Бисо
Has thanked: 49 times
Been thanked: 38 times
Re: Stream. The basic features and rates.
Post by Бисо » Tue Oct 08, 2013 21:26
Hello Michael,
I have questions:
1. Do you think that the stream of articles 2.5, 2.6 and 2.7 is optimal for successful business development?
2. Could this combination of products translirovat on a person who has no experience with BJ and even has no idea what is all this?
I plan translirovat this man two years continuously.
Thank you very much.
Пианистка
Has thanked: 10 times
Post by Пианистка » Tue Oct 08, 2013 22:23
began to interfere with earrings (small), removed.
арте:м
Been thanked: 8 times
Post by арте:м » Wed Oct 09, 2013 0:28
is it reasonable to increase the number of similar products in the slots? for example, one stream 3.0 will be highly effects to differ from those broadcast five 3.0 (in each slot of the group)? as it is billed from the point of view of the obligation to repurchase 10 months broadcast on the product: in the same example where each slot group busy 3.0 - it will be necessary ten months to broadcast all five pieces of 3.0 or will be satisfied in two months, because sumarno out ten times the monthly rent for 3.0? thanks for the replies!
Артур888
Has thanked: 7 times
Been thanked: 5 times
Post by Артур888 » Wed Oct 09, 2013 1:02
арте:м wrote:is it reasonable to increase the number of similar products in the slots? for example, one stream 3.0 will be highly effects to differ from those broadcast five 3.0 (in each slot of the group)? as it is billed from the point of view of the obligation to repurchase 10 months broadcast on the product: in the same example where each slot group busy 3.0 - it will be necessary ten months to broadcast all five pieces of 3.0 or will be satisfied in two months, because sumarno out ten times the monthly rent for 3.0? thanks for the replies!
It may be better to include mode 5 ( detailed. For resources it's much more succinct (approximately 4 times) Gives a very detailed study of the broadcast, large effects. )
So as I understand it is 4 times increases the stream of each slot and perhaps this is analogous to broadcast in the four slots of the same product, but maybe more powerful .
Post by Михаил_ » Wed Oct 09, 2013 4:39
there is no difference in how many slots is the product (well, more accurately, almost no difference in per cent), and therefore, I see no special meaning.
Some difference exists in the broadcast of the same products (or product groups) from different servers.
Ie if you get 3.0 and not on 5 different slots, but with 5 servers, each of which leased 5 slots, and one of them on each 3.0 - there will be a tangible gain, but it is also not a multiple of the number of servers (a lot less). Therefore, for most and this makes no sense whatsoever.
Владмосква
Been thanked: 7 times
Post by Владмосква » Wed Oct 09, 2013 9:03
Beso,
it is better to start with a 2.2 in the most General case, and then add the older version.
СветаР
Post by СветаР » Wed Oct 09, 2013 10:56
Michael,
The standard and the Gene with simultaneous traslyatsii how can/will interact? Or better serial connection?
СтАвР
Post by СтАвР » Wed Oct 09, 2013 11:08
answer for Michael in his own words
Михаил_ wrote:Etalon with the genome will work fine
Бисо
Post by Бисо » Thu Oct 10, 2013 0:48
Владмосква wrote:Beso,
Thanks for the reply.
Post by Михаил_ » Thu Oct 10, 2013 1:07
Бисо wrote:Hello Michael,
I have questions:
I do not know what BJ will be optimal for business development, because they're all for the recovery of the person and the business can be any.
I would start with 2.2 and panacea for business is a good stabilizer and ск1м
3.0 for advanced operators, too elegant for business.... or better yet a combination of instruments, it is impossible to answer this question definitely.... but probably better to start with either 2.2 or panacea.
In the most General case, a panacea more seroprevalent tool.
Very good use (passive), the PC is just for business opportunities.
For example PC+2.6 and panacea + Stabilizer I think is a good set for business.....
Although many of my friends use PC+3.0+frm+panacea
Including from scratch....
Yes, you can, for example, in the topic about experimental stream Basil tells the story with a broken cocoon girls, they broadcast the set I mentioned above (and is to this moment). The breakdown was eliminated, at the same time postroilis working relationship with the boss and the staff (right) and many more in life and at work... before that, no experience with any of my products did not exist. After a couple of months call Basil with a question about how to know what happened in past incarnations (that's a joke - post.the effect of a man dipped in the theme... :) )
I don't see any restrictions on the stream at the beginner of any products, the stream itself is "soft" way, though with great effects.
well, mode 6, maybe not right away, but also depends on the person and situation...
I think two years is enough time for absorption of any product with a zero initial level<
Кирилл.
Post by Кирилл. » Thu Oct 10, 2013 9:27
Good afternoon.
the Purchase of products from group "basic" (3.0, panacea, 2.x, PC, etc.) entails the obligation to redeem the result of a year's subscription to each in not more than 2 years.
In other words, if You buy a 3.0 with a monthly payment and actually pay 1 time per month, for two years you have to buy 12 times for 1 month but not continuously.
Violation of this obligation will result in loss of broadcast and the renewal will be possible only after the payment of the "tail" (in other words no other and the new products won't be connected). It is also no cost, through the "other registration" for the person.
This limitation is also connected with the fact that we are not going to devalue the cost of the desired and important physical products and that really "fluent" reflect the same "three rubles" may not be sufficient and you will receive a semi-finished product, instead of a quality product "always with you". This warning applies to freeloaders who can arise the idea of paying 1 month and the abyss.
If you have already purchased the physical media for broadcast basic product, this restriction remains in force.
Post by Михаил_ » Thu Oct 10, 2013 13:29
the limitation, of course, remains in force... it's different instances of the product, what have previously purchased... I'm not talking about the fact that the price was set and so the lower bracket and slightly below.....
Бисо
Post by Бисо » Thu Oct 10, 2013 16:48
Michael, thank you very much for the detailed answer!
Already ordered the base, 2.2 for the first month or two.
I will add more products over time.
аквамен
Post by аквамен » Thu Oct 10, 2013 18:32
Michael, and "timer healer" works for broadcast 2.2 ?
Post by Михаил_ » Thu Oct 10, 2013 18:59
why not? of course....
Has thanked: 5 times
Post by Воффка » Fri Oct 11, 2013 9:10
Michael_
Michael, Hello!
Stream the adjustment on chronopuncture way? Maybe some additional commands you can give?
Post by Михаил_ » Fri Oct 11, 2013 12:51
there is no stopping....
Post by Михаил_ » Fri Oct 11, 2013 15:04
I apologize for the delay in connecting new events - forced conversion in hardware (quite a lot of applications, we optimize processes).
although in General I have meet in one three - day period from the date of receipt of the application :) described above in the product description)
the connection of the 8th number (usually process in the evening-night after the day of application processing by office) and follow them (i.e. 8+3=11это today) are all activated last night. Guaranteed. (including those that will arrive today)
Ie office on this account is not to pull.
Connect up to 8th numbers are all implemented.
Connection from Saturday and Monday will most likely be made on Monday by Nocera.
Ярый
Post by Ярый » Fri Oct 11, 2013 15:55
Michael, ask for advice on the selection list of products for broadcast wife (without her knowledge).
The fact is that about 2 years ago she started having intermittent loss of consciousness. The reason is not exactly known, actually, as always from our doctors! The doctors think it's epilepsy, it seems to me that this is a manifestation of vegetative dystonia.
Wife 2.0 is about six months. I think to connect her Panacea and FRM, and, accordingly, the base 2.2, connecting the 3rd modifier, but can advise a set poeffektivnee?
Post by Михаил_ » Fri Oct 11, 2013 16:10
I suggest all PC to include.... it is very effective sozdadut personal-viscous-elastic area of influence and recovery processes are more efficient
I also think that this VSD in the background pinching in the neck, let him do the warm-up "arbekovskiy" if only for the neck regularly.
Post by Михаил_ » Fri Oct 11, 2013 16:36
Then came the experimental FE "normalization of male urogenital system", which obviously goes well with the UI for the husband.activation energy, the standard genome, 2.2 or a panacea and other obmenonline and health products.
in Fe sewn some algorithms associated with typical approaches sujok reflexology to correct the degradation and infectious-inflammatory processes in this area. Of course it is not a pill and not a cure but merely a reprint of the techniques of acupuncture, herbalism and other things - on the information level. Ie should not be confused. Was done at spectace one.... customer (not from here).
For 2 weeks work - there is a flow of cold feet as in the sessions sujok, have General symptoms began after exposure and other things happen.
PI is 3 slots, i.e. the base cost will be 1500, (we assume that it is PI of the first type).
I recommend to put in one set with the activation of male energies and 2.2 (i.e. to take in slot group 4 positions of the 5, one to leave for 2.2)
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Fri Oct 11, 2013 18:54
Михаил_ wrote: ... is the IRR on the background of pinching in the neck...
Will brighten this point experience a doctor vallista-homeopath.
Measures the blood circulation of the head - in indications of a violation to the left. Massaging your finger half a minute at the base of the skull to the left - indications in norm.
Says, watching it all the time - the vessel is OK but pinched a nerve, they are managing, usually to the left. (Not necessarily fatal had shown effects). In General, the IRR for cervical radiculitis. Grit can be 1 to straighten vertebra(Atlas), but usually goes back.
Talking about this one chiropractor, and neck reigns. Nothing says there can't be - there's inch of the way from the bone to the nerve.
In one of the branches was a reference to the Swiss method of straightening Atlanta, like it only takes one time for 5 min and 12 sput. Advertising snot, apparently...
Ho-Ho-Ho with these doctors at least have a bit of a niche up.
So myself and Norbekova, either option should be supported.
Post by Михаил_ » Fri Oct 11, 2013 19:08
in short, it was not IRR, it is necessary to stretch your neck regularly (minimum 4 times a week for good).
:) actually it's just from the side seen on people, especially when they talk about their problems with blood vessels or pain of the head... it is immediately obvious that there is in the neck block, and immediately clear that this vertebra, starting from the incorrect position of neck during work (bend) and ending with the birth trauma is not removed.
the mass of options and yet a little while, but found really everywhere (this despite the fact that I don't like to heal and diagnose, not my thing.... I have something bigger and with scope :) )
take care of your body.... :) it is still useful :)
Хаст
Post by Хаст » Fri Oct 11, 2013 21:08
Michael_ and how is the connection for the person is not registered on the forum? Is there enough unique information (name and passport number for example), or do I have a full link in one slot for 25K?
Артур888
Post by Артур888 » Fri Oct 11, 2013 21:41
an Ardentalso headaches used to, and dental, was tested at the doctor says the teeth normally. Doctors normally do not know, had to guess what it is, even in the military during the survey wrote about the cervical vertebra C4, that it was something. I read on the Internet and he is responsible for teeth, eyesight, etc. I suspect and headaches have been connected with it. Did the exercises from this CD http://rutracker.org/forum/viewtopic.php?t=1242690 ( a set of exercises for the spine ) + more some exercises from different courses and books took, what my feelings gave greater effect, resulting in a month were headaches and my teeth stopped hurting, but he did every day. And by the way I have a diagnosis of VSD (loss of consciousness was once the truth - sharply up from the computer went on the bar and fell with him, woke up not knowing where I am, and so are dizziness when you stand up quickly ), but then throwing lessons again the pain came. Actually that was a stable result, then you need to support it at least 2-3 times a week specifically to do exercises for the spine, especially the cervical and the thoracic. We ought to also do your spine tightly. Does anyone have an interesting set of exercises ?
p.s. by the way, very often people are on one side and the neck is curved to one side(and when I go to the other side so uncomfortable and unpleasant in the neck ), this is one reason disorders of the cervical, which I notice
