Desensitization and reprocessing (injury) eye movements EMDR.
рустам
Re: Desensitization and reprocessing (injury) eye movements D
Post by рустам » Sun Apr 09, 2017 16:07
Андрей Патрушев wrote:We are not interested in ideas at all. We work with actual emotion, which stuck. This is the main purpose of this technique. When applying this technique to some other situations, You are free to use their common sense and intuition.
Thank you.If a situation causes different emotions and many body sensations,the work in every emotion and feeling in the body separate sessions or take the situation completely for one session?
Андрей Патрушев wrote:Take some emotion (which stuck), the actual here and now, we find where and how it manifests itself in the body (the place the properties (cold, pressure, a tugging feeling, etc.), shape, color, taste and smell, movement (where it begins, where and how it moves), - focus on these sensations and work. Words (phrases) associated with this emotion helps us to focus on it.
These words (phrases)related to this emotion we say during the session or only the beginning?
Post by Андрей Патрушев » Sun Apr 09, 2017 16:48
рустам wrote:If a situation causes different emotions and many body sensations,the work in every emotion and feeling in the body separate sessions or take the situation completely for one session?
"Different emotions" is a label associated to a greater extent, the socio-historical roots. That's why we are working with sensations in the body associated with energy as such (according to research they are approximately the same for different emotions). These feelings are most often localized to the head, chest and abdomen. Less so in other parts of the body (oddly enough, coinciding with the chakras except the root and the crown), and very rarely outside the body (work the same).
Usually after feeling one emotion in particular is rather local in time episode, when you return in this episode to check, other emotions disappear somewhere. Sometimes (rarely) found other locations in the body, which can be easily practiced in the same key.
A very bad choice - to ride in one session according to various traumatic episodes.
рустам wrote:These words (phrase)accompanying this emotion we say during the session or only the beginning?
These words (phrases) we say during the session.
рустам
Post by рустам » Sun Apr 09, 2017 18:07
Thanks Andrew. :ay
Константинос
Post by Константинос » Sat Jun 17, 2017 0:51
Interesting program just on the topic. For those who have no opportunity to buy Mindmachine. Link http://psyberia.ru/soft/eyemover
Константин_
Post by Константин_ » Sat Jul 07, 2018 18:17
Did not understand what the story ended with the introduction of stereo-vibration-speaker in the work with EMDR on the Navigator
Does it make sense to bother ? :oops:
Or issue was maloaktualny or at least overrated ? :?
Post by Андрей Патрушев » Sat Jul 07, 2018 19:27
Constantin
Yes, in fact, nothing complicated. Take the phones from the phone :) some wire from an old headphone, with surviving Jack 3.5 mm, prisobachit it to the phone instead of headphones (or zero throughout the system collect). In any session OPN replace (free editor) in the bottom row bearing at 165Гц (if I remember correctly), stick system with phones in the second headphone Jack and enjoy.... :wink:
митек
Post by митек » Thu Oct 18, 2018 13:06
Димас wrote:And with your eyes closed session EMRD/ 33 min not as effective? Just during the program with open eyes when looking at one point begins to cut in a dream...
To do better sitting with a straight back.
Yes, with my eyes closed is less effective. With your eyes closed for this purpose, the effective frequency scan - Mind Healing.
When emotions come in 1-2 on a scale of intensity (or when stop progress) it is useful to scan the body, thinking about the problem, and find where she's "sitting". To continue with the session, concentrating on bodily sensations.
Andrew! I started healing mind and opn01 to try. Could you clarify what is meant by "effective frequency scan - Mind Hea"?
Thank you
митек
Post by митек » Fri Oct 19, 2018 22:35
Андрей Патрушев wrote:demAs
More effective, IMHO, the rectangle ("r" at the end of the session) and moving red. But once again I want to stress that it is not necessary to force yourself - better this will be. "Softness" increases with the increase of the number of the program.
Good luck!
There are many techniques for self-development, using this technology. but they are all in English. I hope to translate and publish here or in a separate article.
Andrew, good day!
do not prompt where to find in the Navigator 2 sessions with r at the end of the name??
Your message is already somewhat "outdated" and led belonged to the navigation device 1.
Thank you
Post by ЛИЛИЯ-Р » Mon Oct 22, 2018 18:19
MiTek In the Instructions to the Navigator, and the 1st and 2nd of the same -
http://www.mindmachine.ru/photosonix/navigator.htm
12 EMRD Session to work on the method of EMDR(EMRD).
13 ATr2 Alpha тренер2 Not later than 2 hours before bedtime. Jump frequencies in the alpha range contribute to training flexible and quick thinking and help create a good mood.
14 ATr3 Alpha тренер3 Not later than 2 hours before bedtime. Swing frequency in the alpha range contribute to the removal of mental blocks and solve problems.
