Succor Punch.Manual on usage and sessions.
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Mon Feb 14, 2011 12:16
Updated session
I Recommend to pay attention: http://www.mindmachine.ru/viewtopic.php?p=45464#45464
2-week session!
session healthy due to the fact that "silence" is also framed as MP3.
I later preconverter format "machalek". This will reduce the size.
Альвидас
Been thanked: 2 times
Post by Альвидас » Mon Feb 14, 2011 13:39
I also did a SP the other day. Now versed in the topic sessions and frequencies. Have any simple questions, who is not too lazy to answer - please.
Here we work with thoughtforms. Someone needs to sell unneeded trainer, someone to improve health. A good example with the simulator - specific goal. A thoughtform is recommended to load the state of satisfaction from the fact that the trainer is sold and the place became more. The question I have - what frequency makes sense to apply in this case, when crystal put the note with the thought form? This is unlikely to be the chakras, right? And hardly Lumanovski resonance. But what? That will strengthen the thoughtform?
Here Logan mentioned frequency 15 Hz, 741 Hz, and 5075 Hz as safe. What they are safer than the rest and how do they work?
Currently listening to the frequency simply through headphones, while sitting in the office.
Actually, I need to normalize the endocrine system, affirmations I've read, but which frequency to choose for this case - did not think.
Практик
Post by Практик » Mon Feb 14, 2011 14:16
Alvydas
At endocrine and chakra read here: http://www.kornilov-s-a.ru/chakras/chakras-5.htm
Post by Шалтай Балтай » Mon Feb 14, 2011 14:22
Альвидас wrote:Question I have - what frequency makes sense to apply in this case, when crystal put the note with the thought form? This is unlikely to be the chakras, right? And hardly Lumanovski resonance. But what? That will strengthen the thoughtform?
experiment.
I assure you it's very personal, moreover - programmable.
I tell You Schumann - You am I "spite" will find THEIR the frequency - and rightly so.
Альвидас wrote:Do I need to normalize the endocrine system, affirmations I've read, but which frequency to choose for this case - did not think.
http://www.mindmachine.ru/viewtopic.php?t=3600
Альвидас
Post by Альвидас » Mon Feb 14, 2011 15:19
Practicesthanks for the link. Arguing on the basis of the material - if the derelict hypotheis, it is necessary to stimulate the ajna. Bad pancreas produces insulin, since she does not command the pituitary gland, we tested the dowsing. It turns out that the sinking of chakra is needed (thanks to the Humpty Baltay 15 minute sessions).
Here, however, the question arises. Have one side of the tracks from Humpty of Baltay, and on the other, here: http://www.mindmachine.ru/viewtopic.php?t=3600 these Merkaba frequency of the chakras 174, 285, 396, 417, 528, 639, 741, 852, 963. I have them at home generate, they sound different than in Sete Humpty. How to understand that the chakras correspond to the two sets of frequencies?
Humpty Baltay, I'm talking about Lumanovski resonance as wrong said just for example, not knowing the right answer. From Your words I can conclude that just Lumanovski resonance and will reinforce the thought-form. Believe me, finding something "in spite of" contrary - it is not about me, youth is gone. I'll just znakomlus with the theme, You have a lot of experience, but listen.
Post by Шалтай Балтай » Mon Feb 14, 2011 15:29
Альвидас wrote:Have one side of the tracks from Humpty of Baltay, and on the other, here: http://www.mindmachine.ru/viewtopic.php?t=3600 these Merkaba frequency of the chakras 174, 285, 396, 417, 528, 639, 741, 852, 963. I have them at home generate, they sound different than in Sete Humpty. How to understand that the chakras correspond to the two sets of frequencies?
what got the Merkaba is a musical frequency.
Their listening ears.
Technically not the fact that generally there is a sense to pass them through SP.
Really, I think the effect should be. Try it, tell us.
Альвидас wrote:From Your words I can conclude that just Lumanovski resonance and will strengthen the thoughtform
I'd say Yes.
Альвидас wrote:Believe me, finding something "in spite of" contrary - it is not about me, youth is gone. I'll just znakomlus with the theme, You have a lot of experience, but listen.
well, by the way in vain.
Knowledge necessary to grind.
Knowledge free then is a waste of time.
Still won't work...
I little advise.
IMHO the response from SP.
If there is, then experiment.
View what You need. All requests are different, I assure You. Even if the same (MONEY! AND MORE!) - well, put on the SP, with time - trebuetsya :)
it gets better trust your own feelings. Not, of course listen to what others say is possible, sometimes useful info, but in the end, the report will have to keep only to themselves...
here You have the starting and ending point of reference.
Else - Path...
Need - stomp... :?
Post by Шалтай Балтай » Mon Feb 14, 2011 15:42
IMHO, the main problem with SP is that it works on a subconscious level, what people most don'T REALIZE. I'm here for a year bought РАД2000 and almost a year with SP. Here I look back, a small revision, then will not start ... smile...
but it's funny how all... :)
Альвидас
Post by Альвидас » Mon Feb 14, 2011 16:53
Ie materialsbase maybe something that sits in the subconscious and repressed from consciousness. It is desirable that the subconscious was not byaki...
About linking, ask a question. Prick your finger, smear the blood of the exposed end of the crystal and the blood and leave, not washing, or washing. So? Or, you can then crystal wash? Hair/nails/picture we do not leave on the crystal forever?
And even If Kalinkovichi SP for me, for example, it will only work on me? On the other is not? To save a multiplayer mode, to link SP probably does not need?
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Mon Feb 14, 2011 17:01
Humpty Baltay
At not I got, at Logan. He suggested the use of 741 Hz instead of 32000 Hz, at the same work, and use 528 Hz.
Post by Шалтай Балтай » Mon Feb 14, 2011 19:01
Альвидас wrote:about linking, ask a question. Prick your finger, smear the blood of the exposed end of the crystal and the blood and leave, not washing, or washing. So?
it is possible and so
Альвидас wrote:Or then crystal wash?
if the crystal wash, then some time will be the effect of sticking, but eventually the link will disappear
Альвидас wrote:Hair/nails/picture we do not leave on the crystal forever?
why not?
Альвидас wrote:And even If Kalinkovichi SP for me, for example, it will only work on me? On the other is not?
mental binding is as strong stuff, so definitely Yes, to say it is impossible, but in theory, Yes - just for You.
for example, if You are constantly worried about what crystal to someone zelinkova, then... :)
Альвидас wrote:to save a multiplayer mode, to link SP probably does not need?
Yes,
better in card.
you can use Velcescu program (Manifestacin which) is all operate.
Седой
Has thanked: 13 times
Been thanked: 36 times
Post by Седой » Fri Mar 04, 2011 12:46
A curious phenomenon was found.
Since my crystal amethyst and violet.
I it is often applied to different parts of the body. Really helps. I think because of him I was sleeping 4 hours in two days with this fit and healthy. Used to sleep 7 hours a day.
But most of all I was attached to the forehead. Liked, by the way. The feeling of cold heat. Invigorates better than coffee.
He always stood between me and the monitor with the edge in my direction. So intuitively placed.
Today I read here that the Ajna corresponds to the Amethyst.
димыч
Been thanked: 16 times
Post by димыч » Tue Mar 08, 2011 18:47
don't see where to download one-week session, there is and there is no link
Post by Шалтай Балтай » Wed Mar 09, 2011 11:12
димыч wrote:can't see where to download one-week session, there is and there is no link
where are you looking at?
димыч
Post by димыч » Thu Mar 10, 2011 21:23
Yes, sort of figured out, just says 2 gig of something, and then unpacked the first week and here it is
Post by Шалтай Балтай » Wed Mar 30, 2011 11:14
Tag, people
interest in the sessions there at all?
Who what uses?
I think about what to write probably, which would be fashioned session schedule may mixer, voice+the beats. Is it interesting? In principle, it is possible to put online, what would anyone could under him what to mix.
The interest is there?
Димонъ
Post by Димонъ » Wed Mar 30, 2011 15:30
Is.
Практик
Post by Практик » Wed Mar 30, 2011 20:34
there is certainly
Владимирович
Post by Владимирович » Wed Jun 08, 2011 22:50
Шалтай Балтай wrote:Session
Chakra ~ 300Kb (zipped)
http://files.mindmachine.ru/files/sp.se ... ras.tar.7z
Code: Select all
01-Muladhara mp3¦ 10 M
02-Swasthisthana mp3¦ 11 M
03-Manipura mp3¦ 12 M
04-Anahata mp3¦ 12 M
05-Vishuddha mp3¦ 14 M
06-Ajna mp3¦ 14 M
07-Sahasrara mp3¦ 14 M
For those not familiar with 7zip: http://www.7-zip.org/
Why is the frequency for Agni and Sahasrara are the same ? So should or how?
Post by Шалтай Балтай » Thu Jun 09, 2011 10:16
where You have data that frequency the same?
Владимирович
Post by Владимирович » Thu Jun 09, 2011 17:44
Checked the frequency because the hearing seemed the same tracks. Coincide with accuracy up to 0.01 Hz. It turns out or is the difference more subtle or frequency the same.
Post by Шалтай Балтай » Fri Jun 10, 2011 10:28
Владимирович wrote:Checked with a frequency counter because the hearing seemed the same tracks. Coincide with accuracy up to 0.01 Hz. It turns out or is the difference more subtle or frequency the same.
I would be very grateful if you could give more accurate information
1. what frequency was measured (PC or external device?)
2. What kind of frequency your frequency
3. tested whether other session?
Errors are quite possible
Everything was done in manual mode, at the moment there is Tula, which would allow to write a script and get a rectangular impusle output.
Владимирович
Post by Владимирович » Fri Jun 10, 2011 22:58
1. The external frequency counter, not to say that is very accurate, but very good indeed.
2. 13 Hz.
3. The others did the same, the difference is very noticeable....
Going to do a hardware frequency generator for SP, in this connection, interested in exact values of frequencies. One idea is to make it as an "elaboration" of the chakras by the change in the frequency in the "Central"
1Андрей1
Post by 1Андрей1 » Wed Jun 22, 2011 12:44
DD. Can't download SineGen, all references to the disconnected server. Who is not difficult throw off on soap 1andrey11@rambler.ru.
Thank you.
Свами Доупаду
Post by Свами Доупаду » Thu Jun 23, 2011 1:30
1Андрей1 wrote:DD. Can't download SineGen, all references to the disconnected server. Who is not difficult throw off on soap 1andrey11@rambler.ru.
Thank you.
-Threw SineGen + one little function generator from 1Hz to 22050 Hz.,it may be useful..
1Андрей1
Post by 1Андрей1 » Thu Jun 23, 2011 19:48
Swami Dopado Thank you :D Received. az
