Novice Navigator
Hello.
You can use it, if You like.
Re: Novice Navigator
And the fact that the working range of headphones 10-18000 Hz(to your discou recommended 20,000 Hz,your program I'm going to listen to) it may affect the effect ?
Gleb
For my programs these headphones are a poor fit (part of the effect, though small, will be clipped).
Максимус Алексович
Hello. Recommend whether to conduct sessions of AVS at a temperature of 37-38, SARS, acute respiratory infections, the flu and if Yes, what session-the software better to put?
Maximus Alexovich
Hello.
I do Not recommend at all. Especially close to 38 and 38.
For the insatiable: session (up to 37.5 and above) - only Healing (Hlng.ses)
Hello.
Hello! Prompt for the "gifted" as found in the Navigator built-in drives Andrei Patrushev . Realized that the Audio section.gate, and then? You can step, please!
Sorry to bother you, got it. Although to learn and to master!
Hello!
Tell me what type of batteries it is preferable to use Navigator from the first version? Ni-Zn will fit?
Which at the moment the firmware is the newest?
Алексей Крячко__
Voffka
It is preferable to use NiMh batteries because the built-in battery charger only works for them. If you have other type of batteries with a voltage of 1.25-1.5 In, then you can use like alkaline batteries only for work, but the charge in the charging device for batteries of this type.
New firmware 2.00 (for all), the link is from this forum, one of the top pinned topics.
Hello! When I found audiostrobe records and combined sessions, the sound sometimes slows down, as if stuck. Flashing to version 3.10 has not eliminated the problem. The usual session voproizvodit fine. What could happen?
Алексей Крячко__
One of the common causes of this behavior when playing files associated with memory card. You can try to copy one of the gate records to another memory card (after creating her the same utility folder as described in the instructions - otherwise you will not find your entry) and check how it works. If the problem persists, we will continue to investigate.Дэм wrote:Hello! When I found audiostrobe records and combined sessions, the sound sometimes slows down, as if stuck. Flashing to version 3.10 has not eliminated the problem. The usual session voproizvodit fine. What could happen?
