Small offtopic.
Алексей Федотов
Friends, I was told that there are cases of forgery of ASD. Tell me where in the MSC you buy a good ASD? The addresses of the pharmacies.
Re: Small off-topic.
Address of the shop "ZOOвосторг" : Moscow, street New Basmannaja, d. 7 (metro station Krasnye Vorota).Алексей Федотов wrote:Friends, I was told that there are cases of forgery of ASD. Tell me where in the MSC you buy a good ASD? The addresses of the pharmacies.
Veterinary pharmacies Vetlek at:
107370, Moscow, open highway, the house 5, building 6.
(20 meters from the metro station Ulitsa Podbelskogo)
105066, Moscow, Nizhnyaya Krasnoselskaya street, building 28.
(metro station Krasnoselskaya, Baumanskaya)
Sites : vetlek and Soulstorm
These precisely tested.
Holographic universe on your fingers
http://sly2m.livejournal.com/611647.html
Interesting explanation, but is it really? I believe that a bit differently.
And what is the role of human consciousness in this player? Then, where are 'records' all information shared in the World and where its borders, well, that I remember was the old space, they say it is nonsense.
So many questions in my head...
If the answers are not for the public part, it is possible for OM to continue.
AVZ-vetzaschita -Moscow m. Sviblovo , ul Kola 1 bld. 1 , the same area that our office only in the main building, in a gray 8-storey. We are there to take Moscow. Armavir there.Алексей Федотов wrote:Friends, I was told that there are cases of forgery of ASD. Tell me where in the MSC you buy a good ASD? The addresses of the pharmacies.
...Андрей Ермаков wrote:Michael, why is it that when solitaire was doing time intervals so placed...
I answered this question at the lecture - there is in the record and it was long BEFORE the solitaire
I actually have a script, which the case said.
http://s-a-p.in/time/calc.php?start=09.10.2014 14:30&coef=60
You need to specify the start parameter (the desired date and time zero point) and ratio (it depends on the duration of time intervals).
Can be used not only for solitaire, of course...
Андрей Ермаков
- Has thanked: 3 times
- Been thanked: 15 times
Respect
I'm Excel did the same.
Александър
- Has thanked: 17 times
- Been thanked: 1 time
Andrew S., I tried to do it in June on the vermin wasn't smart enough, did not happen. Tell me how in a script to specify the desired date and time zero?
Andrey Ermakov, if not difficult throw off your file on file sharing and give a link!
Both Andrew thank you in advance!
As my link indicated in the example and specify.
Андрей Ермаков
Calculation time in Excel, there is no cofficient https://yadi.sk/i/63nfa7cobunMm
In the script, change the numbers in the browser bar (http://s-a-p.in/time/calc.php?start=09.10.2014 14:30&coef=60), in Excel the top cell of column C.
Александър
Guys, thanks a lot!
Hello,
I have problems to find a company that sells the Piezo ZP-1 and makes the delivery to Bulgaria.
I'll be glad if someone can send a few pieces SN-1! I will pay all costs associated with the purchase, shipping and time costs.
Thank you in advance.
Алексей Федотов
Exactly how many pieces have?Бисо wrote:Hello,
Any preference on manufacturers?
And that in Bulgaria, there are no analogues of SN-1?
If for W1, they don't have these to use, you can even instead of one ЗП1 any two pesika, just worked from the audio output.
Hello,Владер wrote:And that in Bulgaria, there are no analogues of SN-1?
In Bulgaria, I did not find analogues of SN-1.
Yes, I want to use SN-1 for W1.
I don't know from electronics and different options and decided to stick to the instructions, courtesy of the Druid, where he used two piezodynamic SN-1.
At some point I was thinking about this: http://www.elcomp68.com/zumer-piezoplas ... urr_arr_j=
Or this: http://www.ebay.de/itm/290956418199?_tr ... EBIDX%3AIT
Well, I didn't want to save or make a mistake and decided to ask for assistance on the forum, regardless that it will cost much expensive.
Feel free to take here http://www.elcomp68.com/zumer-piezoplas ... urr_arr_j=
And tip - don't try to solder to them thick wiring,lived one of the wires will be OK.
SN-1 is worth 5 rubles.Бисо wrote:Владер wrote: Well, I didn't want to save or make a mistake and decided to ask for assistance on the forum, regardless that it will cost much expensive.
Is 5/40 = 0.125 U.S. dollar.
If necessary I'll send the bag though. Give the address in PM. Pay for the shipment and all this spending, I think $ 50 invest.
Although of course the analogues of SN-1 is in Bulgaria.
All right!Алега wrote:feel free to take here http://www.elcomp68.com/zumer-piezoplas ... urr_arr_j=
"SN-1 is worth 5 rubles."
All I found online was from 39 to 90 rubles. I expected that everything will be worth it, as you said under $ 40-50.
If my first proposal is quite suitable for the manufacture of W1, then the cost will be much less. And more importantly, I won't waste time, no one else.
A big thank you to all that helped to resolve this issue.
Again And-1, and wasps.
OSA I've been bitten in the leg, cured by the device, the leg is not swollen, but only itched.
Today is +25C, now Indian summer, came the flies and wasps Nemer. Hot. Wooden house, living creatures rushing from all cracks.
As usual lying on the couch, read the news, again OSA has bitten in naked feet right in your finger..
Well, I routinely poured a glass of water, loaded, drunk, antenna pressed toes and lie. A minute later another water "came" to his legs and bitten his finger began to severe pain if its a lighter tan. The process has begun.
It is usual and normal just say.
But why, after the procedure, all wasps on the window have died? Or rather not quite dead and twisted in agony, lay on the floor and the windowsill.? Pieces 10-20 maybe..
That is the question.
PS. Flies remained.
And now a new batch of wasps came alive and vigorous. And the old krujatsya on the floor.
PS. Flies remained.
Interesting observation. The pain was , even if the left leg is treated , the flow and stabbing to the right. And sometimes on the back, the spine will velesi and bursting with all of the stomach and flows and the pain...not too shabby. But then subsides and warms the place. The wound heals within a couple days , if not much running, bloodstream drives well. Water obrabatyval watched an interesting photo came out. The notion that mothers face, into her area balabanis so someone. The water in the ASD mug loaded , then processed And-1 , the residue at the bottom of the mug photographed. Almost fight, but how? Potala in different modes :color , black and white and in all that there is on Android. The precipitate was zheltokoren , such as metals, white flakes and it all settled by the label on the mug and emerged a terrifying figure. So if it is her , I don't even want to call it, then treated the mother and stoppage and panacea through the generator . Map OS+ in it ,is BJ 2 2 o C++ , 2 2 , 2.5. Svetlitsa. The second week is already flying, the process has begun, weeping Wounds healed, the swelling subsided, the skin appeared on his leg. But the place where to start all this shit cyanotic. Or that'd been ill since may and she was silent for partisan and its garden served until the fall, and when it blew so Oh can't help. Now , there are already normal skin on the right leg, there are already threads in the leg and warmth. Week almost anything foot didn't feel the leg was like a bubble, fiery hot and sick and mock leather. All that remains now is the skin is thin and senbee spot. But we continue.Hovered in ASD and drank it and beetles, too, and without resistance. After processing I-1 balm Dorogova 10кой, and under the film. Without film balm and ointment with ASD are quick to dry and the skin tightens. In the office we have veterinary on the Kola girls are told, had a client , who myself so the leg was restored ASD and rubbed balm 10ку and under the film.
Владмосква
- Has thanked: 1 time
- Been thanked: 7 times
a new batch of wasps from another nest. And the old party OS - collective organism, "we are many". The action of one affected the others. Well, as the mosquitoes in the woods, the mosquitoes here recently history was written...why, after the procedure, all wasps on the window have died?
But don't laugh.Владмосква wrote:a new batch of wasps from another nest. .
When he wrote about "a new party" - I went and one of OSU glass caught. While caught, she of course bit me in the hand.
Again, standard procedure. Water-the bite. When the water comes - wild burning, now in 2 locations.
The wasp in the glass opposite on the table, watching.
When it begins to burn unbearably like as it also affects it, but it is can not say.
Had the procedure, an hour later, the wasp was dead.
PS. While in places the bites are just red spots, there was no tumor.
more amusing is that their radiation I1 or rather water them-structured - killed...
generally IMHO the wasp - embodiment of chaos (a bee order) and form nests = judge for yourself....
so the water was applied topically (compress) or inside? I don't fully understand....
