Advice from Andrei Patrushev
Post by Guest » Wed Nov 26, 2008 0:47
Andrei Patrushev
Class! :D I feel that my spiritual development is envisaged rapid leap forward! I like everything! Super site! :ay I really want to try it out for yourself. Quickly! Tell me Andrew, do You have a dealer in Kiev (I mean mm, such as discs can be purchased in Kiev)? With gratitude, Natalia :o
Андреич
Post by Андреич » Wed Nov 26, 2008 11:33
Brought discs.
Explorer.
Massage of the brain.
Ultramesh.
The endorphins.
Listened yesterday the Explorer before bedtime.
Followed the recommendations on the cover and website.
Only the headband was not worn.
Nothing unusual felt.
Maybe I should change something in the technology of listening?
Or you get the result after some of the auditions?
Евгений Кош
Has thanked: 2 times
Been thanked: 2 times
Post by Евгений Кош » Wed Nov 26, 2008 11:42
Андреич wrote:Or result appears after several auditions?
Yes.
usually the first time the mind is very curious :)
Дмитрий Игоревич
Post by Дмитрий Игоревич » Wed Nov 26, 2008 12:34
Hi Andrew!
Please help to chart the audition.
According to the forum it would be good to listen to CD's "Explorer" and "Healing" to begin. Right in my case also?
Is it possible to listen to one disc in the morning and another at night?
The best time to listen to each disc?
Or more correctly, to listen to one disc (how many days?) then take a break (how many days?) and listen to the second disc?
Briefly:
Are learning a foreign language, PhD thesis, present physical activity in the form of exercise several times a week. Disk Heal: Scoliosis, Allergy-atopic form of asthma.
Thank you for your answer,
Варя
Has thanked: 3 times
Post by Варя » Wed Nov 26, 2008 12:43
Андрей Патрушев wrote:
Варя wrote:
Андрей Патрушев wrote:Tips to give immoral...
And even immoral to eat alone. :evil:
If it's about me, I can't afford to choose a stranger to his fate. :? I and so all I could have shared... :)
God is with You, Andrey Vadimovich! It was the innocence of a flood. Just added to the list immoral: to give advice and to eat alone. :oops:
Андреич
Post by Андреич » Wed Nov 26, 2008 14:55
Yes.
Okay, thanks, will try later ))
Post by Андрей Патрушев » Wed Nov 26, 2008 16:46
Дмитрий Игоревич wrote:Hello Andrey!
Briefly:
Hello Dmitry Igorevich!
You can, of course, and one day to do it, but then to live-when :) (the more diser write)? Listen before sleep through the day each disk (21 times each).
Post by Андрей Патрушев » Wed Nov 26, 2008 16:48
Варя wrote: And even immoral to eat alone. :evil:
:o :o :o
Дмитрий Игоревич
Post by Дмитрий Игоревич » Wed Nov 26, 2008 18:15
Briefly:
Andrew, thank you for such a prompt response.
1. Does your practice what is the data what is the difference and effect if you listen to a day each drive and listen for 21 days then the second one?
2. What drives the development advise after this?
Last edited by Дмитрий Игоревич on Sun Nov 30, 2008 11:23, edited 2 times in total.
Светлячок
Post by Светлячок » Sat Nov 29, 2008 1:25
Hi Andrew! Thanks for the reply :) After reading the forum,has postponed the Massage of the brain and decided to start to work with a Guide.Today was the second session-feeling great!Total relaxation of body and asnos consciousness!
Thank you for your work! :o
Андреич
Post by Андреич » Sat Nov 29, 2008 12:10
Greetings to all!
After three auditions have noticed a positive change:
increased performance (although the installation was done by another).
But the meditative state when listening is not felt.
And so you want...
Андреич
Post by Андреич » Sat Nov 29, 2008 14:43
Once went to a booze ))
Andrew, there is a question:
Work involves constant meetings.
A lot of information.
Of course everything is recorded.
But I would like in the realtime mode to drive voice information in memory for immediate use.
Whether in this connection a positive effect, if I in one ear, insert the earphone-plug in and turn on all-day track "Super training" disk "Ultramesh" ?
Will the effect of "monopressure" (through one ear) and will not burst if my head from such a listening mode?
Гвоздь
Post by Гвоздь » Sat Nov 29, 2008 20:02
Hello, Andrey. After reading the forum I had here a question: whether the reduced action drives, if you listen to them through a normal player with headphones, and not using a mind machine? if so, how?
Евгений Кош
Post by Евгений Кош » Sun Nov 30, 2008 1:41
Андреич wrote:Once went to a booze ))
do you think that voice information is not remembered by you? :)
explain what it means "immediate use" of the sounded information.. it is not clear how it can immediately ( literally in the same moment) to use. ?
Post by Андрей Патрушев » Sun Nov 30, 2008 12:26
Гвоздь wrote:Hello, Andrew. After reading the forum I had here a question: whether the reduced action drives, if you listen to them through a normal player with headphones, and not using a mind machine? if so, how?
In addition to Endorphins is almost not reduced.
Post by Андрей Патрушев » Sun Nov 30, 2008 12:31
Briefly:
1. There is no difference. The optimal mode (in terms of training) to drive and mindmachine - two days on the third.
2. The ones that get You the most relevant. :)
Post by Андрей Патрушев » Sun Nov 30, 2008 12:34
In one ear useless and colleagues may not understand. :)
Just go about with the alpha-relaxation and the 2nd track from the disc space wanderer (in the morning instead of coffee) and soon notice significant progress in this issue.
Андреич
Post by Андреич » Sun Nov 30, 2008 13:23
Евгений Кош wrote:which means "immediate use" of the sounded information.. it is not clear how it can immediately ( literally in the same moment) to use. ?
This means that I would like to use in the analysis of the information received five minutes ago, an hour and six hours ago.
Given the amount of information, not all information on time involved in the analysis.
Андреич
Post by Андреич » Sun Nov 30, 2008 13:27
Андрей Патрушев wrote:engage with the alpha-relaxation and the 2nd track from the disc space wanderer (in the morning instead of coffee) and soon notice significant progress in this issue.
Where you can read about the alpha relaxation? I don't know what it is.
Гвоздь
Post by Гвоздь » Sun Nov 30, 2008 13:38
And Endorphins principle will be useless without a mind machine, or some action will be?
Евгений Кош
Post by Евгений Кош » Sun Nov 30, 2008 15:42
and.. well, my concept is - "in the future" :)
Andrei Patrushev gave the answer - the alpha pump .. ( and be sure to remember to call it in any moment).
As pump - will feel that in this state and is thought of differently and different ideas became more :)
Дмитрий Игоревич
Post by Дмитрий Игоревич » Sun Nov 30, 2008 16:47
Андрей Патрушев wrote: Hello Dmitry Igorevich!
1)
If you listen in the morning in this manner:
1 day Explorer
Day 2 healing
3 day massage of the brain
and so the cycle
It turns out each disk on the third.
Efficiency how to change? What do you think about this scheme?
2) the CD "brain Massage" completely replaces the "Star traveler" and largely replaces the "Endorphins" + "Ultramesh" judging by the description and reviews on the forum. Understand correctly?
Again, if it is of benefit to the scheme outlined above.
Post by Андрей Патрушев » Sun Nov 30, 2008 17:12
Дмитрий Игоревич wrote: 1) If you listen in the morning in this manner:
1 day Explorer
Day 2 healing
and so the cycle
1. Normal mode.
2. Yes, there is such effect, but for some without the preparations the Massage of the Brain is given a bit of a nightmare...
Post by Андрей Патрушев » Sun Nov 30, 2008 17:14
Гвоздь wrote:And Endorphins principle will be useless without a mind machine, or some action will be?
Of course,the effect is,but the difference, according to the observations, significant.
Post by Андрей Патрушев » Sun Nov 30, 2008 17:17
In the"Articles"section are my guidelines. Alpha-relaxation - all session of "r" and session i2.
