Water purifier "BSL-MED-1"
Re: water Purifier "BSL-MED-1"
If they would just take the time to study the threads here and on the manufacturers ' websites, you would get more use. For yourself. Because my experience is my experience, I have it in two messages don't tell you.
- Has thanked: 3 times
- Been thanked: 15 times
Maybe it was written already: it refers to the ice water from the river, i.e. the ice breaking on the river (of course in a clean place) and the house melted into the water? Thank you.
well, apparently as spring water...
And someone uses to clean the water purifier of the type of coagulant electus or hyacinth.
http://otzovik.com/review_314606.html
I wanted to know the difference in taste of water.
I myself polzuyus by electus has probably 4-5 years don't even remember when I started.
From the very beginning felt the softness of the water but right now it's pall, except that now with tap water to drink at all I can't very much give how not to bleach so escho garbage different.
the rest of the water which is deposited in butyle with all sorts of debris, we house the flowers watered, so they love it as dressing))
- Has thanked: 1 time
- Been thanked: 7 times
If (theoretically, because no practical sense) to BSL pour the distillate of the output slurry will or not?
If it turns out that anode = consumable? Aluminium loses even if the water is 100% pure at the inlet?
(I'm aware that the distillate is harmful to drink because of the salts no, the question is theoretical).
1. cuttings will be very small
2. of course expendable, but how else?
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
- Contact:
All good zdraveska
I have a question
Do I understand correctly that this is a miracle of nature "prepares" what is called "living" water, i.e., a negative ORP (I could be wrong, correct if sho)
But if I need a "dead" water, there is no chance of the switch?
saved
I have a question
saved
- Contact:
No, it is alive and dead initially mixed, or rather, not even separated.Шалтай Балтай wrote:do I understand correctly that this is a miracle of nature "prepares" what is called "live" water
The switch is on the "Emerald STO" - he makes dead and alive, and the mixed water.
Humpty Baltay
Oh, Humpty, live, I'm just commemorated the topic of water
viewtopic.php?f=44&t=1230&start=1075
do you think yoga (and maybe not yoga) practice of rubbing anolyte (dead) and the use of catholyte (live) inside ??
why are those dead ?? okay, I'm all ears
in principle, the objective of the electrolysis cope Ekovod, the main thing is to find the concentration of salt for the correction of the rigidity under the optimal ratio processing time/water parameters.
is enough two-chamber, three-chamber, I took see of greed
I can still Vitalong and Melesta Google
![Аплодисменты bi](./images/smilies/bi.gif)
In the water after BSL and bagel precipitate in the form of white flakes. No residue on the walls and at the bottom and at the bottom of the bottle.
Question: bagel time to change, no longer be able to hold sludge?
- Ольга К
- Сотрудник mindmachine.ru
- Been thanked: 17 times
- Contact:
Attention!!!!!
In connection with the increase in the price of water Purifier "BSL-MED-1" provider -
new price 9000 RUB.
new price 9000 RUB.
- Шалтай Балтай
- Contact:
thank you all for the answers
took
for dead water will probably take another thread is necessary.
probably already been discussed, honestly not looking for
I after purification (via Bublik) (do everything according to the instructions), still in the white water slurry
obviously this is the slime
probably someone already faced this problem
there is a solution?
and then have a coffee filter to pass, it takes time
in fact, this bagel and manipulation of his nervous
veg is it needed?
you can't just water through the "standard" filter BRITA miss this or something?
all pre-saved for otvety
PS
sorry that almost did not happen, over time, the tension
in war as in war
took
veg is it needed?
PS
in war as in war
Humpty Baltay
good health, a personal look don't read-here the scratching
here the development of the theme of the anolyte
you why anolyte (dead water) need? as I want to use it?
- Шалтай Балтай
- Contact:
antiparasitic cleansing
Humpty Baltaysunk a reference to the reception circuit
- Шалтай Балтай
- Contact:
Gubarev worms quadrupeds unknown
http://aum.mybb.ru/viewtopic.php?id=633
http://www.pravdu.net/publ/zdorove/para ... /2-1-0-111
Humpty Baltay got it, thanks
- Вадим Перелыгин
Recommend BIOMEDIS. Effectively enjoyed with the 2010.Шалтай Балтай wrote:antiparasitic cleaning
Sorry for offtopic and unsolicited advice.
![Embarassed :oops:](./images/smilies/icon_redface.gif)
That's it, then. Sorry I have no ORP meter, I would check it out.
Jason little hard to believe, most likely shifts the acidity, not the ORP.
Humpty, the same problem, after BSL and bagel water a little muddy, that pisses me off.
Bagel clamped to the limit - does not help.
I think to pass through the pitcher, Brito any.
Times the manufacturer says that this water you can drink, and a jug it is not very dirty and a cheap filter long enough. Another thing, how will this affect ORP and structure, because Michael wrote that ORP is not the only useful.
Prompt, filter coffee using disposable or reusable?
Drinking acidic water, I would not venture, parasites pressured the bio-resonance, but for preventing tooth pick also martoutsy device.
How to choose, write pliz here model, maybe I'll take it.
Thanks In Advance!
Thanks In Advance!
- Воффка
- Has thanked: 5 times
- Been thanked: 8 times
- Contact:
I wonder how the jug on the ORP will be affected, has anyone measured?
