Bracelets Life
Post by Михаил_ » Thu Jun 10, 2010 17:51
Александр86 wrote:
1. do not pull the time, do yourself today the 1.0 version, well, nothing could be easier... at least watch to charge (if they vodopronitsaema, it is better without water, just wrap, and that many were drowned).
What you can make yourself and make sure before you buy that works?
And then I bought a zirconium bracelet :? don't want to.
It can "charge" ? And how ? can a reference.
Oh by the way I somehow think that zirconium bracelets really do work. At least their explanations fit very well with my understanding of some processes. Another thing is that maybe someone is "working" manifests itself clearly, and someone did. I do not know. BJ of course work is clearly more pronounced, but again the sensitivity is different for everyone. Vaughn Myrtle deliberately took a 2x2.6 in order to "experience" (read on the forum personal branch Mirumir test). Well, tests I no longer give, so... to me some things were interesting :)
My grandfather still hairy in the Soviet years was a magnetic bracelet imported from Japan his friend. He said he relieves his pressure on time and headaches... and there are many who do not feel the effects completely.
I in recent years the masterly "sat in a puddle", I realized that things I thought were not working still somehow work, just had not enough sensitivity + understanding. And now I am very careful in conclusions, because he before himself crap do not want :)
Post by Михаил_ » Thu Jun 10, 2010 18:07
Александр86 wrote:
the Bracelet of life 2.0 (the tree). Price: 1 000 rubles (add to order)
Bracelet of life 2.5 (wood engraved). Price: 10 000 rubles (add to order)
Bracelet of life 2.7 (a tree). Price: 25 000 rubles
Why such the price difference is?
2.7 = 25 thousand too much something.
well, everything is simple. There is a free public version. It is enough for most utilitarian home use. Who needs something more serious, have a good reason and bought a 2.7 on the whole satisfied with the effects, as I understand it. I think that the price is adequate, and it is not because someone wanted to do something "expensive", but because you have to put the price for a number of reasons. One of them will come cheaper (I find it easier to remove from the sale of this version).
I'm old-fashioned. Have some bearded and moss-grown traditions. I believe that the artifacts of some kind can be made commercially available and require hand-crafted, absolutely not by any hands. Even very much not arbitrary.
You may not believe me anyway.
In the result, the sad fact is that 2.7 is a waste of time, and so I do not have a car, I prepare the removal of the manufacturer to another person but not first person (criteria are very hard).
When I did the first 2.5 - then 1=2 of the day recovering, the process is harmful to the cocoon at the moment of creation - breaking the fields while the pattern is applied partially. Then adapt so that you do not notice these effects (some protection gained). But in General, the older versions this is another story and handmade. Now it will engage other people, but under my strict master control. People are able to withstand and harmful factors of production and to preserve the purity of the product. (for example, I don't know what will happen if one will do 2.6-2.8 stoned or watching television ads of the strong effect this will have, the bracelet works on the basis of basic functionality and properties version, but it will fundamentally not true. The same applies to the mood of the factory at the time of coating).
In addition, there are other good reasons to have this price(including those described on the forum). This is not the limit.<
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Thu Jun 10, 2010 20:06
Михаил_ wrote:I suspect that is a situation that left (working for the man, his problems and health) is much more loaded. I see no other explanation.
I.e. when change of location the trend of "destruction" of the surface can be moved to another bracelet?
Thank you!
Sincerely, MAG.no
Post by Михаил_ » Thu Jun 10, 2010 20:13
there is a suspicion, Yes.
Post by Маг.нет » Thu Jun 10, 2010 21:03
Here is the experiment. The results will write.
Called User, to offer to change, the way it is presented, "left" - "to bring health", and "right" - "to illness was taken away," in General, a COUPLE of HEALTH AND I heard that right as new, but left... "he boobles" and the rubber band snapped, as if parched. Tomorrow will look, and the rubber band will help to change. After you swap them, I'll see...Michael_, threading the elastic-assembling the bracelet, as it can be further "coordinate" his health may temporarily... Which Modules health can be activated after a short time... if I'm not wearing this bracelet, you activate the Module.
Thank you!
Sincerely, MAG.no
Post by Михаил_ » Thu Jun 10, 2010 21:16
nothing specifically to do not need repair and so begins itself when it gets enough energy.
If you gave the bracelet can use the timer of the healer upon him, but the subconscious will still be wearing the "commander in chief", without the pressing need of a healer timer to use is not advised, it is the special equipment for those working with patients.
Post by Маг.нет » Thu Jun 10, 2010 21:30
Thank you!
What can be considered a special need?
Sincerely, MAG.no
Post by Михаил_ » Thu Jun 10, 2010 22:01
the actual need to force some modules of regeneration, when it is impossible to do it yourself (or if you can not explain him what was happening and why). Usually lack of offline mode. I.e., such a need is a kind of acute situation.
Post by Маг.нет » Thu Jun 10, 2010 22:40
In principle, of course.
In this situation, the complexity in the explanation.
Poor General health, fever, respiratory symptoms - there is a need (and opportunity) call Module regeneration? Will automatically activate the required Modules? At a concentration of (increased attention) to the diseased organ, for example the throat, will automatically activate the required Module, if the User will say (literally) the band: "my throat hurts".
Thank you!
Sincerely, MAG.no
Post by Михаил_ » Thu Jun 10, 2010 22:43
everything will work itself out.
Post by Маг.нет » Thu Jun 10, 2010 22:52
Autopilot?
Thank you!
Sincerely, MAG.no
Post by Михаил_ » Thu Jun 10, 2010 23:05
and who says? autopilot.....
верунчик
Post by верунчик » Fri Jun 11, 2010 0:05
Michael.
It should not be changed, even so is :)
Мирта
Post by Мирта » Fri Jun 11, 2010 4:05
About right/left bracelets on the related hands seems to be true. So for example, right wristband on my "stuff", kept on parole, and on the left only two managers flew.
About 2.6 nothing can not say, as involuntarily change their positions. And here's another funny-looking little strange - a couple of days ago I noticed that the links 2.6 on the chest, next to the parlor has acquired a noble, dark-brown glossy look and the new look newer, which is not observed on the foot bracelets.
ГОРОДСКОЙ СУМАСШЕДШИЙ
Has thanked: 115 times
Post by ГОРОДСКОЙ СУМАСШЕДШИЙ » Fri Jun 11, 2010 9:28
Andrey Kabanov
Consider placing the branches of the presence of the BZ model and appearance.
Conveniently, the types of workpieces (photo 1,2,3...), models and color for choices...
Ready to order bzh 2.5, 2.6, 2.7. The messenger in flight, June 30 before that time, I would like to define the look and ...reserve. If the redundancy payment is guaranteed!
Thank you!
Been thanked: 182 times
Post by Андрей Кабанков » Fri Jun 11, 2010 9:49
2.5 and 2.7 are all the same species and size of wood.Today, take a picture.
You can choose only 2.6,but with them everything changes very quickly.Closer to the 30th decide with him.
Post by ГОРОДСКОЙ СУМАСШЕДШИЙ » Fri Jun 11, 2010 10:04
Andrew, thank you!
"Hot cakes", however, these BJ.
Better pre-selection to determine that the queue does not stand...
Post by Андрей Кабанков » Fri Jun 11, 2010 10:07
20 days to put something problematic with such a small work.
Post by ГОРОДСКОЙ СУМАСШЕДШИЙ » Fri Jun 11, 2010 10:23
Not a problem!
When selecting the appropriate option, ready to pay for 2.6, and to take away with the other instances after the 30th day.
Will choose!
Post by Андрей Кабанков » Fri Jun 11, 2010 15:05
Post by Маг.нет » Fri Jun 11, 2010 17:34
Describe two events, the first one is "oblezet" of the surface.
Looked cherepichny gift. Really, right, new left, the impression that is dry. The links did not lead, but "Salomatlik" structure of wood, like large sandpaper "soft tissue" vyskoril. Gum is also dried, the braid is intact, and inside the rubber crumbles. Gum changed such bracelets are sometimes changed, will see... will unsubscribe by result.
Event the second:
Yesterday I visited "injured" User of my gift - BJ 2.0. A leg injury received the day before, could not walk, lay. When trying to rely on my right foot got a sharp pain with cramps of the gastrocnemius muscle, while not passing ache in the lower leg. For moral support and a speedy recovery, have established (in communication) the mood - in the morning the pain will pass and get back on my feet (note, the User has a high degree of trust - faith my words). Here yesterday with You about the timer Healer talking...
This morning I Wake up, when you try to get up, a sharp noise in the head, seizures (such for the first time for me) the calf muscles of the right(!) legs and ... a veil before the eyes. Pain very(!) strong, lasted about five minutes, then passed, leaving a "memory" of pain, which took place after the launch of the Funnel drain.
Call "traumatized", is interested in health, improvements it didn't... I described him as my "good morning".
Call in an hour, explaining that my previous call caught him in his sleep, and so he slept... got up (forgetting about the injury) and went, this time remembering my Wake up call, his injuries and noting that the PAIN WAS gone COMPLETELY! Left only bruises. After another hour he was driving.
This here is a GOOD MORNING!
Michael_, Your comments are always very interesting and informative.
Sincerely, MAG.no
Post by Михаил_ » Fri Jun 11, 2010 20:02
:) Good morning, Healer :)
Post by Михаил_ » Fri Jun 11, 2010 20:28
Really happened like this. You gave the command to my subconscious to rectify the situation in humans. The features of the band such a strong trauma in one night is not enough (based on the capabilities of the person and his personal energy), your subconscious mind by morning solved the problem to solve in a forehead. Made a simple healing method, which I STRONGLY recommend anyone to do consciously. Once it did, so I knew she'd handle it..... and so man can do, and then to disentangle consequences. Produced overlap and overwriting of a healthy matrix (with You) to your friend. Until combined, You felt HIS pain as my own.
Your energy together with the bracelets You have and he of this surgery enough.
There are no steps to any specific module, it is mostly your work.
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Fri Jun 11, 2010 20:35
Tired of waiting video, the body requires new information. I will pump crude. :)
Post by Михаил_ » Fri Jun 11, 2010 21:44
As I just found out that my letter was lost on the Internet and to Vladimir did not come.... the strange thing is this rarely happens. (this is the meaning of the video, so came the delay).
