BJ 2.1 / 2.2 / 2.4
Re: БЖ2.1 reinforced "hard" version 2.0
Post by Михаил_ » Fri Dec 23, 2011 17:05
Use a good well water. The well is deep. Water is environmentally friendly and clean. Still use BSL-med (in emerald+BSL-med. Plan to use the activator own development (more powerful, working on different principles, now I spend it debugging and testing + analysis of water outlet).
It's not the fact that attracted and not attracted to. And not even cleaning.
Although it, too. In particular my well water contains excess iron. And after BSL-honey - no.
The fact that the normal water needs to be AFP-negative and that it is not such - it is a problem enough on a global scale, i.e. breaches at the level of planetary ecology (simplified for example).
Even Schauberger in his early articles written in the last century, so 100 years is almost like, warned that improper use of water and incorrect water to drink, will lead to an increase in the number of previously unknown diseases and in particular to a jump in the number of cancer patients.
Which is what happened.
And he also stressed that the correct water is "fully born". I.e., pushed to the ground by rainfall and born of spring, meaning that it rose to the surface. But spring must be right-natural conditions.
Good springs now there are quite a few, and the water is kept long. Therefore, the activation of water - a thing no alternative, if you want to maintain a proper and healthy condition for a long time. As air in principle.
But this topic is very large and quite far removed from 2.1
Константин.
Been thanked: 2 times
Post by Константин. » Fri Dec 23, 2011 17:17
But I've been wondering about the activator! will there be somewhere to tell?
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Fri Dec 23, 2011 17:35
Michael_and you have not performed checks how much time keeps the negative ORP water, after BSL-Med?
Post by Михаил_ » Fri Dec 23, 2011 20:06
Of water and storage conditions dependent. But IMHO it is better to use within 12 hours. Again, depends on how it is done. I chase two loop, one after the other followed. Because one is not enough usually (that's two drove -140 output).
Emerald took a new, double-reactor regime, alive and dead water, and control mixing. I switched to this mode but the regulator has left close to pH neutral water, but slightly more negative ORP. After BSL it gives -400 and this is kept much less.
Again depends on what to strukturirovaniia. As I wrote, the matrix 1.0 light shifts the ORP closer to slightly negative.
At zero or a zero - a little lower (weak), in sub-zero increases. I, frankly, did not fully understand why. That is, to investigate can. but it was not on time and reasons. Apparently for 1.0 light water it correctly.
By the way, I noticed that the Pets (dog and cat, natural, i.e. not a breeding species), with the constant use of such water for drinking (and negative structures) is clearly less eat. The dog is very noticeable.
(but on people too :) )
the boiled water now can be seen only in coffee, to which, however, lost the taste (rarely drink anything else), you know now my friends, who a long time ago, preparing herbal teas to freshly harvested weed in a mountain of multi-herb, always boiled water in addition to the first gurgling not to boil completely. But now I do not really pull on clean water, Yes.... Actually well water after a good charge ('ll post photos of my bottles for fun) - currently perceived me as the most delicious and enjoyable drink. Quality which varies according to circumstances.
Although, being in a social environment (in the city) can and something else to drink "for the company."
Белый Камень
Post by Белый Камень » Fri Dec 23, 2011 21:27
That theme again)) left, I'm sorry, maybe the queries people have matured :) and all this is not without benefit, I hope.
I personally about all of this is met in two forums, just I have some other position... well, or even just priorities,what frequently emerges.
But it does not touches, is just what it says and is used, for themselves, all this does not deny, as an occasion for reflection and tools.
For a detailed explanation thank you, and I think I'm not alone))
Post by Михаил_ » Fri Dec 23, 2011 23:15
Just a fall into the extremes.... A useful synthesis. Chizhevsky and Lachowski was clever.
Тяфа
Post by Тяфа » Fri Dec 23, 2011 23:47
Michael, I'm sorry that I write in the wrong topic but I really need your advice. Read the information of BSL-med, so can't tell who makes quality products and who is fake : devices go under different patentee (78789 patent, the head of the Ermakov like kontrofakt, and the patent 74910 original), so it really do not want to make the wrong choice! Your device the patent of which company? THANK you mentioned it on the forum, and wouldn't know never about such device.... :oops:
Тяфа
Post by Тяфа » Fri Dec 23, 2011 23:52
Well that is not much arguing about the band: Yesterday I sit reading the forum about the modules, I feel that bracelet like stopping, I wanted to correct him and immediately withdrew his hand, the bracelet was hot, very hot! I decided that I already read all of the information touched his forehead hot, a baby at home, went to touch him, so the child was very high temperature!!! My bracelet began to cool! I was blown away! I didn't expect this! The more that I wear it only two days. That is, the bracelet worked even on the child and suggested that with him the problem! I am flying now...
Post by Михаил_ » Sat Dec 24, 2011 14:27
1. there are two threads about water, here the local (small) and the Gazebo is a large and more versatile. There including it all repeatedly from different angles were discussed with different opinions by different people.
2. http://www.bsl-med.ru/ (Vita)
3. I recommend to download the video
4. Bracelet most likely is not suggested, and just made my job. The relationship of mother to child energetically very strong, especially the first 6-12 years. At this time (and next too) quite effectively to treat the child through the mother, and the problems they often work together rather than separate. I.e. physical and mental symptoms can only be one of them, but this does not mean that it is a personal problem. In reflexology for children of this age practiced through the influence of parents is effective, but repeatedly made to adult children.
With regard to morbidity, in Moscow, according to my understanding, was launched virusot to reduce the activity of the people before the elections. Now possible second wave.Our friends also temperature in children is high.
By the way water is ORP-negative also a good thing. I mean a quick recovery in such cases. But there are plenty of other measures. For example, to draw a black line (though the marker from the base of the nail up to the joint on the fingers (mom or child) - it changes the energy of heat, but based on the fact that the temperature helps a person improve their health, and to shoot it down only if it is too high (but not as much as recommended by modern doctors), then it is used dosed. )
Experience tells us that the body helps to overcome the painful condition of good microflora. For example, Vetom 1.1 in the proper amount. Nozdrin. Water-structured KV can be useful.
This is with the exception of standard tools prescribed by doctors (formal excuse :) )
BJ you can wear the baby. On the left hand.
In General, for such cases you can have for a child 4 BJ.
There is a great configuration of magnets for anthropologe status (need switch magnets sujok), like mentioned it on your forum, but can't remember where.<
Тяфа
Post by Тяфа » Sat Dec 24, 2011 15:27
Michael_ :o
Post by Михаил_ » Sat Dec 24, 2011 15:36
sorry, got a message from the PM here, entangled in the forms of the response was removed.
Тяфа
Post by Тяфа » Sun Dec 25, 2011 19:12
Twice already when filling the bath was placed in her bracelet, the water is very soft, its density seemed to increase, direct pushes and then a boost! Great! :wink:
Post by Михаил_ » Sun Dec 25, 2011 19:49
I'm right with him to put in his her 4 bracelet :) I really like the feel on the body when they are in the water.
And KV is often put in the filling, but it has a different quality of water.
Тяфа
Post by Тяфа » Sun Dec 25, 2011 21:01
Михаил_ wrote:I'm right with him to put in his her 4 bracelet
:lol: :lol: :lol:
And I noticed an interesting feature when the water has filled and the bracelet is removed, the stones all motn-white and even thought that the green cast :roll: wear on hand and also swim with him in 2-3 minutes, the stones are returned to the original version ( transparent, almost Nude, very similar to Topaz). What would it mean :roll:
Тяфа
Post by Тяфа » Sun Jan 01, 2012 14:00
Tried to enable the modules (from the kit). It turns out. There are the interesting feeling. First around the bracelet, you receive a bundle of energy greatly vibrates, and then starts to move and look for clips. I have one very strong in the area of the cervical vertebrae, it starts straight batter, but not yet struck. I think soon we will defeat him! :)
Тяфа
Post by Тяфа » Sat Jan 07, 2012 12:17
Michael, do you believe that it is from time to time putting the bracelet back on the map transfer to recharge or there is no need to charge it once and for all (well, if the object does not change)?
Post by Михаил_ » Sat Jan 07, 2012 12:42
Check. I think it makes no sense, but it can be reset to the operator (who is not the operator, and mode of supply) and for many this can be a desired effect - updating the feel of dressing as the first time.
Тяфа
Post by Тяфа » Sat Jan 07, 2012 21:49
I think it will not, we bracelet is very well found common language, I almost do not feel, or rather feel like it should be! First, a little sausage, it's all good!
Белый Камень
Post by Белый Камень » Sun Jan 08, 2012 14:00
If the sticker panacea switch matrix 2.9 cut and paste 2.1
is there any sense in such upgrade? Or suppose the matrix P to be applied and switch in 2.9?
And whether the bracelet "from the editor" to adjust to the person as a normal bracelet?
Post by Михаил_ » Sun Jan 08, 2012 15:21
to adapt is of course what he did not adjust.
but 2.1 is better not to spoil.
Александр 1
Post by Александр 1 » Sun Jan 08, 2012 21:18
bofara wrote:There is a positive development in Your problem?
I'm sorry, that is not the topic. You are not from Russia or poorly know Russian language? Well, very hard to read ALL of your posts.
If you still know Russian language, please, respect the forum and write competently.
Again sorry for the offtopic.
Post by bofara » Sun Jan 08, 2012 21:28
Александр 1 wrote:You are not from Russia or poorly know Russian language?..
Both.
Александр 1 wrote:Well, very hard to read ALL of your posts...
Sorry. :o
Александр 1 wrote:If you still know Russian language, please, respect the forum and write competently...
If I knew more well, of course I wrote in literacy.
Dear forum, sorry!!! :o
Смолка
Post by Смолка » Sun Jan 08, 2012 21:42
bofara, all right, we completely understand :ay The main fact that the man was good, and not get bored with you :)
Игнациус
Post by Игнациус » Sun Jan 08, 2012 22:26
bofara! GOOD writing, keep going. :) just not always the correct declination. but it doesn't matter. for example, I don't know any of the Bulgarian language. and you can always understand, so you have something to rejoice. if I do not understand someone's message, I do not read it. everyone has a choice.
Александр 1
Post by Александр 1 » Sun Jan 08, 2012 22:33
Gee, I saw about Bulgaria ))) for the Bulgarian very well )
