About the players, soundcards and other Goodies...
_Сергей_
Post by _Сергей_ » Wed Sep 10, 2008 12:31
no desire to bear the costs of the acquisition of the music center, and portable something like.
If sound card Creative X-Fi for audiostrobe discs?
Post by Гость » Wed Sep 10, 2008 14:28
As can be seen from messages on the forums , the question is - what to listen to CDs Andrei Patrushev - a very topical, problems, not to solve them is not to get disks purpose for which they were intended.
It seems one solution is to buy disks MM and not to bother, (less will not work :ap )
Post by Андрей Патрушев » Wed Sep 10, 2008 16:20
Гость wrote:As you can see from the posts on the forums , the question is - what to listen to CDs Andrei Patrushev - a very topical, problems, not to solve them is not to get disks purpose for which they were intended.
You see, mindmachine not designed to playback discs. In my opinion, the problem is far-fetched.
_Сергей_
Post by _Сергей_ » Wed Sep 10, 2008 17:03
how can you determine that a particular cd player is suitable for efficient drive of Andrey Patrushev?
Work if such and such player noname ???
specifications:
range 20-20000hz
frequency 44.1 kHz
modelirovanie 16bit
method ispravleno error CIRC
o the resistance of 32ω
o Moses 20mW
Post by Андрей Патрушев » Wed Sep 10, 2008 17:34
_Сергей_ wrote:how can you determine that a particular cd player is suitable for efficient drive of Andrey Patrushev?
specifications:
range 20-20000hz
frequency 44.1 kHz
modelirovanie 16bit
o Moses 20mW
The characteristics will fit.
Post by Андрей Патрушев » Wed Sep 10, 2008 17:36
_Сергей_ wrote:no desire to bear the costs of the acquisition of the music center, and portable something like.
I think that fits - I have an immaculate...:)
Post by Андрей Патрушев » Wed Sep 10, 2008 17:43
Anonymous wrote:Good afternoon.
Suitable for listening to CDs Andrew following combination of devices:
1. Headphones Beyerdynamic DT 860 (5-35000Гц/32ω/97дБ)
2. CD player of unknown brand Miro. It is written that the output is 20-20000hz. When listening to discs with audiostrobe in principle, the bulbs on the glasses blink.
How to determine what player is suitable for this purpose?
Or is it necessary to take any player from the brand like Sonia?
The characteristics like. If stutters on disks with a lot of high, all right.
_Сергей_
Post by _Сергей_ » Wed Sep 10, 2008 19:09
Great. Andrew, thank You very much for the reply.
Ростислав
Has thanked: 35 times
Been thanked: 28 times
Post by Ростислав » Fri Sep 19, 2008 17:15
Andrew! tell me in the forum I read that some of Your disks used frequencies from 8 Hz to 20kHz! So if you use players with a frequency range from 20Hz to 20kHz low frequency cut off right and this will be the effect when listening to discs with circumcision от8гц to 19 Hz? Not do you lose the effect?
Илтуак
Post by Илтуак » Sun Oct 05, 2008 14:55
Hello everyone, Read the topic, and I have a sneaking great doubt that drives you to listen with favor to my player with these characteristics:
Frequency response 50Hz - 15kHz
Sampling frquency of 44.1 kHz
D/A converter 1-bit
Knowing people,prompt,please.
Post by Андрей Патрушев » Sun Oct 05, 2008 21:15
Ростислав wrote:Andrew! tell me in the forum I read that some of Your disks used frequencies from 8 Hz to 20kHz! So if you use players with a frequency range from 20Hz to 20kHz low frequency cut off right and this will be the effect when listening to discs with circumcision от8гц to 19 Hz? Not do you lose the effect?
The disc includes also frequency 0,016 Hz to 20 kHz, but this is not important, since low frequencies are specified using binaural beats and modulations.
Post by Андрей Патрушев » Sun Oct 05, 2008 21:16
Илтуак wrote:Hello Everyone, Read the topic, and I have a sneaking great doubt that drives you to listen with favor to my player with these characteristics:
D/A converter 1-bit
Yes, the top is clearly not enough...
Илтуак
Post by Илтуак » Mon Oct 06, 2008 9:37
Андрей Патрушев wrote:Yes, the top is clearly not enough...
Thanks for the reply,Andrew.And like the Conductor and Theta meditation,where,as I understand it, there are no high frequencies, it is possible? Or too little?
Post by Андрей Патрушев » Mon Oct 06, 2008 11:48
Can.:)
Илтуак
Post by Илтуак » Tue Oct 07, 2008 8:02
Андрей Патрушев wrote:is Possible.
Thanks for the clarification.Special thanks for your work and... for your voice on the wire - such a warm,soulful and mesmerizing.While I know close only with a Guide,so about it and write. :o
Тестер
Post by Тестер » Wed Oct 08, 2008 16:17
Hello,
when listening to "Healing" for Sony D-NE240 clearly slishen sound
audiostrobe from other players including an old SONY, SAMSUNG has no such problems. The sound of"shuffling", personally bothers me relaxed. How do YOU think what the problem and the solution - replacing the CD player?
Thank you.
Post by Андрей Патрушев » Wed Oct 08, 2008 16:41
Thank You! :o
Post by Андрей Патрушев » Wed Oct 08, 2008 16:44
Тестер wrote:Hello,
Thank you.
In electronics I'm not good to explain it all...
But I've noticed in practice that the worse the earphones (speakers), the more they heard the sound of audiostrobe. Most likely, it audiostrobe modulated by the noise generated by the device.
Тестер
Post by Тестер » Wed Oct 08, 2008 18:10
"Shuffling"-audiostrobe sound rhythmic and unfortunately in the foreground on the feeling more than the left.
Headphones almost DJеские TEHNIKS, tasted quite different from simple to very HI-FI. But the sound unfortunately is clearly only on the above-described device, it's a nuisance.
Thanks for the reply.
Post by Андрей Патрушев » Wed Oct 08, 2008 18:39
Тестер wrote:"Shuffling"-audiostrobe sound rhythmic and unfortunately in the foreground on the feeling more than the left.
It may not be audiostrobe at all... But on the other disks as?
Тестер
Post by Тестер » Wed Oct 08, 2008 18:53
I have audiostrobe only "heal, and"Endorphins", took the disc "Healing" from a friend, just hear "shuffling"sound.Moreover, the rhythm in sound is different, i.e. not a continuous noise, and rhythmic and rhythm is different.
Somewhere on the form read about such effect.
Well, actually it does not bother me as there is another player,
well at the very least because you can on the iPod in wav format to listen to.
Listen to today's "endorphins", and say has an effect or not.
Тестер
Post by Тестер » Thu Oct 09, 2008 10:28
Listen to "Endorphins", first in the left ear, "whack-whack", then
right and then "residence permit-W-W-W" General plan.
So like audiostrobe.
Thank you.
ЭлизабетСуон
Post by ЭлизабетСуон » Fri Oct 17, 2008 13:33
Good day!
You have an interesting website.
Now www.mindmachine.ru I'll keep coming back
олег77
Post by олег77 » Mon Oct 20, 2008 9:03
Hello!
I have a MP3 player SanDisk Sansa е280 - 8 GB, is he playing Waw files, I usually proslushav ham sink the discs are translated in Waw format. I'm bad razberayus in electornica, do not know what is important the frequency of the sound output from the player, I think that's enough to transfer the file in Waw format. On the Internet I can not find anything about the Sansa sandix. I would appreciate if someone suggested information about this player, and if he's good to listen to audiostrobe drives.
Thanks in advance for your answer.
Post by Андрей Патрушев » Mon Oct 20, 2008 9:48
олег77 wrote:Hello!
listen to most audiostrobe disks can be on anything...
