Reviews about the effects of version 3.0
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon Nov 15, 2010 20:40
Михаил_ wrote:1. ...I.e. it's not different layers, but that should be combined in a single layer. So I suspect that if something polimerici, then after all 3.
2. box after 3.0 had little use for something else...
3. ...the artificial stone in this aspect would be preferable.... here's a strange thing 3.0
4. ...The difference between the 2 lies in the meteor implementation. And in my opinion that is why the price is so. Moreover, it is associated with a significant increase ... in the cost of overheads (over the meteorite substance pay).
5. I kind of never wrote about 20 channels? And what exactly do you mean? In classical literature and traditions known 12 heavenly stems (see the same acupuncture for example), but this kind of primitive picture.
1. I.e. the polymer cannot be the basis?
2. Storage 3.0?
3. No wonder our dialogue, and that's the basis... but what about clause 1?
4. So in both cases written on the content of meteoric protomatter in S+ it in a different form?
5. 12 heavenly stems and 8 of the planetary, this is what is meant.
Sincerely, MAG.no
Post by Михаил_ » Mon Nov 15, 2010 21:11
1. pre-hardened and then "charged" - can. Otherwise it is heterogeneous instead of homogeneous quality of the resulting gradual shift.
2. you can, but why? he boxes well stored :oops:
3. Yes, maybe the polymer, the question is that it is not necessary to divide the process into layers.
4. in the description of S+, I just didn't remember about the meteor substance. It is not there, but layered laser treatment significantly distinguishes it from S exactly as the other procedure firmware information prior to engraving.
5. 9 the planetary. No, it's not. I.e. here the principle seems the same, but the energy is different. Easier to try to compare.
Post by Маг.нет » Mon Nov 15, 2010 21:43
Presentation: http://www.mindmachine.ru/viewtopic.php ... &start=650
posted: Wed Oct 20, 2010 3:11 am
N - full version, easy charging, normal, will be available to the club and may in the future publicly, includes 4 stages of manufacture.
- this version is not supplied in the sale.
S - super-version will be available in commercial form, media + special charger technology, but based on the same four stages as in Normal version, only sold on special. install.
- this version is already in the office (first few pieces) and can be quickly attached to him.
price 20 000, material of Blackwood, aka Eben, he's black African wood (thanks for the idea Methuselah and contacts), this material is well suited for 3.0, size closer to standard bracelets, usually present in the office, the links are rectangular, color black. Photos later (can be ordered separately on these 2 links.x in addition to 2.5, for 2.5 we need a different wood, while maintaining regular prices).
It will be the cheapest of the paid versions 3.0, still restrictions on the quantity in which it can be made (limit of resource production).
at the moment there are a few pieces.
S+ a super version with laser engraving [and with the addition of special composition, including the meteorite substance are extremely rare type. By the way don't know what I'll do when it runs out, as this type of is hard to find, only in personal collections.] -TYPO
Used in the manufacture of special methods of processing materials. In the production of this version will have 8 stages to reinforce it.
it is not the cheapest version.
This version broke the two
S+ = same as N version, blank same but different processing, multilayer laser engraving on two sides of links and additional activation procedure.
price 50000r
these can be pre-order. Will go to the office tomorrow or the day after, I will focus on the number of orders in manufacturing.
S++ = too, but harvesting more massive, larger, which in addition to the multilayer laser processing caused by the composition containing the rare meteor brotowasisto - chondrite C1 (or Сl1 it is the same), i.e. if in General, the chondrites are named due to the formation of chondrules - inhomogeneities due to heat in the fall, then in C1 of these chondrules actually no, he was not exposed to thermal attack in the fall (apparently these pieces are from the inner parts of meteorites, which did not have time to heat up), so it is not broken "native" signal energy.
this meteoric material has a very high value and extremely rare with a unique power characteristics.
photo of the workpiece will lay out later, photo finish will not fundamentally can publish (your head mind).
This version will cost 100 000 and requires special care in use.
will be back in stock in the next few days, you can place pre-orders, I'll focus on them.
Unable to REFUSE the sale (I'm not the right candidate for a mental hospital). Ie I will ask the office to say those who want to buy from me. And then believe your caution, I have long ceased. Also strongly recommend to take it to someone who has not worked for some time with 2.x, preferably from 2.6
SE+ This is the high tech version that contains the embedded source of energy is extremely high power. Until available, worked through the technological process of production, but it can not be purchased from, you first need to gain experience from working with previous.
This version will appear in about half to two to three months. Will only be sold to those who bought one of the preceding. It will be tough and strong additional energy flow. For many enough for it to hold out a few minutes to a long time to experience.
Since today is my trained colleague got almost the ultimate thrill of 3.0 S, and the events started to happen YESTERDAY when I outlined (specific bracelet) as intended for him and he started to work at a distance, on the basis of this experience I do not really recommend to play with expensive and powerful toys, even if there is such a possibility. OK?
I can count on consciousness? in short don't overload yourself.
On other issues clear.
Sincerely, MAG.no<
Post by Михаил_ » Mon Nov 15, 2010 22:12
you should fix the typo. The meteorite substance is only in S++
in the description on the website ( in the directory) that way. initially find the message correct. Apparently Tocopherols chunks of text.
Post by Маг.нет » Mon Nov 15, 2010 22:36
Михаил_ wrote:want to fix a typo.
Everything is clear:) no problem:)
Sincerely, MAG.no
Post by Михаил_ » Mon Nov 15, 2010 22:44
I realized there in the description confusion... twice is one text and correct the lower part. hmm... here are the consequences 3.0 :) in action. (actually I have a few days was very ...specific condition as probably many who are).
from the practical part.
the feedback received on the part of regenerative processes.
Two cases, both people have some, but very weak personal sensitivity + health problems. Wore 2.0
Enter Lite 3.0 and 3.0 S+ in daily use gave positive feedback to reduce the manifestations Chronicles + fatigue after Ls. transport and working day in other case, zero, i.e. there is no fatigue.
Also quickly passed head injury and its consequences :)
Maybe I will reconsider the restrictive recommendations in the direction of easing in this regard, if there are more similar examples.
However there are other... I mean when 3.0 went quite hard on the body and / or consciousness. (fatigue, etc.)
Малика
Has thanked: 251 times
Been thanked: 110 times
Post by Малика » Mon Nov 15, 2010 23:08
3.0 (from 2.0) in combination with 3.0 (from 1.0.) quickly removes the pain, or dulls pain. Checked a few times.
3.0 (former 2.0) wear all the time.
Post by Михаил_ » Mon Nov 15, 2010 23:53
From personal observation.
The most powerful option - 4pcs (hands legs), but enough for only one of them was "strong", the rest are at least light.
After a while of constant wear began a SIGNIFICANT restructuring of the energy sector. So it was somewhat unusual (but was not, and there).
Specifically, the uniqueness lies in the fact that I'm not used to such flows and to the fact that activated and opened channels at the ends of the fingers. I feel them physically. Specially consulted (I do, but always believe that it is not always the person can assess themselves adequately), he said that the part looks like a very positive process.
Another similar pattern of slightly weaker - one 3.0
And in that and in other case in the 3.0's were really heavier denomination (blank under S++)
Very serious developments carried out by the food.
I started to feel synthetic products... so that soon little will be there... :) I.e., to intercept the road something left, but previously valid, was impossible simply because I'm this you can believe.... but the taste sensations at the same time... and generally feeling strange to say the least. So to do worse than nothing.
Besides, if I wasn't there, but I didn't like to do, now and mechanical habit gone.
Periodically feel the need of a particular product or drink in a specific amount, usually not very large.
Тоха
Post by Тоха » Tue Nov 16, 2010 0:07
And I thought that this song I have one. No is all I can. But with the hands and fingers a small ambush. First began to ache right hand. Secondly it itches. The sensitivity of the fingers has increased significantly. Well, goosebumps on my legs darting constantly. My 2 bracelets. 2.0 and 3.0 on each. Very unusual sensations. And pulled all sorts of vegetables. To the meat of what indifference or what. There is something I can, but if there is a choice, are unlikely to choose.
And the most interesting that if I relaxed the hands raise over the subject of how something I'm starting to feel some currents from it. Don't know how to describe. But if you are using version 2.x this was not.
Олег27
Post by Олег27 » Tue Nov 16, 2010 0:23
Yes 4 pieces (one for the hands and feet) is really very meaningful. The only not always possible a long time to wear 4 because for some reason begin to "spark" when working with a computer and other devices. Condition is not so annoying, but don't really want to involuntarily draw the hands, if unwittingly, to something touched. :wiz
Post by Михаил_ » Tue Nov 16, 2010 0:32
Yes, it is.. in a completely non-synthetic clothes previously not seen in the generation of statics, I was walking up the stairs of a shop slapping his hand on the railing and "lamenting" - "what are you fighting every second....?!" :) but it shakes :)
was younger - of course it was present constantly.... without 3.0, then worked a lot with electronics, and to restrain themselves, and then burn something easy.
рыжая
Has thanked: 34 times
Been thanked: 46 times
Post by рыжая » Tue Nov 16, 2010 0:55
Михаил_ wrote: Very serious developments carried out by the food.
N-Yes, I do. In fact, we have a large selection. Nuts, seeds, honey, pollen, vegetables, fruits. I have all my life loved the sausage, now I can't have it all. Drinking large amount of tea, coffee almost refused. Next step: go to the consumption of energy directly from the surrounding space. :)
Олег27
Post by Олег27 » Tue Nov 16, 2010 0:57
I such as generally used was not peculiar, if only sporadically, but now only 4 pieces so I am sure after some time starts to spark. WELL to curb yourself, even as it is not impossible. I'm not a magician, and just learning... :?
Post by Михаил_ » Tue Nov 16, 2010 1:36
the funny thing is when then people beat shock starts.... and they are afraid to touch :)
Олег27
Post by Олег27 » Tue Nov 16, 2010 2:00
Михаил_ wrote:the funny thing is when then people beat shock starts.... and they are afraid to touch :)
Sure! This has already happened. And offended at the same time...say what you will "shoot"...and actually say nothing :)
Сергей12
Post by Сергей12 » Tue Nov 16, 2010 3:05
About the current not particularly noticed, thought of shoes, but now watch. As for the food, that is very similar to the changes described above with some additions - started drinking only water with a negative ORP(tea stopped) and had a strong desire Wheatgrass. Fried chicken, so favorite a month ago, cause aversion one of its kind :oops:
Карапуз
Post by Карапуз » Tue Nov 16, 2010 11:21
Michael, for the bracelet version L has a value type of wood? Want to order a piece of ebony to make a few bracelets. Don't know whether it makes sense, if the option of charging the easiest.
Малика
Post by Малика » Tue Nov 16, 2010 11:38
Yes, with food I have the same thing going on..and before that was picky with food,always thinking about what to eat, and now only eat boiled corn on the cob. Somehow got addicted..
As for the "shoot" that I have long wanted to ask advice - how to avoid this?! "Shoot" so that the sparks are visible not only to me, and people in contact shy. It from me long ago. How to reset static electricity ? For battery hold - does not help. Synthetics almost never wear. bc
Малика
Post by Малика » Tue Nov 16, 2010 11:58
Михаил_ wrote: then worked a lot with electronics, and to restrain themselves, and then burn something easy.
And I think that's why I'm not friends with appliances that are worn on the head (like electric, etc.). Beats so that the device becomes inoperative, and I've come.. :shock:
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Thu Nov 18, 2010 0:40
[quote="Michael_"]Yes, it is.. in a completely non-synthetic clothes previously not seen in the generation of statics, I was walking up the stairs of a shop slapping his hand on the railing and "lamenting" - "what are you fighting every second....?!" but it shakes
was younger - of course it was present constantly.... without 3.0, then worked a lot with electronics, and to restrain themselves, and then burn something easy...[/quotе
Before-13 years ago, that I was too.Burned a tape recorder which at the time was included on a radio wave. Came home from work ,the kids are asleep and my brother listens and loud. I told him off and he has zero emotions. I hand in the direction of Magna sent and didn't get to say what raskolotoe it. A tape recorder clicked and sparks showered. In General rested directly without recovery. Then it fired a lot .tired to spend money on it and decided to restrain their emotions and that's kind yet .....
Except comp which is why it works but Opera ekhs(file)-cover and eksploer the same .And does not want to be repaired. 14 a night.(October) shut and still. Waiting for a miracle .Or assistance.
And so do current beats everything-but it's not a miracle and no bracelets. Static in the cold dry season so all shoots and all
Besides, who has dry skin and other things also contribute to it. Especially those working with fast-moving devices and machines. So there is generally a frost in the current byot. worked with gloves -bounce tired and in pain but current. Humidifier for air good help from this :)
Post by Михаил_ » Thu Nov 18, 2010 0:53
In some cases, it is of course clothes, statics and stuff... but believe me, not always :) and among other things it related.... i.e. the conditions where "the work" static accumulates, boost personal development. Very slow (takes it day by day for a long time), but real. Electricity and the fact that the Sens are perceived as energy, they are different sides of one whole. So radiant pumps up the energy of the impulses of a special form.
3.0 is clearly influenced by the processes that "shoot" more than previously, the weather raw, clothing - same.... statics on it, and the sparks like a high school-College years... just Oh. Well at least the technique does not suffer, I long ago learned to protect itself.
Post by ЛИЛИЯ-Р » Thu Nov 18, 2010 2:22
Here's to all learn how to defend. :o . And that's not just me and the computer and other started to fail. These are people with whom I communicate say. But every day and not one. How to be? Please read more about the protection!!!!!!!!!!!! :oops: Itself as the loopholes? :ay
Post by Михаил_ » Thu Nov 18, 2010 3:36
You need to include the technique in its internal picture of the world, with working and stable. Then between her and You there will be no potential difference and sparks too.
For this reason, there are technicians, system administrators, programmers and other people working with computers and electronics, in whose presence the technique itself repaired and ceases to fail. Even if they specifically do not do any practices. Just have a part of their world and it technician preferably working. For them it is not complicated, simple and clear. Therefore, the very detailed integrated inside because well stabiliziruemost. Even if the computer is for someone a "black box" need to be perceived as understandable, useful and stable piece of metal and it will be such....
well, the stabilizer will help... to finish, including public (free) version.
Generally, this symptoms, and from General changes in the world. And their soon to be significantly more, as well as similar equipment glitches. So soon people-stabilizer it will be in demand :)
Малика
Post by Малика » Thu Nov 18, 2010 12:51
Thanks for the clarification! And then my laptop shut again, in August, carried in repair.
In fact, if I take the device as is clear, is working long and steadily..
A humidifier really does not hurt, it is long overdue. Thank you Lilia for the tip. :)
верунчик
Post by верунчик » Fri Nov 19, 2010 2:01
Wore BJ 3.0 , it was like many, does not want to eat...
But 3.0 S and today the whole day in front of kebab, with about CNY this with onion tomatoes and in addition the song is kind of stupid for Maruska:
"The train rushes, and the car pitching. And the farmers of Maruska money pack. Here the puppies are in the stocking. Masha sings in her sleep..."
Think about where this song came from, whether she in a past life was the stage, whether it stocking money :)
That people here are on high, and I have this crap all day :(
I wonder if the older 3.0 version on the 4 limbs to wear, which will make, and what songs they will sing? :)
