Reviews about the effects of version 3.0
Наталья73
Post by Наталья73 » Sat Nov 13, 2010 3:03
Test spinning girl: Bracelet 2.8 on the left hand turns counterclockwise, the bracelet on the right - clockwise. Without a bracelet is always clockwise. What is it ?
Post by Михаил_ » Sat Nov 13, 2010 3:13
obviously this is the bracelet on his left hand, then on the right :)
2.8 energizes the consciousness and the left hemisphere apparently, "trained" for more energy in life, takes on this thread more, and that gives the effect.
On the right - the effect itself is weak because this does not happen.
3.0 and washing gives General (not only on the mind) and the attention in the right area shifts like ...tough... or hard.
It is an interesting observation. Now I think I understand why Constantine wrote that he most liked the combination of 3.0+2.8 the common sense of his condition as a different taste.
I feel it did not work, I on the background 3.0 2.8 don't feel almost nothing, especially that he's already "worked out" much, i.e. I feel so weak for a long time dragged without respite.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Sat Nov 13, 2010 16:29
Produced an intermediate step 3.0 N++ from a meteorite of the chondrite performing multi-stage charging as the meteorite itself, and multilayer polymer masses of different composition (and charging algorithms) layers. Charging was carried out for more "physical" fixation "charging Mandal" at the facility. To further enable this, 3.0 in designed system (a complex object) of the other (composition) charged 3.0.
Have controlsa quickly (on the hand bracelet 3.0 N), the performance change 3.0 (compared to the bracelet 3.0 N) was significantly higher, the feeling is much softer but proyavlenie (that reminded aspect of 2.0-2.6).
To continue further "restructuring" began production "charging machine", continuing to load the next object - a quartz crystal with applied layers of polymer mass, and "physical" fixation of Mandal on the object. This is the second part of this design 3.0. Between them provides a third 3.0 with similar processes, but multi-piece. After General charge of the design.
Sincerely, MAG.no
Post by Маг.нет » Sat Nov 13, 2010 17:16
Just think to charge a meteorite pyroxene, for further grinding, while receiving the expected effects and applying when charging for the bracelets 3.0.
Sincerely, MAG.no
Малика
Has thanked: 251 times
Been thanked: 110 times
Post by Малика » Sat Nov 13, 2010 17:34
bi Good luck!!!
рыжая
Has thanked: 34 times
Been thanked: 46 times
Post by рыжая » Sat Nov 13, 2010 18:58
MAG.no, Hello.
What is a meteorite and pyroxene meteorite chondrite? What properties do they possess?
Мистраль
Post by Мистраль » Sat Nov 13, 2010 20:13
About pyroxene don't know a chondrite is a Mage.no letter mixed up.You have to read the Blues.It means the meteorite is not in the mood.The Blues he :wink:
Post by Маг.нет » Sat Nov 13, 2010 20:43
the Vast majority of stone meteorites (92.3% of the stone, 85.7% of the total number of crashes) — chondrites. They are called chondrites because they contain Hendry — spherical or elliptical formation of a predominantly silicate composition. Most of the chondrules has a size not exceeding 1 mm in diameter but some can reach several millimeters. Hendry are clastic or crystalline matrix, and often the matrix is different from the chondrules not so much in composition as in the crystal structure. The composition of the chondrites is almost identical to the chemical composition of the Sun, excluding light gases such as hydrogen and helium. It is therefore considered that chondrites were formed directly from the protoplanetary cloud that surrounded and surrounding the Sun, by condensation of matter and the accretion of dust with an intermediate heating.
In the described specimen Hendry 3-5 mm yellow brown color shown. Mestorozhdenie unknown.
The pyroxene component of the meteorite-pallasite.
Structure
The main motive of the structure of the pyroxenes are chains of SiO4 tetrahedrons, elongated along the axis C. In pyroxenes, the tetrahedra in the chains alternately pointing in different directions. Other chain silicates the period of recurrence of the chain is usually more.
A third sample - magmatic iron meteorite (a type of Iron IIB-OgH).
Their properties are not deeply studied, plan to use to extract the signal of 3.0 for consideration.
Sincerely, MAG.no
Мистраль
Post by Мистраль » Sat Nov 13, 2010 21:02
Grams iron meteorite worth more than an ounce of gold!!!You Are A Magician.no rich man!!! By the way all these meteorite should belong to the state.So You be careful with the messages!
рыжая
Post by рыжая » Sat Nov 13, 2010 21:34
Мистраль wrote:Gram iron meteorite worth more than an ounce of gold!!!You Are A Magician.no rich man!!! By the way all these meteorite should belong to the state.So You be careful with the messages!
I'm sure the Mage.there are no complications with the law.
:) Already amused. And the fact that he has a better chance than the other, well, he is a Magician!
MAG-no, if not a secret where the meteorites were getting? Through friends?
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Sat Nov 13, 2010 21:44
Мистраль wrote:by the Way all these meteorite should belong to the state.
And the state belongs to the oligarchs. The oligarchs resent!
Post by Маг.нет » Sat Nov 13, 2010 21:47
Anomalies:o a Fine of 100 rubles...:)
Sincerely, MAG.no
Post by Маг.нет » Sat Nov 13, 2010 21:49
It is a gift, and the gift has a special legal status. And so, the prices are different... the Way the price laid down costs "brand of descent", sometimes costs a lot of money...
the Authenticity and the "cosmic history" of the meteorite properyt in special research institutions. Russia is a laboratory of meteoritics Institute of Geochemistry and analytical chemistry Russian Academy of Sciences. Analysis is not worth anything, but the person who found the new meteorite, needs to donate at least 20 percent of its weight in the national collection. The rest he can keep, and then sell, give, or take abroad in the prescribed manner. But if he will give into the collection not 20, but 80 percent of the mass, someone else will get a tangible prize. Certificates for meteorites meteoritics laboratory is not given, but diplomas nahodtsya issues necessarily. By the way, a meteor on the world market, no special certificates are there. Collectors enough brand label issued on is well known and respected meteorite dealer.
Taking into account the Russian mentality, implying, for any reason, the appropriate "paper", since the certificates for the collection samples of meteorites began to issue our society. But only those meteorites which has already been named, investigated, introduced into scientific circulation, registered in International nomenclature Committee, and their samples are in Russian national collection. Unknown meteorites "from the shed" we don't issue certificates
Serious collecting is not particularly harmful to the science, rather the contrary. First, among collectors, a lot of very competent researchers studying meteorites out of their collections and publishing the results. Secondly, collectors are happy to join the national meteorite collection of samples of new meteorites. Much greater damage is caused by clumsy attempts to get rich on the discovery of the meteorite.
Sincerely, MAG.no<
Post by Маг.нет » Sat Nov 13, 2010 23:03
After the collapse of the USSR it turned out that the meteorites, in most CIS countries is mentioned only in the law on subsoil. And since meteorites are most often found on the surface of the earth, the depths are not related, in fact the laws are silent about them. Unless abroad they can not be exported without special permission, which, by the way, to Russia is very easy. It is only necessary that the meteorite was known to science and are represented in the national collection, and the rest is purely a paper process. To save a new, unknown meteorites to science may not the law and people's understanding of the fact that the unnamed meteorites lying in barns, on the meteorite market is not interesting to anyone. But if you share my find with science, of course, not much rich, but quite substantial material support Nahodkin can get and it is completely legal.
Also noticed a significant weakening of the signal when removing it,and leaving the bracelet 3.0 N, while "bar 3.0 N++", although much more noticeable Vice versa. I wonder what will the charge on the crystal, something else? Or the same but in different intensity? Pre-charged crystal Etalon with audio, picture and insulation, producing the fixation properties of the crystallizing polymer. The smoky quartz.
Sincerely, MAG.no
Post by Михаил_ » Sat Nov 13, 2010 23:29
Experimenter..... :)
1. in my opinion the meteorite can not charge.... or even need not to charge.
2. the meteorite should initially carry a signal very similar to 3.0, processed in the fall often carry something else. Try different - I think it will be a noticeable difference. For this reason and used the chondrite C1 (no chondrules, not basking, apparently the cause of their formation - rupture of the nucleus of a larger meteorite, where the middle part just did not have time to heat up and formed Hendry)
meteorite need not a lot of in S++ the grooves in the middle of each link, диаметр6, depth 3.5 mm, additional fixing holes of the type "dovetail" with a small diameter to "seal" with the meteorite flew, the cost of 1браслет about grams, this is quite enough for the reference signal adjusts the entire bracelet. Well, considering the cost C1 grams is not enough...
well I get them at a discounted price, close to the lower limit of prices for a given class of chondrites
I'm here today on the floor of the day took off 4штуки 3.0 (two booooly S and two light). A week I wore or longer, something got overweight... like the day 2.0 on the hands was significantly better. I assume then go to 4's and then 4 S++
and by the time SE will be ready
Now S+ wear occasionally.
Gave reproach to a man for a day "cleaning" of the body.
Gave reproach another in the campaign... unlike the version with the 2.6, he removed his see, says fatigue (severely damaged body, lots of alcohol but drink), and gave him due to the fact that the campaign was dangerous, and anything else at hand was not - took off what was.
Gave to vilify another member of the family on the day - a burst of energy, zero fatigue, but he has a soft addictive, it's him I gave 1 link before, he wears it....
Post by Маг.нет » Sun Nov 14, 2010 14:47
Маг.нет wrote:has started the production of a "charging machine"
Michael_, "box shungite" outside coated with aluminum foil on the inside to keep shungite surface (coated with a thin polymer layer) or cover with foil?
Sincerely, MAG.no
Post by Маг.нет » Sun Nov 14, 2010 15:17
Михаил_ wrote:1. in my opinion the meteorite can not charge.... or even need not to charge.
2. the meteorite should initially carry a signal very similar to the 3.0
1. Charged layered polymer mass is poured directly on rock. Each layer has its own task, "physical fixation" in the layers of the contents of the algorithm (of the mandala). Meteorite - source, resin - 3.0 system that retrieves signals from the sources.
2. Crystal of smoky quartz as the signal source effective?
3. For bracelet planning "box" for storage and recharge of gray clay and polymer, multilayer, covered with foil. For the uniqueness of the strata plan to add different natural materials in the clay - "cleaned-charged water, silver shavings, crushed quartz and..., individual dye in each layer, well, "physical fixation" of the algorithm layer. Base - grey clay (from a clean source, without any treatments after the extraction, the extraction site - Leningrad oblast, Chkalovsky), polymer - DECOFIT (don't know why I liked it).
Sincerely, MAG.no
Post by Михаил_ » Mon Nov 15, 2010 2:02
Sincerely, MAG.no
not sure, I think box is made of shungite, it's not about three... but then try not to cover the inside and glue. in General I think the serious effect this will have, but some can.
Post by Михаил_ » Mon Nov 15, 2010 2:11
Sincerely, MAG.no
1. if it is in PP1 is about the charging system, there is NO NEED to separately fix the quality layers, it will be some distortion that will interfere with the work of 3.0
2. no, absolutely not effective. He carries a different signal, i.e. if something happens, then it won't be 3.0, but something else in essence.
3.Ostap carried.... MAG.no. gray clay is suitable for anything, but not for 3.0. It is there generally contraindicated. Categorically. Can change the frequency and get how-to a projection of 3.0 instead of him. Like a shadow.
Different layers - is also contraindicated.
4. charging him the idea is not needed.... but perhaps it will somehow influence the sensations with each new dressing (like a reset).
something You imagined excess....
if this all is a complex process that will have a positive impact on the ultimate efficiency is your consciousness that is stronger than was recorded in the process breaking it into many difficult small steps.<
Post by Михаил_ » Mon Nov 15, 2010 2:15
from the meteorite was enough to take the impression of quality.... and not all of it entirely, but this requires not melted essentially. Ie those that have power as iron (sun-fire) are not suitable for such an operation.
in my opinion, too clever by half.
Post by Маг.нет » Mon Nov 15, 2010 10:32
Shungite box - insulation chamber and for charging 3.0 or something else... it's just the isolation from external.
The quality of the recorded layers when system charging, including "unifying" layer.
About the quartz and the clay is clear. The land is not suitable for the 3.0 the difference between the layers to identify the layer properties.
Михаил_ wrote:in my opinion, too clever by half
So it's a creative process. Here and clarify that would be in futility not to waste time.
Sincerely, MAG.no
Раймис
Post by Раймис » Mon Nov 15, 2010 13:55
:offtopic:
MAG.no
Sorry don't mean to pry...But how old are you?
Post by Маг.нет » Mon Nov 15, 2010 14:06
Раймис wrote:how old are you?
:)just a kid:)
*a fine of 50 rubles...
Sincerely, MAG.no
Post by Маг.нет » Mon Nov 15, 2010 19:47
Михаил_ wrote:MAG.no wrote(a):
3. For bracelet planning "box" for storing and recharging the gray clay...
Michael_ wrote(a):
3.Ostap carried....
Do I understand correctly that bracelet of stone can't be 3.0?
From the presentation 3.0:
Михаил_ wrote:S+ super versions with custom laser engraving and add a special composition, which includes the meteorite substance are extremely rare, like...
S++ = too, but harvesting more massive, larger, which in addition to the multilayer laser processing caused by the composition containing the rare meteor brotowasisto
The only difference in the weight of the workpiece? Bracelet durationfrequency (judging by price 50000.00 and 100000.00)? Another question, the effectiveness of S++ more or less 2 S+, by what principle?
As far as I understand 3.0 is the "intersection point" 20 of the energy channels, it is appropriate and how can increase symptoms of one of the channels on this list, or not one?
Sincerely, MAG.no
Post by Михаил_ » Mon Nov 15, 2010 20:19
1. to obtain output 3.0 properties do not exfoliate and are overlaid in turn. ie first preparatory is in some ways analogous to "cleaning" in 1.0, then 3.0, and then actually fixing him hard matrix. I.e. it's not different layers, but that should be combined in a single layer. So I suspect that if something polimerici, then after all 3.
2. box after 3.0 had little use for something else...
3. the stone is in principle suitable, but it has its cons and it's not a rigid structure ( not the element earth), the fact is that if the stone is natural, it is linked with the planet from the inside, but the 3.0 link on a different principle - the view from the outside. Charger 3.0 can override the private properties of the stone, but I assume that the result will be weaker than in other media.
artificial stone in this aspect would be preferable.... here's a strange thing 3.0
4. between S+ and S++ have some differences. The first blank... and Yes, it is two times more about. And it gives the power increase. And it's probably about the same as 2 for S+ dressed together, if not for the difference 2.
2 the difference lies in the meteor implementation. Well it changes the purity of the signal and its effectiveness. And in my opinion that is why the price is so. Moreover, it is associated with a significant increase in not only production time but also the cost of overheads (over the meteorite substance pay).
The third difference is the possibility of an upgrade, still this is not accurate. Ie, there is no certainty that will make the "E" overlay on S++ and not a separate bracelet.
The fourth difference concerns the quality of the prints. S++ because of the greater area, there is still great detail, which reinforces the impact.
5. I kind of never wrote about 20 channels? And what exactly do you mean? In classical literature and traditions known 12 heavenly stems (see the same acupuncture for example), but this kind of primitive picture. Severoceska system, being artificial, then do not, if it was about her.
No, no symptoms strengthening is not necessary, it makes no sense and generally there is in fact no separation. In General, if normal to enter the as 3.0 there is no that would require some auxiliary techniques (such as stress that one), since this condition where the result itself is without any worries about the technology implementation.<
