What are You Dmitry, I understand, You're a busy man with a lot of work and other worries.
I really appreciate the time and attention You spend on something that would answer my questions. A huge thank You for this!
I hope You will do me the honor and continue to answer, for I have yet a ton of them
But take your time please. I'll wait for Your answers as much as you need...
Well... 695/705 Hz - 795/805 I focus 12 don't remember...
Yes! You are absolutely right! These two couples were not in focus 12, no Mr whatever You have in the programs
I added myself already, engineering focus...
I guess I should not do? To expand the combinations which have been approved by the Ima? This greatly changes the impact of the focus on the brain?
14 Hz falls right away, because it is not a multiple of the frequency
Please explain to me why fall is 14, not 12 or 10 or 16 ?
Please explain the principle of multiplicity in these tricks, because I do not understand something - what kind of runout relative to what must be a multiple of?
16 Hz - you can try on the background of low-frequency rhythms (1,2,4, 10 Hz), relatively low power. I do not remember the exact numbers, they change on different soundtracks, but exactly 10 dB for them to do less than low frequency, and maybe more.
Did I understand correctly that the foci where have already entered frequencies starting at 16 Hz, the pairs of bearing 16 Hz and above are allocated in one additional group of couples?
That is added from the top to the base 1-2-4-4-4, which is already added 8-8-8 or 10-10-10 Hz?
If so, how to understand what the beating of the "second group" what is the upper frequency of the "third group" you can add?
24, 32 Hz they can be put in a very quiet monaural beats at multiples of the carrier above 1000 Hz - Monroe did (ф27).
Wow, well, this is at the moment, for me, far )) then let God deal adequately in the lower simple tricks ))
In General, Dmitry please tell me, monaural beats (mixed in the channel) anything at all give the brain? Or are they too more as an aesthetic element?
A similar question would like to ask the so-called Isochronous Rhythms. What is the isochronous rhythm? Is not the same as a monaural beat?
they tried to add phase modulation some harmonics
Sorry, I though the sound guys but don't quite understand what You mean here.
You mean phase modulation when the signal wave of floats back and forth, then stretching the contracted frequency? So floating in frequency from harmonics?
in addition, the recordings Super Sleep THEM I saw Frank artifact in the form of 60 and 120 Hz interference, which completely suppressed the working effect of these recordings due to interference with the carrier frequencies of BR.
Oh yeah! This lead can be seen not only in Super Sleep, but in the Sound Sleeper, where the second track is an exact copy of Super Sleep, just a little quieter.
Additionally, this tip is found in other Mr programs. And the most terrible, the fact that this crap is even in my opinion in really Going Home! Right? Recently I watched the range And was.. and there seems...
And well even harmonic of 120 Hz, a relatively weak... But a hefty hard-on 60 Hz it's just hard! He just spoils the whole bottom of the focus
It is a variant of course. But it is necessary that this first set of frequencies given approximately the same time say, on the 2nd stage of sleep everyone listening. I'm working on it.
And with what combinations do you suggest I start?
And it would be great to monitor Your research and results! It will somehow somewhere be published?
Or Your job is done just for the sake of the development and production of a new product? The type of mind-new machines or something else...
Sorry for the indelicate questions, but can I ask what is this place (ran?) where You're doing all this, and who You are as an expert?
And what about You and Your current work, I have heard only sketchy rumors ))
actually, Monroe is also in GE tracks the type Plus Polarity
It seems that this exercise is only in the old set of 7 waves, right? In six-wave set (Lori) there is no such.
PS By The Way! I was promised the other day to make rips unique drives of graduates of Gateway Voyage and GuideLines
These discs seems to be impossible to order/buy or download anywhere. Say they like is pure magic for training. That will be great to analysed and compare with the rest of what we have
And You, Dmitri, was not in possession of such good?
Thank you for your attention and answers! I'll be waiting.
A whole list of questions waiting
But don't just want You to throw a mountain, so not too much time You spent on me at once ))))<
