Inside, of course.Михаил_ wrote:or inside?
Small offtopic.
- Has thanked: 1 time
- Been thanked: 182 times
Re: Small off-topic.
The growth of the population will begin selling modified beetles healers.
Wishing to acquire, place pre-orders on the website http://juk-znahar.club/
See, in more detail.Михаил_ wrote:that their radiation I1 or rather water them-structured - killed...
Country attic, wood covered with an iron roof. Two Windows in the ends between 7 meters.
Operator 2 meters from one window 5 from other means.
For radiation - do not interfere-axis "window", and the top even reflects.
But, as I understand it, the effect only occurs when there is a response of the organism through the pain (effect). And it turns out after taking the charged water (inside).
The same garbage was when I treated dogs from piroplasmosis mites. I just didn't pay attention apparently.
The engorged tick-gingerbread man
Very interesting... and appropriate, thank you, this time !
Eugene-M Ie , the tick got? So he survived, or simply "lame" ? Beetles were dying from And-1 , although they are in the room in the closet , the door ajar a little for air, 2 meters from the place of impact, the fly had flown , too, zivinice fluttered while in the window, not kicked out. What are observations and plants not seen anything strange?
plants and seeds from T1 healthy (and the water from it) - from its creation began....
Here the problem is reverse signal, so I think... not in izuchenii device and STOP what started a parasite or wasp joint forces body+ I1-water and the device.
Michael_ Mike, a strange image after processing with a Mug of ASD and I-1 , there is such a mug
I turned on every phone and a mug to her in the frame does not accommodate, niche failed. Are you not watching? Pictures will show you can not insert)))
By the way the leg from mom almost ...(THUTHUKILE) remained the skin will change completely.
Yes, but why do beetles have wings spread out when standing near the device during processing, if now out of the Cup will fly)))?
ЛИЛИЯ-Р wrote:I mean , the tick got? So he survived, or simply "lame" ?
Apparently so! Ie there is some sort of "return" from the body (the bite is aching, body screaming in pain!) in the processing device and the "tank line" effect on the wasp.Михаил_ wrote:and STOP what started a parasite or wasp joint forces body+ I1-water and the device.
Again, the example of the tick. With the dog already took let's say 5 ticks, she lies on her side, drank water, drive the antenna in the wool.
The process goes flying.
And then find the sixth, bumped into him. It's the bun. Start above it antenna to work, it moved. Take out, hold in my hand as much as he moves..And the unit is humming fan, shows all the body is ill or bleeding.
A tick is the same bun blood sick sucked.
Then of course I just stepped on his.
Pro OS.
It took 2 days left bite marks OS. Nothing is swollen, in the morning itching is typical. Put device, well as usual the warm light is, but pain is not natural. And it was such as a lighter burned.
Over the beetles did not drive, they are in another room entirely. But best of all beetles living in boxes 2.6 and 2.2, the stable effect, I wrote about it.
Taking the opportunity a question about Zhukov Modified®.
It turns out that I need to buy at an occasion 300-500 beetles-producers to improve their population?
Владмосква
- Been thanked: 7 times
mine live in boxes with P-labels and are more active and cheerful than individuals who grew up in the normal boxes. And multiply very quickly.best beetles live in boxes 2.6 and 2.2
Eugene, and box 2.2 how You doing? Cards transfer?
2.2 (or 2.1 I have confused myselfВладмосква wrote:how do You make box 2.2? Cards transfer?
2.6 transfer.
Experiment clean.
Brought beetles in the same container, and were seated in different including 2.1 and 2.6
So that's where the sticker - there is simply boiling all of the larvae in the transfer of 2.6 they run like mad there
the same CHS
But carrots are not eaten.
Eat zucchini, but sluggish. The cucumber here is the food!
well, the photos in the mail to send ... me for example ...ЛИЛИЯ-Р wrote:Michael_ Mike, a strange image after processing with a Mug of ASD and I-1 , there is such a mugI turned on every phone and a mug to her in the frame does not accommodate, niche failed. Are you not watching? Pictures will show you can not insert)))
well that helped her, I am sincerely glad...
device for and made to help people.
beetles fonit probably / possibly including statics, or rather aspects antigrav... activation of the wings is...
have a look at your leisure....
Владмосква
1) Conventional and modified beetles to the mix is not necessary.I need to buy at an occasion 300-500 beetles-producers to improve their population?
2) modified the Population of beetles is not recommended to drop below 200 individuals.
come home - and there I see a levitating bugsaspects antigrav
Vlad, and you can read more why not to mix?Владмосква wrote:Conventional and modified beetles to the mix is not necessary.
And about the number too. Comment.
Clear. Mom thank you very much.Except the feet of some other points of improvement have emerged. Hair to dark steel gray)))and darker than their relatives. Joints ache ceased, and the cold comes out fine. In combination with ASD, in General, all is+++++++Михаил_ wrote:well, the photos in the mail to send ... me for example ...ЛИЛИЯ-Р wrote:Michael_ Mike, a strange image after processing with a Mug of ASD and I-1 , there is such a mugI turned on every phone and a mug to her in the frame does not accommodate, niche failed. Are you not watching? Pictures will show you can not insert)))
Владмосква wrote:1) Conventional and modified beetles to the mix is not necessary.
The retreat, found on the OM response.Евгений-М wrote:Vlad, and you can read more why not to mix?
Whom I referring here.
http://openmagic.org/ph/showthread.php?t=166&page=10
Lille, Here is the most valuable experience for I1 on those who have significant deviations from the norm... although in the family I see regularly (despite the fact that everything is good and it is prevention or small street-socialnye Viru, and so passing well with the device - and faster/better)
Good times to treat the LIVER. Including (if no I1) dodecanol (rubbing and every few days compresses for 15-20 minutes).
I have such a treatment (dodecanol) pulled on the skin rash, is clearly not a burn from todikamp and something that got in the impurity processing - this despite the fact that I'm so sickly brushed...
Although there are in General completely normal health valuable experiences...
4 years ago honey massage makes...Also pulled the skin all icky... so 4 years and not passed)) Experience of course, only on the beach did not come outМихаил_ wrote:I Have the treatment (dodecanol) pulled on the skin rashes
no in my case, even very is including the same dodecanol.
By the way I recommend to try (in your case) - external use simpler and more massively than with ASD (as rubbing in massage and compresses) and together with the inside gives a good effect.
ASD topically applied, but it's massively hard/and too strong smell and acrid.
Then softer, but strong internal effect. When mixed with bath ASD - generally good, although there is a problem - not all places have a bathtub (with a shower some where).
Todikamp consumed on empty stomach WITHOUT water (and drinking) the effect was very different and much more powerful than a loose in a small amount of water, but from such a scheme I do not recommend - quite hard.... It's true I did not try, but trust the person who told. I'm just not looking for a too strong cleaning - like and so all is not bad itself works, but the experiments sometimes....
And on the bottle of my Surfraw manufacturer says: "1-5 times per day to apply, not to conceal and not to massage"...Михаил_ wrote: external use of simple and more massively than with ASD (as rubbing in massage and compresses)
Herbalist about the water not stutter, so never diluted with water. However, not much controlled, how long before the water they drink. Need more time working harder...
Recommended 30-40 drops, but drops of kerosene with a different surface tension, I guess. I'm on the water(it's more) tried and "sat down on the syringe"
Burp the first time felt. Especially if the time before meals will not stand.
Well, I focus on the description Method as to the old/proven a huge mass of patients and their personal experience of family (he kept a private reception for many years).
There and ointments and compresses and microclysters ....more(diluted with oil) I'll post later manual although there are answers to the questions on the website there is also there.
Drops I thought - it turns out about the same (also doing the cube its about 80)
Water (a water film) I still Valera taught, when I first tried it.
Well, kids to water easier, and if through the needle quickly into the water -that all the emulsion is almost odorless. By the way, IMHO, cadikovski really cleaned the kerosene from which removed part of factions, so the effect may be different - I smell almost non-existent (it's very weak). H/e/ the first time, he still somehow is, then of course a habit, but really, even when rubbed into large areas (back/legs for example) - almost no smell. As with drink.
And by "other producers" was very odorous burps
I will do my - will clean kerosene required. At least two different methods, I think you need to remove the heavy fraction (oily) and light (fragrant), leave the middle (feels like).
Yes... if you use as a "massage oil" consumption large
- absorbs very quickly and I like the effect on the body is very. Although it is not give - they recommend "small areas" in turn... well, I have and body some do not like the man in the street as of yet...
okay,,, well, the thyroid can think studiocom to podremontirovat....
