Panacea or product "P"
yana
Re: .Panacea or product "P"
Post by yana » Thu Jan 05, 2012 2:33
So you haven't learned yet :?
Post by Михаил_ » Thu Jan 05, 2012 2:47
Well, you can also in the opposite direction - in the sense of moving somewhere, not necessarily permanently, but to change the social circle.
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Thu Jan 05, 2012 10:11
I have such feelings:
- childhood waiting for something (it was especially strong in adolescence, and then, I think it is beginning to be felt) something prepared - accumulated, accumulated, and the realization somewhere ahead, had not yet come to a point. Then family, work and stepped aside.
- was funny and endured a frivolous attitude, but now it's like started to change, as it is not a turn the vectors of the family in the direction in which my aims. Prevented and prevents the inertia of loved ones, but to get away from this or not, and learn to work with this load, trying to pull them away.
- yesterday and today do this kind of work - soften the consciousness and the subconscious that was soft, pliable, and everything in them gets hard (stones, pins) is not mine, but imposed by society, I do not need - throw in the furnace (burn) make install to question all the axioms, assertions, beliefs, test them and if not mine, to build new connections to bypass, and as soon as it is not necessary separated and localized - throw away and burn.
In General every day life becomes more interesting, like get closer and closer to the true self to appear desire new or forgotten old. Constantly thank the universe, the Creator, the earth, the Sun, angels, subconscious mind, body, herself, Michael, his project, and anyone as it tells me what to do and what you can do (I wrote about this earlier that define the problem and the intention and then find the answer or a hint on the website of Michael, as if I sent the request and the answer came to me through the channel through which I can get). THANK you to EVERYONE who helps me and not only me. Generally had the idea that I wanted to live in an era of change, the dynamics fascinated me.
Константин.
Been thanked: 2 times
Post by Константин. » Fri Jan 06, 2012 15:06
Today, in the morning we had to work with his hands, so took both 3.0, stayed on his feet panacea and pendant.
an hour later inside began irrational neurosis. when the place does not find, the itch in the first place he esba enrage) because they do not understand the reasons for this rage:)
not immediately but realized that has changed left me one panacea!
3.0 qualitatively smoothed this too much for me, and I almost broke.
reaching home as I could, put everything we had, 10 minutes was normal.
Conclusion: the first three weeks of socks necklace bracelets P, was quieter in terms of nerves. was other work.
Now if you keep the necklace and bracelets P - I that it works out apparently, but bear it long it turns out.
Друид
Been thanked: 3 times
Post by Друид » Fri Jan 06, 2012 16:12
Yes, I too recently felt that 3.0, as 2.0, very much smooths out the action of the panacea. Up to this point, that is not coming no shakes and everything is going so smoothly... like a dream. Used to wear it all together, and panacea, and 2.0 and 3.0. And now it has become mono to wear. For example, only a panacea. And began vylazit new manifestations of panacea, which climbs when was the compote. I have long wanted to write about it, and then began to read the forum over the past two weeks and it turns out just this topic is discussed. And this last time, I think about something, I want to ask, you come to the forum, and just have the answer to your question read)))
Игнациус
Post by Игнациус » Fri Jan 06, 2012 20:27
with me today also irritation rushing. just do not understand why.
Константин.
Post by Константин. » Sun Jan 08, 2012 20:31
Almost all of this week feel the freshness in the upper sinuses.
That is, in the depth of the nose, constantly is a strong feeling of freshness, very strong and constant.
Hands on 3.0, panacea on the legs and pendant. most of that does not use. A couple of days even did not work with O3.
How and why this occurs deep in the nose - I don't know
Unpleasant, this is not much more unusual, Chur fresh breath.
over time this feeling is only enhanced.
Post by Михаил_ » Mon Jan 09, 2012 17:04
this is normal. Due to the perception of energies.
irritability - not good, but is not bad, is also normal. This roughness of the work of the cocoon when contact with the outside world climbs.
Игнациус
Post by Игнациус » Mon Jan 09, 2012 23:03
Yes, I agree.
more about irritation. it is... to something external, is not fully conscious. the only thing that I understand you don't want "you"(something unconscious, external) to bend, to do what "you" want. well, as you can? - in a series of internal questions and protests.
at this point I was home the whole range of the BZ, reinforced 3 N, which I tried not to wear previously.
Petr99
Post by Petr99 » Tue Jan 10, 2012 6:40
Ignatius if you can, please write like increased 3.0 N. I yesterday had a strong irritation with his wife quarreling, went for a walk in the woods in sorokogradusnuyu frost and calm down before the end of the day could not (yet inside like calm as they begin to interact - something climbs), it seemed to me that due to the hard work of a bunch of panaceas, 3.0 OZ + Explorer in the morning. Fell asleep with guide, morning nothing I wanted, now warmed up a little, I think the crisis is to rebuild the picture of the world.
Игнациус
Post by Игнациус » Tue Jan 10, 2012 11:06
twofold turned phrase. this meant: the set BJ was added 3 N (non-reinforced, normal).
I think this is because of the large number of BJ, version 3... and changes in the world.
when I took 3 was easier.
Post by Михаил_ » Tue Jan 10, 2012 15:01
For lovers of strengthening the 3.0 - way of the old TV (or monitor), i.e., a CRT with a conventional microscope.
turn, may transmit noise.
put his screen up. On top of the screen place the charger wrap with 3.0 N for the entire treatment period (can be recharged already available).
Then look at the effects.
АП
Post by АП » Tue Jan 10, 2012 22:49
Michael you need to completely redo all the charge cycles or just last? that is wrapped in three mandalas, the top foil and the audio? and all this construction is put on a working TV? or.....
Post by Михаил_ » Tue Jan 10, 2012 23:16
working without configuring a TV program. The entire structure. Better all the cycles, but can be last. The result will be in any of the options. This is of course weaker than a full charge, but stronger N will.
And just one example of how improvised, which is everywhere, to do something useful....
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Tue Jan 10, 2012 23:24
Михаил_ wrote:may transmit noise.
noise means any sound (including hard rock :) ) or just shoby chiapello? :?
Петрос
Post by Петрос » Tue Jan 10, 2012 23:26
Михаил_ wrote:working no setup on the TV program.
here is the answer that I am not careful :?
АП
Post by АП » Tue Jan 10, 2012 23:44
Will try :)
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Wed Jan 11, 2012 1:08
Well, thank God. At least someone found a good use of TV! :)
Петрос
Post by Петрос » Wed Jan 11, 2012 1:14
Логик wrote:Well, thank God. At least someone found a good use of TV!
that's for sure, now I have it on the balcony, not just a corner is :)
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Wed Jan 11, 2012 7:54
A little more modern "box"(I have saved) when no signal canaverial screen with a blue field, unfortunately...
Else. If this thread is moved down to 3.0 and the noise, at this the subject matter concerned.
Here, in a city apartment, noise from transport. As far as the noise from the street, which is not "white" and "pink" fouls when charging the tracks БЖ3.0N ? If the summer-house not to wait.
Petr99
Post by Petr99 » Wed Jan 11, 2012 8:19
Michael, thanks for the advice. Another question: the dynamics of work required (audio) - it can be turned off; subtract; preferably at full volume? And another thing: I read somewhere that you can increase the panacea of activated magnesium whether this activation for 3.0? Thanks again!
Post by bofara » Wed Jan 11, 2012 12:25
Михаил_ wrote:...on Top of the screen place the charger wrap with 3.0 N for the entire treatment period...
if the wrapper is done repeatedly, the third time, etc. of course the number of layers in a reasonable measure of/, i.e., the lower /inner/ layer - mandala/mandala/, then aluminum foil, then paper or plastic wrap, and then again, ending on the foil - it's to strengthen it still more "charging"? 8)
Михаил_ wrote:...put his screen up...
hmm, if put in a electrical substation? or over a certain antenna for a cell phone.
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Wed Jan 11, 2012 12:41
ФилиНН wrote:a modern edge "the box"(I have saved) when no signal canaverial screen with a blue field, unfortunately...
In slightly more modern box should be a setting menu in which the blue the screen turns off.
Тяфа
Post by Тяфа » Wed Jan 11, 2012 19:23
My body does not react the Cure, wear a week, no sensation, although it may well :)
Петрос
Post by Петрос » Wed Jan 11, 2012 20:51
Михаил_ wrote:but stronger N will.
Yes, and the matrix charge 3.0, panacea in this way will increase?
