Bioresonance modulators
Your own guide in the energy-space
Aura
Has thanked: 22 times
Been thanked: 1124 times
Re: Bioresonance modulators.
Post by Aura » Fri Mar 07, 2014 0:13
лексветер wrote:what do you mean time, thank you in advance for your reply
So with the properties work over time
нева
Has thanked: 21 times
Been thanked: 90 times
Post by нева » Fri Mar 07, 2014 0:31
лексветер wrote: info field from Tesla and other friends whose works have not fallen into the mass, it is possible with this devison,? being a techie thinks and practiced in this direction,
Sorry to barge in. The axis of the superconscious allow you to interact with the noosphere..that according to scientists..used dear Tesla...it's occipital region of the left hemisphere is the center of the head and the right frontal lobe...in other words, the horizontal diagonal axis of the third tribute-..Tien in Taoist alchemy...and outstanding logic..this is the opposite diagonal axis....the right occipital lobe - the center of the head and the left frontal..........this is the topic about the alchemical meridians...)
Валерич
Post by Валерич » Fri Mar 07, 2014 1:02
Аура wrote: Or you want the house. In fact it may be the desire of protection.
Here, the response came bi . In fact, the apartment is sold with to buy a house. Other sources of very large scale funding is not see. Protection - Yes, most likely, to cut off from the bustle.
Аура wrote:preferably the use of auxiliary forms of infused fluids primarily structured water. She is capable of, at least, take the information of the crystal.
.I'll probably do so. Insist on shungite, and "consumable" decanter stands on Aqvadisk. It's funny, but the kids are coming to us, first drink a glass.
Аура wrote: the Criterion that you have formulated the right intention, can serve as emotional response.
Auraturns out , it's not the most easy thing to work with BRM. Because the choice of the true goals is always a difficult task. And does this mean that the only true purpose will be realized? By the way, passing a technical issue - contact with BRM (visual in the case of smoky Quartz) are necessary only during goal-setting? The rest of the time is enough to be in the field of action?
And today I have the interesting thing was otfiksirovat. Everywhere I go, everywhere it's easier to Park, no queues and everything is best. Usually I pre-plan, visualize the situation successfully. And today without dopustili all like clockwork. Surely the BRM itself with the subconscious reads?
But real estate today, the silence, and before that, after 2 week break 3 days views, only 4 customers there.
Aurathank you for your help.
нева
Post by нева » Fri Mar 07, 2014 1:13
Валерич wrote:And today I have the interesting thing was otfiksirovat. Everywhere I go, everywhere it's easier to Park, no queues and everything is best.
..Sorry dear..) As the testing Brmy just noticed..you finally came out for certo determine which reflexes response.. heartily congratulations..respect you.. nesomnevayus that your apartment will sell.. at its best.. just relax...and stop raping the World.. their settings.....giving the World to be ..as it is..you can get more than we ask of Him..)
Валерич
Post by Валерич » Fri Mar 07, 2014 1:25
нева wrote:finally out for certo reflexes which determine the response
Don't really understand what this means. If you can - a little more about this. It is often the seemingly straightforward words are understood by different people in different ways. At least 2 different meanings, you see.
нева
Post by нева » Fri Mar 07, 2014 1:27
Valerich
I rent an apartment...the ruble fell and I.. the tenants themselves have offered more money..what I see the justice of this World...but not raped tenants higher rents..
нева
Post by нева » Fri Mar 07, 2014 1:31
нева wrote:don't really understand what this means. If you can - a little more about this.
Every action is a reaction....and the use of BRM..this is action..and we need a counter..?) let him work..)
I mean to require a crystal..not very well..it is advisable to give it a run myself..)
Акела
Has thanked: 28 times
Been thanked: 64 times
Post by Акела » Fri Mar 07, 2014 9:37
нева wrote:Every action is a reaction
It mechanice in Newtonian and quantum every action forms a potential...probably :?
Акела
Post by Акела » Fri Mar 07, 2014 11:21
Аура wrote:Yes, it is possible, by combining any metal object to mount the crystals do not several. minutes...but you can depositional crystal, and it may be that you have it will stop working.
And if the cell water dives and the crystal will flare and reset?
нева
Post by нева » Fri Mar 07, 2014 12:48
Валерич wrote:If you can - a little more about this. It is often the seemingly straightforward words are understood by different people in different ways.
Well, it is believed that the brain is exclusively reflective, so the picture of the world is more or less stable condition. But if, roughly speaking, connections in the brain can change and rearrange, then we say to change neural connections ..in the abdominal brain quite difficult. Just wanted to say that a "reflex response" to better understand the nervous system as a whole. For example..here's a woman with a head can understand that there is no reason to be jealous, but still jealous and with nothing to not do anything and comes up with different occasions, in which she begins to believe. "out of hell"..this is a big step, through the whole. In terms of netdania preference "for or against" "bad or good", "logical-illogical" or even something of a departure from expectations. or the impartial position of the observer. Like, even though it seems simple and trite, but really, not everyone is able to do this easily. So we want from the world what they want, and exactly how we want, and its pressure is only caused by the reaction force. And allow events to happen in a natural way, without our pressure, it's almost "magic") ...it's about feedback..)
нева
Post by нева » Fri Mar 07, 2014 13:05
Акела wrote: and on a quantum every action forms a potential...probably
........uh..Yes! Sure! ..almost forgot...thank you..)
Валерич
Post by Валерич » Fri Mar 07, 2014 20:37
нева wrote:.and the use of BRM..this is action..and we need a counter..?) let him work..)
Like here have already explained that BRM is a tool like a hammer. Put - lies, he nails haven't scored, but the glass is not destroying... :?
нева wrote:to allow events to happen in a natural way, without our pressure, it's almost "magic") ...it's about the feedback
But this is only one position - the position of the observer. Contemplation - a thing pleasant, especially if those 3 cases, but you can also participate in the presentation. It is probably in the need to cross the threshold in force and the amount of wasted emotions that bind to process.
But still sometimes I want to create something! Or at least the knowledge and ability to share...
лексветер
Post by лексветер » Fri Mar 07, 2014 21:59
was a similar question earlier, but I don't much about others.
Aura, if activated BRM, I was a bit used at work, then had the desire to give people etc. how to remove activation and binding to me, that is to say to reset the BRM to reactivate already people etc.
2. there is a saying "squeaky clean", so You do not notice the difference in the results of the work of BRM, depending on which person he is in the hands and whom it serves, the dependence of the result, getting old, etc, depending on what kind of mood, thoughts, desires, energy, the owner of BRM.
нева
Post by нева » Sat Mar 08, 2014 11:37
Валерич wrote:But this is only one position - the position of the observer. Contemplation - a thing pleasant, especially if those 3 cases, but you can also participate in the presentation.
Actually, I agree with You. Even more than agree ) myself tuning into resonance with the desired event or with another person or with something.. that inner STRESS. Even thinking is a purposeful effort. And of course.. no effort anywhere..)
With resonant tuning myself, had to face long ago, before Brow. With Brami was interesting and stronger and somewhat easier. But observation shows that while the effort is done, the result comes, but comes after. It looks as if a strong sweating by the decision of a question, and then let go and even forget but it's somewhere there in the subconscious will digest, and after some time POPs up in the best possible way.
нева
Post by нева » Sat Mar 08, 2014 12:05
лексветер wrote:then had the desire to give people etc. how to remove activation and binding to me
Better not..) charged to love..and give a desirable woman. )))
PS joke
нева
Post by нева » Sat Mar 08, 2014 12:41
Heartiest congratulations to all the Lovely Ladies (MD) ..with women's day! All the very best !!! :o
Акела
Post by Акела » Sat Mar 08, 2014 12:56
нева wrote: charge for love
Well, just Kashpirovsky, "...charge for good... :wiz " :lol:
Aura
Post by Aura » Sat Mar 08, 2014 14:20
Валерич wrote:Aura, it turns out, is not the most easy thing to work with BRM. Because the choice of the true goals is always a difficult task. And does this mean that the only true purpose will be realized? By the way, passing a technical issue - contact with BRM (visual in the case of smoky Quartz) are necessary only during goal-setting? The rest of the time is enough to be in the field of action?And today I have the interesting thing was otfiksirovat. Everywhere I go, everywhere it's easier to Park, no queues and everything is best. Usually I pre-plan, visualize the situation successfully. And today without dopustili all like clockwork. Surely the BRM itself with the subconscious reads?
Yes, all devices that operate on the realisation of the objectives of the operator, require some development - different from "charged". In BRM, the key is contact with the crystal, in principle, no special actions for the development is not required. Here again an analogy: you bought a trip on the metro, just cheap, but you get a trip from point A to point B. Or you bought a car that requires development, but by car you can go wherever your heart desires, and even other people for money to carry. But cars-that are also different...there are those in which only the city and fast, and the other in another country with the wind...
Crystal reads all intentions. The better the contact with the BRM, the more precise the alignment. This is similar to the interpreter with memory function - the more often you use it, the more he adapts to you. The true intentions of causing a person inner joyful response, cause fluctuations much stronger than usual thought, so the crystal is filled with them better and faster. You can speak/present (depending on the language of the crystal) it is the intention, and it is possible to remember that physical sensation and play it every time when talking on the phone. So crystal began to give, you need to accumulate a certain amount of information, more often, of course, the better, but not to fanaticism...several times a day, but a lot depends on the type of crystal. Rauch, for example, has expressed the stage of accumulation and the stage of broadcast. That is, first nothing happens and then when it starts like and forget about the work with BRM, suddenly start feedback and materialization of intentions. Contact rohom not only visual to stare at him not sure. If you have a better attention works, please, and generally to establish contact simply their attention to the crystal guide. Here the transfer intentions better happening in the visual channel, i.e. the intention to better organize the image it clearly and in detail to draw in the mind the image of fulfilled desire. Crystal (at least the Quartz Code) is not able to transmit to the memory crystals of gadget information from the subconscious (besides, it's usually quite weak electromagnetic oscillations) and the gadget immediately began to broadcast a signal, just, apparently, you periodically do it goal setting with Parking and the crystal, this information has managed to accumulate. While my own experience and reviews from the beginning of the work with BRM to happen successful matches, situation in the right way. Apparently, there is another mechanism, not the main chain of operating systems - BRM - CCM - of GAIP.
Here's more about "fine tuning": I think it is important to avoid in the wording of the intention "want". Information was taken and will go and record, and if GEIP go "I want...", it is desirable to move away, to want more and more. Wanted to want will want. So always identify the ultimate desired result.<
Aura
Post by Aura » Sat Mar 08, 2014 14:31
Акела wrote:And if the cell water dives and the crystal will flare and reset?
Well, if on the day of BRM in the water put, can,crystal, and drain...like a battery.
Валерич
Post by Валерич » Sat Mar 08, 2014 14:34
Natalia! happy holidays to You!
You all sorts of benefits, just joyful and kind! And good mood will not leave more You!
Aura
Post by Aura » Sat Mar 08, 2014 14:41
Valerichthank! All the beautiful half of the forum on the holiday!
Валерич
Post by Валерич » Sat Mar 08, 2014 14:43
Aurathanks for the comprehensive answers.
Interesting new thing occurs 2-3 days constantly come across his name. Have in mind that there are namesakes. On the Internet, in the news, the seller, the Manager with the same last name... 4-5 Times a day. The name is not the rare, 17 - the prevalence of Russian surnames. But can firmly say that this had not been observed.
Aura
Post by Aura » Sat Mar 08, 2014 15:02
лексветер wrote:was a similar question earlier, but I don't much about others.
Peel off the BRM and do not use a while (the amethyst for a few days, Rauch -for a week, the bridge HA - for a week or two). The crystal itself is "zeroed" after a while. You could give (BRM can be activated by multiple people), if you have a good attunement with this person.
Of course, on the person depends on something and the same BRM different people will work differently. It was observed that BRM works better in people with a developed ability to concentrate and be more agile mind. People still sending via BRM global, ambitious goals must be willing to change something in your life. And as in the joke about God's will: "well did you at least buy a lottery ticket"..
It was also noted that two crystals of the same type, with one field, past the same processing is still at least a little different. Therefore, each crystal is numbered BRM.
нева wrote:Better not..) charged to love..and give a desirable woman. ))) P. S. a joke
Jokes aside, BRM is really possible to charge your positive attitude to people and give. This particularly applies to grenades.
лексветер
Post by лексветер » Sat Mar 08, 2014 22:48
I let will do the comparison with a radio transmitter, if its wrong, correct
so that person expresses their thoughts in the microphone membrane which begins to accept and vibrate the coil turning it into electrical oscillations which in turn are bass modulation at the transmitter, low modulation, in turn, the source for operation of the RF transmitter , am or FM modulation will not disassemble on the essence is not affected, further amplifier stages translate this woofer in a strong signal promobladnannya modulator. sorry the long radio in the past in my life but why for me what is the similarity principle, BRM modulator, tel -signal amplifier, where it is, sorry for the confusion and ease of presentation :wink:
лексветер
Post by лексветер » Sat Mar 08, 2014 23:22
AURA!thank you for your patience and understanding in answering questions, the more I try to understand the essence of BRM, the more questions arise :wink: :roll: maybe what You used not too much to distract will give links where you can read about priecia and theories that went into the idea of creating a device
