Thank you! Clear enough....
Sincerely, MAG.no
Тяфа wrote:ideally, if I took your gold bracelet and put it on the card transfer 2.1 will there be a charge? Or you need to manage on a sticker to stick, which is practically impossible. Bracelet are pretty slim...
Here can not find, please help if anyone remembers or throw a reference....Михаил_ wrote:But there is a thread somewhere here matrix which can be covered. It even handwritten on a sheet or envelope to write.
quote from viewtopic.php?f=31&t=4357&start=175Михаил_ wrote:in order to be able to keep the card transfer as you like, there is a "cover sheet". I didn't write about it because it was interesting, how quickly will this question.
The cover sheet is sufficient to cover the printer or matrix
TSL
EUR
OTS
One big enough (at least a pen to write).
BUT!
In General this is NOT NECESSARY.
Can remove the card in an envelope, notebook, book (etc.) just by thinking that it is turning and not recharge. Map transfer does not match and not switch, and the support of complex programs, sufficiently reasonable in order to properly respond to such commands.
Overall, advanced users can learn to operate in General the whole process mentally. I think it is clear that this gives quite some additional perspective. You can "sectoral" card somewhere... in a safe and "do not kill" place. .....
Overall, however, I recommend to start standard operating procedure (for the user).
Маг.нет wrote:1 transfer carries potential 1st BJ, it is easier perhaps to understand, is the BZ of the 12 links, it can be divided in two, four, etc. its potential will be shared accordingly. BUT this applies to a single object divided into parts, when charging of the individual parts (theoretically) can get a full charge on one part and empty in others.
The difference between a "migration" from classical BJ that made by classical technology has on hard links, "transfer" - KO (maps) on a leash tied to the object of charging, after transfer of functions BJ to another object may remain and the weak link. Try and describe....
What is this "copy protection". Dear, You take me for ?МерКаБа wrote:Michael_ please tell me, what if a loaded card bracelet (large size) broken, and then gathered, but in two smaller braceletAs then the work copy protection
? Et I, out of curiosity.
When you first publish on transfer described in detail this procedure. Probably need to ask this to be moved to a directory with forum.Тяфа wrote:Received a card transfer 2.1, honestly thought it would be something like a cover letter to it, or explanation.... Well then, tell me what to do with it. I understand that you take the bracelet, put on it and how long to wait? And still interested in "mental kick" card as his right to implement that it worked
Soon the answers to my questions will be a guide for complete dummies!
