СК1М
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Tue Jun 22, 2010 14:29
Clear. Wait...priorities
Sincerely, MAG.no
Post by Маг.нет » Tue Jun 22, 2010 22:04
Michael_, with SK 1M seen that, under all the same conditions (same), with a transmitter, player, recording setup, one volume (5%) on the battery turns ~60 hours without a charge, denoted by so, about 3 weeks out of the previous 5 days, rather 5 - 3, high battery enough for 1o-12 hours, realizing that "whiling away" like nothing, was going to ask the question why? However, the last 2 days everything was back to normal. How to explain this phenomenon.
PS In the circumstances "distortions" was not direct manifestations of the installer too.
Sincerely, MAG.no
Post by Михаил_ » Tue Jun 22, 2010 22:46
1. the simple solution is to take the player that allows you to work from the network (e.g. MP3 player charging from miniUSB and an external power supply that can simultaneously charge and play, these players, for example, is a series of transcend 840-860)
2. the reason is quite simple and prosaic. W1 during operation activates certain properties(quality) of the surrounding world, which affects the flow of physical processes in his area. The player is generally desirable to push him a little further away (not to die accidentally). And then I remember how I ruined the old digicam....
Ie the instrument during operation is abnormal area. And what kind of - depends on the course of processes.
Quick discharge, as I recall, is associated with a shift in invariants (faster time). I.e. where there is not enough switching to a different branch probability, the device worked, and that was a "glitch" in the time of discharge.
ps I have long been on such trifles do not pay attention. Yes... there openmedia have somewhere a printout settings "stabilizer" in the sense of the picture. It is possible for the player to be stuck to the bottom... should some of these jokes clean. About not sure, since SC is more powerful than the printing at times.
Post by Маг.нет » Tue Jun 22, 2010 23:00
Михаил_ wrote:Quick discharge, as I recall, is associated with a shift in invariants (faster time). I.e. where there is not enough switching to a different branch probability, the device worked, and that was a "glitch" in the time of discharge.
The answer is clear, clarify some current issues, there are additional options (not related to the recorded installation). And everything fell to normal.
1. The player kept at a distance of 1 meter and in a different plane (shifted along the vertical, horizontal and depth), with simultaneous playback/charging problems is not present, only will be better to charge to "anomalies" to notice... compliance to observe.
Sincerely, MAG.no
Post by Маг.нет » Wed Jun 23, 2010 1:41
Just noticed, side time the player lost in the negative (lagging) 6 hours 12 minutes. (failure was not, the date , taking into account the lag, right). Funny.:)
PS I changed the wire on the 2.5 m and the location of the player.
Sincerely, MAG.no
Новик
Post by Новик » Wed Jun 23, 2010 14:19
Michael_
Audio files would quickly spread to SK :oops:
Post by Михаил_ » Wed Jun 23, 2010 14:36
Friday should be (now on slow channel far from the city, not really spread).
Post by Маг.нет » Thu Jun 24, 2010 20:36
Маг.нет wrote:"anomaly" to notice... compliance to observe.
Маг.нет wrote:Just noticed, side time the player lost in the negative (lagging) 6 hours 12 minutes. (failure was not, the date , taking into account the lag, right). Funny.
Miracles... Time is not translated, the player is not disconnected, the battery sat down more than usual, but not much, at ~30-40% more than estimated. Here time, time-time +1ч53' from the real, that is +8ч05' (with -6ч12') from "predictable"...
Sincerely, MAG.no
Post by Михаил_ » Thu Jun 24, 2010 21:20
the most offensive, that this is not the first such effect, at me from these damn effects a good Swiss watch has died, however maybe changing the battery might help, but it of 5 years a year has passed, and the watch is not a fake(there are kiosk - "any brand over 200), and natural, does not behave like it should. Before you die - each day it was running a few hours behind....
but to reproduce this on demand - in any way :) and that would be fun for disbelieving FOM :)
if someone is your attention at this very time (no matter the player, hours, phone or something) to follow, waiting for the effect of the shift will go as it should, without any tricks. Jump because no one keeps track of personal attention. In General, this is the easiest way to protect equipment from bugs to think about it.
Новик
Post by Новик » Sun Jun 27, 2010 2:49
veronik
As a prefix to SK coming?
There are some interesting developments?
Post by Михаил_ » Sun Jun 27, 2010 18:15
1. Judging by the fact that consoles almost over, this question not only to the Faith.
2. Basil, received the prefix to the first, describes a very striking effects from finding her near, but didn't notice fundamental differences from the work in a set SK (says "so fast and so quickly"). In other words, to highlight the specific influence of the prefix on the event is likely quite difficult.
3. From a theoretical point of view, there are situations when RF will give the best effect, and is when it use to work situations will be minimal (some will anyway, because the total power would increase.
most clearly noticeable when working with space and man.
Новик
Post by Новик » Mon Jun 28, 2010 2:43
Michael you probably will need to declare an embargo on the consultation of the PM.....what though something appeared on the console on the forum
Post by Михаил_ » Mon Jun 28, 2010 3:38
I'm actually trying to make the forum, even the questions in PM, dehumanize (publish anonymously) and answer possible here.
Just the prefix thing is very simple. As a household light bulb :)
everything valuable has already been said. And the rest - well, imagine that SK is prefixed, solves some problem, no matter what mode. Though the room harmonizes, though the situation... HOW to separate the influence of the consoles? Well, sensitive people in "private" mode without SC good you feel, do prasarana came out (I'm thinking not to do me for such a thing under the seat :) square meter and a half or two) :) But in a joint mode, and even when the input device submitted the audio... but who the hell knows what the prefix from the UK, they work as a single unit.
So if there is a personal sensitivity, I recommend you sit in the office with this thing in hand, somewhere on the sidelines, about 10 minutes. (although in General this is a provocation, I'm not sure you want to leave without it).
верунчик
Post by верунчик » Mon Jun 28, 2010 9:33
Новик wrote:veronik
The console works in tandem with SK. Works fast, sometimes not even have time to keep track. Very good at detecting weaknesses in a given situation, and accordingly the correction comes need information( Oh and to drink juice or not is the work of man) :)
Time has somehow accelerated. Days like hours
Well, I bought a second IC with a prefix (for office)
The acquisition of the first SC was my initiative, then the second - his.
Новик
Post by Новик » Mon Jun 28, 2010 12:21
Here knowing yourself you know what just read I fail :lol:
Новик
Post by Новик » Wed Jun 30, 2010 14:23
Michael_
Here is the question: I Want "hard" to bind SK to itself....
Want to unwind and photo inside to leave in all the attributes(the drop of blood, hair.....)
Possible to do so?
Post by Михаил_ » Thu Jul 01, 2010 2:46
Distressing fact - it is not possible to untwist.... it is monolithic. On the other hand is a huge plus to break down is not anything special.
On the prescribed algorithm, the setting is taken from the audio and / or top of the table. Just put it all....
In General, he's so determined by one operator and the selection operator can only be conscious and voluntary desire thereof, to transfer device for temporary or permanent use of another person. So he and so attached very well. You just need to remove doubts on this score out of my head.
In principle, of course, I can make a personalized version to order, by entering the components inside the manufacture, but what we will do, if you suddenly want to "turn off" ? :) to destroy such a thing is not so easy.... I for one, think that without my active participation, even the complete physical destruction of a material object (the device) will not give the full effect. Phantom because cellular technology will remain almost eternal. By the way is physically destroy the device too hard. I think at high temperature some components are sintered, but as a whole it will not burn, and the abrasion powder, the powder will not lose all properties :) In short, a blast furnace can help, but not certain, if not help, then the whole is cast metal....
in short. Council.
Do not look for unnecessary adventure.
SC now works in contrast to BJ as an external factor.
If it is so hard to relate (ingredients giving a direct hard link), then it will be the extension of the BZ increased power. But it is not removable.
If you really want, pour all conceived in flat thin casting and put it on the table
Новик
Post by Новик » Thu Jul 01, 2010 11:05
Michael_
What material will you recommend for casting?
Tried tinkering with stationery glue....che is not a durable cookie cutters work.
Post by Михаил_ » Thu Jul 01, 2010 13:11
kants. glue is a good material with interesting properties of its own (the silicates in the habit of actually solidify forming a honeycomb structure of molecules) but dries slowly, it is possible, just a layer then do 1-2mm, and wait until dry a couple of days.
you plaster, it hardens quickly.
you can epoxy.
a thick layer is not needed, you need a minimum number of external stuff, just in the form of combining objects factor.
Post by Михаил_ » Thu Jul 01, 2010 13:12
Although actually in my opinion all of this is just the inscription on the stage or just the mental setup of the device.
Post by Маг.нет » Thu Jul 01, 2010 13:21
Michael_, you can stream the set SK to "list of persons", or better a separate "binding" to build. The list will link participants?
Sincerely, MAG.no
Post by Михаил_ » Thu Jul 01, 2010 13:48
What the problem? to associate the participants and translirovalis settings or just to broadcast settings?
The list will give some connection that naturally.... but in principle a stream of identical configuration, potentially also creating a relationship. True, and in that and in other case it will be a link at high frequencies.
If you need communication on a business level, it is necessary in the forehead to prescribe.
Post by Маг.нет » Thu Jul 01, 2010 13:50
Easier stream tune in to a few people at a time without bundles them into one.
Sincerely, MAG.no
Post by Михаил_ » Thu Jul 01, 2010 14:03
Then it is better to put them in Twister turns through the audio input. Short recordings (a state for some time kept).
Post by Маг.нет » Thu Jul 01, 2010 14:08
Thank you! How can "spin" independently, without my involvement?
Sincerely, MAG.no
