Michael, if time does not preclude, and in Topeka it is, what it's for reasons not related to treatment, in respect of the condenser Naumkin?Михаил_ wrote:not without a certain sense, but for other reasons.
Small offtopic.
Re: Small off-topic.
I took away information that you can not http://www.rinat-shay.chat.ru/img/rotator.gif I understand that the more he writes, that is still possible? Or simply is it misleading?Михаил_ wrote:1. glass fiber - you can.
Just the situation here.ФилиНН wrote:And then through TO from the P-Lite on the rim will be mu-the effects remotely, without biliskov with "home delivery" to? When it stops on the right hemisphere to beat?Михаил_ wrote:Yes. for a start it is not necessary Mandal on the turntable.
KO - it is a mere "beast" eating ownerless energy.
Will cause - it will be routed to the specified target and so on. But the direct impact will be weakened.
Therefore, I recommend to then realize how much and what happened, first to feel the direct effects, and then enable "routing" via KO.
I already wrote somewhere - gave the man his home turntable, author (I could say the gift was made). Gave for installation on cars for tests. She gave a zero change. And then I remembered that I threw it TO from U2 model........ ie, she stood at the car, and fed ...
Therefore, I recommend everyone to try in turn. Because the experience is a personal thing that makes sense to, in some cases, not the stories, and individually.
I meant that the author's explanation of why it is that there is a radiation, rather nonsense.ФилиНН wrote:Michael, if time does not preclude, and in Topeka it is, what it's for reasons not related to treatment, in respect of the condenser Naumkin?Михаил_ wrote:not without a certain sense, but for other reasons.
And the reasons for the possible operation of the device in other physical processes.
But IMHO - the weak.
Though try. So what is easier. Tell us then.
well, let's just say I would be to a lesser extent encouraged the use of plexiglass on top (and bottom).Воффка wrote:I took away information that you can not http://www.rinat-shay.chat.ru/img/rotator.gif I understand that the more he writes, that is still possible? Or simply is it misleading?Михаил_ wrote:1. glass fiber - you can.
Nothing fatal not see. It will be bad when closing the material (of the same type of aluminum).
In General, vskidku, one proper spinner (native rinatovna) and the other without top cover and with the base on the piece of wood around perceived 1к2 in favor of my. At the same rpm. So I don't know, as there is for the theory.... But I'm talking about purely the physics of body perception.
And compared to the V4 is all the toys
Interestingly, if indeed the chopper 'panaceas' in some way, would it be possible if subsequently unused energy generated by the fan can be stored in cans as in uhh. But the question is and in know-how, not only the potential..
Michaeland You can tell if the particles are 'mu'Rinat Shaymuratova and 'm'particles from the Pak Jae Woo has some similarities, or is it totally two different things.. Curious indeed.
2. this is exactly the same thing and they have their own mind, though quite similar to ours. Their behavior will never exactly match the expectations or formulas of two identical setup will not be identical in the parameters.
1. storage of energy in uhh involved, including the time factor. In "home" conditions is the use of at+as combinations.
I have the aluminum marking "D16", it will greatly impair the quality or you can use it?Михаил_ wrote:by the Way it is, I'm very sure, duralumin disc was.... pure aluminum is only on the tires for control panel - it is very soft... sharpening from it is very difficult to mount in the machine - just prominaetsya.
One more question, if D16 is not advisable to use which grade of alloy that will suit best, and thus it can be processed on a "normal" machine?
Yes place what it is - not essential I think.
Воффка wrote:And now for another question, how to mount the aluminum ring to the base?
1. In this construct turns out that the lid and bottom will be kept on the same bolts?Михаил_ wrote: better through holes and screws, if such one-piece construction. Need a precise and rigid mounting.
2. Tighten much?
3. You need to leave a gap as here here or make a completely closed construcive?
it makes no sense, besides the engine itself will not be sealed. The speed is not limited by air resistance, they are limited by the strength of the planes - they just break and it is really some kind of explosion. Can kill.димыч wrote:is there any benefit if the space where the rotating disk is to make a tight and pump out the air?
the idea will be to spin very much, because of otsuvstviya air resistance..
1.Yes, it is possible on someВоффка wrote:Воффка wrote:And now for another question, how to mount the aluminum ring to the base?1. In this construct turns out that the lid and bottom will be kept on the same bolts?Михаил_ wrote: better through holes and screws, if such one-piece construction. Need a precise and rigid mounting.
2. Tighten much?
2.much it vibrates, you need to Unscrew.
3. without much of a difference.
"Silver dust" that is clearly visible after the session mind machine ... and mu - particles is of the same nature phenomenon?
Simply put : this is the same identity?
As our formation is correlated with Silver dust?
Yes, that is about one. Or rather the dust is the manifestation MJ in our locale.
Don't know how to explain without getting involved in lyrical arguments
about something like, "I flew here, it was interesting, looked and flew forth" - that glare of this visit is perceived.
The intensity here locally is extremely small due to the fact that the creativity of people almost does not use.
That is like smotre a star that no longer exists?
1. How reasonable is this substance?
2. How significant a role it plays in our life, development?
3. If at all there are many ways to mobilize the "mu"?
4. As you know, the chopper is only a special case and not the only one?
5.It turns out the interaction is beneficial? or just as the water of the river along the way turns the drive wheel millstones?
Howcast just... can't sleep...
Воффка wrote:I'm puzzled as to the base to attach the motor from the CDM. Actually at CDM he held three small screws as it is mounted on the tablet while have no idea.
Came to the production base of deciduous trees and re-emerged visualase question. How much is the minimum thickness of wood? I think 5mm, if thinner, it will crack all to hell. Turns a long screw must be 8 millimeters, such cogs in CDM... There are no screws from the top cover of the case, they are of the order of 6mm, but the motor they don't fit the thread anymore. Nuts with thread as in the motor just a little, millimeters at three somewhere.Михаил_ wrote: motor mount drilled three small holes for tiny screws. You can find the same longer. From other places of the same CDM. Well drill and other missing places.
PS Actually, I expect the base to make about 9-10mm. to make sure not cracked from vibration, and cover is 5mm.
1. Read Pulman (for example) or fry's, where about feelings in the hallway. Just figurative answers, they somehow or rather short phrase.maverik wrote:That is like smotre a star that no longer exists?
2и5. The key, however it is not clear who is in whose. Symbiosis.
3i4. The main way = creative expression of man. He's the one. The rest of the methods = in fact, light distortion, but they are very, very much, and technically they can be in no way similar even without external similarities.
well then nuts to bury, and solid wood to leave it as is. You can also drown myself CDM (usually there is just the option that the motor is recessed in the thickness of the substrate). As when not the whole Board is thin, and only its point part, the separation and breakup less likely.(PS I got on the first chopper Board 5mm, cover is not).Воффка wrote: Came to the production base of deciduous trees and re-emerged visualase question. How much is the minimum thickness of wood? I think 5mm, if thinner, it will crack all to hell. Turns a long screw must be 8 millimeters, such cogs in CDM... There are no screws from the top cover of the case, they are of the order of 6mm, but the motor they don't fit the thread anymore. Nuts with thread as in the motor just a little, millimeters at three somewhere.
I in light of the above about the MJ particles was thinking about Simoron, it is necessary to behave not normally accustomed to, but strange
then the particles will stick to you
as an example, do not always choose their usual routes, clothing, behaviour:) there is some risk but in fact will be walking radionica
well, no radionic cannot perebdet person. Use from them only in view of the inferiority of the current condition of man and the world, that the local manifestations are conditionally constant in time.
Apparently this is based on the ancient magic technique ..to walk backwards in a strange hat with a pointed conical top,strange clothes and in strange places..( the forest, the graveyard..)димыч wrote:I in light of the above about the MJ particles was thinking about Simoron, it is necessary to behave not normally used, and strange then the particles will stick to you
no, not on it. This is just an outsider it all seems strange
But Simoron - is a good thing. In native bolanowska and without kinks. Madame burns. And her male mate is somewhere closer to work.
