Theta meditation
Post by Guest » Tue May 19, 2009 10:07
Going forward
self-hypnosis specifically,but not Svetlitsa :)
Идущая вперед
Post by Идущая вперед » Tue May 19, 2009 10:30
[quote="Guest"]self-hypnosis specifically,but not Svetlitsa :)
I also was totally skeptical until I try....
hranica and then acts.... :D :D :D
and still I'm consumed with a terrible curiosity - what's inside the :wiz
Просто_идущий
Post by Просто_идущий » Thu May 28, 2009 14:27
the PLANE wrote(a):
Andrei Patrushev wrote(a):
Series Theta Meditation can not be combined with mindmachine, because it has its own rather complex matrix of binaural beats. It can listen on a normal player.
Can, or should, listen not only on a MM?
Drives absolutely safe, so can mindmachine will only interfere with the operation of the matrix on the discs, so needed.
Hello, Andrey!
But if combining the session on mindmachine with Your discs without audiostrobe, completely lower the volume on MM, it remains twinkling of glasses and the sound from disk.
So you can listen? There is no conflict with the matrix disk?
Post by Андрей Патрушев » Thu May 28, 2009 21:47
Просто_идущий wrote:
the PLANE wrote(a):
Hello, Andrey!
I do not recommend.
Дмитрий В.
Been thanked: 2 times
Post by Дмитрий В. » Sun Aug 23, 2009 20:32
Andrew,
ie, the player generally must be disconnected from the MM, and to include headphones straight into the player?
started listening to Deconcentration.
I am deeply sleep under the disc, worse than a knockout in MM.
Is this normal? Do they work?
Post by Андрей Патрушев » Mon Aug 24, 2009 14:48
Паскаль wrote:Andrew,
It is not about that. The matrix of frequencies on the disk does not coincide with any session at MM.
Паскаль wrote:started to listen to Deconcentration.
Yes, it's fine. I would advise Deconcentration in disorders of natural sleep, but it certainly can't cover all the reasons...
Listen to sitting with a straight spine in Lotus, or to the feet exactly relied on the floor...
Дмитрий В.
Post by Дмитрий В. » Thu Sep 03, 2009 9:11
affirmations can be set before the hearing.
Post by Андрей Патрушев » Thu Sep 03, 2009 13:00
Паскаль wrote:affirmations can be set before the hearing.
Completely. :)
Алив
Post by Алив » Mon Sep 14, 2009 2:49
But if lying?
Алксндра
Post by Алксндра » Sat Oct 10, 2009 3:34
Андрей Патрушев wrote:the Scheme is simple:
- deconcentration;
- lucid dreaming;
- hypno-TRANS;
- creative visualization;
- concentration.
For 15 days on disk. In the second half of the day (in any case not to drive a car with a driver) and no more than once per day.
Hello, Andrey!
How to change this scheme with the advent of a new theta-meditation "Journey through inner worlds"?
:wink:
Константин АКА Аватар
Post by Константин АКА Аватар » Sat Oct 24, 2009 4:11
Andrei Patrushev
is it possible to combine the use of the device Alfaria listening to the first track of the CD "Journey through inner worlds"? I.e. to cause simultaneous stimulation of the right and alpha and theta rhythms of the brain?
With respect, Konstantin
Post by Андрей Патрушев » Mon Oct 26, 2009 15:03
But if lying?
Though standing... :)
Post by Андрей Патрушев » Mon Oct 26, 2009 15:04
- deconcentration;
- lucid dreaming;
- hypno-TRANS;
- concentration.
Hello, Andrey!
:wink:
Hello!
No way. :?
Post by Андрей Патрушев » Mon Oct 26, 2009 15:06
Константин АКА Аватар wrote:Andrei Patrushev
It makes no sense. Will the mess in my head, not the stimulation... :?
Иван83
Post by Иван83 » Wed Oct 28, 2009 22:24
interesting render someone better with the help of "disk imaging"? I have no campaign at all.
Иван83
Post by Иван83 » Wed Oct 28, 2009 22:27
Even the guide had not held me nowhere... Shame... :( Already started to hear voices from different sides and safely dismantle them. just information in 2 times more and all. but visualization is not.
Post by Guest » Thu Oct 29, 2009 0:59
Иван83
But as memories of dreams? This should be an indicator of alpha.
Ideas visualization is not the appearance of the image grained nor any of this. This feeling immediately from all restriction of the senses, just ordinary people dominated by the vision... Visualization occurs when you fall into a partial trance, roughly in dram, when the dreaming is there you take them before the consciousness passes out and pull - ie you have to pass a certain stage of relaxation. The fact that you're analyzing the voices, so that you don't relax enough. In auditory training is the criterion for relaxation of coolness in the forehead. So to achieve it without the complete relaxation of the muscles of the body and face is impossible, and when you are to this extent - you nesostoyanie that either analyze only registrovati availability. Pay more attention to relaxation, and aboites'll just fall asleep. In the beginning you'll povalyatsya to sleep then not rasslablyatsya enough, but modern you will be able to balance on the verge of sleep. And after a while cause the render state with a partial relaxation of the body - when Alfa will is gained by so.
Good luck! Keep us posted, and if you find some trick - share, please. Suddenly someone will help...
Иван83
Post by Иван83 » Thu Oct 29, 2009 1:17
I'm just relaxing to a state of weightlessness. This is no problem. And the fact that fall is for sure... the Dreams I can't remember. The fact that the disk Explorer it works I feel, but my goal is different... It is a visualization. I feel like I'm in a trance (or omitted Spis or not) but all dark. And you try vpitat information when two parties say different things... I personally can't. And the TRANS can. but it is dark and not interesting.
Post by Guest » Thu Oct 29, 2009 9:16
If dreams do not remember, not the fact that you are not rendering, is that person a month is beating, and nothing, and then remembers vaguely that this month that was out, Yes, but he doesn't remember. The accumulated alpha wave should serve as a bridge between different States of consciousness and the tunnel of the subconscious( theta waves) with Awareness(sorry for the pun, is bysh to beta waves). Otherwise, either you live a double life and this nidulariales or exit from podsoznanie.
Try to listen to the session to alpha waves(not necessarily only on them. can and the mixture of alpha and theta, and any session, but the OS - still the composition is almost the same, just the name is the Sauce) Try it at night in bed PRAMO photoreductive to either(at the classics on the tip of the nose, nidubrolu, the tip of the tongue - are so important), it is important that you feel than the focus(visually represent inappropriately). Five minutes in the evening worth it as a half-hour in the morning and usually in the end subconscious is trying to wash you into sleep... posprocessing a little bit... And somewhere in weeks two to four you have, by far, with one hundred percent probability, will appear to shift with visualization. The main thing here is trying, sooner or later should get. While no recipe for success in this does not exist( to the above exercise is not the case - too it is simple and General, proven Patanjali, to speak).
Good luck!
Post by Андрей Патрушев » Thu Oct 29, 2009 13:35
Иван83
But as You have obstat things with images at all? What happens, for example, when You remember, what a child You had a favorite toy? :)
Иван83
Post by Иван83 » Thu Oct 29, 2009 15:15
Andrei Patrushev Yes, I just remember them all. I probably dominiruet Snezana. I know it is not clear where.
Guest I alpha 3.5 months listened. Wanted to Teta go, Yes mm is broken. Something with the plug.
Ахнаф
Post by Ахнаф » Sun Nov 01, 2009 17:41
I would like to clarify the following question. I ordered and received the CDs theta meditation - 5 pieces. When they began to lose (the use of laptops), I saw that at the bottom left (where the inscriptions are in the playback) when setting any of the five CDs theta meditation is the inscription "Giprotrans", every disk is written in different names (well, as it should be in the book, Visualization, Concentration, etc.) Is that I is all the same put, wrong, confused? Or is it as it should be and you have to believe the inscription, which is on top of the drive, and does not come out while playing? Huh? bc :wiz
Post by Андрей Патрушев » Sun Nov 01, 2009 17:59
Ахнаф wrote:I would Like to clarify the following question. I ordered and received the CDs theta meditation - 5 pieces. When they began to lose (the use of laptops), I saw that at the bottom left (where the inscriptions are in the playback) when setting any of the five CDs theta meditation is the inscription "Giprotrans", every disk is written in different names (well, as it should be in the book, Visualization, Concentration, etc.) Is that I is all the same put, wrong, confused? Or is it as it should be and you have to believe the inscription, which is on top of the drive, and does not come out while playing? Huh? bc :wiz
On the basis of the recording method of disks, most likely, it is still only Giprotrans... :cry:
Post by Андрей Патрушев » Sun Nov 01, 2009 18:03
Иван83 wrote:Andrei Patrushev Yes, I just remember them all. I probably dominiruet Snezana. I know it is not clear where.
Well... :? Do You remember their sense of touch, the sounds they made, the smells, the color, the shape? Which is better? What non-visual parameters helps to better remember visual?
Ахнаф
Post by Ахнаф » Mon Nov 02, 2009 4:52
If it's all Giprotrans, we would like to replace. How to do it? :oops:
