About the parlor
Артур888
Post by Артур888 » Wed Apr 29, 2009 22:46
By the way, and how it can be aimed at protecting , even if the author wrote that the device does not deviate in one direction or another. The fact that it is aimed at normalization.
Post by Dimas » Wed Apr 29, 2009 23:17
Артур888
I incorrectly expressed,is not a defense and removing unnecessary information from the field,thereby bringing her back to normal.
Артур888
Post by Артур888 » Wed Apr 29, 2009 23:30
Dimas wrote:Артур888
But when everything comes back to normal and life gets better and things go their way. Actually then , if you have everything becomes normal , then the other room was SOMETHING ELSE ADDED. Question : What ?
Карил
Post by Карил » Wed Apr 29, 2009 23:42
Артур888
The normalization is likely to receive. There is a story similar to Fret when the device chose the main. I mean modulator Octopus, he is also for protection from radiation. But Svetlitsa-super helps to achieve the goals, and no WAY.
But with these devices is a mess. For example ekonorm reduces the amount of carbon dioxide and increases traffic safety. But the person also emit carbon dioxide. And your finger is on the leg of the table will fly, that's me to the question about safety. In the ekonorma hardly written that it works only with cars, most likely with people too...
If there is no money, why not look to the parlor of the first generation - ellipse locket.
Post by Dimas » Wed Apr 29, 2009 23:45
Артур888
I will not write,wait for Sergei Dinovich,we will explain everything.
Now my question to Sergey Dinamico. Could be the front room (Benefits of Super) as fokusirovki thoughts or intentions?
Карил
Post by Карил » Wed Apr 29, 2009 23:48
In the booklet it was written that the Svetlitsa-super helps to achieve the goal.
АСД
Post by АСД » Thu Apr 30, 2009 0:40
As far as I understand,Lad this is for protection from negative information that carries a field,and that's Super and Good,this is about life and all sorts of improvements...Yes,the differences of influence there,but it is better to explain the author when from Germany back..
I'll try to answer from Germany. None of our product from anything does not protect. Take for example the Way. His task is to agree on the structure of the electromagnetic device with the electromagnetic structure of man. That is, to remove the conflict of structures. It's like the computer has one or the other, but together are unable to work because of a conflict (or a resource of the same or any interruption of same). Then write a third program that performs the function of adapter - will coordinate their work together. Therefore, all our devices are called system adapters. Svetlitsa - Windows coordinate space structure space the structure of a person. Ekonorm performs a harmonizing function in the car. The mirror will agree on the temporal characteristics of the person. And so on.
АСД
Post by АСД » Thu Apr 30, 2009 1:49
Yes , but they all improve the aura. I remember the author wrote that if it improves the aura of the person more visible to other people ( as it becomes stronger when a person gives love and so more visible to others and they are drawn to it) with the same strong aura , and people with a weak aura people are not interesting to him. It turns out due to this and it turns out that you have more successful cases. But all chamber improve the aura. I do not understand what is the different auras from different parlor ? They're all the same , so the effect is similar.
Let's talk about the aura from the point of view of measurement of the luminosity on the GDV. Consider a pool which resemble several of the pipes that transfer water and several pipes through which water flows. The water level in the pool is determined by the difference between total flows to arrival minus consumption. The luminance level of the person can be compared with the water level in the pool. There are streams of energy going to the person is the energy consumption. The power consumption can be a useful needs, and can be lost. Various factors (both natural and man-made) can lead to losses. These include the influence of electrical, distortion of space-time structure (pathogenic areas), etc. Various products LIK clean different types of energy loss, depending on the task at hand. If we in the pool will block one of the pipes, which is the outflow, we see the rise of the water level in the pool. And if it will block another tube, we see the same effect - increase the water level. The same applies to products LIK. If any of the products reduce the energy loss, we see the strengthening glow (aura). But is one form of loss. Another product also reduce the losses (will block other precio outflow of energy), but it will eliminate other reason. From the point of view of the GDV, it is impossible to determine what type of loss is removed. Always seen an increase in the aura. This device is not able to identify the features of various products LIK. They are different and have different solve one task - to restore the integrity of the body, to make it resistant against the influence of various factors. Thus, the products complement and reinforce each other's action. But not interchanged.<
Артур888
Post by Артур888 » Thu Apr 30, 2009 3:00
ASD
Thanks , now more clear. Then it turns out Svetlitsa super will reduce energy losses from all factors ? Or is there a specific ?
ю.м.
Post by ю.м. » Thu Apr 30, 2009 7:40
Svetlitsa-super
ю.м.
Post by ю.м. » Thu Apr 30, 2009 8:03
Hello! Today, I use almost all devices LIK, i.e., the parlor. Distribute these products in Vladivostok.
Post by Dimas » Thu Apr 30, 2009 11:51
Yu.m.
Please share your best practices!Very interesting!
Post by Guest » Thu Apr 30, 2009 21:29
Артур888 wrote:ASD
Svetlitsa-Super is designed for recovering the spatial - temporal structure of liquid crystal systems. Man is basically a liquid crystal, as is 80% of the water. Water is a very complex system, which is due to hydrogen bonds, can display and store large amounts of information. All processes in man go through the water and how clean it crystal depends on the quality of implementation of these processes. How Svetlitsa - Super affects the structure of water can be seen in the section materials on the Parlor - reports - Kristall.doc
How to change the characteristics of biological systems can be seen in the same section in the file Кирлиан1 (effect on enzymes and white blood cells).
Карил
Post by Карил » Thu Apr 30, 2009 23:04
Can you provide a link to Kristall.doc?
Post by Guest » Fri May 01, 2009 0:03
Dimas wrote:ASD
Sergei Dinovich,need advice!
1.Material obstacles (pillow,mattress,leather,metal) are an obstacle on the way of exposure?
2.It makes sense to put the Benefits under the pillow or under the mattress,or enough Super under my pillow,and the Benefits can be put under let's say a pitcher of water at night?
I saved these days, enough money,a lot of energy,I really like it.Please explain again,for the gifted (me)...No reason to buy from Good-gold,why?Because I don't fit the dimensions of the goods are encrypted in the card or...sorry,I can't intelligently speak))))What if I still purchase now?
1. Material obstacles regardless of the material increases the distance from the product to humans and, therefore, reduce the efficiency is proportional to the distance(perhaps in proportion to the square of the distance).
2. Under the jug is better to put the Svetlitsa - Super, it for LCD systems were designed. And Good possible and under the pillow and under the sheet, as you prefer.
Sense to just buy Svetlitsa-Blogged is. I'm only against the creation of naprijenie with this purchase. If the price is annoying, it is better to postpone. As there are expectations. But the realization of these expectations may require some more time than You expect. As to the desired magnitude of the stream of benefits still to come. If there is a desire and Finance to buy.
Олегггг
Post by Олегггг » Fri May 01, 2009 0:17
Андрей Кабанков wrote:my mom's dream was the first time in six months.Yesterday gave her the room,she was lying at night under the pillow.
I Svetlitsa 5th day,can feel the increased capacity for work,Wake up earlier hour than usual.
Today skated on a motorcycle okolo 100 km,and on jams a third of the way.For me the measure of my energy - the speed of faster flow between the ranks in traffic,when simultaneously it is necessary to control many factors and speed is determined by the ability in the moment to such a control ,so it is increased up to 45-50 km/h with my usual 40 km/h.And this road is not tired as he had earlier.
Appeared as,when you are confident in terms of physical reactions,it's as well recognized.At the time when I was doing jumps on the bike it is in this state, all turned out,like courage or something.And in his absence to the same places only injury received.
The topic only recently, just a couple of days as bought Nova Pro 100 glasses of colortrac and a bunch of disks. Bought because I hoped that there is already a sewn-up session to increase the energy potential, and the wheels Patrushev (the same endorphins) - too close in purpose to this. And then with great surprise read messages from You, Andrey, and Dmitry and from other users Mandarin whose energy and recharging it should be all right - there are still problems and fatigue...which mindmachine not be solved, and then suddenly miraculously solved now neopredelennii the parlor...what's the catch? why?
PS sorry have not had time to study the forum, maybe the answers to those questions where we consider...
Татьяна-Эльфа
Post by Татьяна-Эльфа » Fri May 01, 2009 0:41
I'm from Munich. Products FACE use since 2004. I will share some impressions. Imagine you emigrarea in another country, you are over 40 and your education nobody will recognize, even though you are behind two of the University. And really want to return to your profession in a foreign country. One way out to go again to University and finish it with good grades because they affect the possibility of employment. But apart from that we have to work to pay for accommodation and tuition fees. Load crazy. I was in a situation to work two jobs and attend school at the University of Munich (there are no distance learning). I had to work 16 hours a day (and I'm not 20). To sustain such a regime and not break helped me Svetlitsa-Super. When a large mental load stuck to the hair. The head shone, come creative thoughts. Those interested in details, reply via email tanja1757@mail.ru
Post by Гость » Fri May 01, 2009 2:24
Good night to all of the branches of the discussion!
The question is still more the author of the parlor, though perhaps someone from the parlor owners can share their experience and/or authoritative opinion.
The question is:
want to buy Super and Good. There is one caveat that I want to clarify before buying. I always carry a chest amulet made by individual order and privezeny of Indian places of Power, loaded, special. under me. (In sensual terms, feel its energetic effect is strong enough the subject). The question is whether and in General, can Svetlitsa "in conflict" with my amulet, Yes, or in principle any other such charged thing? Or possibly synergetic effect, as with the two parlor? For example, the amulet is charged under a certain direction, for example, "to protect the" possible conflict or suppress the action of the amulet (because the action of the chamber aimed at harmonizing/normalizing)or, conversely, reinforce one another?
Help to understand! The answer may not only I will be useful and interesting. :)
Карил
Post by Карил » Fri May 01, 2009 17:08
2 ASD
Why the parlor is the active side, and products of Infotech no. I asked the club KIT is there a difference which side is closer to said there is no difference. But the principle is the same. So who is mistaken Infotech or FACE?
I would like to get a detailed answer, as I will try to ask the same question to the Director of the Laboratory Infotekh with your comments.
Артур888
Post by Артур888 » Fri May 01, 2009 18:46
People , and what is WAY . Is that a sticker on the devices or what? It carry ? how are you ?
Артур888
Post by Артур888 » Fri May 01, 2009 19:00
Hit me with this phrase in the description.
After using the device Mode (e.g. on the phone) people have a normal glow, fade breakouts aura. This indicates a positive influence on people device Way.
And how it is used on the phone ? So this sticker ? Or did the locket ? Please clarify.
Артур888
Post by Артур888 » Fri May 01, 2009 22:00
And if that sticker , it means it saves only one appliance . From that to which it is attached will ?
АСД
Post by АСД » Sat May 02, 2009 3:23
Гость wrote:Good night to all of the branches of the discussion!
The question is:
If Your amulet is acting beneficially on your structure, the effect of the FACE products will contribute to strengthen the action of the amulet, and a possible synergistic effect. If there are some hidden conflicts your amulet with your structure, then conflicts will be neutralized and removed, as the main effect of the use of products LIK - normalization of the manifestations of Your true structure.
Example: I was visiting in a family, recently returned from a trip to Tibet. Let's call them He and She. She showed me the stone that she found in the mountains and with whom to interact. Proposed to measure the aura on the GDV. Made 2 measure. To communicate with the stone and after 20 minutes of dialogue. Found a decrease of the luminosity by 30%. It turned out, the stone gives the energy of the hostess, but she is nice as there is some redundancy of energy at the time. Svetlitsa - Super shot stone effect, correct defects in the illumination.<
АСД
Post by АСД » Sat May 02, 2009 3:33
Карил wrote:2 ASD
What about the principle of action is a separate question. The phenomenon of using a single structural shift. Perhaps infothe call it otherwise, because in this region there is no uniform terminology.
But electricity also can be considered as one phenomenon, but many implementations. You can do light, can heat, can communication, it is possible the water pump....
The same with the phenomenon of structural shift. There are many possible technological implementations.
To illustrate: in an AC circuit, the polarity is not important, and in the DC circuit - schematic.
