Appeared in the sale of rims from Andrei Patrushev
Post by Андрей Патрушев » Wed Jun 13, 2007 13:08
Серррёга wrote: And more. This is probably a question personally to Andrew. I do not quite understand what feature of the disc "Star wanderer". Kind of "changes in people" it can completely replace the Massage of the Brain and Healing. Or not? He has a CHIP, which is worth it to buy?
Disk space wanderer is best suited to children with a label of "unteachable" (or more mild forms of problems with learning), on the other hand it is written as a holistic meditation - cosmic journey (though each track is functional).
Effects it really replaces the Massage of the Brain.
Post by Dimas » Wed Jun 13, 2007 13:20
Despite the fact that "Massage brain" is not recommended listening for children up to 14 years.I understand "Star traveler" is designed for children above 7 years of age.It turns out that "mm" is for adults, "ZS" for kids! :wink:
Серррёга
Post by Серррёга » Wed Jun 13, 2007 17:57
All figured out. So the machine I will always have time to "catch up", you can start without it. Thank you for the answers!
Александр_
Post by Александр_ » Fri Jun 22, 2007 2:07
Question to Andrey Patrushev.
First of all I want to thank you for your work.
The results are felt on the forum, and I read the whole forum (because of this in my head of course easy %-), but I'll survive :) ).
Very friendly and warm here.
I think this is an important indicator.
Talk a little about myself : today I brought Innerpulse with colorstream.
And I have already filled all your session in the machine.
So I'm happy to prescribe on this forum, among people who are interested in the same things as me.
(By the way Demos with his post - special thanks !)
My goal is to learn conscious control of various States of consciousness.
I have need for even greater harmonization of life, and to achieve out-of-body experiences, and Havo.
After reading Michael's Rainbow - "Outside the body", it became clear to me how I can achieve what I wanted in life, but the only videnii key for this today is the practice of the development of the WTO and Havo.
After studying the forum, it became clear that I could really help.
It is done!
The device is, and its effects compared with BWG stronger in order!
On the forum often found your recommendation to start with alpha rhythms.
This is what I started to do in the meantime.
Now I want to ask you -
1. Which disks should I buy to achieve my goals ?
2. What session, other than your recommend ?
3. What should be the approximate program of studies ?
(to start as I already knew from alpha for 3 weeks)
I will add also that time the car, and I have a flexible schedule.
And here's another question :
Listened To The Conductor.
In that place, when "we fly in a spiral fluffy cloud of" slightly annoying "twist" of the helix in a counterclockwise direction.
Tried to introduce a different direction of the spiral - nothing.
I know that left-hand spiral, the helix is negative.
Why did you decide to use it is this ?
It unconsciously, or you know something I don't know ? Please share.
And :
What sessions innerpulse, I can listen to the Guide ?
And :roll: :
As it became known, the frequency of the earth, which was previously 7, 8 on which the military equipment was calibrated, in recent years has changed towards increase, to 11 cents on the last known ine data.
reference :
"The Schumann resonance - the frequency value of the standing wave formed by the current between the lower boundary of the ionosphere and the earth's surface - Pro-the generations of the aeons of time was constant and ranged from approximately 7.25 to 7.8 Hz. It was so stable that it was calibrated even some scientific instruments. Gregg Bray-den, the famous author of the book Awakening to zero point> (), indicates that at the present time (may 1995) the value of this resonance is measured in the range of 10 to 11 Hz.
The esoterics say that the planet is entering another phase and energy evolution, and thus the vibrations change.
As a way of changing the collective consciousness of the people ...
Perhaps the frequency of 7.8 is not the same ?
PS. Very sorry for some offtopic.
Евгений Кош
Has thanked: 2 times
Been thanked: 2 times
Post by Евгений Кош » Fri Jun 22, 2007 9:24
Александр12345 wrote:nor car, and I have a flexible schedule.
You know what prostornaya spiral, this negative spiral.
About how!
I didn't even notice that there is there (today, 18 times propovednik listened to..) :) In the beginning, listen to what they say, and then enter a state where I remember not everything that is said in the guide.. and they say it is mainly for the subconscious :) although the consciousness is also useful to listen to :)
Post by Dimas » Fri Jun 22, 2007 11:45
Александр12345 wrote: My goal is to learn conscious control of various States of consciousness.
reference :
Andrew already explained on the forum about the frequency and its changes,try to find through a search on the forum,but not sure,maybe I personally discussed the question with him,as I was interested in...Explorer you can listen to and separately from the sessions in the machine,it was designed to do it..however it can also be combined with session training,where You enter a state of heightened suggestibility,look in the description to the machine...I also bought the audio book of the Rainbow...impressed but I'm not sure that the WTO and OS-REAL solution of some internal problems and the implementation of masked desires...Entertainment-YES,extension of experience and possible knowledge of the unknown-PERHAPS, TOO, YES,but hardly a solution to the problems...because it turns out that You start to live a full life in a dream and not reality...don't You think that is a kind of escape from reality???and then...an overly strong desire for something (WTO and OS for example) moves You away from the object of desire..from experience..as soon As You tell yourself,"Ugh..fuck it pisses me just fine without OS there any and the WTO (just need to take it sincerely)..",and then they can poperet as..well I don't know."And you forgive and and let go and-and-and-and..."-the song of the famous singer :lol: :lol: :lol: :wink:
A counter-clockwise or for it-everything is subjective,depends on where to look.. :wink: IMHO IT's certainly possible not to pay attention...Sees the root! :wink:
Александр_
Post by Александр_ » Fri Jun 22, 2007 11:47
About how!
Sorry, mixed up left.
To define very simply, when a sound like a muffled, no treble, then this is what happens when we hear a sound from behind.
And just at this point the sound switches from left ear to right, and then we hear a sound with all the frequencies moving from right to left.
It turns out - left spin.
Ie counterclockwise rotation.
In torsion fields - a destructive left-hand and right-hand creative.
Александр_
Post by Александр_ » Fri Jun 22, 2007 12:04
reference :
Support DIMAS.
I offer "you" :).
Feel you agree :).
Absolutely true what you wrote, I want only to add something.
Any their problems and glitches that prevent to live, man if I caught, I can consciously survive and transform.
Thus changing your karma.
Our karma is simple - the results of my research, karma of a person is merely the result of his habitual actions.
For example - I used to overeat, get obese.
Used to play sports and get a healthy body.
To do right, we often prevent event which was our childhood, or the events that have been pushed out of our consciousness as too traumatic.
Usually we fight with wrong habits, changing their behavior according to the principle used to do, now do not.
It's complicated. It's like windmills to fight.
Need to Mature to the root, as you say :)
The problem is she's like an iceberg - 90 per cent under water (in the subconscious).
If you pull the light of the very cause of the problem, and then work through it, the bad habit will disappear itself.
So in this respect, the methodology of the Rainbow - a powerful tool!!!
And what about the rotation of the spiral - I'm sure Andrew will be interested to learn more on how to perceive its products.
Post by Dimas » Fri Jun 22, 2007 12:18
I agree! :wink:
in karma I don't believe...believe in cellular memory that can be reprogrammed (religion I have :lol: )..although it CAN BE...
And about the methodology of the Rainbow...Yes, his methods then there is no...the guy may just have mastered the various methods of exits from the body...
although IT can also be considered a technique...And then everything in my opinion on a primitive level...the depth is not enough you know (and Yes,we're for you :wink:hard somehow)...
Александр_
Post by Александр_ » Fri Jun 22, 2007 12:31
Support Dimas !
The phenomenon shitty life can be called whatever you like - and the habit and cellular memory and karma.
And I his book made a very big impression.
Very methodical guy. I need to learn from him.
And by the way, a question for you : as I on the forum I saw your message that you changed the duration of your meditation to 50 minutes.
How did you do that ?
Post by Dimas » Fri Jun 22, 2007 12:36
Select the session,click on PLAY,the countdown begins until it has ended you press SELECT,will be displayed the duration of the session,press UP increase the duration (you can click multiple times),respectively DOUN click-save.
Post by Андрей Патрушев » Fri Jun 22, 2007 15:38
Александр12345 wrote:a Question for Andrei Patrushev.
Welcome Alexander 12345, in our friendly team. :D
In fact, all so individually, just a horror... :P
Perhaps we should start with the Conductor and Massage of the Brain.
The sessions I have already written - it's all, "r", i2, P2.
The program should be individualized, but the General rekomendacii: two times a day for 15-20 minutes with a break of at least 3 hours.
Well, using Your picture of the World, I can say that "like attracts like" :) I, for one, hear what "clockwise"... :P
In fact, auditory perception is much better than the visual. When listening with headphones excludes such important sumpremacy as the skin of the face and resonant cavities (the maxillary and sinuses). Incidentally, an attempt is made to simulate and vertical movement (i.e., like a sine wave, closed in a ring). Some hear it, others, again, no.
In my opinion, still much rotates (E.g., in the hemisphere in normal right-hand spiral, in the South - on the contrary. Does this mean that there are some assholes live? :D )
And :
Perhaps only with L3.
And another :roll: :
reference :
By the way, the lock turned. I read this question. and then came to me the guys (physics) from the local branch of the Academy who are professionally engaged in the study of the Earth's magnetosphere. I Your question immediately forwarded. I must say that for a long time they laughed at me and made various offensive assumptions about me, - I in old age was fond of the yellow press... I really You did not give... :D
Александр_
Post by Александр_ » Fri Jun 22, 2007 17:43
approx.
thanks for the reply.
about Schumann's a bummer then.
I need to write Gregg Bray Dan famous that he is mistaken :)
Post by Андрей Патрушев » Fri Jun 22, 2007 17:48
Александр12345 wrote:approx.
Yeah, and write that the Russian Academy of Sciences - against! :D
Александр_
Post by Александр_ » Fri Jun 22, 2007 17:51
well, it is wonderful that we have such an.
in General, this synchronism was obviously addressed to me, to correct the picture of the world.
accept.
Влад
Post by Влад » Fri Jun 22, 2007 22:42
Andrew and tell us what a good session P2? And the old manual will not suffice.
Same question. I understand the alpha training you need to osushestvit sitting with a straight back, as in meditation-visualization?
Post by Андрей Патрушев » Fri Jun 22, 2007 23:12
Влад wrote:Andrew and tell us what a good session P2? And the old manual will not suffice.
P2 is good because it is also alpha session (well, a little bit of beta). R1 - with theta, which can lead to depressed and nightmares for beginners.
Alpha training can be implemented. Straight back specifically helps to visualize everything.
Влад
Post by Влад » Fri Jun 22, 2007 23:18
Andrew, these recommendations read the topic Quick guide buyer's mind PHOTOSONIX machines
so I decided to ask
Choose the most comfortable position
You can choose from the following options:
· Sitting with a straight spine on a chair – beta and alpha programs for concentration;
IMHO it is right, we practice alpha training, then to meditate and visualize. :)
I understand that this is alpha with a little beta. That is, its effectiveness in the combination of the alpha and beta frequencies?
Post by Андрей Патрушев » Sat Jun 23, 2007 9:09
Влад wrote:Andrew, these recommendations read the topic Quick guide buyer's mind PHOTOSONIX machines
so I decided to ask
Recommendations there are no hard requirements. :D If You want to have rest, it is best to sit in an easy chair, leaning back (ideally 120 degrees between back and seat), if you really want to meditate, then his back to keep straight.
Евгений Кош
Post by Евгений Кош » Sat Jun 23, 2007 18:22
What does it mean - "straight back".. straight back may be sitting and lying and lying..
Video - in the sense of vertically?
Post by Андрей Патрушев » Sun Jun 24, 2007 1:45
This means sitting down, not leaning on the back of a chair.
Саин
Post by Саин » Tue Jun 26, 2007 21:36
Good day, dear friends. Take the newcomer into their ranks. It has long been doing binaural beats and I recently came across purely by accident on drives Andrei Patrushev. As I understand it, there are not only binaural beats but specifically chosen music. Or am I wrong? Recently I got acquainted with the first disc Patrushev, namely Ultramega. Tried under the 2nd track to prepare for the exam and this is what I can say: I don't know why, but I have a couple of days after listening to lost normal sleep. I usually go to bed at 2-3 a.m. and after the track began to Wake up at 5 am. It's a side effect, or it should be. As I understand it, I knocked my biorhythm. Perhaps the problem stems from the fact that I did other methods binaural, or not? And another question to Andrew: "Tell me please, is it possible to convert Your tracks to MP3 format to listen on your MP3 player and not think about the fact that will not be enough space in other music?"
Thanks in advance
Евгений Кош
Post by Евгений Кош » Tue Jun 26, 2007 23:41
See.- the forum thrives :)
it pleases :)
Сперанца
Post by Сперанца » Wed Jun 27, 2007 9:13
By the way about the forum.
It would be interesting if there was a sub-forum "Diaries".
Which who wants to can write in your diary, for example, "Diary Speranza". In piravom post mindmachine what to write, what points are what drives. And leave this post editable permanently, that is, a man bought a drive, wrote in the first post. And delshe author of the diary is divided, he listened to what feelings, asking questions. It is clear that the subject of the diaries you can write and the other participants:)
I'm such in a forum about weight loss seen. :D
And here I am every time I think what would me a topic to write.
And here is its theme, you can write it all:)
Post by Dimas » Wed Jun 27, 2007 11:20
The idea is great,hope!But something tells me that either in other threads people cease to write,or write the person a few posts in your journal,then it will still be in the existing branches to write..and because man is a creature,which is interesting to read and talk mostly about THEMSELVES,will interest most members of the forum THEIR diaries...? :wink:
