In the gut there, although something people can do things with a positive effects(In the skin, but her condition is strongly associated with the liver, like. Also know that one expensive BAD Betulin made on the same birch bark and very good. works well on the liver.). But some of the info was about carcinogenic possible from raw. On the skin a pimple cauterized somehow. Fungal, apparently.Аиша wrote:tar And no one tried
Small offtopic.
Re: Small off-topic.
Remember. I then presented a bit overdue for the sealing oil. So its in the inside too is filled, except for the use in massage with osteochondrosis, and You still spoke about the work of St. John's wort as MAO inhibitor. In oil for massage it works, don't know?Михаил_ wrote:as a "massage oil"
Andrew, thank you. Yesterday launched. Watch)).Some time before the next time point is included the thought process for a given trend. And somewhere in a minute appear in front of me watch, Recalling that this is it. + other resonant amenityАндрей С. wrote:I Have, incidentally, is the script, which the case said.
http://s-a-p.in/time/calc.php?start=09.10.2014 14:30&coef=60
You need to specify the start parameter (the desired date and time zero point) and ratio (it depends on the duration of time intervals).
Can be used not only for solitaire, of course...
Not for that. By the way, how do I then correctly pointed out, the number of steps on the rise-a rollback may be another, and the wave can be configured under each situation separately... But I was too lazy to code it
"the Druid was almost right. It was a rat. She chewed a hole in the net."
"well, I had this idea... but I dismissed it due to the fact that the bugs you described as lapsed into a coma - it's funny, it means they have it turned on when natural removal of common fields."
Two quotes of Andrew and Michael with OM.
Are you sure that it's a rat?
I'm not.
The thing is, I had the same! And not just me.
Did not write, did not betray value.
The boxes are on the shelf.
I have one box two pieces of bread ended up on the floor, but not under the box (fell), and much to the wall. Doesn't look like a natural fall..And 2/3 going back to the bread and hung out there, and 1/3 lay unconscious nearby and showed no signs of life. The bread I brought back, but the bugs from the floor are not collected, thought died..
Petrovich had moved the whole box Assembly, meter and a half. He does not read the forum and some effect (suggestion) is excluded.
Called - laughed.
Once went to a booze, I have sinned in your kitten's "the Martian" which. Rat and mouse droppings, "the bites" carefully watched-nothing. Cats and I were not allowed categorically.
And boxes with beetles always fresh the bread is, bran....don't want to eat..Well, what a rat to do there.
And sometimes from the air as the beetle appears, and creeps along the arm for example..times 3-5 so it was ( in a completely different room or car).
Tomorrow Petrovich asked with passion, he noticed.
According to the food.
Eat fresh raw corn, but it must be cut longitudinally to open the seed end. Then a pair of beetles burrow in the seed and eat it from the inside, and now cob has finished. And they really like peanuts a little bit muffled, especially the larvae.
I'm not.
Called - laughed.
it was definitely a rat, because Andrew was pribil
teleport bugs I observed on his hand... so that one does not exclude the other.
Well... maybe my mind very much wanted to find a materialistic explanation
Владмосква
- Has thanked: 1 time
- Been thanked: 7 times
and teleportaloo a rat in the roommaybe my mind very much wanted to find a materialistic explanation
Eugene-M, and You have a box with a mesh/gauze closed? And mesh Luggage elastic fixed?
Called Petrovich, he says exactly move the box. Rarely, but it happens. And certainly not on a meter and a half, and less, as the kitchen is quite on the micro-Khrushchev.
And all of this activity was to solitaire. (I have it)
A spontaneous appearance on the hand or the clothes - I.
Vladmoskva no I have them airing out with the lid open, and closed at night with plastic. The bread ran out in the afternoon, the lid was open.
I have in each box is formed by boiling. This is a local field, usually under a piece of bread, which is just unrealistic movement of larvae, young, bright and black.
Time was such - in box 2.1 all larvae rise up and live sand cover everything - bread, cucumber. So tight that shows only the living surface. And black is not, apparently buried in the rice.
There were a couple of times(the period of use is small), but after my direct contact with the bread with them. While associated with the fact that I did not notice the crawling.Евгений-М wrote:And the spontaneous appearance of the hand or the clothes - I.
And not one, although not under each piece. I have one black.Евгений-М wrote:I have in each box is formed by boiling. This is a local field, usually under a piece of bread, which is just unrealistic movement of larvae, young, bright and black.
Another observation. They quickly and creatively remade the surface of the space habitat - moved the "plates" oat flakes on ribs. Elevator-type box for easy descent into the bottom in the maternity section.
It is clear - children sometimes "get it"Евгений-М wrote: the larvae rise up and live sand cover everything - bread, cucumber. So tight that shows only the living surface. And black is not, apparently buried in the rice.
It was observed that )) my Mom also missed one apparently on a Bathrobe, got into hair and were busy all night. In the morning his mother found in my hair. What is the teleport, when they themselves might fall out on clothes for example ..and allФилиНН wrote:Been a couple of times(the period of use is small), but after my direct contact with the bread with them. While associated with the fact that I did not notice the crawling.
Fact, by the way. Received that info, what individuals out of a population fall into suspended animation.ЛИЛИЯ-Р wrote:Mom also missed one apparently on a Bathrobe, got into hair and were busy all night. In the morning his mother found in my hair.
The human biofield is prevents may... Replaces the mother(population) native.
I think I have a clue.
I have a rack. On the bottom shelf are containers with beetles. And on the top shelf Stabilizer, and exactly on the container where "escaped" bread. Vertically is obtained between 30-40 cm total.
The room "Reilly" - due to the stabilizer including, for nobody wouldn't start.
Could this be the effect? Something I never thought of it.
I'll keep looking.
Okay, how to explain that they appear in the machine (the arm which they rule) when parked coming from work? I mean what also thought that they're hiding somewhere, for example in the hair, and then are born. Although creep in the care is the place to be every day.ФилиНН wrote:Been a couple of times(the period of use is small), but after my direct contact with the bread with them. While associated with the fact that I did not notice the crawling.
I'll keep looking.
Well, I can answer for their cases. I always have it very "soon" after contact and not more than a couple of meters from the box. (Box panaceia\You, too tough\. Here's another caveat is perhaps a greater influence private teleport "vzbrykov".)Евгений-М wrote:Okay, how to explain that they appear in the machine (the arm which they rule) when parked coming from work?
PS Now tightly work contact method, and noticed suddenly feel the running bug and immediately in the middle of a hand and how he got here - no. And the top could not fall. Flew off and was not seen or ... ?
And my mob.-the stub is also higher, at 30 cm, slightly to one side.
Everyone is trying to explain his race...... miracle? My mom also drinks them, so she'll empty out bread on the table and on the floor and the Bathrobe...and even when drinking, apparently not all swallows, PEP is probably out...... That's the whole key. Some fly with wings, but they are few .Евгений-М wrote:....
I'll keep looking.
A correct and not abusive word - carelessness.ЛИЛИЯ-Р wrote:to explain his races...... miracle?
In short they had a science experiment:
1) Get off with a flashlight under the shelves and have collected the "rotters" who spent no less than 2 months.
Considered 14 pieces. First came alive when I scraped off a strip of sheet metal from the floor, drunk as he was Kruglyi macrogel to another and woke him up. All put on new, clean bread. It took 3 hours - only 2 dead. Others apparently alive.
Conclusion perhaps this quality can be used for long shipments?
2) Experiment with HF puck (am a few days).
The old containers where the place of power (the melting pot) has formed the premise of the HF washers in one case, gave a moving party under the washer, the other not.
Today settled out of black in a new container, after 2-3 hours, all gathered under the washer and began to boil.
Razdolbaystvo nothing to do with the miracle, too. Frogs, toads are more precise (I described this story) I was sick from the well at the time to bail out... and read about them teleporto-abilities in the network after. Yes, and Valera said. Well, they really were including me in the clay not a breakthrough that layer of stone, with stones, scrap this layer of beaten egg in there in the cavity and in suspended animation.
Bugs story - in the middle of his hand, he found himself exactly when I'm in a topic about the bugs climbed and think about them unobtrusive. And the boxes in another part of the house. There far. I was there 2 days at that time did not come. And bathed/showered. And where he had me sit to on hand to get Yes even in the middle of the palm, which I type on the keyboard???? ( well, in the sense of not the palm side, the back top he was sitting ).
ABOVE the HAND in this position, there are no objects including my head. Out of the box in normal mode they don'T CRAWL out (do not know). But by the way, when I arrived and made an inspection box which was without me and stood in another place - there is next to and under it a few dozen bugs found as it shook inside, was alive... I even thought that as long as they don't come out... and if you want it probably can...
don't know about beetles, but that was the last one in the bag, and there are somewhere with all...of the matrix teleport, but reached into the bag , buy ASD mothers had, and there in that place, 5 tyrov.
Or am I a klutz or something like that....but it certainly didn't and only one piece of paper had to be a thousand))))Well, if it's teleport , then okay. So I will train on.)))
Why the beetles can be mass-die? I have 4 containers tipped over in large numbers...suspect that could poison rye bread, not very natural, and can partially suffocated... my containers are closed with plastic caps with holes, plus the containers of the hole, now opened fully, the plague continues... the Worms feel comfortable. No mold. Live in wheat bran finely ground (like flour) with cereals, and even two weeks I didn't give them vegetables and fruits, can this lack of impact?
I'll try to put capsized in a separate container, we'll see what happens.
From suffocation (larvae can too) / by the light of day
From malnutrition.
See no other reason (well, from age if they are all the same age)
From malnutrition.
Thank you)) Probably age. Still watching the moisture. Worms was created by heat in a closed container and it gets fogged, I was a couple of days, when opened the smell was powerful, they all live there with the bugs and it seems to have dramatically multiplied/increased . This was done several times in the same container, forget about it. In the end had to leave it open for a long time, since the whole substrate was soaking wet. Dried properly, mold did not appear, life is not faded. Now there are a lot of worms.
PS
The woman I took recommended your method against pain, to chew the beetle, says a great anesthesia.
PS
I expanded a partially closed - better to reproduce and Yes, there is heat directly from the maggots ... but there were many bugs with the bad nacrelli and I thought it was a moisture problem (although most likely all of the modifying events).
About the tooth/ pain - thank you, I hope I won't, but confirms different thoughts - in particular to try different versions of the tincture topically and externally....
Bread in Russia the problem is, even officially recognized that no single plant could not do the flour according to GOST. Everyone is doing some kind of approximation. The reasons are many, it is not for this topic.ПиАр wrote:poison rye bread, not very natural,
On the topic, "rye", "Borodino" and so it is filled with chemistry, be reasonable and accurate.
The second source of threat to all grain now 100 percent infected.
Pick up "bread" more or less safe, at random and without uluchshayzerov.
Probably need to try to make bread from the same spelt himself?
ПиАр wrote:Worms created heat in a closed container and it gets fogged, I was a couple of days, when opened the smell was powerful, they all live there with the bugs and it seems to have dramatically multiplied/increased . This was done several times in the same container, forget about it. In the end had to leave it open for a long time, since the whole substrate was soaking wet.
There is and I have. The weight they generated very much.ПиАр wrote:about two weeks I didn't give them vegetables and fruits
Fruits - water beetles and larvae. They should podvyalit, but give definitely.
And to experience the best of down pour on the thickness of a finger round the Krasnodar rice is a desiccant and the "cat toilet" is beautiful.
PS. Regarding the teeth. Petrovich has taught me to "milk" beetles, bread beetles and raise the language. They shoot at him, the secret language of numb for half an hour. Teeth similar principle I guess. Local application we need to explore, it is a pity that the usual intermediary alcohol (tincture) is not suitable here.
look at all there bugs out of the box emerges
I have two weeks ago there was a case, I really value not given, at night I closed the box with gauze, covered with a lid and sleep.
This morning took out a box from the drawer and notice that the walls of the box are a few bugs and can barely move, well, I have them back in the box and will throw, they immediately fled. Yes, and beetles these are not modified
