Disk Explorer
Post by Guest » Sat Oct 10, 2009 9:44
Andrew, good morning. I'll be very short. Your voice is heard phrases, sentences, understand and recognize, of course, can not, that You inspire us?
Post by Андрей Патрушев » Sat Oct 10, 2009 17:52
Александр86 wrote:From the user to the Conductor
Before you start the meditation session, define your goals, ideally in writing. You can make a long list, but every lesson put in front of a one - two. First, put a small, very specific (the result) and achievable (at this stage of Your development) goals.
Andrew, and please clarify the following point:
My goal is now to improve health, there are some problems him. But it's not a small goal and 1 lesson for her to achieve. How, then, to be here? What purpose, then, to put?
And You specify more precisely, what exactly You want to and then work with that (you can gradually).
Post by Андрей Патрушев » Sat Oct 10, 2009 17:53
Anonymous wrote:Andrey, Hello. I'll be very short. Your voice is heard phrases, sentences, understand and recognize, of course, can not, that You inspire us?
Hello.
Алевтина
Post by Алевтина » Sat Oct 10, 2009 21:58
And the text Civate You? The voice is not very the same as Your external appearance...
Please don't be offended I am a man by nature suspicious, but I really want to help...
Post by Андрей Патрушев » Sun Oct 11, 2009 11:13
Алевтина wrote:And the text Civate You? The voice is not very the same as Your external appearance...
Everything changes... except the voices on the disc. :?
Артемчик
Post by Артемчик » Mon Oct 12, 2009 5:37
Алив wrote:Similar problem - I also have no one to audit. About engrams - I think that it is impossible to fully neutralize. Technical means the auditor will not replace.
By the way, it would be interesting to see how Hubbard treated tekhologii AVS, because the first mind machines appeared during the life of Ron.
History is silent about it, although he works in bulk, like Lenin, maybe somewhere he wrote about it
Артемчик
Post by Артемчик » Mon Oct 12, 2009 5:51
About engrams - I think that it is impossible to fully neutralize. Technical means the auditor will not replace.[/quote]
In my opinion, the Explorer is also much like the procedure of auditing, only problem is the other, do not wash specific engram, and to reduce the impact engramic Bank, by positive attitudes on the subconscious.
Алевтина
Post by Алевтина » Mon Oct 12, 2009 11:57
I don't understand... In a trance I am, apparently, does not include... a Psychologist, which is what we started to do, frankly asleep, even if we do it at work. I carefully listened to the words, but I can't shake the desire to find in words that the magic word that will solve all the problems. Not to say that memorized, but at the moment new words are not... find me something wrong or I something wrong doing? Oh, by the way, a few days before class started taking afobazole (not on purpose, the record appeared unexpectedly), I don't think I can define what gets to me lekarstwo chemical or Your...
Алевтина
Post by Алевтина » Mon Oct 12, 2009 11:59
Forgot to add that in our Arsenal there is a Nova Pro 100.
Advise to use it or not?
Post by Андрей Патрушев » Mon Oct 12, 2009 12:26
Артемчик wrote:
Артемчик wrote: about engrams - I think that it is impossible to fully neutralize. Technical means the auditor will not replace.
In my opinion, the principle of Erasure something else from the mind is deeply flawed (what would any authority or written). The task is not to erase, and to integrate at this level to not interfere with live. 8)
Indeed, in high tones engram does not appear. :D
Post by Андрей Патрушев » Mon Oct 12, 2009 12:30
Алевтина wrote:Forgot to add that in our Arsenal there is a Nova Pro 100.
The disk has audiostrobe signal...
Post by Андрей Патрушев » Mon Oct 12, 2009 12:31
Алевтина wrote:I don't understand... In a trance I am, apparently, does not include... a Psychologist, which is what we started to do, frankly asleep, even if we do it at work. I carefully listened to the words, but I can't shake the desire to find in words that the magic word that will solve all the problems. Not to say that memorized, but at the moment new words are not... find me something wrong or I something wrong doing? Oh, by the way, a few days before class started taking afobazole (not on purpose, the record appeared unexpectedly), I don't think I can define what gets to me lekarstwo chemical or Your...
Just pay attention to relax, not paying attention to the voice.
Артемчик
Post by Артемчик » Tue Oct 13, 2009 5:09
Андрей Патрушев wrote:In my opinion, the principle of Erasure something else from the mind is deeply flawed (what would any authority or written). The task is not to erase, and to integrate at this level to not interfere with live.
I think that to erase, you can only remove the part of the brain. In this case, Erasure is the knowledge of hidden information, then this information transformirovalsya in life experience :oops: :o.
Whatever it was You Andrew thank you very much, Your disks are! :D
Андреич
Post by Андреич » Wed Oct 14, 2009 23:59
Greetings to all!
Finally got hands (or ears) to listen to the Conductor during 21 days without interruption.
The result is unclear.
First, I will describe how that felt, then ask for advice )))
Primarily engaged in goal setting: the first audition was nagell themselves mountains of gold and a harem under Windows (shareware :) ).
Before the second audition was studied the topic of "Setting goals". Formulated 5 goals. In the future these objectives were outlined prior to each audition.
Listened basically before bed started to listen to normally at 23.00, 00.00.
Before listening exercises in the tension of all muscles of the body and configuration of the breath.
At the end of the listening basically just fell asleep.
Woke up 10 minutes before the countdown almost every audition.
Were the sessions when I realized the whole text from beginning to end.
Inclined to the conclusion that the TRANS was not even once.
Although the relaxation of life problems do not happen. At least the stress does not happen to fall asleep can in any situation in the shortest time.
Tell it not in order for the fingers to bend, but because they want to understand.
Thoughts "works-not works disk" basically was not focused relaxation.
Read the posts in this thread, about how people have cleaned brains, changing the perception of the environment at the time of the TRANS and envy ))))) Also want to experience new sensations.
Now, in fact, the reason of this post: I have listened to the "rate" of the disk. TRANS log failed (IMHO, these are the feeling - maybe I'm wrong). On the achievement of goals far sooner.
What should I change in the method of listening (or just listen) to enter into a trance?
Not contraindicated if another listening without interruption from the previous auditions?
Whether it was taking me to the purpose to enter into a trance using mind-machine? If so, please give recommendations for models and first steps for its use.
Perhaps it makes sense to combine the Explorer with your other drives?<
Post by Андрей Патрушев » Thu Oct 15, 2009 13:03
Even removing part of the brain (of course not most of it :)) it is impossible to erase the memory. The memory recorded in the body on the holographic principle. :?
"Language is magic. Using sloppy language, get a random resultati". :?
Post by Андрей Патрушев » Thu Oct 15, 2009 13:06
Andreitch
The efficiency of the drive is independent from the "TRANS" and various sensual and video effects that sometimes occurs (some) while listening. Simply deep relaxation while listening. :?
Post by Guest » Thu Oct 15, 2009 13:34
Андрей Патрушев wrote:Andreitch
Clear )
Andrew, are going to continue working with a disk (disks), so could you answer my other questions?
Андреич
Post by Андреич » Thu Oct 15, 2009 13:35
The guest in the previous post, that's me )
Post by Андрей Патрушев » Thu Oct 15, 2009 14:14
Андреич wrote:is Not contraindicated if another listening without interruption from the previous auditions?
Not contraindicated, but the break is always better to do it than not to. :)
TRANS is a "here and now". Five mine (and often immediately) You might never realize that was there. :?
In my opinion optimally to acquire Innerpulse. The recommendation is simple - three weeks of alpha training for start (all sessions "r") then "C", "D", "E" for the same. 8)
The conductor goes well with disc Healing, if you engage with them through the day. :)
Андреич
Post by Андреич » Thu Oct 15, 2009 14:41
Андрей Патрушев wrote:Conductor goes well with disc Healing, if you engage with them through the day. :)
Ie one day the Conductor, the next Healing, the next again Windows Explorer, and so on?
Post by Андрей Патрушев » Thu Oct 15, 2009 15:18
Yes.
Андреич
Post by Андреич » Thu Oct 15, 2009 15:37
Got it, thanks! On Saturday buy machine, try.
Андреич
Post by Андреич » Thu Oct 15, 2009 21:54
Then in passing a question: in the forum posts I realized that the Explorer from time to time finalized: rules text that changes the background design.
Exists somewhere "version history"?
How can you tell what version of Explorer updated?
How can I get the updated record?
Артемчик
Post by Артемчик » Fri Oct 16, 2009 12:03
Андрей Патрушев wrote:Memory recorded in the body on the holographic principle.
You mean the image pictures?
Post by Андрей Патрушев » Fri Oct 16, 2009 17:19
Андреич wrote:'ve been passing the question arose: according to reports on the forum, I realized that the Explorer from time to time finalized: rules text that changes the background design.
For three years, as sold by the latest version of... :?
