Thank You, Alex!
Reprogramming of the device. New firmware version
Alexey Kryachko__
Thank You, Alex!
Thank You, Alex!
Юрий Зиберов
- Has thanked: 1 time
Re: New update program IN the "Navigator"
Alexey Kryachko__overlooked I guess about the translation of the Navigator in replace mode program. In order to install the driver for Винд7 must also be translated in replace mode?
Navigator is still in the device list as a "temporary device" and it also not put the driver.
Алексей Крячко__
- Been thanked: 17 times
if we're talking about the driver that relates to the program for a replacement, then of course you need. First translation in replace mode, then connect to the computer by USB cable included and if you will request the driver pointing directly to inf file which is in the archive.Юрий Зиберов wrote:Alexey Kryachko__overlooked I guess about the translation of the Navigator in replace mode program. In order to install the driver for Винд7 must also be translated in replace mode?
For mode flash memory no driver necessary.
Work with PC (if you choose this icon in the main menu) are not yet supported by the editor sessions. Therefore, the driver in this mode is not laid out.
in the future avoid any problems, preferably before you turn it into a reprogramming mode, and also enable in device Manager to remove this "temporary arrangement".Navigator is still in the device list as a "temporary device" and it also not put the driver.
PS to experiment with flashing, I would advise those who have still the old early version if you have version 1.16 to do nothing.
Alexey Kryachko__
Alex, are there somewhere the technology to replace the memory card? Just want to put higher capacity drives to not bother. Are there any rules for naming folders, etc. Or just thanks everything as it is and all?
Алексей Крячко__
No special technology. Put a new memory card, turn on the device. He creates all necessary folders. (under the splash screen when you turn it on for some time, the words "create folders..". Then shut down, connect via USB cable to PC and copy these folders all that is necessary if small volume. If it is necessary to copy the wav and mp3 files, it is better to pull out the memory card from the device and record it on the card reader is much faster. A description of what folders and what files it contains and what is in the instructions (see p.2.3 "Working with memory card" on page 16-17).Павлум wrote:Alexey Kryachko__
Not to think what and where to write - can still memory card "to upload as is." And the remaining amount to use to fit your needs.
Not yet listened to. but everything seems to be fine. Now another workshop will fill and try.
Only the firmware version of 1.16 is* . Sprocket is this normal?
Алексей Крячко__
Yes, actual working version 1.16 and should be with asterisk, I did it primarily for myself, not to be confused, and that was several test options with the name of 1.16.
Still be asked to return the ability to start charging in manual mode or at least increase the threshold of the automatic recharging. And create an opportunity after the release (transfer) to the main menu, as notification of low battery, to continue track from the same place (i.e., emissions not using "stop" and using "pause"). Already faced a few times before you run "disk Patrushev" the battery indicator shows less than the maximum, even charging doesn't work, and not before he got to the end of disc eject, disc well when mnogoruky and familiar, like something you manually back to an interrupt or so, but for example the Explorer only if you first. Repeat to combine the charging or power supply with a normal job MM I have a not - unpleasant noise. Oh, and another thing, after charging I have to reboot via off/on or sometimes, even more precisely, very often begins to fail streamdecoder (all diodes are shining, not blinking or faded out not IGN) or sound (loud bursts and distortion), but as already noted this only happens after charging, and if not turn the appliance off, until they solve the question by hand - after off/on this does not happen, so not so critical.
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
I have, after upgrading, constantly burning glasses red diodes
it happened when in strobe mode-record total change on the chords, now the light is red constantly and will not turn off
Stavr
Try to remove and reinsert the batteries.
helped run mode, the chord a different color and all became norms
Re: Reprogramming of the device. New firmware version
Alexey Kryachko__ I like a malfunction of some sort. With headphones the right channel is inaudible or audible, but there is a strong interference (crackling). That left exit, go straight interference or no sound, on the upper outlet at first, is normal (maybe quieter than the left), then start interference. Sometimes disappear themselves. Song checked, the card is also OK.
First thought on the headphones, took the other too. Then I decided to reflash to the same firmware (latest), nothing has changed. Sewed for XP listen from batteries. Somewhere came across infa (not found), it is possible to do a reset to factory settings. There is a sense?
Or truncated kapets?
This thread in General, someone reads, or again, all went into the forest?
- Been thanked: 182 times
Haven't truncated1Андрей1 wrote:Or truncated kapets?
Contact the warranty in the mail mindmachine@bk.ru ,repair.
I wanted to do a small force
Алексей Крячко__
no, if you have a device earlier releases, the reset may not do the reset by the way refers only to the clock/calendar. And now in the newly manufactured we this possibility was excluded by applying a different power source for hours.1Андрей1 wrote:Alexey Kryachko__ I like a malfunction of some sort. With headphones the right channel is inaudible or audible, but there is a strong interference (crackling). That left exit, go straight interference or no sound, on the upper outlet at first, is normal (maybe quieter than the left), then start interference. Sometimes disappear themselves. Song checked, the card is also OK.
As for the sound, it will be interesting details : the crackle and interference arise during play sessions or while playing audio files/strobe-ROM from the SD card ? How does the device if you connect the power adapter, i.e. will there be interference ? What type of memory card used ? (different set for the time of issue of the instruments )
Alexey Kryachko__ reset clear.
Difference batteries or the power (ACC. removed) no.
Lost earlier only player - the usual. Was afraid to break the glasses. wav hiss in the right, mp3 no sound.
Connected glasses, turned on the strobe - Patrushev - conductor. First time (1 minute) in the right silence, points almost never burn, sometimes one diode will flash on and off. Second run ( 1 minute) from the crackling, burning glasses, normal (sort of).
During regular sessions, R (1 min) all seems OK, sound good in both headphones, sunglasses work fine.
Memory card my not from a kit (worked on it for more than six months) Kingston 16 GB. HC class 4. Copied still on transcend 8 GB. HC class 6. There is no difference.
Bluetooth Handsfree ND ND 238, and 438.
МаратГалиаскаров
Good day to you, Alex!
After connecting the USB cable to the computer and switch on the appliance, it is not detected by the system. I have Windows Vista is installed (system type: 32-bit OS). Driver or used previously for recording programs in mindmachine Navigator has never been installed. In device Manager's “universal serial bus Controllers” (Universal Serial Bus controllers), the device “atm6124.sys AT91xxxxx ATMEL Test Board”, not detected. What actions should be taken to install a new program for updating the firmware of the device?
Sincerely, Marat!
Sincerely, Marat!
Алексей Крячко__
Good day !
To the device was detected by the system for programming it is necessary that he was first transferred to the programming mode. Ie when you turn a blank screen and a solid orange led.
about how the device will be switched to the programming mode the instructions written in the program. Next you need to check the USB port, it is possible to switch to another port. There were also cases of faulty usb cables. In device Manager, the device should appear (before installing the driver) as unknown, and
after specifying the. inf file it should appear in the list of COM and LPT ports as one of the COM ports.
Алексей Крячко__
most likely it is the audio codec provides you all these problems, if the session is reproduced normally. In this case, the playback of wav and mp3 might be missing one of the channels, or not at all sound. The device you need to send us for repair, there are no other options. If you are going to send, preferably with a memory card which worked last time (16GB).1Андрей1 wrote: Connected glasses, turned on the strobe - Patrushev - conductor. First time (1 minute) in the right silence, points almost never burn, sometimes one diode will flash on and off. Second run ( 1 minute) from the crackling, burning glasses, normal (sort of).
Hello! In the latest version of firmware noticed the following bugs:
1. The above-mentioned charge. You have to specifically discharge the batteries to the level of the automatic trigger charging. Otherwise it turns out so: the indicator shows low battery, but when connecting the power cable the charging does not start. If you include a session on such a charge, it will not play the game - will turn off...
Play audiostrobe sessions:
2. When powered from the mains (battery is removed) sometimes not play out the session to the end - hangs...
3. When setting brightness to maximum and the subsequent inclusion of other session in which the brightness is required on minimum, happens here that:
I gradually turn the brightness to zero and despite this, the diodes nor the sudden flash at full brightness, the moments when flash choose for yourself... is Treated by increasing the brightness on a couple of points and a subsequent decrease it to zero.
Нетрезвый Сурдопереводчик
- Been thanked: 1 time
I have bugs similar. When I put the brightness to max(30),in some sessions, in some configurations, signal LEDs do not blink. Today included R05N with the shape of the signal bell,light level 30,but there is no light at all. The battery level may not be guided,the failure to inform about low battery level is fraught with "fun" state of mind,because some of the sessions,and programs A. Patrushev critical to sudden breakage. At least I have so.
Алексей Крячко__
Charging I also noticed a strange thing. Appears when the batteries are discharged with a small current, during fast discharge even when the scale is filled to half - off it goes.Воффка wrote:Hello! In the latest version of firmware noticed the following bugs:
As for the brightness adjustment. The principle of operation is simple : the state of the brightness is stored to how it was in the last session. When you start to play a new session, then the brightness should increase from zero to this value, which was the last time. At the end of the period of increased brightness and volume is checked the brightness level and if he had not reached the final value it is immediately exposed to this value. Then you can easily adjust this level and its value is stored. This "bug" arose because the brightness is regulated probably at the beginning of the session, when she should rise smoothly to the value used in the previous session.
In the future I will certainly rework : if you start to adjust to the brightness and volume are set, their levels are fixed in the values on which they are stopped at the time when the user began to adjust and then would depend only on this adjustment, and the value from the previous session would be lost. Meanwhile, just to adjust costs after the sound and the brightness set.
hang with playing the gate tracks will check until such a problem when powered from the adapter encountered. When rabotek battery was in the earliest versions of the firmware (1.10-1.11) has not yet been introduced to control discharge of batteries.<
Алексей Крячко__
with the high check, just previously this bug did not get out because few people used max. brightness (brightness level 27 is no different in perception from 30 - brightness adjustable linearly, and the eye responds to a linear change in the brightness only at the beginning of the adjustmentНетрезвый Сурдопереводчик wrote:I Have bugs similar. When I put the brightness to max(30),in some sessions, in some configurations, signal LEDs do not blink. Today included R05N with the shape of the signal bell,light level 30,but there is no light at all. The battery level may not be guided,the failure to inform about low battery level is fraught with "fun" state of mind,because some of the sessions,and programs A. Patrushev critical to sudden breakage. At least I have so.
