G2.0AT - extension BJ on a cell phone.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Tue May 24, 2011 13:04
ММ wrote:Please urgently publish step by step photos of HOW to stick AT 2.0 G on mobile phone, home phone, Android, ipod. Thank you!
Photo no .1 .Remove the cover of the phone and attach a gold sticker on the battery .
2.take out of phone battery and pick up the silver sticker on the back side of the battery.
READY!!!!!!!!
ММ
Has thanked: 185 times
Been thanked: 40 times
Post by ММ » Wed May 25, 2011 23:28
Pasted at on your cell phone and began "miracles" from Michael. And all this happened immediately after gluing. My phone shows 20.51, while the exact time 20.26 :)
ММ
Post by ММ » Mon May 30, 2011 20:48
After 2 two days after gluing at suddenly became seriously ill child. And this at a temperature of 25-26 degrees Celsius. All covered with pimples, temperature 38, pain all over body, flowing from his nose. I don't know if the flu, or tricks at :evil:
Post by Михаил_ » Tue May 31, 2011 0:35
Are you talking about? At works extensions at and in fact within the f-functions at - i.e. with connections. As problems people - enough described. What about the child?
Ie work at has nothing to do with other people in the family. With the exception of direct f-functions at can strengthen You personally and your BJ, but they in turn are not able to create overload (clearly seen on impacted from U2 - all different people, but overload none arose).
Ie work at a child is bound to be.
Post by Михаил_ » Tue May 31, 2011 0:36
By the way, I hope You use at together with BJ? Since this extension of the BZ....
ММ
Post by ММ » Tue May 31, 2011 23:08
Yes, of course I am. I am a newbie. Immediately pinned the 4 BJ 2.1
Until the result is zero :? . That is, feel nothing. Wear 4 pairs of BJ may 20 + IIM-1 permanently in the hands of a + at in the pocket.
As for the child, when the warm weather she was never sick. But after gluing the at began feeling unwell.
Been thanked: 10 times
Post by Мастер 108 » Wed Jun 01, 2011 1:00
And today I have coatinga has died...:cry: Can also be from the fact that periodically put on your BJ?
After that, not so vsledsvii this. What do you think, MM, and?
Still, the cat was 17 years old, and for cats is age, you know.
ММ wrote: As for the child, when the warm weather she was never sick. But after gluing the at began feeling unwell.
The weather might be warm, but the breeze could blow cold...
Post by Михаил_ » Wed Jun 01, 2011 12:30
ММ wrote:Yes, of course I am. I am a newbie. Immediately pinned the 4 BJ 2.1
And what kind of results You want for the week, and why I constantly Iim-1 in hand?
You have to wear ONE BJ (1.0 or 2.0 or even if you want - 2.1) at least a month, then increase their number. And nothing to wait for.
Isn-1 is not constantly in their hands - and to put on the table.
And at might as well have photoshopped in later, at least a little time with BJ. In the forehead there certainly did not say that you can and as You do, but it is better to build up gradually.
BJ, at, ISS, and so to not influence in any way he could. Your personal fortune could indirectly. Because You naturally overload. No need to wait for "something to feel". The sensitivity is either there, or wakes up meeeeeedlenno, sometimes for years, that does not reduce other common effects, this is just restoration of some f-functions of energy.
Just on 2.1 the description says "hard version". People and seasoned, take 1pc, gets vivid effects.
Child up to 6-7 years, and further to 12-14 years is very strongly associated with their parents, stronger than usual with my mom. In reflexology (and not only) treat via effects on parents, if there is no possibility to influence the child (e.g. to put the needle a small child often is technically not out - does not understand and is against).
Much shaking yourself, when You could shake the baby. But until now such cases were not observed any. Most likely - the cold still just a cold. Always something that happens the first time. But I would recommend completely independently to that you do not chase effects, and gradually get used to the 2.1 and isn. Smoothly.
It will be correct.
If you read the forum a while getting used to the strong versions of the BZ, as would the development of management, you get some shake in society and in the family. Directly it is not connected with the products, this is mainly due to the accumulated stresses of social and family Affairs, which crushed the man, but the man doesn't notice. If the child has a cold in the summer and it never happened before, it could be just a cold, maybe just chill on the background of your energy shake is a little unreasonable in intensity, and maybe even the psychological aspect of the relationship between You and the child. It happens. And often. Even if people think that everything is perfect (especially when think). A good therapist in such cases is shown is always for the better. A bit of soul-searching, and removal on the level of awareness of some inner psychological blocks. Well, or a disk Explorer work course WITHOUT a purpose.<
Смолка
Post by Смолка » Sat Jun 11, 2011 16:20
An interesting side effect from at: On the phone recorded practice set of energy. By doing so, I noticed that the effect has increased significantly. Specifically checked, listen to the MP3 player - there is no such effect. Recently, while at work, I decided to tweak the program in SC and the Stabilizer via at( first). Once created the file, I heard a whistle in my ears, and the workers, the receivers have dramatically failed. Apparently overdone.
Post by Михаил_ » Sat Jun 11, 2011 16:32
At - absolutely hilarious stuff.
Keep in mind - it tends to Smolnitsa in weak copies on any computer and transmitting equipment disposing of its spurious radiation(which is useful in environmental terms), and harvested capacity goes to the core algorithms at - ie columnae harmonization, however the Virt. copies are significantly weaker than stickers, but still nothing. If this instrument is your owner - the office is on it if unattended or your probation (such as work) on You. The equipment of this influence should not, but can theoretically. Prescribing certain algorithms, it is possible to delineate the boundaries used at, for example specifying that only take one core, although this would be less efficient.
PS U2 will try to make more detailed control.
Смолка
Post by Смолка » Sat Jun 11, 2011 16:58
Михаил_ wrote: and harvested potential goes to the core algorithms at - ie columnae harmonization, however the Virt. copies are significantly weaker than stickers, but still nothing. If this instrument is your owner - the office is on it if unattended or your probation (such as work) on You.
Sure! A week later, I was at work for us came the programmers said you wanted to upgrade the complex. For us it was a fabulous gift. I correlated it with the Stabilizer. And now think - at helped, thank you, Michael, explained :)
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Fri Jun 24, 2011 20:10
Don't know whether it is connected, but judging by the comments perhaps.
Rustled one of the fans in the computer, vacuumed, the noise stopped, but a couple of three days and appeared again while I was going to buy and change the fan decided to try to "harmonize" just put smart on the at without any "settings" on the computer, 10 minutes later the noise disappeared for a couple of weeks is not repeated :)
Sincerely, MAG.no
Post by Михаил_ » Sun Jul 03, 2011 17:17
The other, after some time of work at, the phone stopped to see the network get through to him was extremely difficult. Zero technical defects, all OK, but the network regularly has gone.
I tried to convince him that there is a background among its secret desires. He did not believe. Was there - he didn't know how to resolve to buy a new cell phone, although I have long wanted. How they were solved - the problem was gone.
Игнациус
Post by Игнациус » Sun Jul 03, 2011 18:24
At on the phone. actually several times when you don't want to be bothered, you can't reach me on the phone. the machine is working, and incoming calls are not received SMS about missed calls don't come or FREE come, but much later.
Post by Михаил_ » Sun Jul 03, 2011 19:36
Yes... and I noticed another funny feature on the topic postupayuschih calls, but only in person - I can spend all the energy at (especially holding the phone in their hands), so that it all the signal to eat. In this case, before I get through I can not, but the phone manages to miss the SMS that I had a call with minimum delay. If I need I call back immediately. But I'm not sure this effect from many (online at hard to spend zero).
Post by Маг.нет » Sun Jul 03, 2011 20:00
:) Here is where :) I was surprised the first time..... SMSes are coming from, and the call is not used. But there is a possibility to choose.......
Sincerely, MAG.no
Александр 1
Post by Александр 1 » Wed Jul 06, 2011 11:35
Maybe someone asked a question here, but did not read the whole thread :)
What should I do if I have an iphone 4? There until the battery gets.
Post by Михаил_ » Wed Jul 06, 2011 12:35
asked, it's very simple - both stickers on the back outside cover next to each other
Стэллари
Post by Стэллари » Wed Jul 06, 2011 16:43
Михаил_ wrote:5. but to get the Lite version and easier...... though in this case it will be even more light.....
Michael, and how you can get the Lite version? tell us, please) :)
Post by Михаил_ » Thu Jul 07, 2011 16:29
well, it's for careful readers only.
Стэллари
Post by Стэллари » Thu Jul 07, 2011 19:10
Михаил_ wrote:4. on the phone from which the sticker is removed, will remain "light" version, i.e. a cast TO work and not going anywhere, just no stickers their work will be a little (probably significantly) weaker. How - I hope I can answer this users question, I don't have experiments to otdiraniya.
Воффка wrote:Michael_
Михаил_ wrote: 5. but to get the Lite version and easier...... though in this case it will be even more light.....
For a bum like me, this is just right! :D Tell us how you can get the Lite version? :)
Михаил_ wrote:1. until you tell me how :)
if I understand correctly, the Lite version is obtained after removing the stickers from the phone is a working replica) but you can get the Lite version and in a different way, but which I never found) :cry: can someone from a careful chitateli share a link?) bc
Post by Михаил_ » Thu Jul 07, 2011 19:26
more light is obtained by a phone call from the phone which is at it "avtoclavirovnie", the copy works with the new operator, i.e. the owner of the phone which, not with which.
But due to the fact that no sticker is present, manifests itself much weaker.
Стэллари
Post by Стэллари » Thu Jul 07, 2011 19:34
Ah, there it is)) thank you) :)
that is, everyone I talk to from your at phone, free then get the Lite version?)) and if I don't want someone to give it to? we're not always with pleasant to us people on the phone))
Post by Михаил_ » Thu Jul 07, 2011 19:47
Your do not want will not affect the process. If you don't understand, read about social Oh products again from the beginning on. It is useful to all. And anyway... the trouble people is a subjective thing.
Стэллари
Post by Стэллари » Thu Jul 07, 2011 20:01
agree), subjective)) so I appreciate people like pleasant and unpleasant subjective to me)) about products read)) may call the at phone unpleasant to me and change his status for me)
At I have yet, to be honest)) now just choose between at radionica and bracelet)
