In the help Navigator
Re: the help Navigator
Post by Андрей Патрушев » Tue Dec 04, 2012 22:49
AHHH
Cardiovascular diseases are still on the first place of mortality...
СветаР
Post by СветаР » Mon Jan 28, 2013 18:20
Please tell me how to start listening on the drive(s) Patrushev with music.center. Cords connect the socket "right". And then what? To load into memory, or don't want. EXT. the entrance to the Settings on.
Post by ЛИЛИЯ-Р » Wed Jan 30, 2013 12:59
СветаР wrote:please Tell me how to start listening on the drive(s) Patrushev with music.center. Cords connect the socket "right". And then what? To load into memory, or don't want. EXT. the entrance to the Settings on.
In the first window line is a strobe decoder, connected glasses and headphones in the machine ,the cord to the SD player and in the car in the slot at the top ,between the headset and goggles.Next, turn the disc from the player ,the volume on the player .Egorovca the level is often different for each gate drive Patrushev . So try to reduce or increase the level. Can strobe to change to chord and common. As you like.
If that is not answered in writing ,I will clarify.
Бауржан Танкеев
Post by Бауржан Танкеев » Sat Nov 16, 2013 16:38
can't run goggles when playing strobe signals. help.
Post by к-13 » Sat Nov 16, 2013 17:36
Describe what You do, then tell me where was wrong :?
Бауржан Танкеев
Post by Бауржан Танкеев » Sat Nov 16, 2013 19:37
include. I go to the player. choose plain. go to the directory using "..". I go to STROBE. choose one of the 12 files of the workshop (adaptation) and run. the points are not working. thank you.
Post by к-13 » Sat Nov 16, 2013 23:36
Glasses and should not work in a normal player - they should work only in audiostrobe decoder. Try to turn it on.
Give a little hint for old times ' sake - to do this, even the instructions do not need to read - the answer is given at the beginning of this topic in the second message.
Бауржан Танкеев
Post by Бауржан Танкеев » Sun Nov 17, 2013 18:50
Thank you. understood.
Гарет
Post by Гарет » Thu Jul 17, 2014 12:40
Good day!
The device does not charge, not red light. Included-switched off several. again, green lights and no red, then the device goes into standby mode.
Bought a couple of weeks ago, remembered that first time it shut off suddenly in the middle of a Conductor (any sounds that he never published, just all blacked out), although judging by the scale of the charge was half. This was another time or two.
Алексей Крячко__
Post by Алексей Крячко__ » Fri Jul 18, 2014 19:27
Hello! Such behavior of the battery is in low charge, then the charger may not turn on or if the loss of capacity. ie it can occur with either a new set or old. Also occurs if 1 or 2 battery is removed and used in another device, or initially in a new set of batteries were a variation in capacitance or voltage. Now can recommend to use or a separate battery charger (if available) or to work from the network adapter or use firmware 1.15 with the manual switch battery. In the beginning of the week plan to put a modified firmware where this problem is solved ( there's also a manual switch on the battery charger as in version 1.15), while the rest will remain as in 1.16.
We already have version 2.01 in which the charger will turn itself and in the manual, but there's too many changes at work, it has no instructions and there arose a need to Refine the playback of the combined sessions, so we don't put in access.
Гарет
Post by Гарет » Sat Jul 19, 2014 22:35
Hello!
The device has been charged despite the fact that not burning the red light and displayed that the power comes from the network. A day was set once again charging, this time the red light was involved :)
Алексей Крячко__
Post by Алексей Крячко__ » Sat Jul 19, 2014 23:25
usually after 8-10 cycles of discharge and charge for these NiMh batteries they are in the normal mode, and they leveled the charge.
However, the firmware will be adjusted in the charge mode, that it was not with new and old batteries. When the light turns green without red is a regime of "floating" on the weak current, this is not a charge.
Путешественник
Post by Путешественник » Fri Jul 25, 2014 13:59
Hello.
Is it possible to put the flashing in the right and left eyes in different phases? For example, in the left eye the device emits light in phase with the stimulation frequency and to the right in opposition.
May be I something have not noticed, but while such features are not found. Only within the rows and between them... :?
Post by Андрей Патрушев » Fri Jul 25, 2014 14:03
Путешественник wrote:Only within the rows and between them...
What else is necessary??? :shock: Put 180g - here You have opposite phase. 8) :)
Путешественник
Post by Путешественник » Fri Jul 25, 2014 14:06
But this rule applies only between the rows of LEDs. I would like to give signals to each eye in its phase. :)
IMHO, the whole rigidity of the sessions InnerPuls and New is called to the fact that in some segments of the signals in the right and left eye are served asynchronously with an angle of 180.
Post by Андрей Патрушев » Fri Jul 25, 2014 14:15
Путешественник wrote:But this rule applies only between the rows of LEDs.
Why do You think so???
Путешественник
Post by Путешественник » Fri Jul 25, 2014 14:24
I will explain more specific. If I edit a phase, say the top right led, the effect is spread on the upper right diode for both eyes.
But if I want to apply for them (the eyes) light asynchronously? For example, the left eye is stimulated only after the fade of the LEDs in the right (180gr.)? Perhaps there is a solution, but I have not yet found... :?
Post by Андрей Патрушев » Fri Jul 25, 2014 14:31
Путешественник wrote:let me Explain more specific. If I edit a phase, say the top right led, the effect is spread on the upper right diode for both eyes.
As it should be. Physiology of vision such that the right field of each eye due to more than thick nerve bundles with the left hemisphere, and Vice versa. Glasses Navigator, unlike many other light and sound devices, this is taken into account. By the way, on the forum it has been discussed with beautiful pictures. :)
ImageThus, when talking about phase, is the communication between the right group of LEDs and the left group for each eye.
In principle, of course, you can ask Alexei to do in a firmware option to all LEDs of one eye (on the line) worked synchronously, but it will not be physiological, because thereby you will stimulate both hemispheres regardless of phase.
Путешественник
Post by Путешественник » Fri Jul 25, 2014 14:39
But even so it would be nice to be able to influence the rhythmic activity of the hemispheres more izbiratelnoj. For high beta this is especially true, since consciousness has no time to catch such a high frequency flicker. As it is, I think, plays in their learning a role. The frequency doubling method is an asynchronous signal for different eyes, in my opinion most it. The more beta rhythms never (in norm) are not synchronous and hypersynchrony, as well as the alpha (with the exception of the most terrible pathologies).
Post by Андрей Патрушев » Fri Jul 25, 2014 14:45
Путешественник wrote:But even so it would be nice to be able to influence the rhythmic activity of the hemispheres more izbiratelnoj.
Just everything is exactly the opposite (see above).
Путешественник wrote:the frequency Doubling method is an asynchronous signal for different eyes
Not a doubling but a halving in. But not in Your case. :)
Путешественник
Post by Путешественник » Fri Jul 25, 2014 15:07
Why? The idea in this case, if megalochari connections everything is in order, the transmission of the excitation between the hemispheres frequency-induced potentials should be summed up. In fact and in right and left visual center will be the centers with the same frequency but in different phases of the period?
Post by Андрей Патрушев » Fri Jul 25, 2014 15:16
If you do not do separate stimulation fields of view for each eye (as in Navigator), then with the full illumination of one eye and stimulation occurs simultaneously in both hemispheres. Thus, no matter - what eye to light (at least in phase, out of phase though).
If you do separate stimulation fields of view, that, while one hemisphere is stimulated, the second - "resting" - that is, for each hemisphere the period of stimulation, at a phase of 180., increases exactly twice, that is the stimulation frequency is reduced exactly twice.
Post by Андрей Патрушев » Fri Jul 25, 2014 15:26
Путешественник wrote:the idea in this case, if megalochari connections everything is in order, the transmission of the excitation between the hemispheres frequency-induced potentials should be summed up.
Following this logic, it can be argued that synchronous stimulation frequencies evoked potentials should be summed, however, this did not happen...
Путешественник
Post by Путешественник » Fri Jul 25, 2014 15:44
Андрей Патрушев wrote:If you do not do separate stimulation fields of view for each eye (as in Navigator), then with the full illumination of one eye and stimulation occurs simultaneously in both hemispheres. Thus, no matter - what eye to light.
But after a while the brain will give excitement from the optic center to other areas, and at the time of signal addition, the impact of phase and protivogaz will be interpreted by the brain as the sum of the period and the two half-cycles of the fundamental frequency and their difference.
Thus, the evoked potentials must be at frequencies 5, 10, 15, 20Hz. If megalochari links all in order, the idea is everything has to look exactly...
Post by Андрей Патрушев » Fri Jul 25, 2014 15:47
the Traveler
However, it is not (see above). :?
Harmonics appear only when stimulated by rectangular signals due to the harmonics already contained in the signals, but not at the expense of addition of signals in the brain.
