BJ 2.1 / 2.2 / 2.4
амарра
Re: БЖ2.1 reinforced "hard" version 2.0
Post by амарра » Sat Nov 19, 2011 14:34
Михаил_ wrote:
амарра wrote: But another question. Now bracelets I can only wear. On the hands and feet appeared red spots, imprint bracelets (right rectangles). I have the feeling that they are some accumulated negativity in yourself and can't self cleaned. There are options what to do? Whether cleaning with water, light, fire? Or just give them a break?
questionyou all that in what they construct.
No, the bracelets do not can accumulate on itself the negative.
1) if the bracelets on the Crimean blanks (plain wood), then they would just start to dissolve the varnish (or the impregnation on the surface). This may be the reason.
2) if it is ebony, the reaction components of wood resin
and in that and in other case it is rather the fact of strengthening of work BJ (got used to and You have the potential increased possible). If 1) the inner part of the sand these can literally. if 2) the more useful will be the opposite - to cover what kind of wax.
In addition, the zone of high energy and tight fit can in itself give redness.
So the General advice is to change the place where dressed + possible wear on the sleeve top (if used on the feet to toe for example and not by him)
All bracelets ebony 2.1. One for the hands and feet. Change of place does not help again is redness. I'll try to cover it with wax for wood.
Post by Михаил_ » Sat Nov 19, 2011 18:10
either provide a layer of fabric between them and the body. I also constantly 4pcs and nothing happens. Do not shoot almost never. But sometimes, when they are strongly activated - move to a new place, to build it really is a little redness, like blood flow, takes a couple of minutes. Associated with the energy exchange.
It is also possible elementary the sweating sickness (as well as any tight subject)
СтАвР
Post by СтАвР » Sat Nov 19, 2011 22:53
2.1 replaces 2.0 completely?
if I wear 4 2.0 now and gradually replace them with 2.1 effect it will be more?
and if 2.1 binding to the operator or, as in the case of 2.6, every time the new?
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Sat Nov 19, 2011 23:10
The effect will be slightly different:
Михаил_ wrote:2.1 added the following features:
- better integration with БЖ3.0 all versions (need to add the program КО2.0, since 3.0 came later).
- good integration (improved two-way communication) with all products of the series Ah, starting from at
- enhanced regeneration of the cocoon
- heavy work with "educational" interactive systems, the first of which is a series of cartridges Vx (work with perception, vision)
- enhanced recovery of human abilities, the restoration of the cocoon so that it and from an energy point of view and from the point of view of compliance of the body, could "serve" these abilities.
the more active function of their own security operator
- a more Autonomous and regular activation module "Explorer experience" to activate their own abilities and their recovery
.... a number of other minor changes .....
Most of the changes for the work TO not affect the base functionality for all BJ 1.0-2.x - total and is not divisible in nature.
2.1 also integrates better with 2.5-2.6-2.7-2.8, being able to switch to paired work with them when you activate these qualities.
Increased "maximum power" of the BZ.
At BJ, there is attunement with the Operator, but BJ, if necessary, and can re-tune to another Operator. BJ 2.6 including.
Sincerely, MAG.no
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Sun Nov 20, 2011 23:36
Маг.нет wrote:From BJ, there is attunement with the Operator, but BJ, if necessary, and can re-tune to another Operator. BJ 2.6 including.
2.0 softer in the manifestation of qualities than 2.1. 2.0 is able to soften hard symptoms of any quality bracelets and jewelry. He, according to my feelings.acts as a transformer .
With your BJ, you can manage modules "Kit" to help close ,if he has the bracelet ,and not able to work with modules.
Post by Маг.нет » Mon Nov 21, 2011 0:20
ЛИЛИЯ-Р wrote:as with your BJ, you can manage modules "Kit" to help close ,if he has the bracelet ,and not able to work with modules.
"Timer healer". It allows you to project onto the bracelet another person call only modules running in the health and only the person who made the bracelet and gave. While still a supervisor role is played by the subconscious mind of the wearer, which may block this action if it deemed incorrect. The point is that the subconscious mind is wiser than usually, but often not in a hurry to help until the problem became very much the cornerstone. For this reason, it is possible to be issued bracelets to prescribe a schedule for modules like chronopuncture twice a day (for example), set a specific time.
The manufacturer or donor does not necessarily "close"....
ЛИЛИЯ-Р wrote:2.0 softer in the manifestation of qualities than 2.1. 2.0 is able to soften hard symptoms of any quality bracelets and jewelry.
Yes, focus settings 2.x stretched across the range of the BZ, reducing the actualization trends 2.x.
Sincerely, MAG.no
Sunshine
Been thanked: 2 times
Post by Sunshine » Thu Nov 24, 2011 23:32
MM
"I burdock MM carry 4 pairs BJ 2.1 already since April 2011 and absolutely no results." - Strange, why are you talking about the male and female kind )) :lol:
Тяфа
Post by Тяфа » Wed Dec 21, 2011 18:16
Loaded gold bracelet card 2.1, but on the advice of Mikhail bought a bracelet from natural stone citrine and moved the charge already on it. If I understand correctly the first bracelet is also survived charging like version 1.0. Now both of the bracelet on the hand, the any unusual or new experiences is not noticed. See...
Michael wrote that with the bracelet 2.1 can be applied information on the water. Tell me how to do it?
Тяфа
Post by Тяфа » Wed Dec 21, 2011 18:24
Another question :oops: on the night of the bracelet to remove the need or feel?
Sunshine
Post by Sunshine » Wed Dec 21, 2011 18:38
No need, now, its never no need to remove ))
Sunshine
Post by Sunshine » Wed Dec 21, 2011 18:39
The more you tie it to commitments, the stronger it will burn, so he shows his active work, get used to it - eventually it will pass))
Тяфа
Post by Тяфа » Wed Dec 21, 2011 19:32
Sunshinethank you , I with him enough komfortno, friends! :D Although at first afraid, because you first recommend the 2.0 I 2.1!
Тяфа wrote: Michael wrote that with the bracelet 2.1 can be applied information on the water. Tell me how to do it?
Now the bracelet is put in a water bath, I want with essential oils, maybe the cold will help. Now, the place where the bracelet like burns and crushed :roll:
Post by bofara » Wed Dec 21, 2011 19:36
The bracelet on the neck of the bottle for some time /it will be good if a minimum of 40 minutes, a very good 2 hours or more, and at night/ the water is ready. :)
By the way You can and matrix 1.0 Lite or matrix Panacea to paint a marker on the bottle.
Matrix Lite 1.0:
EPA
RZM
ASL
very good for a start. And so bracelet will always be on hand.
Тяфа
Post by Тяфа » Wed Dec 21, 2011 20:53
bofaranot get tired to thank you for your answers :o deepen the question :) I understand that it is possible for water to put certain information, how to ask or it is not? And that water is brilliant if you just charged a bracelet, what information it carries?
Post by bofara » Wed Dec 21, 2011 21:12
Do not quite understand, sorry. Sings don't want, inadvertently, introduces dabloidami response. If someone can - please let him answer. Sorry. :?
Белый Камень
Post by Белый Камень » Wed Dec 21, 2011 23:09
A lot of options its important to understand the General principle, then improvise
Тема1 Тема2
Film
You can for example, without going into details just take it and give the job the matrix a Panacea, to make the magical waters.)), the most useful for you now or for anyone/anything. To take better boiled.
And the bracelet, probably just useful with its properties in water option))
Тяфа
Post by Тяфа » Thu Dec 22, 2011 12:18
bofara wrote:Matrix 1.0 light:EPARZMASL
I wonder if this matrix is applied to the bottle, which is charged by the Designer of the body that will be, they reinforce each other or Vice versa :roll:
Тяфа
Post by Тяфа » Thu Dec 22, 2011 12:22
White Stonethanks , it was interesting to read, especially now that zadumalas about buying KV :)
Post by Михаил_ » Thu Dec 22, 2011 23:13
The charged water bracelet carries information similar to the ACC. versions of the BZ.
Post by Михаил_ » Thu Dec 22, 2011 23:18
I use water such as HF, Panacea, 3.0,
Some time ago used and 1.0 is light, but sealed this bottle stickers panacea. All three versions are different.
Previously used and 2.1 water and also from ск1м specialized - but too much of different waters :)
And use a Cup with a sticker panacea-personalized bar of my youth.
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Fri Dec 23, 2011 9:42
the Yip
Белый Камень wrote:it is better to Take boiled.
Better to take alive, i.e. water with a negative ORP value. As an option from the filter BSL-MED.
Белый Камень
Post by Белый Камень » Fri Dec 23, 2011 10:29
What to take? If you need to apply the information is minimal distortion, then you need to take boiled water, they talked about it, monks say, before reciting on water, suggest her 4 minutes to boil.
It does not prevent to do anything with live water and juice and beer.
Understand what you need and then it will be clear what to take. az
Post by Михаил_ » Fri Dec 23, 2011 13:48
Monks - the monks :) they use "option for the poor", which is not high-tech means of water treatment, just because their a certain time period, and the rest is tradition and it has formed rules.
Voffka absolutely right.
The same BSL-med or Emerald erases the structures that were in the water at the entrance and give it correct physical properties.
And my means of charging absolutely do not care that You give at the entrance - boiled or not, or even what. They in the shortest time will structurat in any form. So better to take good water. But boiled it is better not to use.
Белый Камень
Post by Белый Камень » Fri Dec 23, 2011 15:27
It is possible, and the city is irreplaceable I guess.
Don't use filters, etc., by the Way, these are the most high-tech, less beginning to attract my attention, which pleases, though I think the inertia on pair with laziness, still have time to clean up my purse :evil: :?
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Fri Dec 23, 2011 15:36
Белый Камень wrote:don't use filters, etc.
Have used regular carbon filter. The water was better, but not much. Now Polous BSL - med. Pour in the filtered carbon filter water BSL-med. After the cleaning is clearly seen that the filtered carbon filter water contained quite a lot of things go... Now I am glad that all of these substances remain in the catcher and not in the kidneys.
