Advice from Andrei Patrushev
динара
Post by динара » Tue Nov 18, 2008 13:15
Hello, Andrey . I have player "a CD / DVD with tuner and device, decoding the recording format MP 3" knemo attached a normal earphone can listen to "healing" with this player.
Post by Андрей Патрушев » Tue Nov 18, 2008 21:31
динара wrote:Hello, Andrew . I have player "a CD / DVD with tuner and device, decoding the recording format MP 3" knemo attached a normal earphone can listen to "healing" with this player.
Hello.
Yes, of course.
Post by Guest » Thu Nov 20, 2008 0:48
Zdravstvuite, Andrew.
I am an aspiring "maker", but quickly learn :oops: . Bought all disks of your, UH, books...different. I want to start - I don't know why...I'll Try to explain what you'd like to achieve as a result. The work I have enough stress - the team is complex, a lot of information, a position responsible. Morning still OK, but by lunchtime, passions sometimes run high to the extent that I, as a sensitive person, for dinner is all electrified spring inside, everything "vibrates and shakes", apparently you need to remain calm, and status is what to focus on and work no longer works...I would Like to learn to relax without losing the ability to analyze and think...I should be grateful for the advice.
Post by Андрей Патрушев » Thu Nov 20, 2008 15:50
Anonymous wrote:Zdravstvuite, Andrew.
Hello.
Start from the beginning. :) Exercise every day (if possible, at work at lunchtime (better r2), if not, then right after work) with the sessions of the section "r", setting the time of the session (see instructions) within 15-20 minutes. If you have trouble sleeping, you can add a bedtime drive Healing. You can drive the healing of the alternate disk Explorer. Three weeks you can begin to engage with the discs Star traveler or a Massage of the Brain.
Good luck!
Светлячок
Post by Светлячок » Fri Nov 21, 2008 3:06
Hi Andrew ! I'm new on the use of CDs for meditation Practice meditation without any help.Approximately 1 year.Of course the results are not much.I decided to try the massage of the brain.I have to say that first experience scared me.At the first audition(in the morning,after sleep,with glasses-as it should be) 20-25 minute waves of fear I just covered.Until the nausea.The 2nd time was good-even have fun.3 times all like anything,but the dizziness after the session there were already 3 day I depart.Now,I do not wonder whether I'm for it useles?Please tell me how to proceed? Thanks in advance :o
Светлячок
Post by Светлячок » Fri Nov 21, 2008 3:07
I almost forgot!Here's another amazing sosanie(can't say that have not encountered them during meditation,but not so "strongly". Chuvsvo-feeling huge and heavy.Sensations at the level of Phys-them. What would it mean?
Андреич
Post by Андреич » Fri Nov 21, 2008 17:55
Greetings to all!
I read, think.
The first conclusion is that Scam.
But check for yourself, since the requested money is less of a potentially positive result.
About result I will unsubscribe.
Andrew.
Евгений Кош
Has thanked: 2 times
Been thanked: 2 times
Post by Евгений Кош » Sat Nov 22, 2008 21:00
Андреич wrote:the First conclusion is that Scam.
and where you saw or heard the truth for once in your life.?
Никакой
Post by Никакой » Sat Nov 22, 2008 22:18
Андреич wrote:Greetings to all!
I read, think.
Andrew.
And what are the conclusions,my dear, in your web brainstorming device has led to this conclusion?
дина
Post by дина » Sun Nov 23, 2008 11:50
hi Andrea, I have a question for you.
1. When auditions for "Healing" I fall asleep for 10 minutes , is this normal ?
2. can earn stable alpha just lying down and listening?
3. What if I'm listening to practice autosuggestion
4.is it possible to develop imagination ( to imagine different images )
5. is it possible to listen to while working, reading as background
марат
Post by марат » Sun Nov 23, 2008 18:37
Андрей Патрушев wrote:
Валюшка wrote:Hello, today I will begin to listen to the Healing, decided on the night.is this correct? and how much time it is advisable to listen to?
Hello.
Right.
Three weeks.
and I have the opposite problem. healing listen to this morning, Explorer for the night.
of course first pytalsya to listen to those CDs as described in the instructions.
healing at night, the Explorer - in the morning.
but to put it mildly does not matter. swapped normally.
Post by Guest » Mon Nov 24, 2008 9:49
Евгений Кош wrote:where have you seen or heard the truth for once in your life.?
Никакой wrote:And what are the conclusions,my dear, in your web brainstorming device has led to this conclusion?
Ordered the discs.
Waiting for delivery.
Till you listen, I will not argue.
Because, as I understood from the forum, the subject no one but Patrushev, to prove the effect can not.
All fall into demagoguery.
That actually show the above Postings.
Андреич
Post by Андреич » Mon Nov 24, 2008 9:50
Previous post of mine.
Евгений Кош
Post by Евгений Кош » Mon Nov 24, 2008 11:32
Ordered the discs.
You forgot to quote another post with demagoguery :)
here is the "Greetings to all!
I read, think.
The first conclusion is that Scam. "
PS "Till you listen, I will not argue" - :ay
Post by Андрей Патрушев » Mon Nov 24, 2008 11:47
дина wrote:hi Andrea, I have a question for you.
Hello.
Except for the 5th everything else is fine and you can. 8) :)
Post by Андрей Патрушев » Mon Nov 24, 2008 11:48
Светлячок wrote:I Almost forgot!Here's another amazing sosanie(can't say that have not encountered them during meditation,but not so "strongly". Chuvsvo-feeling huge and heavy.Sensations at the level of Phys-them. What would it mean?
Also one of the "standard" of trance States. :?
Идущая вперед
Post by Идущая вперед » Mon Nov 24, 2008 11:51
don't that you dear lohotronschikov decided to become...
why buy a thing and to be deceived???
not luckel to take money and not to get involved with a Scam?
blaaaaaaa..... az
effect posted on the main page...
about increasing the length of the dendrites can not say anything - did NOT MEASURE... on the device DENDROCOELIDAE FAILURES...
and so is everything else really... :D
Post by Андрей Патрушев » Mon Nov 24, 2008 11:52
Светлячок wrote:Hello Andrey ! I'm new on the use of CDs for meditation Practice meditation without any help.Approximately 1 year.Of course the results are not much.I decided to try the massage of the brain.I have to say that first experience scared me.At the first audition(in the morning,after sleep,with glasses-as it should be) 20-25 minute waves of fear I just covered.Until the nausea.The 2nd time was good-even have fun.3 times all like anything,but the dizziness after the session there were already 3 day I depart.Now,I do not wonder whether I'm for it useles?Please tell me how to proceed? Thanks in advance :o
Fear, most likely, again in my personal trance stories...
Otherwise try simply considerably decrease the volume.
Андреич
Post by Андреич » Mon Nov 24, 2008 12:07
Идущая вперед wrote:this don't you dear lohotronschikov decided to become...
blaaaaaaa..... az
:wink:
МэнСмарт
Post by МэнСмарт » Mon Nov 24, 2008 16:25
Dear Anya!
To find out where to grow growing a brain, read the book of Philip K. dick's "Stigmata of Palmer Eldritch". There are all described in detail.
Post by Guest » Mon Nov 24, 2008 18:58
МэнСмарт wrote:to find out where to grow growing a brain, read the book of Philip K. dick's "Stigmata of Palmer Eldritch". There are all described in detail.
RATHER MEDIOCRE FICTION... nothing special...
it was a pity the time spent on such rubbish...
going forward
Post by Андрей Патрушев » Mon Nov 24, 2008 19:27
Варя wrote:
Андрей Патрушев wrote:Tips to give immoral...
And even immoral to eat alone. :evil:
If it's about me, I can't afford to choose a stranger to his fate. :? I and so all I could have shared... :)
Post by Андрей Патрушев » Mon Nov 24, 2008 19:30
МэнСмарт wrote:Dear Anya!
The entire thread looked.... I wonder who's here "Anya"? :shock:
Евгений495
Post by Евгений495 » Mon Nov 24, 2008 23:51
bought mm and wheels Andrew
I have a question ..
in General, I have some "quirk" , and I start acting weird: can several times to do rearranging things in the apartment,
or I'm starting to think that these things need to be moved to another Cabinet.. or what they are exactly.. or just need some things to throw away and buy the other place..
Advise what to choose to listen to say so is to erase this "quirk" of the brain :)
Post by Андрей Патрушев » Tue Nov 25, 2008 14:17
Евгений495 wrote:purchased mm and wheels Andrew
Do YOU remember the parable about the boy with the nut in the navel? Suddenly, this approach will erase something right and something will fall off?:)
For personality integration and restructuring experience more than just the cable conductor and the Massage of the Brain.
