New product of isn-1 is a modification of the BZ.
Идущая вперед
Post by Идущая вперед » Sat Nov 13, 2010 16:34
Inca cracked right down the middle, the diameter, although there was nothing special... she just stood quietly under the sofa on the printout where the bracelet 2.0 3.0 matrix in (photo)... no special load is not given - it just cracked by itself quietly... :) in General, the glass was brittle... now will remove the glass and cause the matrix... maybe a sign :aa
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Wed Nov 17, 2010 20:34
Michael_
And if you do not look at the size and ease of use, and efficiency. What would be more efficient to fiddle with the negotiations of the RF set-top box to the UK or ИСН1 ?
Post by Михаил_ » Wed Nov 17, 2010 22:58
Isn
Post by Воффка » Wed Nov 17, 2010 23:27
Michael_
Why? :)
Post by Воффка » Thu Nov 18, 2010 11:12
Going forward
Caused matrix? :)
Post by Михаил_ » Thu Nov 18, 2010 14:31
Воффка wrote:Michael_
Why? :)
because the event is happening now, it's not just high frequencies, but lower (actually communication), and IIM - multifrequency. HF also gives a predominantly single high-frequency range, although in fact they are made about the same. There is a link BJ engraved.
The composition is different.
In исн2 will not be level but will have additional software and engraving system 2.0 at the same time available.
Post by Воффка » Fri Nov 19, 2010 0:33
Michael_
Output ИСН2 plan simultaneously with the release of ИСН1 more durable and comfortable to wear the case or the problem will be solved in ИСН1 ИСН2 without changing ИСН1?
Post by Михаил_ » Fri Nov 19, 2010 0:44
исн1 will remain as it is, the wearable version will be an independent device and is very interesting, and ISS-2 - will also be different from these two :) all three used different technology. Ie, fairly fundamentally different.
The isn-2 will be most convenient to operate the premises, halls, offices... up to large. The wearable version will be very powerful, but more...monaural, unlike исн1, where different layers. And Iim-1 will be something like "classics", although I might go to the frameless version later.
тишина
Post by тишина » Wed Nov 24, 2010 14:10
Michael_
when you plan to indulge in the sale of ISS-2? It would be interesting to try)))
Post by Михаил_ » Wed Nov 24, 2010 14:20
at the end of the year or in the new year, do not know, we are trying a slightly different modification, for the manufacture and testing of each takes some time (conventionally a week or two). This is the rare case when it is necessary to conduct experiments in the process of creating the device, as used in IIM-2 technology to us in this form is used for the first time and want to understand that it squeezed the maximum efficiency plus there are limitations of the technical plan, which had rested a few times..... for example, the number of points displaying the object in one version exceeded that within a reasonable time processed computer.
In General, as soon as I get to your table version, which will be able to say that I am completely satisfied at the quality, immediately declare about the readiness and availability.
In General, the Sri-2 is another demonstration that the same can be achieved in different ways.
In IIM-1 the basis is a folding unit, repeatedly reinforced laser engraving. The link with the engraving, in turn, greatly strengthened layer of a special composition, where each layer is responsible for its properties.
In ISS-2, we take the solid material and immediately write on it everything you need inside and out.no lineups, tverdenii, link... but ultimately we get the same properties in emergency (table) form.
Post by Михаил_ » Thu Dec 02, 2010 1:26
Appeared in the office "introductory" model to ИСН2.
Works weaker full. Not sold (at least not yet), if it is sold then at a significant discount compared to the price of the full version.
Photo: http://openmagic.org/files/set2.jpg
charging system G-2 exists on the structure of the fullerene molecule. It is the most balanced structure (for fun learned there are different al-spheres and balls Bogdanov, absolutely not what would fit).
The final version will contain two fundamental differences:
1. will contain the info a substitute of three layers with different qualities used in the Sri-1. Now device (pictured) works in mono-frequency.
2. will be used continuous stand of this glassware, which implements multi-color led illumination from below and rotation. Which is very conducive to the artifact (works as an external energy pumping and constantly changing conditions).
The product will probably be produced in two basic versions and one extra:
- исн2 base, at 3D-laser low resolution, equivalent to that in the photo, but with additional program. A budget option.
- исн2 reinforced, on the 3D laser is very high resolution, the number of points in the chart by more than an order of magnitude higher. Is much more powerful. Decently expensive.
- additional modification in the personal order. Or a big cube, or 8 large cubes of glass, stacked together, make up a whole. As I understand it, the maximum cube of the produce is face up to 200mm....
Through the use of popular 3D -gift technology, исн2 it becomes quite convenient for gift-giving (without explanations of the special properties), or finding office space of any kind. Option 3 (extra large) can be used for large spaces as an element of the interior.
Because of the isn-2 will be more expensive (cost of completing the cheapest version is not small, the work depends on the accuracy of performance, etc.).
Interested in a preliminary analysis of the needs in products of different types in this class.
Estimated price for ISS-2, the first (simple) modifications will be somewhere 10+
For other versions find it difficult to give an exact price targets, as is working with multiple production sites, specified our technical requirements are very conspicuously different from that used in souvenir production on a volumetric glass, and while manufacturers hair stand on end slightly from our queries :)
Increasing the modeling accuracy, we dramatically increase the power (even with the same amount of product).
When you increase the volume also increase power, but at the expense of volume-mass.
And thus it is possible enough individually to produce different sizes and design and absolutely office-looking (which was originally designed ISB) "Souvenirs".
Can record individual programs on top of the basic firmware, I mean engraving them together with the base firmware, so this program worked continuously as a main. This can be applied to certain fixed tasks.
For example, if I have, as in former times, still there was a need for a pair of negotiating rooms, I would have equipped the program with a number of parameters associated with the target destination areas.
In the basic version, isn-2 versatile, isn-1.
A sample placed in the office, so that the Muscovites could twist in his hands when you visit and see the prototype of the production version, albeit somewhat weaker.<
Post by Михаил_ » Thu Dec 02, 2010 1:35
By the way, offtopic, about the stabilizer.
For fun, my colleague made ball with anti-IOS, Yin-type. To check on the contrast of feelings between the two different balls. I, in spite of his recommendation to keep him in office did not.
BUT what he is really Yin, and I believe much later, when he tripled away from the actions of the stabilizers after their transportation.
Didn't believe that he got claimed.
However partially the effect of changing the firmware as it negates itself fullerenov sphere (it has parameters close to Neutra shift, i.e. of what gives the setting from a 2.7, even without a system 2.0, i.e., the balance he gives).
But by evening, the condition has returned to normal in more "normal" and I have the number 3.0 has reduced :) and then I felt that the alternative scope of works the stated way. And before that thought he was fooling me or khalyavnykh made alternative firmware.
_Алекс_
Post by _Алекс_ » Thu Dec 02, 2010 2:56
Михаил_ wrote: Photo: http://openmagic.org/files/set2.jpg
Cute gizmo!) :)
And description more than understood. Need to stop by the office to see) And it will be interesting to see the final version with backlight. It is something that will probably as light crystals?
Audio output will have a stand? Kind of like the UK... Or just a monolith of glass as a stand and a ball? Well, that is the ball clear. More about the stand question.
Post by Михаил_ » Thu Dec 02, 2010 3:10
For Souvenirs with 3D engraving, the Chinese produce the model stand on her colored LEDs (it randomly changes color) and a rotation mode that she delivered. It is put together ball with glass stand (i.e. what is seen in the photo). As a result, the balloon and the structures therein are highlighted in different places in different colors alternately, which is very...conducive to efficient operation. Stand these everywhere model. Changed to audio input or something else to do, maybe you can, but we are still not engaged and did not think to do, although it can be.
To get an idea how it is possible for example on this video:
Post by Михаил_ » Thu Dec 02, 2010 3:14
Another thing is that you can arrange your stand, but I think we won't bother with mechanics. With the light - perhaps. Then you can enter different types of modulation. But the problem is that cheap piece production of electronics do not exist. And manual Assembly increases the cost of the product.
The modulation fundamentally changes the quality. Just the lighting, Yes.
Ie, it's not SK, it's a basic BJ in a hospital. The difference in f-tsijah.
Post by Михаил_ » Thu Dec 02, 2010 3:24
A wearable version apparently will be made of wood and metal... quite specific, the estimated size of the cell of large size.
While not all components are there and not all of the equipment.
If you find a more simple solution for high power and reliability, it is possible to change the idea. While it appears ocheeen difficult, but entertaining.
_Алекс_
Post by _Алекс_ » Thu Dec 02, 2010 3:38
Михаил_ wrote:Another thing is that you can arrange your stand, but I think we won't bother with mechanics. With the light - perhaps. Then you can enter different types of modulation. But the problem is that cheap piece production of electronics do not exist. And manual Assembly increases the cost of the product.
Yes it is clear. Well, if not change the quality, then the truth in this sense is not probably)
Post by Михаил_ » Thu Dec 02, 2010 21:31
Oh, by the way исн2 will be very effective for simple charging of water. I really, honestly, have not tried. But it is doubtful that mistaken. The reason is simple - it is easy to ensure direct contact with water while maintaining sustainability - that is the glass. And the mass of the object at the same time - big. Ie, enough decanter-jar is wide enough, the main thing is not to break one thing on another.
But the UK of course, for these purposes, more flexible and better, just the UK is not all as there is.
_Алекс_
Post by _Алекс_ » Thu Dec 02, 2010 23:24
Михаил_ wrote:Oh, by the way исн2 will be very effective for simple charging of water. I really, honestly, have not tried. But it is doubtful that mistaken. The reason is simple - it is easy to ensure direct contact with water while maintaining sustainability - that is the glass. And the mass of the object at the same time - big. Ie, enough decanter-jar is wide enough, the main thing is not to break one thing on another.
Mmmm. Here is a competent theme. I can't find good clean water, although at my house it consists of 3 stages and still feel medical taste. More precisely, 2 clean and 1 charging useful qualities(the stones of shungite+flint).
тишина
Post by тишина » Thu Dec 02, 2010 23:26
did not wait for the modifications, got Sedna isn-1. Honestly thought he was smaller. Photo box made as above, that just will not notice)) during a conversation in his HAND to twist hard, too massive, much attention will attract! Surprised that a lot of isn carry everywhere is pomegranate still the same!!))
At the bottom of the folding unit, 2.6 seems, and the dark makeup what is interesting is he? filled with only 1/2 glass (previously I thought that the composition for conductivity, and link directly to it). Feel the energy, if you concentrate, without this nezametno. In addition put 2 BJ 2,0, IIM held in the hands. Felt a sweet energy, I have so often in RF. Then a pleasant sensation on the fingertips and inside the void I feel, but a bit)) in the head movement. Everything is manifested not as much as I would like, faint, see what happens next! Waiting for the effects with respect to event-driven processes.
Post by Михаил_ » Thu Dec 02, 2010 23:44
Alex
1.And what brush?
2. исн2 not a means of cleansing water. Although there are many claims ( and I think justified) that any structuring effect on the impurity through changing their solubility, or some other processes. The process I personally have not studied, so I can't say whether it is clearly justified, but it is likely so.
silence
1.it is understood that "in the hands of a twist" in principle can be anything that is on the table :) well, I have a personal leadership experience :)
2. isn-1 is still not the UK, for events, he certainly will be reflected as gain BJ.
3. there are three different layers and all three are functional.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Thu Dec 02, 2010 23:59
Михаил_ wrote:"in the hands of a twist"
...and immediately BEFORE the "event" is not less effective, when AT times, well, when isn "focused", there is no need of it and "touch it"... and so the connection is good, but "in the hands" sensation brighter.
Sincerely, MAG.no
Малыш
Post by Малыш » Fri Dec 03, 2010 0:02
what do you mean focused? i.e. the distance is not a hindrance?
Post by Михаил_ » Fri Dec 03, 2010 0:20
and since when this kind of energy the distance was a hindrance. Just have a little problem that I asked in the subject of Radionics....
i.e. of course if the device is directly within the personal field and involves active points (in the hands for example) then it works automatically. And if not, then weaker since we want to attract consciousness, and they have not trained for it.
In fact the same place (geometric coordinate location in space), time, or similarity in some parameter, only different kinds of resonance. In some ways, the Convention.
But think closely on this subject impossible, and that maybe the roof of that... :) man must live in sequential time stream. But at least the fact that the spatial position and distance - Convention, very easy to understand, at least on the same velcovsky the experiments proposed in the book.
Just direct contact works independently from consciousness.
A potential consciousness and fitness is different for everyone.
But IIM -a pretty powerful, so the inner attention on it or external (direct vision somewhere on a shelf) is quite sufficient factor.
_Алекс_
Post by _Алекс_ » Fri Dec 03, 2010 2:23
Михаил_ wrote:Alex
1.And what brush?
The first is a simple filter, more something new has come up yet. Well, maybe invented I just don't know. The second is a disc which structures the water.
Well, 3E where the stones are the same and shungite cleans and structures the water + flint.
