Deck Alpha-Vit
Евгений-М
Re: Deck Alpha-Vit
Post by Евгений-М » Tue Jan 20, 2015 1:04
Михаил_ wrote:the Problem you need to update, since launched new.
Generally such cases are of course worth having a second deck for quick access (in pocket/wallet), there are very hot situations in life when that's right and it should be spread out...
To clarify, I think it will be useful.
See, yesterday when I set the goal of a global type "peace-peace", I first put the bundle SK + Y4, and then the exact same deck (I did it for exercise). The fact that I work out operational problems type of conflict and the Parking lot, but "global" does not work. You wrote that, what has already been delivered cannot be canceled. Launched the trend and the shuffling will not be able to cancel the "kick". My logic is this - let the "peace-peace" turns to SK and AB I will practice.
And here already it is necessary to understand whether SK (other products) to communicate with the AV or not?
Re: Deck Alpha-Vit
Post by bofara » Tue Jan 20, 2015 1:10
Евгений-М wrote:"global" does not work.
The deck I did, but judging from my humble experience about the "globality" - you need to keep in mind your ability as an operator site /real and not exaggerated; although depending on the trend and Your personal qualities - the size of those areas can vary and training-to grow in this way - at least with a simple magical things and sparcity..
Also check on the validity of desires comparability with the real world /AVIT from what I've read - works with the real world, and not with the system/..
Евгений-М
Re: Deck Alpha-Vit
Post by Евгений-М » Tue Jan 20, 2015 2:26
About "globality," I clarify, is not in vain in quotes.
There was no view of still any long-term trends, not those that meant dear Bofara.
For example, the task:
Harmonization of yourself that you are not "resorbed" is possible with positive probability.
Such a goal could easily spin in the UK? I think Yes
And if you put the goal of AV, it literally made me go to the Stabilizer and to put such an anchor.
Here is an observation. :)
Re: Deck Alpha-Vit
Post by Михаил_ » Tue Jan 20, 2015 3:41
Products can interact. It has long been inherent in the underlying algorithms.
Евгений-М
Re: Deck Alpha-Vit
Post by Евгений-М » Tue Jan 20, 2015 12:24
Is it possible to put a deck in the UK or Amplifier?
Владмосква
Been thanked: 7 times
Re: Deck Alpha-Vit
Post by Владмосква » Tue Jan 20, 2015 19:19
is it Possible to put a deck in the UK or Amplifier?
No! The deck is self-sufficient (it works with all products, the statement which You, but interacts remotely).
The amplifier IC is also not necessary to put.
In the UK can be put only RF console, a piece of paper with purpose and water.
РомБа
Re: Deck Alpha-Vit
Post by РомБа » Fri Jan 23, 2015 19:38
My report and thanks to Michael.
Today made an order with AV which have formulated as good news.
And do during the day heard, and received positive information. First
the girl kindly reported that their firm can provide the goods at a
necessary for us the parameters (which had not been able to do). Then
called the partner informed that will perform the work (and did). Next, I called
close person remembered 10 minutes before this... Well, at the end
the day when the deck was long ago deactivated, I called my father announced that
came the long-awaited payoff for auto insurance.
Michael, thank you!
Has thanked: 5 times
Been thanked: 8 times
Re: Deck Alpha-Vit
Post by Воффка » Thu Feb 05, 2015 0:25
Michael_
Hello, Michael!
Tell me, how should I store a few deactivated decks? Each other can?
Re: Deck Alpha-Vit
Post by Михаил_ » Thu Feb 05, 2015 6:34
you can, just don't confuse them (cards)
Алега
Been thanked: 3 times
Re: Deck Alpha-Vit
Post by Алега » Sun Feb 15, 2015 15:59
But I wonder how it will work is abstract language?Well, for example-"increase the number of beneficial for me probability".Can anyone have a similar experience.We'll share the results.
Petr99
Has thanked: 3 times
Been thanked: 15 times
Re: Deck Alpha-Vit
Post by Petr99 » Sun Feb 15, 2015 18:20
I think it will be like to work with me: the ability to work with probability; the ability to choose favorable; the ability to switch between the probabilities to achieve your goals.
When you work with me through ALFAVIT difficult to identify moments when you need to shuffle. Perhaps it makes sense to put the long-term goal considering the fact that the period between the shuffle will be long (to make it easier to determine the time of dicing).
Ленчик
Re: Deck Alpha-Vit
Post by Ленчик » Sun Feb 15, 2015 18:26
Алега wrote:But I wonder how it will work is abstract language?
Will work :) But you risk greatly "surprised" when you see that your subconscious is much different from your opinion is favorable, it's not only the current moment is guided. It is, of course, good, but could shake up thoroughly. So it is better to be more specific: and easier and the result better.. Or have you already fulfilled all your dreams :wink:
Андрей С.
Been thanked: 4 times
Re: Deck Alpha-Vit
Post by Андрей С. » Sun Feb 15, 2015 20:15
Ленчик wrote:But you risk greatly "surprised" when you see that your subconscious is much different from your opinion is favorable, it's not only the current moment is guided. It is, of course, good, but could shake up thoroughly.
It's true :) It's not so much about the subconscious, how much of the conflict between your true self and current personality. Just yesterday explained to another person (however, on another question), when there is this conflict -- When your essence says, "okay, let's quickly change that shit, this is what all the hell is going on, you call this living?!", and the person was like, "Well, I have things to do, work, business, credit, mortgage, family, friends, acquaintances, and in General, as I used to, I have arranged life is what change?!" :) This conflict is in any case necessary to decide, because if you don't a meeting to go to myself really... nothing good in life will not. The goal, which is motivated from the outside, will never make him neither happier nor more harmonious. However, if until recently I was a supporter of the approach "what shake, let's go, well, what shakes I'll get us there faster :)"now I finally understand :) what if moving too much, you and the car on the way to blowing away the dust and generally will not be reached :) I do understand it theoretically :lol: and continue to believe that efficiency justifies the tapping out of the comfort zone... moreover, it is necessary from time to time there vystragivaetsja.
Марат Г.
Re: Deck Alpha-Vit
Post by Марат Г. » Sun Feb 15, 2015 21:39
Good Evening!
I totally agree with Andrew.
I think many have forgotten about the true self and to their true values due to the fact that the person stubbornly set false goals and trends, and people play the role of others, forgetting his role.
In this regard, and the result is a conflict of drivers)) when a stranger is not played because it is not yours, but forgot..
Because probably disadvantages such as lies, deception, meanness and other.. because alien is not its role and not stretching adequately..
Whereas the own - fair, light and natural remains forgotten and not played..
here it turns out..
Sincerely yours, Marat<
Арго
Re: Deck Alpha-Vit
Post by Арго » Tue Feb 17, 2015 8:12
I want to share the experience of using ALFAVIT -
my wife went on vacation to Thailand.
long as the flight is 7 hours before the flight we were hoping that the plane will be incomplete, because the kind of season that the crisis should not be many who want to go to Thailand, but expectations are not met, the salon was full to overflowing
back when I flew home from Thailand the day before departure I ran to ALFAVIT we were comfortable, close to lots of space, nearby places are not busy.
as a result, in the airport we were given seats in business class,
in the economy class cabin, all seats were fully occupied,
in such cases, often there is not enough space in the cabin and some passengers offer seats in business class
the return flight was very comfortable!
Ленчик
Re: Deck Alpha-Vit
Post by Ленчик » Sun Feb 22, 2015 19:46
Марат Г. wrote:I think many forgot about true self and their true values due to the fact that the person stubbornly set false goals and trends, and people play the role of others, forgetting his role.
Well, can't argue with that :) Just the question was about something else: how to work with abstract language?
Many users here in a hurry "to jump over a house" (German proverb), but it's like in school - first sticks/squiggles then the equations directly from the integrals start will not work :)
And to think before something to do is never excessive. Many Rattles and everyone has their own reasons for it, but it's one thing when necessary, and quite another when the citizens themselves to provoke it needlessly and thus good :roll:
In General, I am for reasonable use of the "Almighty force" az !
Галатея
Re: Deck Alpha-Vit
Post by Галатея » Sat May 16, 2015 1:04
Michael, and if you set a goal for Alfa-Vita "buying a deck Smile Ishirkovo Cat" will come true? I want to buy but no money :oops: .
Re: Deck Alpha-Vit
Post by Михаил_ » Sat May 16, 2015 12:28
Are you seriously asking or joking? What does "come true"? kindergarten of some sort, it's not a guessing on a camomile :) Alpha-Vit - tool for work with vectors personal goals with the kicking of the processes to reach my goal. And here will come true or not come true? How do You think I can answer?
It depends on You, and other factors. ALFAVIT not guarantee that something will come true, and increases the chances to achieve your goals. If you just sit back - maybe nothing will happen.
There are of course the implementation of these objectives paradoxically (found money/gift/prize/bonus/the case of some, etc.), but probably better to look at things differently, for example "as a General change in the financial situation to the point where I can implement the conceived, that requires a financial cost", is to push the alpha and the wit to act independently, too, then of course the chances will be much greater. But if you just sit and wait that the dove is the piece of paper in his beak.
Been thanked: 16 times
Re: Deck Alpha-Vit
Post by Вячеслав. » Fri May 29, 2015 20:18
An interesting feature was noticed when zahodish in the forum...emotions do not always know the height.Ran from the bottom to the top,on the topics glanced at in and out.A few seconds with thoughts going zahodish all differently perceived (probably mentally already accumulated skills with a deck)third,an IED,for operational studies.
Re: Deck Alpha-Vit
Post by Михаил_ » Fri May 29, 2015 21:15
Contact with the forum generates the second component of perception - not verbal. In order to make it work properly, Yes - you need the status of working and over time this comes to some kind of autopilot, rightly observed. Virtually all leave here not only text, but something behind the scenes. And often it's something more or comparable text.
НРР
Has thanked: 2 times
Re: Deck Alpha-Vit
Post by НРР » Sun May 31, 2015 16:39
Michael is the program still going to be released? :)
Re: Deck Alpha-Vit
Post by Михаил_ » Sun May 31, 2015 20:48
Yes, I play with her :)
НРР
Re: Deck Alpha-Vit
Post by НРР » Sun May 31, 2015 22:58
Михаил_ wrote:Yes, I play with her :)
Oh, I wish we play :) :) :)
Re: Deck Alpha-Vit
Post by Михаил_ » Mon Jun 01, 2015 0:38
with the safe version :)
Галатея
Re: Deck Alpha-Vit
Post by Галатея » Mon Jul 27, 2015 0:13
Hello Michael. You once mentioned that they plan to release a more powerful variant of the deck alpha Vit. Whether to wait for this in the near future?
