Panacea-Youth. Holographic system overall profile.
Re: The Panacea-Youth. Holographic General profile
Post by bofara » Thu Mar 01, 2012 11:10
Алекс С wrote:PS Forgot to ask - is it possible (i.e. how effectively) to scroll through the video than through eye sight, and say to the media player and a screen-to-body (the skin), or just in your pocket to live inside the cocoon was played, with both V-audio?
Alexthis information can be useful for You.
Михаил_ wrote:To broadcast the video "youth" is a very effective use of video projectors Casio XJ-series (and other 140-145, see data of the manufacturer, using partially laser sources for illumination of the image). However the cost on EBay, comparable with youth standard, but there are times in 2.5 above. But they can be transmitted indirectly (for example items).
It I so - for those wishing to enhance the effect, including a combination of systems, standard and VIP, and the additional use of video. Only the eyes take care. In the description of the projector must necessarily be stated that it is a laser. Projectors with lamps or light sources are not suitable in any way. (from the monitor then the efficiency will be possibly higher).
Алекс С
Has thanked: 2 times
Been thanked: 7 times
Post by Алекс С » Thu Mar 01, 2012 13:23
Thank you, bofara.
I confess, frankly, this subject was read three times to understand everything so I understood. :)
Even went and looked, there are no laser projectors cheaper, they were not. :cry:
Yesterday we looked at what laser projector - turns out this is a common DLP projector with LaserLED the backlight, i.e., without laser modulation signal, laser lamp stupid and all.
In other words, you can take the media player screen, from which you can break down the backlight and replace it with a laser pointer or diode from CD/DVD.
In media player old model sometimes found transparent screen, then to break is not necessary.
By the way, I remembered one company in Russia produced homeopathic hologram. During exposure of the hologram the laser signal modulated by the information of the product, and in a set of user entered finished piece of photographic film is the hologram and Chinese laser pointer. The perfect solution. But I digress.
You can even easier - just turn the backlight and shined the pointer on the screen. If reflected the signal is clear, then maybe something will come out of this is Michael you can ask.
I know one thing - if Michael would say that in any case it is impossible to project laser video itself on the body, one will find three willing to do it :wink: :wink: :wink: and maybe I including :roll: . What to say, Panacea, Youth, Childhood :wink:
Myself, by the way, noted that if anyone is bored, try to do so, and to project the laser-illuminated video on solidifying the epoxy and see what happens. But winter is over, time for doubtful experiments poumenshilsya.
Post by bofara » Thu Mar 01, 2012 13:40
Алекс С wrote:I'll try to do so, and to project the laser-illuminated video on solidifying the epoxy and see what happens.
Here useful information -
This is the first case where the product is processed by laser optical charging system during the entire curing time of the composition (about a day), continuously...
Легенда
Has thanked: 7 times
Been thanked: 9 times
Post by Легенда » Thu Mar 01, 2012 17:29
Today saw the clip of P-Youth, proper ha ha. Just for no reason, haha and ha ha. The status light is gentle, the mood in tone, I'm happy. Thank You Michael.
СтАвР
Post by СтАвР » Fri Mar 02, 2012 0:52
and how better to do?
first charge the bracelet is 1.0, then a panacea and after youth?
and youth, too, as a panacea enough to write on links to left for a few hours / days and that will be enough?
and will remain on the bracelet even if erased?
what if you write a youth on the big object from the big stone and finishing well, for example home, what effects will manifest themselves at this scale?
and a question for Michael would be more effective if the bracelet than the video, because he is constantly in a cocoon, and live well, 2-4 times a day look and all, it is clear that if the whole day to watch the video more efficient it
well, the question about the phone, videos and pocket :) support
Post by Михаил_ » Fri Mar 02, 2012 4:24
the matrix and the video is a simplified version. They can be applied in any convenient way. The effects are the same individual.
Watching videos is one thing. The subject in the cocoon a little more. Rock - it pocket do not believe, but try it.
Алекс С
Post by Алекс С » Fri Mar 02, 2012 15:09
Michael, thank you for answers.
I won't live in a cocoon twist, though, specifically on the skin vision hoping, and would be glad if You said "Yes, screen to skin basically the same thing."
In this regard, , increasing the relevance of a more fluid videoas "twitching" cause some people (rare but still) discomfort, and in a larger number of frames of information anymore.
Tell me, is there any way to contribute to the creation and reupload this video with a higher fps?
PS Infa for fans to convert and spread, and also for fans to operativity all around - hint:
There are programs that create screensavers from video files.
You can easily find in a search engine or for example read this article:
http://www.comprice.ru/articles/detail.php?ID=42667
Imagine a Corporation so employees to a thousand, and admin all remotely change screen saver.
The next day, everybody jump, dance, run barefoot through the puddles - rejuvenated :D
Been thanked: 10 times
Post by Мастер 108 » Fri Mar 02, 2012 20:57
Screensaver is already there, if one has not yet downloaded, here - http://depositfiles.com/files/i1usbfe9m
Of course, a smooth video would be better :?
And fans convert all, you can program Coagula (http://depositfiles.com/files/bjs5ym2ok) to convert frames from the video P-youth in the sound and listen to V-tracks.
Post by Михаил_ » Fri Mar 02, 2012 22:40
there are 6 channels in the native data. Can make 3 audio :)
СтАвР
Post by СтАвР » Fri Mar 02, 2012 22:49
Михаил_ wrote:there are 6 channels in the native data. Can make 3 audio :)
please...please...please...in the Studio bi :ap :)
Легенда
Post by Легенда » Fri Mar 02, 2012 23:12
Алекс С wrote:Michael, thank you for answers.
I think the video should initially be smooth, but a resource of the computer on which this video was doing was clearly not enough. Videos and so gives the effect, but the gradual work of the effect should increase, but not by much.
Post by Михаил_ » Fri Mar 02, 2012 23:21
well, not quite, there when changing the angle of the projection window the race is for everyone - because from the other dimension projection.
Легенда
Post by Легенда » Fri Mar 02, 2012 23:23
As the video remind me of a gas cloud in space, is very beautiful.
Легенда
Post by Легенда » Fri Mar 02, 2012 23:34
Use video the second day. Two days from my mom the phrase "I love you", heard like 10 times. Although says so, but was this too much for me to say,well, very noticeable influence from the outside ))) Very nice video although it is naturally not shown.
Легенда
Post by Легенда » Fri Mar 02, 2012 23:48
Михаил_ wrote:well, not quite, there when changing the angle of the projection window the race is for everyone - because from the other dimension projection.
I think you'll agree that even these jumps need to be smooth. According to my observation, you used a program ZD-modeling. But such programs are very resource-intensive in relation to the CPU and RAM of the computer. The characteristics of these two parameters are just responsible for processing frequency information.
Post by Михаил_ » Fri Mar 02, 2012 23:54
we use specialized software developed by us for our specials. purposes, and many versions (e.g. the projection on the cards are counted differently). The software is all the same how many to count (this need not be done in real time)
The number of data points such that, for example, the same 3D laser engraving, kind of isn-1-2-3 the patterns are printed in small pieces, it's not like.
The smoothness in the video certainly can be added, but there still occur a discrete on-off points, for discrete data extraction and stepping changing of the viewing angle.
In General this is a flood for this topic. Especially inserted photos they then do not place.
Post by Мастер 108 » Sat Mar 03, 2012 3:32
Легенда wrote:Use video the second day. Two days from my mom the phrase "I love you", heard like 10 times. Although says so, but was this too much for me to say,well, very noticeable influence from the outside ))) Very nice video although it is naturally not shown.
Lucky you. and my mother almost every day, "extrude" for any reason, and no reason - so finger suck and no Panacea it does not work :(
Post by Михаил_ » Sat Mar 03, 2012 3:48
In such a situation and the age of an adult, often useful to live separately from :) it establishes the relationship minimizing roughness :) proven many and many times.
Петрос
Has thanked: 45 times
Post by Петрос » Sat Mar 03, 2012 15:45
Михаил_ wrote:In this situation, and the age of an adult, often useful to live separately from :) it establishes the relationship minimizing roughness :) proven many and many times.
:ay
арте:м
Been thanked: 8 times
Post by арте:м » Sun Mar 04, 2012 3:54
've already put accelerated and converted version of the video, but wanted to contribute. At the link is the file 9-fold acceleration (read: 9 times smoother than the original), with a duration of about a minute. I am most comfortable with these settings to see appeared.
Caution: traffic to ~140Mb
СтАвР
Post by СтАвР » Sun Mar 04, 2012 4:16
Michael, and even so there is some distortion of the received information and the effect of P-youth from these accelerations?
Post by Михаил_ » Sun Mar 04, 2012 13:06
maybe there is - not tested.
Post by Михаил_ » Sun Mar 04, 2012 13:12
Алекс С wrote:Thanks, bofara.
the conclusion about the projector is not quite true or is not true.
When burning the laser on the important parts of POWER. (tens of watts per point). From laser pointers and laser from SD-DVD capacity penny - miliwatt, well known pisalka of which pointers do there to polwatta squeeze, if I'm not mistaken.
The projector 40 odnawialnych diodes. However and points from more than one (compared with laser) but the possible time of exposure to hundreds or thousands of times more, because the material is not destroyed.
In addition, modulated color component. Stupid to Shine through the player - even millions will have no effect, do not worry.
the cost of the projector ebee around 800 dollars, which is comparable to 2.6 for example, or modern cell. Only use 1001 times more than a modern cell phone. Why? because the main purpose of the phone conversation. And all the bells and whistles - Sovremenny stuff. And here is a powerful translator qualities.<
Post by Михаил_ » Sun Mar 04, 2012 13:13
when the link burns 2.6 trajectory forms as a 2.x - it can be erased in General, an important power deposited in the process in the material. Modulation signal there either - there is a trajectory (resonance at the level of the picture relatively speaking). Although we of course use a slightly altered laser.
арте:м
Post by арте:м » Sun Mar 04, 2012 19:38
СтАвР wrote:Michael, and even so there is some distortion of the received information and the effect of P-youth from these accelerations?
In my opinion, much more "distortion" in the perception of video can make: 1) loss of concentration (from exhaustion) and 2) a distraction by extraneous stimuli.
That is, to maintain full concentration and engagement all 9мин. the original movie requires extraordinary powers of concentration. Also, the lack of dynamics in the period of waiting for the scene changes - the probability of occurrence of extraneous thoughts "nothing to do" )
Minute video looks at one breath and dynamic enough to keep the attention continuously. As for the possibility of "geometric distortion" involved the algorithm is simple duplication of frames (not interpolation of intermediate rendering) - so from this side all is smooth :)
Thus (IMHO) can say the opposite, reducing the "distortion of information received" even :)
