Advice from Andrei Patrushev
anux17
Post by anux17 » Sun Aug 28, 2011 20:54
Hello, Andrey.
I suffer from depression for many years, now I drink ESCITALOPRAM, olanzapine. which of Your disks you recommend to listen to? thank you.
Post by Андрей Патрушев » Sun Aug 28, 2011 21:13
anux17 wrote:Hello, Andrew.
Hello.
This drives Endorphins and Massage of the Brain.
But depression is depression different. In Your case you must first consult a doctor. The effect of disks on the background of the adoption of medications are difficult to predict...
anux17
Post by anux17 » Sun Aug 28, 2011 22:11
it's hard to say how competent in this area my doctor. I not long ago she treated and so far all is limited to medical treatment..
Post by Андрей Патрушев » Sun Aug 28, 2011 22:17
anux17 wrote:it's hard to say how competent in this area my doctor. I not long ago she treated and so far all is limited to medical treatment..
Then proceed with caution - listen carefully to yourself. The effect of the disks is not fatal - from one audition takes place no later than three days. Despite positive dynamics, gradually reduce the use of medications. Start with Endorphins, exercise every other day (5-10 minutes to start, then 5 minutes to add).
Алексей72
Post by Алексей72 » Mon Aug 29, 2011 0:47
Андрей Патрушев wrote:
Алексей72 wrote:how to combine them with Healing and Conductor
Yes, it does. Just do all. :?
Thanks for the detailed information!)
But I would like to know more.
She began working with EFT and TAT plus listening Guide and a Healing. Now she observed the following: during the day at work everything seems OK, and in the evening, when he comes and tries to relax, the heart rate increases again. Weekend appears tightness in the chest, slight nauseam, podkrashivanija with expectoration of mucus and increased anxiety. This is normal in her case?
Post by Андрей Патрушев » Mon Aug 29, 2011 0:54
Алексей72 wrote:This is normal in her case?
The cases that are different... do Not all in one heap blame - let him see a doctor.
Алексей72
Post by Алексей72 » Mon Aug 29, 2011 1:22
She went. And not to one. A lot of studies conducted all okay he said. Prescribed a tranquilizer, said it happens, and long may be. Suffering, and the work is very stressful... but sometimes that everything passes, but only when crying (maybe it's depression?..).
Post by Андрей Патрушев » Mon Aug 29, 2011 1:32
Well, pokalyvanie can have many non-obvious (trudnosravnimyh) reasons, such as dysfunction of the bladder or gelecege pinworms...
8590
Re: a Question for Andrei Patrushev
Post by 8590 » Mon Aug 29, 2011 12:02
After a long hearing the discs I got to understand that. Previously dominated by the right eye and everything was fine. But now it's like what's the average eyesight(the merger of the two glahs). what could it be?
домашний
Post by домашний » Mon Aug 29, 2011 18:38
Андрей Патрушев wrote:Hello!
домашний wrote:And if we delay the Conductor and listen every day before sleep, the Healing, would it be too much?
So check... :?
And how to define - too often or not?
домашний wrote:And wanted to ask - does it make sense to listen to the Guide without setting a goal?
Always useful meaning to find something to do something without meaning... :wink:
Yes, it is clear that it is better. But if the goal has not yet delivered, will there be any benefit from the Guide?
Post by Андрей Патрушев » Mon Aug 29, 2011 18:44
home
First of all, listen to yourself - and learn about - the state of health and mood.
Yes, the Conductor, in this sense, self-sufficient - you can specifically target not set.
IRIast
Post by IRIast » Tue Sep 06, 2011 11:45
Andrew, Hello! I have a question about the possibility of listening to music and what about the son? He was 6 years old at birth he had a stroke, eventually diagnosed with cerebral palsy, he can't talk (except a few words, Mama, Baba can pull), understands everything, learned all the letters of the alphabet, not walking alone, sits confidently, the right hand is not working, loves music. Thank you.
Post by Андрей Патрушев » Tue Sep 06, 2011 11:50
IRIast,
Hello!
Mozart's music, jazz.
IRIast
Post by IRIast » Tue Sep 06, 2011 16:27
Андрей Патрушев wrote:IRIast,
Hello!
Thanks for the speedy response. If not difficult explain please why not Massage the brain? well, maybe there are some ways to make the different part of the brain? or is it still small?
Post by Андрей Патрушев » Tue Sep 06, 2011 16:35
IRIast
Massage Brain too hard to bear for kid. You can listen to the second track of the Star Wanderer, but Mozart and jazz are still other components needed for brain development - melody, harmony and surprise.
anux17
Post by anux17 » Wed Sep 07, 2011 19:33
Hello. week how to listen to Your disk Endorphins for 10 minutes. the music I like, but the effect is more negative. today after listening to feel irritable, fight with my wife...
Post by Андрей Патрушев » Wed Sep 07, 2011 19:43
anux17
You disk started to listen to cope with depression (low mood), or out of curiosity?
anux17
Post by anux17 » Wed Sep 07, 2011 20:25
Andrew, both has its place. as I your way can't find a lot of things already tried.
Post by Андрей Патрушев » Wed Sep 07, 2011 21:10
anux17
I mean, this CD along with the stimulation of the synthesis of endorphins, increases the frequency and, in some cases, can increase anxiety and expressiveness. Hence Your result...
Perhaps the Guide might help you to understand yourself. In addition, Greg Bulygina there is a special course http://nlping.ru/p/?id=E417BF48-F46F5-3FBCCFE8 which, at least, can give some momentum in the right direction.
anux17
Post by anux17 » Wed Sep 07, 2011 21:39
Andrew, what frequency the nervous system operates coffee? you know I'm dependent on caffeine and are unable to do anything with it, though I understand that this health is not attached.
Post by Андрей Патрушев » Wed Sep 07, 2011 21:47
anux17 wrote:Andrew, what frequency the nervous system operates coffee? you know I'm dependent on caffeine and are unable to do anything with it, though I understand that this health is not attached.
Coffee affects not only brain waves...
Endorphins or (and) session of machine "Energise" may gradually replace coffee and a bit situational at the same time "racing brain", so that the demand for coffee will disappear... But pay for it (at least in the beginning) will be increased anxiety and expressiveness...
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Fri Sep 09, 2011 20:25
Andrei Patrushev
please tell me which ROM is better to listen to if difficult to concentrate while reading books. Absolutely floats attention, eyes are reading but my head is quite another. And memory problems the last time are concerned, to a greater extent with short-term. Just forget what I wanted to do a minute ago or what I read. And this at a young age, never done that before, on the contrary was surprised by his memory. Immediately after listening to any of your drive, impossible to concentrate, but after day 3 to be better than it was, but then again it all comes back. Recently completed a course Conductor, I suspect that now you need to listen to the Endorphins, but decided to consult you.
Thank you.
Post by Андрей Патрушев » Fri Sep 09, 2011 21:24
Merkaba
2nd track Star Wanderer and(or) Endorphins.
Denisko
What is a trance? I'm confused..
Post by Denisko » Tue Sep 13, 2011 3:55
Good time of day!
've always believed that TRANS is something
unfathomable and it is achieved only with a deep
experience. I believed that trance is a state of complete
the blackout from the external perception with the preservation of
the waking mind and the complete silence in the mind. In various
religions it is called Nirvana, Samadhi, Satori, etc.
Recently read one book on self-hypnosis. It says
in trance is nothing special and incomprehensible
no.
So had a few questions:
1.) A clear definition of trance motsoane.
2.) Perhaps there are types of trance and such a thing as depth of trance?
3.) What are the main signs of being in trance state? Ie
how exactly to understand that I'm TRANS?
4.) Achieving what condition is necessary in order to set
any questions and to get answers - not just Yes/no, and
the images of the internal eye? (I think it can be successfully done
in a lucid dream).
5.) Achieving what condition is necessary in order to "lay"
the subconscious positive attitudes so that they have maximum
effect?
Thank you.
Re: What is trance? I'm confused..
Post by Андрей Патрушев » Tue Sep 13, 2011 16:33
Denisko
TRANS, by definition, the famous hypnotherapist Milton Erickson, is focused attention, directed inward. Usually it is a cozy comfortable state...
For some, it may be ISS, for someone, on the contrary, is the usual condition. :?
