Advice from Andrei Patrushev
This phrase should be properly processed and propagated in the options (someone even soft special did). In the center you can put a quick guide to the subconscious - where, when and under what circumstances You want to get the result, either remove the check box, and then there will also appear the phrase. I'm tired of repeatingАстранавт wrote:Andrew, the file that I created. Now the file name must be specify next to "File with the lines?" In the centre and remains "BSFF-text центр.txt"? And the perimeter is this phrase?
Славь Ян Инь
Hello Andrew and forum users! Do weightlifting and decided for a quicker growth use the following affirmation : My body large and muscular. I have perfect health, but I'm reasonably combine work and leisure. My muscles are huge. My muscles quickly regain their health after a workout.
Please tell me if it is correct and that you want to add.
Hello/
"My body is big and muscular." - How big? Like sumo?
"I have perfect health" - and what does "absolute" mean literally?
"but I'm reasonably combine work and leisure" - "no" is, perhaps, superfluous.
"My muscles are huge". - how huge?
"My muscles quickly recover its working capacity after training". - and in another time?
Hello Andrey Vadimovich!
I am interested in this question. How much you can reduce the playback speed of an audio recording for subliminal suggestions to work for sure?
For example in Sound Forge Pro 10.0, you can reduce the playback speed by 10 times. Work?
I want to make a recording for self-hypnosis without binaurally, music and other things. Just spoken affirmations and words.
Loop for 10 minutes. And between cycles to deliver the same length of silence. Get - block-hypnosis 1 minute block of silence 1 min and so on the cycle.
Written in grimstalker in the script, and listen to throughout the day.
For earlier thanks for the reply.
Алексей Кузнецов
- Been thanked: 1 time
Andrey Vadimovich, today I had one material experience the effect of your disks on the brain. The computer opened the well-known test for synchronization of the hemispheres of the brain ("the ballerina" http://www.teron.fatal.ru/mozg.html). Don't know how much it is reliable, but it works. First, I am duty-turn "ballerina". For the most part it rotates clockwise. Then put on the "player" the disk Concentration. After a couple of minutes was "deploy" "ballerina" is almost through one - two seconds. But then it began to freeze and burst. Feet apart one way, and the body and the head to another. It took 9 minutes, 30 seconds. Noticed, because they called me and I stopped the disk. Twenty minutes later I continued to watch, but without listening. Continued in the same spirit, and even intensified. "Cleavage" has increased. Now sometimes the "body" was divided into three parts, legs, torso, top part of the shoulders with the head. These "fragmani" was short.
I want to know your assumptions on the work of the hemispheres.
P. S. at the time of "cleavage" picture is not rotated.
The conductor 70 min exceeded?Андрей Патрушев wrote:For all stimulation is better not to exceed 45 minutes
My guide was an interesting feeling, please comment on Andrew, somewhere in the 40-50 minute freewheeling is that even a little was scary. Difficult to describe, as if buratina was, and it's not muscular feeling in the head (brain) too, as would "stiff". The whole not like her, as if the body of someone else, not feel it clearly, and from afar. With perelyaku interrupted listening, opened his eyes, thinking:- no, th yourself!, hath not instantly, in a few minutes, he continued , the state did not return until the end of the track. So now I think eh another shot? To the Conductor listened to once the Healing. But in the morning not allowed to listen to long tracks. so listened to autogenic courses at 20-30 min of PD the authors, was nothing like this. Question: is the glitches, or the effect intended when writing the disc? Apparently normal health, drugs and alcohol in the evening was not.
Alexey Kuznetsov
Who knows... the Brain is 70-80% creates an image of what he receives. And no rotation no, just the pixels are changed according to a specific algorithm which creates the illusion of rotation. After AVS training the brain starts to do things differently and sees things differently...
A sleeping body is relaxed and not woody,because relaxed. Under Windows Explorer you are probably not relaxed enough or the head is uncomfortable lying.This is-numb. But it happens to me sometimes when not quite relaxed. The body is in a relaxed state is ,as not his own.But in a state-body asleep,mind awake it is. All think and no body as it were. This is the norm. And sometimes what the body feels so huge that it seems outside the room out. And the mind sometimes goes to the neighbors.Дядя Вадя wrote:my guide was an interesting feeling, please comment on Andrew, somewhere in the 40-50 minute freewheeling is that even a little was scary. Difficult to describe, as if buratina was, and it's not muscular feeling in the head (brain) too, as would "stiff". The whole not like her, as if the body of someone else, not feel it clearly, and from afar.
So you went out dramatically from the desired state and back ,you need time. And it's not a glitch.Дядя Вадя wrote:With perelyaku interrupted listening, opened his eyes, thinking:- no, th yourself!, hath not instantly, in a few minutes, he continued , the state did not return until the end of the track.
Go ahead and do it.
Алексей Кузнецов
Thanks for the answer, Andrey Makarevich. I understand that this "cool pixels". Just gave an example of what interesting phenomena there are, and just how real "improvised" ways to determine the impact of your development on the brain. Everything is real, not "alien" like, I feel. And it can be seen almost within a few minutes.
Thanks again for your development.
Hi Andrew! I want to talk about my friend, I apologize in advance if the question is repeated in the themes forum.
Female 36 years. Had surgery for the osteoma parietal bone (not the brain). A month ago, the bone defect was closed with a plate. Is now weakness, fatigue, bouts of depression and seizures (rare). Gets anticonvulsants and sedatives.
After a session with the disc "Healing" notes that the nausea began to increase irritability, agitation (that says "I want to break headphones"). After the 3rd listen to the CD was postponed..
Hence the question how it is possible to listen to your CDs (mode) , which drives and is it possible? I'd like to help her to overcome the disease...
When passed a course of the Conductor ,the next was easier. . Then I used only when I wanted to condition.
Then decided again to repeat the course as a whole ,it's been more than two years from the last. Relax ,enter a state and then drove off.The left leg began to twitch and talk on it to run. And so to the end almost until the leg buckled.
the right is somehow less and not hurt. So I have always at first. This prevents much.
The body of a stranger was not aware of but when to the neighbors to visit the mind wandered , here Yes.And had to be relaxed and now I'm where I want and then the upstairs neighbor(so his frog kicked) as always Skoda. I thought what he roars? And hop here and there. That's where the beginning of the shock.
Liliya -R
thanks for the response. I will continue experiments to put, interesting, and maybe "the neighbors would look down". the main thing that it's not a glitch and not a raving lunatic. if my feeling, that is to say tolerance.
A. Patrushev said that's cool.
Now we have to try in this comp-NII to cuddle up and stay
It is best not to set themselves goals shop ,that I have involuntarily had. Only to relax and let the consciousness and subconscious to do their business.And you only track and work with what you've indicated.
Actually Andrew said that the best way to relax and get the most use something like(not verbatim).Vskie attitudes and expectations of what will interfere .
Hello!домашний wrote:Andrei Patrushev
Hello!
What drives do you recommend for the solution these problems?
In the morning each day 2 trek Star Wanderer (the last Ultramega) before sleep a Guide and Healing, alternating through the day...
