СК1М
Post by Михаил_ » Fri Jun 18, 2010 15:24
it is better to take stones and sand, resin and water does not store energy, although the resin at the end solidified (petrified) is also very good. well. The metal itself is generally poorly recorded.
A good effect can give the smelting of tin and casting somewhere, but it needs to be done specifically on the point of active
and can the transmitter from the transmission pair to put? I'll have to send a new one in return khalyavnykh. I will need the room from him, you can bind more than one receiver. Interesting to see the place in more detail.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Fri Jun 18, 2010 15:52
Михаил_ wrote:I will need from him the room, you can bind more than one receiver. Interesting to see the place in more detail.
Agreed, but which area is more interesting (light/dark) transmitter I have one...
Several points to explore different, say in time I will fix where the transmitter, then will leave at some point. There is almost no anomaly :roll: This difficulty is not a problem, it will depart at 10 km, there and the Internet would probably be...
Sincerely, MAG.no
Post by Маг.нет » Fri Jun 18, 2010 16:23
At the same time offer to "explore" another "object" -the heat deflector plate with Buran (who was in the space of 15 November 1988), is a white "plastic" type of PTFE. make sense?
Sincerely, MAG.no
Post by Михаил_ » Fri Jun 18, 2010 18:13
no, to pull the transmitter is not an option. Should be left in any one place for a long time stationary, it is desirable that it could not be simply extracted from there by marking it on the map, and the other to mark on the map the same relative to the first. The transmitter can be used as a beacon from the channel is very durable, so durable that even the anomalous zone will be a steady signal :) it is not cellular.
Plate Burana somewhat less interesting :) although the same thing is funny.
There is also no GPS signal? Like something is going to go probably... but clearly not this year... transport yet suitable.
Post by Маг.нет » Fri Jun 18, 2010 19:26
Михаил_ wrote:, the Transmitter can be used as a lighthouse from the channel is very durable, so durable that even the anomalous zone will be a steady signal is not cellular.
Understand the principle of the transmitter, don't know how the surrounding space can be considered...
You need to decide what area to leave, I'm interested in 5 zones:
1. In the circle (say, "the navel of the EARTH");
2. Dark place (sverhodarennym activity);
3. A bright place But (increased activity);
4. A bright spot In (verhovynna activity);
5. Lake Linevo (say portal).
On a limited plot of Land of small extent are representations of almost all official religious movements.
Navigator I have the PDA - Navitel (though never used), set point will, I don't know how to copy, I hope you will understand. The photo shoot also you want to make these points.
Configured on the following Saturday, I will not cancel, transfer is only possible due to heavy rains (but we can do without them - not the season), where the road... or rather them from the village no, just trail walking and driving.
Sincerely, MAG.no
Post by Маг.нет » Fri Jun 18, 2010 19:32
Understand the principle of the transmitter, don't know how the surrounding space to "see" you...
Navigator I have the PDA - Navitel (never really not used to), set point will, I don't know how to copy, I hope you will understand. The photo shoot also you want to make these points. Psyleron to take have the ability or he out of the house I record can?
Configured on the following Saturday, I will not cancel, transfer is only possible due to heavy rains (but we can do without them - not the season), where the road... or rather the lack thereof, just trail walking and driving.
Sincerely, MAG.no
Post by Михаил_ » Fri Jun 18, 2010 21:06
I will think (about the place) and answer by this time...
psyleron from home can write, but the place will be more interesting to work, he will write the place even without human intervention (slightly).
Новик
Post by Новик » Fri Jun 18, 2010 21:50
just wait for third-party experiments, then this to fully understand the time-the time you need...
I agree....shall need to gain experience by SK.
Wonder how many owners of SK at the moment?
Maybe it's time to open a topic which will be review to work well, any thoughts?
Post by Михаил_ » Fri Jun 18, 2010 22:29
one of the original patterns of SK there is a long time and it accumulated reviews for a long time, but it is "intimate business", not everyone wants to share.... As for BJ, feedback outside of the forum, in PM, much more than the public.
And the theme - here it is.... can come here and write.
It is certainly possible to create a separate, but still kind of makes no sense.
The number of devices is still in the zone of two-digit numbers.
верунчик
Post by верунчик » Mon Jun 21, 2010 11:52
But if this "cap" on the head to fasten :)
Again to the points :) DU 20 (Bai Hui Hundred meetings)
I wonder what will get the output :)
Post by Михаил_ » Mon Jun 21, 2010 12:40
heavy and will not stick :) but... I guess I still have enough influence over his arm.
In General, the conceptual, the best effect is when the whole cocoon has received the proper amount of energy, and not a single point.
верунчик
Post by верунчик » Mon Jun 21, 2010 17:19
Michael, please reply to the whole cocoon got equal number of energy to use SK+ 'caps'?
But identity is still the cap is not fastened, and the roof as that goes :)
Just please, people. language, and even better for blondes - to the UK, where this thing :)
Post by Михаил_ » Mon Jun 21, 2010 18:26
Option 1. the console is placed on top of table IC, a table is used as usual (if something puts something under the console, although you can try on top, the idea is no difference).
Option 2. the console works by itself - just use it in my arms or next to him. My colleague received for 1 copy from me, he says he was exhausted in a week of processing, but after the appearance of the prefix on the table - sprang creatively :) and finished the day on cheers.
ACC. in the embodiment 1. we get a wider range of frequencies (it is desirable), similar to the 2.7+2.8
in option 2, we powered up and down still goes through the formation of surplus.
I like the hand on top of him to put... funny feeling, it begins to seem that the surroundings are slightly floating....
option 3. similar варианту1 is to work with situations external purposes. the UK gets the opportunity to work on different frequency levels. More precisely the opportunity he has, just here at RF energy levels begins to have more and it's not always a grab...
PS how the overall impression of "toys" ? :)
верунчик
Post by верунчик » Mon Jun 21, 2010 19:43
Time haven't had to deal with them ( but almost :) )
Put on h the svadhisthana X on R on W on!
Put on SC - can't be near, the ears, the air density or what, (I don't know what to call it) at least take it and lepi snowballs :)
Left alone, somewhere around the hour itself like a sauna, but is now better. I'll catridge "chakras" and the kitchen, and then with posts wife fired :)
Новик
Post by Новик » Mon Jun 21, 2010 21:22
Michael_
Sorry may have missed where and what is it the console? What about the fact that you drowned the link of the band that I realized what was drowned?
Post by Михаил_ » Mon Jun 21, 2010 21:43
Inside a specific composition that provides the desired properties. Natural in nature, except for the filler to cure. Black :) very rare... (not shungit, to avoid any speculation).
Post by Михаил_ » Mon Jun 21, 2010 21:45
by the way the coating 2.8 and WP prefix is slightly different, though used the same material, but different application technology.
верунчик
Post by верунчик » Tue Jun 22, 2010 0:27
The console can only recommend, it's worth it.
Michael, as You Skatert-Samobranka can be ordered :)
верунчик
Post by верунчик » Tue Jun 22, 2010 0:29
Hmm, Ah, and what do You have in your sleeve? 8)
Post by Михаил_ » Tue Jun 22, 2010 1:12
about the ground I think... I have until unstable effects on this front....
a full list of what is yet to announce will not, and not will be interesting :)
Although the following two items the program can read, it's not a secret...
Новик
Post by Новик » Tue Jun 22, 2010 1:42
Code: Select all
Let's disclose :shock:
верунчик
Post by верунчик » Tue Jun 22, 2010 10:14
Новик wrote:
Code: Select all
Waiting for :)
Post by Михаил_ » Tue Jun 22, 2010 12:51
well, in terms of SK, the expected points are:
1. active amplifier, which, as HF can be used independently from the UK as an independent device (waiting for the production, purely organizational moments).
2. notorious the calculation program of corrective action. While in passive mode, the last two weeks it was no time.
3. Audio files to enhance certain modes of the IC specified in the documentation. This piece is not mandatory, but for someone useful... however, they effects probably will be a little brighter. They are ready, but you need to execute and put, hands have not reached.
Post by Маг.нет » Tue Jun 22, 2010 13:16
Michael_, of course not the topic, and Psyleron waiting for Your extension on time.
With respect the Magician.no
Post by Михаил_ » Tue Jun 22, 2010 14:26
waiting.... ever wait for. We planned to release its gauge, but here it is necessary to continue research work, which takes time and finances. Until a little before that. The principle is very simple - in the development of priority are those areas that are most interesting for the application ourselves. The rest is secondary :)
