot of interesting things happened. Therefore , do not despair. Everything will work on. The main thing here is not to say that's enough to not come back. Else everything will go downhill.May need some revision purposes or just not to forget, the Best and safest way.......<Анатольевич wrote:Causes alertness and concerns the following situation. 2 weeks was on vacation, BJ just wore (modules not used) phone at next to me was not (also didn't use it). After leaving home for work, there were complications (torn BJ 2.0 on the left hand, severe pain in the left elbow, all kinds of small and medium difficulty work, the money became less, lost the ability (power) to influence events, etc.) the feeling that exploded a connection with the BZ. And if before the leave was "excessive" force and confidence in the possibility of the formation of events, which sometimes had to consciously restrain "that would be the roof blown off", but now the opportunities and 25% left. 1. Is this normal? 2. How to return the opportunities that beat or are they coming back?3. Plan to buy a BJ – and BJ 2.5 Range since leaving on vacation for 1 month. and would like for them to adapt when you are away from work, what would be the situations even more shaking. Can they right now use? or wait until everything is back to normal still with the existing BJ 2.0. and 2.6.?
1. do I need to add other products - I don't know, You know better.
2. In General, Lily is right - shifted deeply.
3. useful in such cases to have what's=what is dragging your trends without your undivided attention (IC or regulator-set targets).
Wear a BJ for about 3 months. Didn't feel any changes in health, just noticed that you no longer want to sleep on the job.
Recently a sleepy state came back (this time I connected the U2-U3), maybe it's because of the amplifiers, is not yet understood.
According to health is never ill and does not fall off, more changes were on situations.
For what purpose was connected to the Amplifier? If there are no global targets , get the Overdrive, ptomu and sleep clones. But last week not only because of the U-4 (if connected) were all sleepy. Though not as much as some.
I have a global goal, there were two, one made up by using BJ, the second can't reach. Don't know what's the catch.ЛИЛИЯ-Р wrote:for what purpose was connected to the Amplifier? If there are no global targets , get the Overdrive, ptomu and sleep clones. But last week not only because of the U-4 (if connected) were all sleepy. Though not as much as some.
The reasons are very different. 1.Peresmotret purpose, perhaps not yet ready to accept it...Гестия wrote:I have a global goal, there were two, one made up by using BJ, the second can't reach. Don't know what's the catch.ЛИЛИЯ-Р wrote:for what purpose was connected to the Amplifier? If there are no global targets , get the Overdrive, ptomu and sleep clones. But last week not only because of the U-4 (if connected) were all sleepy. Though not as much as some.
2.To review the affirmations regarding that goal.
3.whether it is harmonious and does not violate the harmony of others.
4.not always what you want, the desires of the universe and other people(if the desire is connected with them)
To progovoriti best and safe))))) then everything will be solved by itself.
BJ 1.0 was produced in the form of a pendant amulet your zodiac sign on a string, worn around the neck. More than a year has suffered a shimmering arrhythmia, thought heart attack, were such disruptions of rhythm. So, were going to go to the North (live in Belarus), on the day of departure BJ was already in stage of readiness, dressed and went. On arrival in Moscow, noticed that the heart rhythm clear, in General, arrhythmia as licked, and so far everything is great! These are the miracles. By the way, carried his 3rd of the day, then handed his wife. Now BJ 1.0 on the bracelet neodymium magnetic balls that are sold as nano cubes.
Michael, thank You!
Michael, thank You!
You would get rid of these fucking magnets. And better charged something easier (a piece of wood or stone).
Yes neodyme even in hands to take health dangerous, even small - all of them field, maim, and even to wear - only if slow suicide - the purpose of all life.
Yeah, I did not expect!... Wear somewhere from a month, parallel wear on the right hand BZ 3.0 on a wooden base, any deterioration in health was observed, more to say, negative circumstances, diminished, became more positive emotions, despite the divorce and dismissal from a good job at the same time...
I have to Michael question: when recording BJ 3.0, subject to pre-oborachivaetsya foil before wrapping the mandala? And yet, would it be correct if an object is wrapped in a mandala tube? Then the mandala can be used repeatedly.
Discussed a hundred times. First, the mandala, then foil. Tube - not necessary, just wrap and all.
a couple of very weak magnets placed on the right point person with the desire to kill, and in a short time. And a lot of strong standing in the area where a lot of energy channels can significantly skew the energy body to distort the cocoon, to tumors of different properties and whatnot. Not immediately of course. As a result, benefit from the BJ spend on restoration of the destroyed on the spot his own.
And 3.0 I'm not sure what You want.
Michael_Hello
I'm going (after a long break) to again start to listen to CDs Andrei Patrushev - a Guide and journey through the inner worlds. Always wear 2.6 and AMB. To remove the bracelets while listening to or not to withdraw?
Thank You for all that You do
You help me to live.
1. the feelings. Generally I always recommend to not listen me and my feelings. Of course there are exceptions, but the task of each learn to trust yourself and not me.
2. generally, in bracelets, the effects can be much brighter, especially in the AMB, although it depends on the objectives. Interfere they will not. Well, theoretically, if a purpose when listening nakosyachili, though conduit is almost impossible, there "built-in" formulations perfected by Andrew to the limit (I still hear both channels being conscious for at least a couple of times and remember
), i.e. to load before listening to the dangerous target I think is quite difficult, it will smooth the process to the optimum. IMHO.
Thank you, Michael_I'll listen to the bracelets , if there are interesting observations - write
I would also add to the list of "star wanderer" to listen to. With him, life for many becomes quite interesting
including the background of the BJ.
I have a "brain Massage"
Question to Michael. Use Your development about two years reviews +++++ Have a SK HF-1, and so on. Collaborate with seeing on your devices. The product is very interesting especially the UK . But a couple of months ago I decided to look back . Two years ago BJ 2.0 soft and pleasant RELAXATION now empty. 2.1 is much more powerful. now empty and podlucky strangers. BJ card P. Before, even in the hands ate held . Wondered how I wear the same capacity. But a week ago I came up with the idea and if bracelets have registered on me. Started to look . Saw the hands and bracelets. Tried to call-ins and she stared work as well as BJ . Maybe You have the old?
Seeing your not so little, seestom wrote:Question to Michael. Use Your development about two years reviews +++++ Have a SK HF-1, and so on. Collaborate with seeing on your devices. The product is very interesting especially the UK . But a couple of months ago I decided to look back . Two years ago BJ 2.0 soft and pleasant RELAXATION now empty. 2.1 is much more powerful. now empty and podlucky strangers. BJ card P. Before, even in the hands ate held . Wondered how I wear the same capacity. But a week ago I came up with the idea and if bracelets have registered on me. Started to look . Saw the hands and bracelets. Tried to call-ins and she stared work as well as BJ . Maybe You have the old?
1. with original bracelets and a map of the migration and all the rest, everything is fine, they have no expiration date and no there's no other podkluchit, it is guaranteed.
May be only those channels (and they can be), who created You yourself, at different points in time, it's beyond the regulation of the BZ (the principle of freedom of will, to limit your actions BJ can't, it only helps the settings and principles of operation without replacing anything).
2. naturally, the quality of taken over by you, i.e. become your personal will without overloading (which can get hard) not popular with bracelets.
In other words, BJ now for You not a means of support in ordinary time (they will become so in case of overload), and because they are not active.
Operator leaves You.
Demand potential from them.
Even BJ 1.0, where KO does not work (its not there) it is not possible to define it as something abnormal and energovydeleniya if they are passive to the operator and a many just don't see (as it was stated many times).
Thus your seeing was not looking at BJ and so on, and their active working - i.e. it makes sense ONLY in conjunction with the operator!
now the operator fed - so no visible activity.
As for phantom BJ - that is a documented feature that exist specifically for situations when the original is not with You.
So due to the fact that BJ is not similar at all to normal energy-active products, artifacts, and amulets, diagnosis and from (all) was not conducted correctly.
Well, it described many times by the way.
phantoms with hands You can remove it easily but I would not advise to do this - a very useful thing.<
by the way a very useful property is that the bracelets are not visible as an active unit, unless they are under load. At least my friend often came across the situation with the negotiations (and still fall), when someone on the other side of the table, obviously a mage. And he (she) is surprised, but artifacts in the source usually does not see and even what little I understand, in short, "what the hell"
and with a 3.0 and those with him - even fun. Even when BJ is active and the pump energy on the operator, from the point of view of sense can be confusing whether they are source or just part of the statement soaked in its energy. Looks holistically. One reason for this (in older versions from 2.0 on) -the presence of CO, which is distributed to cocoon, and also the fact that the energy comes in the form of and quantity demanded by the body - i.e. "like a native", she was hard to visually distinguish. Most sources will just feed the human operator is not frequency - it will be noticeable, but cocoon will spend resources for processing and may be different from this burning body.
Tell me, and make sense if they neocultural from 3.0 L is nothing to dotarget it to a more powerful version of 3.0 N with a TV and bismuth, or continue short-term to wear this?
(security conditions are met, length 1.0 and 2.1 months, panacea Lite 3 months)
And by the way the letter matrix on the bracelet nesteros, and just deeply ingrained in the wood, wrote in red marker on oil impregnated pine.
