Healing and the conduit through the day. With Trauma on their own - methods of TAT and EFT(FS).Алексей72 wrote:And what drives you recommend her and how she listen to them?Андрей Патрушев wrote: Hello!
Yeah, maybe, but we have to work with Psychotrauma.
Advice from Andrei Patrushev
You can learn more about these methods and how to combine them with Healing and a Conductor?Андрей Патрушев wrote:methods of TAT and EFT(FS)
EFT http://www.koob.ru/craig/eft
TAT (Tapas Acupressure Technique) http://yauveren.com/wp-content/uploads/2011/03/ТАТ-по-шагам.pdf
Yes, it does. Just do all.Алексей72 wrote:how to combine them with Healing and Conductor
Andrei Patrushev
Hi Andrea
Is it possible in the goal setting use the phrase "the right good metabolism" or "good metabolism", and that water is...
Thank you
Hi Andrea
Thank you
Yes, I think so.Пианистка wrote:Andrei Patrushev
Hi Andrea![]()
Thank you
Andrei Patrushev
thank you
thank you
Andrei Patrushev
Sorry, I forgot to ask
I'm listening to Healing is to then begin to listen to Puteshestvie internal worlds. And lost count...
if I listen to not 15, but 16 times is not terrible?
Thank you
Thank you
Who?Пианистка wrote:it's not scary?
For correct result? because can't say for sure - it will be 15 or 16 auditions...Андрей Патрушев wrote:Who?Пианистка wrote:it's not scary?
the Pianist
"No effect values"...
thank youАндрей Патрушев wrote:Pianist
Re: a Question for Andrei Patrushev
Andrei Patrushev
Hello!
Here you are advised to listen before going to sleep Windows Explorer, and Healing, alternating them through the day. And if you put the Conductor and listen every day before sleep, the Healing, would it be too much?
And also wanted to ask - does it make sense to listen to the Guide without setting a goal?
Hello!
Hello!
So check...домашний wrote:And if we delay the Conductor and listen every day before sleep, the Healing, would it be too much?
Always useful meaning to find something to do something without meaning...домашний wrote:And wanted to ask - does it make sense to listen to the Guide without setting a goal?
Andrey, tell me the condition in which the person remains when listening to your CDs, I mean an altered state of consciousness, very different from that which is when a person meditates, and whether your drives as a substitute for meditation, because as far as I understand when continuous listening is addictive, and drives become useless, and with meditation it does not.
If I fill the disk Endorphins in a mobile phone with stereo output format in wаw the effect will be?
Disks are not a substitute for meditation, but after practice with the discs and the meditation much more productive.Кэст wrote:Andrey, tell me the condition in which the person remains when listening to your CDs, I mean an altered state of consciousness, very different from that which is when a person meditates, and whether your drives as a substitute for meditation, because as far as I understand when continuous listening is addictive, and drives become useless, and with meditation it does not.
In Wav format will be.Валид wrote:If I fill the disk Endorphins in a mobile phone with stereo output format in wаw the effect will be?
