Thank you!Малика wrote:What gorgeous beads! Yes, even bronze..Probably it's gonna be a harmonizer! Good Luck To You)))
Aku-WAC billet. Wire 4 mm.
It is the same, but are silver plated in a silver solution.
Yes , the beads are gorgeous)))Пчела wrote:Blank coasters. Bronze. Weight 5.5 kg. Most will turn into chips.
This makes the honor of your shrewdness. Of course the stand under the globe, will be welded on and even a hole up to the globe.ЛИЛИЯ-Р wrote:AND stand ...what do you mean? Like Sliema, which then vpaivaetsja will ring for harmonizer? At least somebody would point in exactly. And to test it))))like everyday life.
Not quite. Cropped all six rings on both sides, about 2-3 mm, and then the ends were set at an angle of about 60 degrees and welded together. Your idea was, first ring normal length, the other shorter are welded to the first. Inside welding as the backbone, the ends of the first ring.ФилиНН wrote:"is of interest weld-braze process"![]()
... when the rings are joined on one level.
From accurate length measurements of each ring except the first shall be deducted the pieces(2 pieces) that have these welded nodes or not?
And what are you against?ФилиНН wrote:it is Unclear all that...
There is a current on the pigtail of the 2 lived torsionic because of PereVesti and whammo! Soldering-welding the same point. Linear 3mm. goes-revolves and again - Bang! ...
Who Hamutal? You?ФилиНН wrote:is unclear is hometeam ring nylon strips - plain and simple.
I don't mind, I'm not clear as written.Пчела wrote:And what are you against?
WE Self-dergez All Self-made HarmonizerПчела wrote: Filin wrote(a):
It is unclear hometeam ring nylon strips - plain and simple.
Who Hamutal? You?
Alternatively, pills at the pharmacy or own harmonizer on the head.ФилиНН wrote:I'm not clear
And the bark from the tree haven't tried? From willow for example? From which the bast weave. Or come to Primorsky Krai and lime kick.ФилиНН wrote:of Filin wrote(a):
Who Hamutal? You?
My brain, plus the purchase of the cable, cleaning of the membranes, the results of wire for the manufacture of Aku-Vaca andriamena, rings, search of material for beads and stands, transfer the finished Aka-Vaka silver, chewed Turner what I want to have, gathering all the parts together, shipping the welder, chewing what and where to weld, participation in sarasmom the process as a hold. Further, independent processing of the product, his running and subsequent and previous chewed some of the functionality of this product.Шалтай Балтай wrote:Who did? Bee? Or, again, just to organize the process?
By the way, I forgot to add. Everything is thought out and calculated, including the dimensions that got together in the end, docked and cooked together, what would the consumer do not have to scratch turnip in thinking. Where Aku-Waku stick/attach it? And maybe a rope to tie up? At one end, or both? Or gum to the floor stick, and the rest has to be turned around, to find the best solution of the problem?Шалтай Балтай wrote:Who did? Bee? Or, again, just to organize the process?
