Planned changes in the commodity row of the entire line BJ-SK, etc.
Re: proposed changes in trademark row the entire line BJ-SK
Post by Михаил_ » Tue Oct 09, 2012 18:53
Андрей С. wrote:Nifiga a super-light :shock: Now it is clear that 3.1 commercial take is not worth it, and that was a thought.
But the feelings, is still not quite in 3.0 shifts a little differently. Either too high, unusual power.
hihihi
Well actually it's not so scary...
A commercial version, as in the case of 3.0 S->S+->S++ will be felt softer and somewhat smoother.
It's like if you compare training course driving the plane and he flips into the pilot's seat in extreme situations without warning.
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Tue Oct 09, 2012 20:31
димыч wrote:well, as always, the question is whether or not the bracelet in the printout to wrap?
Or one "prong" of the bracelet 3.0 N further "familiarize" with the video?
To among other types as special "overlay" :)
Post by Михаил_ » Tue Oct 09, 2012 21:00
not sure it will have an effect. But you can try, then tell us.
I. e. it is primarily just a video to view. It may be used in conjunction with the lining for a more intense effect from the joint action.
PS 3.1 production we'll be back somewhere around the 18th ( and the process will take about a week). To me more precisely determine the size of the first batch (the process is long and time consuming) I want to leave a request in the office.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Tue Oct 09, 2012 21:15
:) Funny thing. Tasted. Resolved, "do not fear" and make an Order.......
Sincerely, MAG.no 〠
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Post by Владимир Ш. » Tue Oct 09, 2012 21:38
1) a very powerful thing. Especially looking forward to the full version.
2) MAG.no - thank you, that moved the people. Google is really not that... :-)
Владимир Ш.
Post by Владимир Ш. » Tue Oct 09, 2012 21:46
Михаил_ wrote:I ask those wishing to leave the application.
I bid already left earlier.
After reviewing the video the order confirm.
Post by Михаил_ » Wed Oct 10, 2012 1:51
well, Google but from me easily pumped and I'm comfortable :) I have Google drive commercial bought mnogogolovy..
Post by Михаил_ » Wed Oct 10, 2012 1:56
those applications that have already been obtained and do not cause problems. Just because then people start fighting.... and I would know in advance what size the tree to collect or more. (tree, this sort of thing on which hangs that will be cast in the metal before casting in the mold). Just the less - the easier :) but once the second feat I'm ready. (pendants large range of 2 backfired a good echo, it is good that they do not beat - they already used during the manufacture of such a world around a little too hard hopping and not very stable, ie not stable).
For this reason, I would be grateful for timely application, then, will make only a small margin for the fact that the product of the specific and primary demand will cover for some time needs.
ора
Post by ора » Thu Oct 11, 2012 15:29
Михаил_ wrote:to compress there is no possibility - will be lost most of the data. So rejoice that not 200гиг :)
Use the archiver ;)
http://samlib.ru/f/fedotow_m_i/nkm000021.shtml
PS Ordinary people I recommend to read the stories. They are very topic.
Tough propose to implement written... :)
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Thu Oct 11, 2012 17:18
tried a roller, the second day right head ache, strong stuff
Акела
Has thanked: 28 times
Been thanked: 64 times
Post by Акела » Thu Oct 11, 2012 17:25
Петрос wrote: second day right head ache
Yes, You have two heads? However... :)
Петрос
Post by Петрос » Thu Oct 11, 2012 18:35
only two :)
Post by Маг.нет » Sat Oct 13, 2012 13:00
will Share the results of their research.
Decided to look at the state 3.0 at hand, had even more to recede, which just contributed to the roller 3.1, i.e., external observation of an active Observer (with the possibility of adjustments - Creator) showed the funny moments. First a little bit clearer has become the Source of energy in the 3.0 – a World in this setting, softened, allowing zapotrzebowanie in the relationship of the structures of the objects energy, i.e., any Object becomes an emitter and it is only one pole, the other pole – to the contrary, any unbalanced system has the trend to stabilise themselves – the restoration of the established order. Consciousness in 3.0 is in between the two extremes (of Order and Chaos), and can make a correction structures without drawing energy from the outside, i.e. by embedding change within existing flows. Turns out the "access point" to the correction not outside, and inside structures, while the consciousness becomes tools how to modify an existing and a new design. Further, the very "hit" in as 3.0, as noted above, the structure of the World in the area of Personal Power 3.0 becomes more chaotic, and to make such changes need energy, and quite high frequency (upper range Agni, Sahasrara) to work directly with the World and its physical aspects, but in General it seems to form ice pieces to change, you can first add energy in the internal processes (heat). Interestingly, then to steam to turn back into another ice figure, you need to hold it in a certain form (not cleared), and the energy to zapotrzebowanie in the structure, and this cooling (to eliminate the kinetic energy). That means wasted potential on the input 3.0 when the exit returns you to the place you can make up for other deficient band, the only significant spending in this process is to use the tools of consciousness for "structural adjustments" (including the creation of the "primary impulse" of Creativity), but that's another frequency that may be a bit lower (the tools themselves – the average range Agni, although some reflections may be even lower), while changes are being made at a higher frequency, but without the overhead of the self-energy in this range, and embedding in natural flow "primary momentum". 3.1 and just "tighten" the consciousness in 3.0.
Now, at first glance, turns out as we now expect 3.1 to study and to use these properties more thoroughly.......
Sincerely, MAG.no 〠<
Post by Михаил_ » Mon Oct 29, 2012 1:00
announcement. we made three new case designs, showing hope a very narrow range of products to work with situations(you can say extra work).
In General, they are significantly stronger implementation of similar modules.
products
- shield (installed a virtual boom in a place where there is a very tough interaction with the world, the goal is to minimize the personal consequences and generally the consequences of entering into the world of custom courses), the analogues are viewed for example with 2.6 and the corresponding areas of the stabilizer, but a different way of implementing high-power
- stop (in a way similar to the module wall in order to create space with altered properties in your area of interest occurs as before, but outside interests gets in there with great difficulty, it outputs the part does not need interaction for short range, unlike the above-mentioned "shield" in principle and implementation, is quite a fundamental difference. "stop" is blowing everything around in time, space and cause and effect consequences. a shield is placed deliberately in a visible vector.
Both products are totally "eco-friendly" and "hygienic". Ie do not harm the world and you.
- broken ties. Rather abruptly breaking links virtually all. Has a relatively short relaxation time (stops working and goes into recharge). It is useful to disconnect from society, a situation external influences.
All three products in the light version are implemented in the form of laminated cards, small size (think a La credit cards). and have a neutral and active.
Will be sold a set of three at once.
Later, we will implement a very heavy version of all three (I think after the new year), but it will be expensive.
When using all three You are most likely short-term to neutralize any serious negative interaction with others drawn to You. During this time, you can take eco-friendly measures to harmonize the situation.
Broken ties less environmentally friendly than the first two. but due to the short time action relatively harmless.
All three products are useful to operators BJ 2.x 3.0, 3.0+OZ
I am able to interact with V4 as with the source and with the Stabilizer Operator.<
Moon
Post by Moon » Mon Oct 29, 2012 21:39
Hello, Michael!
Want to know the cost of this kit.
And cost heavy version.
If the reason to wait to purchase the hard version until after the new year?
Or is it better just to buy this? Worried :)what lightweight version of the make out and heavy after the new year still will not.
Post by Михаил_ » Tue Oct 30, 2012 0:24
Doctor, doctor, give me tablets from greed, Yes more!!!more!!! :)
Post by Михаил_ » Tue Oct 30, 2012 1:49
easy version will cost 15, heavy 380. heavy that was with what to compare, would be like (mass, power, and design)the necklace range-2 each of the three, only there will be twists....
So 380 is cheap.
It is theoretically possible to try until the new year to catch, but somehow I doubt that's realistic.
Light will not be weak... just hard to be strong.
Post by Михаил_ » Tue Oct 30, 2012 16:17
Announcement. We introduce into the range a new product of the piece-hand-made. I.e. as a VIP youth is made in manual mode by a particular person. Unique.
Powerful.
Description later today(evening) under exclusive artifacts.
Name - pendant standard.
This is a specialized standard (similar to the selected signal and the module in BZ) focused on the needs of a person, his problem, his recovery abilities and cocoon.
Expensive.
The manufacturer, in this case I did not, and a man whose speciality is this direction including.
That's just the Moon, I understand it could comment on the effectiveness of this thing.
And when I went to pick personally made for me a sample gave Lily to hold, respecting technical safety (there were fears :) what could be reloading). Exploit himself, because there are things for himself very difficult to do and is not as effective as the side view.
Overall this is a unique opportunity, because for example I'll never be fumbling with a personal product is so long - I just have no time so much free.
(we are talking about 20дневном production cycle, where every day is a new personal information layer).
Also there is no guarantee that this product will be for a long time, because the production cycle depends more on the Mets (from a person staying in a particular place).
Moon
Post by Moon » Wed Oct 31, 2012 6:21
Hello!
Comment on:)
Since February I wear two bracelets and a standard single pendant from Severobaikalsk larch.
A little later (I think a couple of months) added another two bracelets Etalon to his feet as they sleep.
The changes since the socks of the standard in your own physical body:
one word prettier:)
the eyes are green,though his eyes did not order:) but now very happy with their green hue.
Now body weight is stable ,about 53 kg with height 165 cm
In the summer ,when losing weight to 51kg my Breasts have not lost weight,and was so delicious:)
Without a reference first and foremost to lose weight very chest.
The waist was narrower,but at the waist I wear a šajbočka standard.
I have as usual:) no Overdrive!
Improvements in the physical body start to notice after four months wear.
Константин.
Been thanked: 2 times
Post by Константин. » Wed Oct 31, 2012 7:37
It should be noted that Moon uses the standard of the previous generation. The current pendant, which Michael says, much more powerful.
Манстер
Post by Манстер » Wed Oct 31, 2012 12:28
Constantine, the current standard unlike the previous one that is powerful, or has a new feature?
As I understand it the main function of the Etalon whether the module in BZ 3.0 or pendant is a complete structure and does not expect updates... ie the standard he is the model already and for all. Or am I mistaken?
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Wed Oct 31, 2012 13:36
[quote="Michael_"]That's just the Moon, I understand it could comment on the effectiveness of this thing.
And when I went to pick personally made for me a sample gave Lily to hold, respecting technical safety (there were fears that there may be overload). [/quote
The previous pendant standard in hands did not hold but the last one Michael had. Michael feared that it will be loaded so I only had time to feel his power ,and view did not work,Michael was in a hurry . In that short time, managed to protest it quite a bit. Feeling powerful ,with legs full of energy went first, quickly climbed to Anahata,and then descended sharply to Muladhara and powerful movement began to vibrate between Mooladhara and Swadhisthana .Then he rose above and so on until the top,vibrating between the two chakras and rising above .Body was buzzing until late at night. If start dvigatel. My feeling was that I went to cleaning and filling the chakras with energy. I was bursting in those places where there was a study almost all day.The evening began to subside,but manifested symptoms of common cold ,although the cold has passed long ago.
Well and one more thing ,I tried to copy the structure,causing it to bump from sekoi(brought Andrew and Marina from America),charged a Panacea. Bolovstvo of course ,but wanted at least some trace of what they felt the Standard left. It turned out poorly,although I'm not sure exactly what it is. But when you take a lump in hand has a weak track and the flow of energy along the same trajectory ,maybe it's my glitches. The STANDARD proved to be too powerful,but thank God no problems. Usually too much I have always climbs with pain in spine , between my manipura and Anahata. Doubles over is not frail.
СтАвР
Post by СтАвР » Wed Oct 31, 2012 14:05
Манстер wrote:Konstantin, the current standard unlike the previous one that is powerful, or has a new feature?
as I understand it, we are talking about E-benchmark
according to Dice it when I got more powerful than the standard, the operator energizes the energy
when a conventional Etalon, at least as I had it, the recovery is faster although physical load on sensations becomes heavier (but only the first time) but the body field comes with time in the norm, for the one who uses that reference for each individual and the norm is also excellent
although nothing prevents "blind" from your body what you want, the truth is there to take into account the purity of the body and of the units of consciousness
in E-benchmark resilience can say increase and plenitude of energy is Increased and supported (you can draw an analogy with BJ 2.7)
and of course everything will run smoothly, with E I'm not sure that's so, I flow stronger
well, from the "sensitivity" depends
maybe we should create a separate topic for this? :)
Константин.
Post by Константин. » Wed Oct 31, 2012 16:48
Created and answered there.
Post by Михаил_ » Mon Nov 05, 2012 15:11
We announce a reduction in the cost of U1 up to 30t. The reduction is due to the presence in the line of devices Y4-micro, is similar in cost and more powerful. Although from a technical point of view these are two completely different devices with different principles, each useful in its own way.
U1 is in stock at the moment (sometimes there are breaks of several weeks with their existence).
