here have you checked it???where dokazatelstva.....Хорошо wrote:in the basement of hard to make "gravity" )
passingwhy don't you ask proof???
PTS even normal!rhetorical I would call.....мимоходом wrote:only asked that there is no such that cannot be explained with the position of the material. It is a normal question
well, instead of trying to figure out now just the reaction of the child "napred". Well, think like an adult - that I bad suggested. To find the unexplained and try to understand it? What's wrong with that... what the process different ideas were found - were not even aware of them...certainly true!))))
yeah...and I just make sure that the oil oil)))and you know about it?)))мимоходом wrote:Your condition is now clear - but the very existence of this condition says that the condition of the other. Consequently throws the States, therefore the equilibrium point is not reached, but the point is to find her butt.
this is not surprising)))мимоходом wrote:And this video answered me recently castaneous, who was unable to answer some questions
of course fail...)))you already know the answer in advance..мимоходом wrote:And if you do not
...conscience-it is at everyone...in power and the best education, so that the conductor nothing to do with....мимоходом wrote: That is to be myself and to push myself, where conscience is the only guide, and the management of psychosomatic (via dozens of well-known techniques, repeatedly described) - an instrument seal in the fields and create the structure.
and in response swelling up to you?))))мимоходом wrote:Most blowing cheeks, as he couldn't answer.
appreciate and take care of those guys)))мимоходом wrote:And Yes, there are such people
wow!..the progress you have some))))to sort things out...Oh no...this is so cornyмимоходом wrote:what are you offended, you can explain?
and in anything))on all your attempts, I do not answer....and are not included in the discussion on the topics, but you read, pay attention...мимоходом wrote:what is the constructive dialogue now?
of course)))мимоходом wrote:the theme-your. Lead it change your mind or something? Well, then the archive
you cut off a channel of information....sharing...to me there's nothing to buy....мимоходом wrote:a common reaction of counter programs is not surprising.
Oh, don't flatter yourself...)))well, what the enemy...especially the first room)))мимоходом wrote:Now I'm enemy number 1 )) as all broke
just the same, I remained in the same condition read...and I read not only esoteric, but...not so important...what is important is that I remain in the same state...but with the new insights from the experience)))мимоходом wrote:a few days later all the same will return to usual state of total absorption esoteric.
all 3 PP -мимоходом wrote:Well, for example, now you too can criticize the assumption. Which is the following postulates and conclusions:1. Man acts as an antenna in some way, according to the laws of physics. The nervous system is the conductor, and the conductor current is induced when an external alternating electromagnetic field (maybe in a separate neurons and other cells). As the host antenna, and radiates (emits between 100 and 900 watt-hours at least in the infrared range and the energy for this is taken the material, the chemical energy of food). Only the induced current is very weak and if the resistance of the nervous system is large (chaotic currents), then the induced currents will be extinguished and do not affect, nor is resonance with their gain.2. This assumption allows us to explain the intuition, the unconscious capture of radiation with different people. Potentially even telepathy and empathy, as well as the capture of intentions and perhaps even the most likely emergency events. Of course, there is a weak point in the form that the field strength falls very much from a distance, but the field is infinite in nature.3. In terms of the nervous system is divided into two parts: logical, Central nervous system, processes information sequentially, the logical conclusion. And the autonomic, peripheral system, which is part of the enteric nervous system that processes information unconsciously, parallel. What is not a division into two parts that try to understand each other, tuning each every? Where the subconscious mind takes in electromagnetism, but doesn't bark because of the large number of signals. In this case, and enteric nervous system and Central nervous system are transient. Where can result, not in the em-field (other relevant fields and not detected), as well as in the DNA to transmit hereditary information.
this question was not particularly, because it is physiologically fixed, as the current setting of your nervous system. A person can not take and stop suddenly to do something meaningless, what I was doing. Instead look at yourself... this diverts all and look very reluctant, because what's inside is often not very tidy.just the same, I remained in the same condition reading...
And for this fuel in the form of a memory . It can be monuments , remembering and paying time on it , and thought how clear al.magnetic ...that's where the attention goes , the energy. It's just a memory Kind(relatives). Friends. Left behind works of any kind and type. It is the memory and the feeding of a person after his death.мимоходом wrote:4. Maybe it's self-generated em field (can be called the aura) can be sealed so that the received em-wave with a certain structure and density will not disintegrate after death and will continue to exist invisibly in the "thin" world.
4. so.мимоходом wrote:And after life nothing to do or to be transported to appropriate their frequency location, or to decay due to lack of structure (glue) and low density.......
can be fonit bone, because under the monuments lie also the bodies are buried =>ЛИЛИЯ-Р wrote:It can be monuments , remembering and giving time on this
not casual as a burial ground used in the rituals...ЛИЛИЯ-Р wrote:Is the memory and the feeding of a person after his death.
well, this is just a guess... As it could be, if it was (which is not a proven fact as such). So it's just the area of philosophy, and then of course the different options can be.There are some dokazatelstva , but again , you can prove anything, the question is what angle to look at it.
I'm on the monuments -no gravestones. Though both is for same - feeding.Логия wrote:LILIYA-R wrote(a):these can be monuments , remembering and paying time it can be fonit bone, because under the monuments lie also the bodies are buried =>
Straight to the point. But wspomagana third-party sometimes in the form of a placebo need . Otherwise, just brain in itself will get screwed. Even just a bystander listening to the story may be useful in the recapitulation(and in fact just the story of...) , the lifting blocks.мимоходом wrote:ITAT:the Placebo effect...there is nothing amazing, basic way of setting up your nervous system "as want to see yourself there and change as opportunities." The placebo effect doctors expect in 30-50% of patients with a variety of ailments that is why medical ethics is not to say the patient that he will die or incurable, and the opposite attitude of faith in himself. Because very often that is triggered. What it looks like physiologically? Man himself shoots psychosomatic blocks (knowing that ill that serious that I need to change), the blood begins to wash the painful area, bringing back the immune body and need substance. And includes work of certain glands, enough brain to want and the subconscious realizes his team (because he knows where the problem, but cannot fix because of deliberate blocking of the body mind in the form of beliefs of some). We can say that all service areas of the DNA code, written over a billion years of evolution. A billion years is really a lot.
necessary and useful. In human terms this is called the support and encouragement. That's just money for a placebo very ugly to take. If viewed from the moral point of view, it's kind of like the man in the car battery died or he's in a deep puddle the car was driven, and leave not can. You got the cable pulled, but before the money has a more stripped. And what is he supposedly guilty, and I noble thing to do, and the money is fair pay and a lesson to him, as he himself climbed, as it should be (about this opinion at all "magicians" selling placebo)But wspomagana third-party sometimes in the form of placebo need
