Reviews and interesting results.
Andrei Patrushev
so just put power to just the ears are not pinched by the current
today in two times less will do
and on the diffuse inhibition that the affirmation to listen?
Re: Reviews and interesting results.
Che, I doubt it... Dangerously hurt you any rubbish to pick up without conscious control.ЗОМБИ wrote:and the diffuse inhibition that the affirmation to listen?
and, it's not scary, then it will be that cleanАндрей Патрушев wrote:Dangerously hurt you any rubbish to pick up without conscious control.
actually, as I understand it, the correct General affirmation of the type "every day I am getting better and better in all respects/situations/blah blah the best way for me"
well, not the fact that every time manage this effect to though... I got it on 6-ke... margin of the brain allows you to grow, so to speak
twice today rocked ALTARIA-dinner 20-30 minutes on 8ке and evening for 20-30 minutes for 10ke
now crawled out of the Shavasana -- as never was -- consciousness never Merk!!
moreover, I believe the key point was to recreate the sensations in the head from alfaria
But I have severely disturbed the relaxation process from childhood. Some diffuse changes in the brain. Almost impossible to relax. For the first time alfaria acted only after a week drinking Valerian and almost falling asleep included a session on the hour, for drug addicts - entered the alpha state, and the hour seemed like ten minutes. And so no extra preparations - the effect is zero.
Does anyone have the results for anesthetic effects?
My mom has arthrosis of the joints, would make it easier for her...
Зерванадья
tell me what kind of brain rhythms can cause ALTARIA in the brain?
Ivan N The forum is not the place for swearing.
Hello! Decided to write a review about the use of Alfario. He thought long and decided to take or not to take, because the device is not cheap. But absolutely do not regret buying
Bought in the office in Moscow last thing straight from the showcase
I use already more than a month.
Briefly about why I decided to buy and the results:
I got around the end of January began the panic attacks and irrational fear, to such an extent that it seemed I couldn't bear it and wanted to die... and all sorts of other weird effects, it's a long story and too strange feeling... (on tentative reasons I guess...)
Well ALTARIA gives a powerful instant result, headaches disappeared, improved mood ,disappeared irritability, stopped to shake hands(this problem appeared for a long time and increases with time), in a total state of peace...
Usually use 1 or 2 times a day for 20 min
Sometimes even I use mode 10 when the feeling of euphoria you receive direct
And sometimes I use the modes and less than 5 because of discomfort.
Sometimes when using the feeling of nausea and dizziness...is this normal? and other times everything is OK. In General, each time differently.
After using mostly body high powerful
Use Alfaria often combine with listening to some affirmations, or APK.
Importantly, almost disappeared the problem which took, well, mental attacks about which I spoke...with 9апр use the device and a similar condition arose only a couple of times.
The only disadvantage is only that the skin on the earlobes began to peel off... What to do in this case? Anyone have this problem?
almost ceased Asomada current pulses in my ears and flashes in the eyes. fear for the apparatus although the electrodes is clearly the signal is, the language clearly visible, although the instrument did not measure.
it's something with me or the device is dead? was that dropped it.
