Advice from Andrei Patrushev
Андрейка
Post by Андрейка » Tue Jan 18, 2011 0:16
Dear Andrew.
Please answer 2 questions.
1.I have a AV block II degree, the pacemaker no.
is it possible to use MM.(I'd like to start)
2.If Yes, what sessions would you recommend.
Thanks in advance.
Post by Андрей Патрушев » Tue Jan 18, 2011 21:55
Алёна16 wrote:what does it depend on 15 or 21 days?
Of Your decision. :)
Post by Андрей Патрушев » Tue Jan 18, 2011 21:59
Владимир С wrote:Hello Andrey!
I have the following question to you.
My friend would like to do with Your discs "Ultra Brain" and "Lucid dreaming" .
But, 2.5 years ago he had an accident he had an open head injury, with the violation of the soft shell of the brain. In addition he had a spinal injury and now he walks (moves in a wheelchair). But despite all the trouble it feels good, no headaches to fainting does not fall.. in a General satisfactory condition.
What can you advise in this case?
Hello!
Ultramesh (except the last track) has meaning only in the study of some educational material. The OS disk only makes sense when doing some technique. Otherwise it is necessary to monitor their condition.
Post by Андрей Патрушев » Tue Jan 18, 2011 22:02
Андрейка wrote:Dear Andrew.
Thanks in advance.
With the big share of probability it is impossible. If you still dare, then the brightness of the light should be minimal - barely visible flickering. Recommendation General - the alpha-session.
Safe to use disks. :?
Андрейка
Post by Андрейка » Tue Jan 18, 2011 23:18
And it can be a little bit more about probability.What it depends on. I think that the information will help you decide to use MM or not. (After treatment was much better, but not re-examined). Thank you
Артемчик
Post by Артемчик » Thu Jan 27, 2011 16:02
Good afternoon, Andrey!
Does Your drives technology of NLP?
Post by Андрей Патрушев » Thu Jan 27, 2011 16:28
Андрейка wrote:can A little bit more about probability.What it depends on. I think that the information will help you decide to use MM or not. (After treatment was much better, but not re-examined). Thank you
Don't know what it depends on purely empirical data (mostly experience with my clients) that if you have any cardiac problems a large proportion of the probability that during light-zvukovoy session will be bad. With one sound this is not observed.
Post by Андрей Патрушев » Thu Jan 27, 2011 16:30
Артемчик wrote:Good afternoon, Andrey!
Hello!
http://www.mindmachine.ru/viewtopic.php?t=514&start=0
Артемчик
Post by Артемчик » Thu Jan 27, 2011 16:50
And in Your other drives?
Post by Андрей Патрушев » Thu Jan 27, 2011 16:53
Артемчик wrote:And in Your other drives?
And there are no other words :?
Артемчик
Post by Артемчик » Thu Jan 27, 2011 17:02
You mentioned R. Hubbard, and I therefore ask that the technology R. Hubbard sees NLP as the labeling of certain tenets, even with the positive moods that begin to lead the human condition. The main fact of self-determination.
Although I Guide very helpful.
I'm going to have auditing, and asking me whether to use NLP to You? For the number of hours of processing in this case is increased two or three times
Post by Андрей Патрушев » Thu Jan 27, 2011 17:11
Артемчик wrote:You mentioned R. Hubbard, and I therefore ask that the technology R. Hubbard sees NLP as the labeling of certain tenets, even with the positive moods that begin to lead the human condition. The main fact of self-determination.
I'm doing NLP since 1992. None of the NLP techniques, in my opinion, does not fit the definition of "naveshivanie certain postulates." But when auditing, I think, can really cause problems, but for another reason... :?
Любимая
Has thanked: 4 times
Post by Любимая » Thu Jan 27, 2011 22:42
Andrei Patrushev
Good day!
You once (a long time) asked the question, what music to listen to children. You advised Vivaldi, Handel, Mozart and listen to the background during the day. And this music can be in MP3 to listen to, children will benefit from it (mental development)?
Иррина
Post by Иррина » Fri Jan 28, 2011 0:41
Hi Andrea Smile
Tell me, please, is it possible to help a person with a diagnosis of disc herniation of the lumbar (the doctors said that surgery is not needed, the size of the hernia 9mm) listening to Your CDs? If so, which ones and in what order? After passing the comprehensive treatment of pain and numbness returned.
Артемчик
Post by Артемчик » Fri Jan 28, 2011 9:37
Andrei Patrushev
If you have the time and desire, can visit the site and read very interesting http://www.stirately.com
Post by Андрей Патрушев » Sat Jan 29, 2011 1:10
Иррина wrote:hi Andrea Smile
Hello.
Some relief of the pain syndrome will certainly take place, but not magically. :?
A guide and a Healing.
Post by Андрей Патрушев » Sat Jan 29, 2011 1:40
Любимая wrote:Andrei Patrushev
Good day!
In the music of several components. To mp3 cut the high frequencies charge the brain with energy, everything else remains. The Chinese have kept (and keep) at home songbirds for brain development (at the expense of high frequencies) in children... :?
Post by Андрей Патрушев » Sat Jan 29, 2011 1:43
Иррина wrote:hi Andrea :)
Tell me, please, is it possible to help a person with a diagnosis of disc herniation of the lumbar (the doctors said that surgery is not needed since the size of the hernia is not large) listening to Your CDs? If so, which ones and in what order? After passing the comprehensive treatment of pain and numbness returned.
Hello.
The conductor and the Healing can somewhat reduce the intensity of the pain.
Post by Андрей Патрушев » Sat Jan 29, 2011 1:44
Кнопка wrote:My mom will have brain surgery to remove vessel. I have a question - the person in this state, you can listen to your CDs before the operation and what? When can I start listening to after the surgery?
Yes, before the surgery can be a Guide and a Healing. After the surgery, around 3 months.
Иррина
Post by Иррина » Sat Jan 29, 2011 12:30
Андрей Патрушев wrote:Hello.
Thank you :)
Иррина
Post by Иррина » Sat Jan 29, 2011 12:56
Some relief of the pain syndrome will certainly take place, but not magically. Confused
Thank you.
Just, sorry, one more question - how best to formulate the purpose when listening to "Conductor"? The function of the lumbar disc is restored or the size of the hernia is reduced (though, and tried to explore the theme of "proper goal setting") is something I'm not very it turns out :roll:
Post by Андрей Патрушев » Sat Jan 29, 2011 13:23
Thank you.
Yes, it is possible not to set any goals. Just listen and all.
Иррина
Post by Иррина » Sat Jan 29, 2011 20:39
Андрей Патрушев wrote:Yes, it is possible not to set any goals. Just listen and all.
Thank you :)
Керенский
Post by Керенский » Fri Feb 04, 2011 21:17
Listened Healing 2 weeks - cholesterol level is still more than 7 - perhaps it is time to exercise and stop eating, drinking and Smoking! :shock:
PS.
But in General, overall feelings are positive - although the specifically state it's hard ...
Continue to practice :ap
Post by Андрей Патрушев » Sat Feb 05, 2011 1:06
Kerensky
Cholesterol cholesterol strife and the causes are also very different... :?
