The CHEMISTRY of the body and not only
Любимая
Has thanked: 4 times
Re: CHEMICALS for the body and not only
Post by Любимая » Sat May 12, 2012 22:26
And about Nikitenko O. Patrushev more:
http://rak.flyboard.ru/topic202.html
Любимая
Мирта wrote:Oh youth, youth...After I saw how was done in Revit, no longer a Walker to domestic vitamin 8)
And how it was done?
Мирта
Post by Мирта » Sat May 12, 2012 23:07
Любимая wrote:And how it was done?
At one stage, in excessive Chan laid "by eye" components of the drug. The best (latest) Soviet drug from the vitamins were pills.
IMHO currently there is no convincing evidence of favorable effects of synthetic vitamins on the prevention of morbidity and mortality, less disease associated with proven deficiency. In this some difficulty: on the one hand the deficiencies among the population there, but to fill it nothing special. Organic products are expensive, but synthetic is not working as it is expected. Perhaps because of the molecular isomer not identity.
Димас
Сотрудник mindmachine.ru
Post by Димас » Sun May 13, 2012 11:58
Мирта wrote:the idea of alcohol, nicotine, drugs, loud music, etc., etc., destroy the body, but the body gets satisfaction from the process of autodestructive ( a protective reset mechanism in the blood of endorphins and enkephalins ) and up to a certain point, believes that everything is fine or better than fine.
Exactly, usually the next day is the payoff for autodestruction in the form of hangover, withdrawal, etc. With thiosulfate did not happen, Vice versa. It's not the substance that the sine causes euphoria and then there is a downturn, the effect of the "swing" is not observed. I drank 10 vials for 10 days, well, how, exactly 1.5 months have passed. No deterioration, in addition to improving, I didn't notice :)
Мирта wrote:About the placebo effect I hope You remember yourself kind of like what I wanted to write an article.
There is a controversial issue, I didn't know what I expect, except the diarrhea (sorry) that the power of thought cause I have not been able :) Waited heavenly blue from the whites of their eyes (did not wait), but a change in mentality did not expect, and I am often in different ISS, and this state was new. Because it was natural and easy, that is, it seemed to me that this is the state in which man needs and is always available.
The article lies at the elderly Professor, still can not critique it.
Мирта
Post by Мирта » Sun May 13, 2012 12:52
Димас wrote:That's it, usually the next day is the payoff for autodestruction in the form of hangover, withdrawal, etc.
Of course, You understand that there's a difference between what is acute and chronic intoxication, withdrawal syndrome. And of course You know that the occurrence or not occurrence of the described phenomena will have a dose - time-dependent character, I'm not talking about the metabolic capacity of the organism to minimize the damage. You as a former ( I hope ) smoker should understand this? One cigarette You really sick? No! And healthier Smoking because it You are not in a rush getting. Isn't it?
Anyway, again, to "listen" to yourself in this situation IMHO irrational. Only need to install - formed is toxic products through metabolism of the oral form of thiosulfate, or not. I showed You that, Yes. Unable to refute on the basis of knowledge of chemistry, and not "...that's where I have scratched and cheeks flushed... :evil: "- demonstrate. I believe that there is a benefit to the body from sulfur dioxide formed in the stomach upon contact of sodium thiosulfate with hydrochloric acid? Give the facts, regardless of Your subjective well-being.
Димас
Post by Димас » Sun May 13, 2012 13:47
Myrtle
I, unfortunately, not a biochemist, so to disprove on the basis of knowledge of chemistry, you can't. So while I'm toying with flushed cheeks and lack scabies. :) But the one cigarette I really feel bad (by the way I just snapped when his wife gave birth) - lack of energy, labored breathing. Return to normal - the pleasure for which I continue to smoke. Sounds crazy, but that sine wave is bad-good-bad-good reason makes me smoke (always good when I'm bored).
By the way, the instruction:
http://www.webapteka.ru/drugbase/name4264.html
"Method of application and doses:
In/in the 5-50 ml of a 30% solution (depending on the type and severity of intoxication) or inside, 2-3 g per reception as a 10% solution. Scabies - topically, rubbed into the skin 60% solution, after drying, moistened with 6% HCl solution."
or
http://www.piluli.kharkov.ua/drugs/drug/2536/
"Indications:
As a detoxification tool used in cases of poisoning by arsenic, mercury, lead (formed of non-toxic sulfites), hydrocyanic acid and its salts (formed rodanistye less toxic compounds), salt iodine, bromine.
Assign also intravenously and inside in allergic diseases, arthritis (joint inflammation), neuralgia (inflammation of nerve). Externally used for scabies."
Also intravenously it's not only intravenously, right?
Мирта
Post by Мирта » Sun May 13, 2012 14:00
Димас wrote:by the Way, the instruction:
But this is something. The issue of the security manual on your link does not remove, as it is not refuted very specific, and simple facts about the thiosulfate metabolism. It may well be that the user has an error or it is written on the basis of unfounded assumptions - that we have in Russia, unfortunately, often.
Димас
Post by Димас » Sun May 13, 2012 14:57
Мирта wrote:In the head then came the seditious thought - and whether it will increase the security of reception by uh...Oh, my God!
Go on,go on!!! :)
Post by Андрей Патрушев » Sun May 13, 2012 21:54
Мирта wrote:security Issue user your link does not remove, as it is not refuted very specific, and simple facts about the thiosulfate metabolism.
Even Paracelsus said that "poison is the substance that makes only the dose". :) Sulfur dioxide is used to OSVETLENIE and obezzorazhivaniya grape wines and a variety of juices and always have present (including in children). The hydrogen sulfide in a sour environment can not be formed from sodium thiosulfate. And even if it was formed, then what? You without harm to themselves unable to breathe hundreds of times more hydrogen sulfide when receiving, for example, hydrogen sulfide baths, mud or... :?
Владимирович
Post by Владимирович » Sun May 13, 2012 23:33
Tell me, and in the head thiosulfate should be rubbed on wet hair or dry?
Post by Андрей Патрушев » Sun May 13, 2012 23:36
Putin
What's the difference? - This is an aqueous solution. :?
Смелый
Has thanked: 2 times
Been thanked: 79 times
Post by Смелый » Mon May 14, 2012 1:58
Владимирович wrote:Tell me, and in the head thiosulfate should be rubbed on wet hair or dry?
Somewhere I missed. Which gives the rubbing of thiosulfate in the head?
Мирта
Post by Мирта » Mon May 14, 2012 3:51
Андрей Патрушев wrote:Even Paracelsus said that "poison is the substance that makes only the dose". :)
Well, Yes, of course, and cyanide you can eat a little bit, but where is the benefit?
Андрей Патрушев wrote:Sulfur dioxide is used to OSVETLENIE and obezzorazhivaniya grape wines and a variety of juices and always have present (including in children).
In wines it is a necessary evil, used as a preservative. But excuse me, where do You see sulfur dioxide in the composition of children's juices?
Андрей Патрушев wrote: hydrogen Sulfide in a sour environment can not be formed from sodium thiosulfate. And even if it was formed, then what? You without harm to themselves unable to breathe hundreds of times more hydrogen sulfide when receiving, for example, hydrogen sulfide baths, mud or... :?
I wrote: "we Can also assume that joining forces with the protons N in the stomach produced by the parietal cells, to form hydrogen sulfide.", referring to the sulfur produced in the stomach that may possibly come into connection with hydrogen. Maybe easier to take the sulfur dioxide without? About the dangers of hydrogen sulfide I wrote.
Владимирович
Post by Владимирович » Mon May 14, 2012 8:30
somewhere infa thiosulfate helps dandruff...
Тоха
Post by Тоха » Mon May 14, 2012 10:25
Correction little, I rubbed thiosulfate into the skin although the idea aroosa. I'll try. After I stretched the use of 10 vials for almost a month, i.e. stability can not speak, I still got results, though not much impressive. Scalp got better! Much better. Dandruff less. Threw nafig all the dandruff shampoos. But after half a month the dandruff started to appear. Feel need normal course and the head to smear thiosulfate.
That stomach began to feel better that's a fact. Today will start another course, but has a maximum withstanding all of the recommendations. And and best the Weight began to leave.)
Димонъ
Post by Димонъ » Sat May 19, 2012 19:28
Has anyone experienced the shaping of subtle bodies? I did not understand where to buy the equipment(min. batch 100 PCs-lot). And yet, is it possible to do at home?
Смелый
Post by Смелый » Sun May 20, 2012 9:39
Димонъ wrote:has Anyone experienced the shaping of subtle bodies? I did not understand where to buy the equipment(min. batch 100 PCs-lot). And yet, is it possible to do at home?
No, it is the equipment to clubs.
In order to do at home, you need to work out in the club. There music is written individually. Begin to work under the guidance of a coach. I've been wanting to get. But we have in the licensed club has just appeared. On the first level. In September be sure to go. In the European part of Russia such clubs are many. You can see all on this website:
http://www.shaping.ru/tech/lightbody.asp
Thing really serious and useful.
Димонъ
Post by Димонъ » Mon May 21, 2012 16:36
Bold thanks.
Been thanked: 2 times
Post by ЗОМБИ » Sun May 27, 2012 17:15
http://www.tv-pomogisebesam.ru/?id=407
ASD-2 can be poke in the ass !! :D
Мирта
Post by Мирта » Sun May 27, 2012 18:35
ЗОМБИ wrote:http://www.tv-pomogisebesam.ru/?id=407
"Preparation ASD has a wide range of curative and preventive action and is used in quite a large number of diseases with different etiology. There is no habituation to the drug."
the Drug is not registered for human therapy and has not passed clinical trials. Ie there is the introduction of consumer confusion. Addictive have - talked about this in an interview with the daughter of an inventor Dorogova.
"after 2 weeks of tumor vygulivala. Cancer: the Drug ASD f-2 stops further development of cancer, quickly relieves pain. Take 2 candles, two times a day. Apply 1.5 years."
For such publications ought to put on ... these candles for a period of...uh 1.5 years 8)
yana
Post by yana » Tue Jun 19, 2012 19:13
Good afternoon.
Tell me, please, for sodium thiosulfate.
Really want to try it for yourself, but confuses the composition and that the drug is intended for intravenous use.
Chemistry are tough for me, but did I understand correctly that when immersed in acid (stomach), you get sulfuric acid and the residue of conventional sulfur? It's not dangerous? As displayed then?
Thanks in advance for clarification. :)
Post by Андрей Патрушев » Tue Jun 19, 2012 20:05
yana
It turns out, the sulfur, the gas is SO2 (sulfur dioxide) and sodium chloride (common salt).
yana
Post by yana » Thu Jun 28, 2012 17:20
Андрей Патрушев wrote:yana
Thank you very much for the answer!
Only I'm still confused from wiki: "SO2 is toxic. The symptoms of poisoning with sulphurous gas, runny nose, cough, hoarseness, sore throat. Inhalation of sulfur dioxide higher concentrations, asphyxiation, speech disorder, difficulty swallowing, vomiting, and possible acute pulmonary edema."
Yes, and oxidized to O3 :(
Post by Андрей Патрушев » Thu Jun 28, 2012 18:25
yana
You wine drinking ever, or at least Sookie? There's quite a lot of SO2. And often You have visited then all the symptoms? :wink:
yana
Post by yana » Thu Jun 28, 2012 23:34
Even as saw, and not only :)
Thanks again for the simple and accurate answer to You!
Probably, it at me something to the effect of braking when matched to something very necessary and useful, then some part of the (bad) begins to look for any reason to prevent it. I can't stand when it starts, it is hard to get over herself :(
